  2. VOXL Dev Drones
  3. VOXL m500 Reference Drone
  4. M500 will not connect to QGC, but still has shh connection
Scheduled Pinned Locked Moved VOXL m500 Reference Drone
23 Posts 2 Posters 5.9k Views 2 Watching
  • Steve SagerS Offline
    Steve Sager
    I've been working on a M500 aircraft that I recently got from Modal. While setting up docker I found that my aircraft had stopped connecting to QGC properly on startup. Do you have any idea why this is happening? Here is what the inspect services looks like. I tried double checking the voxl-vision-px4.conf file and the IP address was correct... I redownloaded QGC. I'm at a loss here, should I just try to update firmware?
      Steve Sager
      Also it has given me this when I input the voxl-vision-px4 command into the shh connection
      Adding manual QGC IP address to udp connection list: xxx.xxx.x.xx
      WARNING: invalid qgc_ip, this is fine if you don't want to use it
      but I do want to use the GCS so how do I fix the invalid ip address, because that is the correct one.
        wrote on last edited by tom
        @Steve-Sager Is the qgc_ip address of the form 192.168.X.Y?
        Steve SagerS 1 Reply Last reply
          Steve Sager
          @tom Yes, thanks for the quick response. the current format is 192.168.x.xx
            @Steve-Sager That is interesting, if you look at the qgc_ip line in the config file cat /etc/modalai/voxl-vision-px4.conf | grep qgc_ip does it show the IP address that you expect?
              Steve Sager
              wrote on last edited by Steve Sager
              @tom said in M500 will not connect to QGC, but still has shh connection:
              after checking it again I did get an output, and it was the same ip address
                Steve Sager
                  @Steve-Sager I would update to the latest release, VOXL Platform 0.9, it can be downloaded from https://developer.modalai.com/asset/1
                  and installed by following the instructions here: https://docs.modalai.com/platform-releases/
                  We've made a lot of improvements recently so it wouldn't hurt to get you using the latest
                    Steve Sager
                    @tom I tried following the install instructions you sent me but ran into an issue. when I try to use the ./install.sh -f command the reboot into fastboot turns off the adb connection to the voxl and fails. Any suggestions? I tried using the expander & debug kit to boot into fastboot, but that results in the same problem.
                    here are some images of what is showing up in my Git Bash prompt.MicrosoftTeams-image (2).png MicrosoftTeams-image (3).png MicrosoftTeams-image (4).png
                      @Steve-Sager We don't support using Windows for flashing. Do you have an Ubuntu machine you could use to flash? Preferably Ubuntu 18.04.
                        Steve Sager
                        @tom I have a Ubuntu 20.04 machine will that be okay?
                          Steve Sager
                          looks like the problem was Windows. let me double check and I'll post again what happens but it is loading now...
                            Steve Sager
                            @tom would you happen to know how to get the ecdsa password for my aircraft?
                              @Steve-Sager If you're referring to the SSH login:
                              Defaults are as follows
                              user: root
                              pass: oelinux123
                                user: root
                                pass: oelinux123
                                Steve Sager
                                @tom After following all the instructions and successfully flashing the new firmware onto the aircraft. I have connected to the ssh once again and set the QGC IP address to the correct laptop ip but the aircraft still isn't connecting to QGC.
                                  @Steve-Sager Here's something else to look at: https://docs.qgroundcontrol.com/master/en/troubleshooting/qgc_setup.html#waiting_for_connection
                                    Steve Sager
                                    @tom I will be looking to the firewall to make sure it wasn't that, but we have allowed the application past the wall. Could this be related to to something else?
                                      Steve Sager
                                      it looks like the previous command you had me run:
                                      is giving me a different ip address than the one we put into voxl-vision-px4. how do I change that one to the correct address?
                                        @Steve-Sager That's interesting, you can use vi to modify the file and enter the correct IP in the qgc_ip field, vi /etc/modalai/voxl-vision-px4.conf
                                          I would also make sure that you're able to ping your PC from your drone.
