  3. M500 will not connect to QGC, but still has shh connection
m500
23 Posts 2 Posters 6.4k Views 2 Watching
    @Steve-Sager I would update to the latest release, VOXL Platform 0.9, it can be downloaded from https://developer.modalai.com/asset/1
    and installed by following the instructions here: https://docs.modalai.com/platform-releases/
    We've made a lot of improvements recently so it wouldn't hurt to get you using the latest
    Steve SagerS 1 Reply Last reply
      Steve SagerS Offline
      Steve Sager
      @tom I tried following the install instructions you sent me but ran into an issue. when I try to use the ./install.sh -f command the reboot into fastboot turns off the adb connection to the voxl and fails. Any suggestions? I tried using the expander & debug kit to boot into fastboot, but that results in the same problem.
      here are some images of what is showing up in my Git Bash prompt.MicrosoftTeams-image (2).png MicrosoftTeams-image (3).png MicrosoftTeams-image (4).png
        @Steve-Sager We don't support using Windows for flashing. Do you have an Ubuntu machine you could use to flash? Preferably Ubuntu 18.04.
          Steve Sager
          @tom I have a Ubuntu 20.04 machine will that be okay?
          • Steve SagerS Offline
            Steve Sager
            looks like the problem was Windows. let me double check and I'll post again what happens but it is loading now...
              Steve Sager
              @tom would you happen to know how to get the ecdsa password for my aircraft?
                @Steve-Sager If you're referring to the SSH login:
                Defaults are as follows
                user: root
                pass: oelinux123
                  user: root
                  pass: oelinux123
                  Steve Sager
                  @tom After following all the instructions and successfully flashing the new firmware onto the aircraft. I have connected to the ssh once again and set the QGC IP address to the correct laptop ip but the aircraft still isn't connecting to QGC.
                    @Steve-Sager Here's something else to look at: https://docs.qgroundcontrol.com/master/en/troubleshooting/qgc_setup.html#waiting_for_connection
                      Steve Sager
                      @tom I will be looking to the firewall to make sure it wasn't that, but we have allowed the application past the wall. Could this be related to to something else?
                        Steve Sager
                        it looks like the previous command you had me run:
                        cat /etc/modalai/voxl-vision-px4.conf | grep qgc_ip
                        is giving me a different ip address than the one we put into voxl-vision-px4. how do I change that one to the correct address?
                          @Steve-Sager That's interesting, you can use vi to modify the file and enter the correct IP in the qgc_ip field, vi /etc/modalai/voxl-vision-px4.conf
                            I would also make sure that you're able to ping your PC from your drone.
                              Steve Sager
                              SUCCESS! we have established connection to the aircraft. everything is working. @tom thanks so much for all your help
                              The solution was to update the aircraft using a linux system instead of windows.
                              Then we had to to use ssh-keygen to reconnect to the aircraft, and used the new aircraft ip address.
                              Finally we had to manually set the qgc ip twice.
                              We are now back up and running
                              Cheers!
                                @Steve-Sager Great to hear! Just to confirm you flashed the latest platform release, 0.9? Making a note of your issue. It's very unusual that you would have to manually edit the qgc_ip. Thank you for being patient.
                                  Steve Sager
                                  @tom Yeah I am on 0.9 platform release
