  2. VOXL SDK and Software
  3. Docker daemon fails to start on voxl
40 Posts 11 Posters 27.5k Views 5 Watching
  • Chad SweetC Chad Sweet
    Are you following the docs here?
    The voxl-docker command is for developing in a Docker on a PC, it should not be run on VOXL.
    The tutorial steps to run on target are:
    yocto:/# voxl-configure-docker-support.sh
    yocto:/# docker images
    yocto:/# docker run hello-world
    If you have run the PC scripts on VOXL, not really sure what would happen
    K Offline
    K Offline
    kiprock
    @Chad-Sweet Thanks for the fast response!
    yocto:~# voxl-configure-docker-support.sh
    Stopping original docker service
    Enabling our own services docker-start & docker-prepare
    starting docker-start.service
    loading hello-world docker image
    Cannot connect to the Docker daemon. Is the docker daemon running on this host?
    yocto:~#  systemctl status docker
    ● docker.service - Docker Application Container Engine
       Loaded: loaded (/lib/systemd/system/docker.service; disabled; vendor preset: enabled)
       Active: inactive (dead)
         Docs: http://docs.docker.com
    May 13 15:46:33 apq8096 systemd[1]: Stopped Docker Application Container Engine.
    yocto:~#
    yocto:~#  systemctl start docker
       Active: failed (Result: exit-code) since Thu 2021-05-13 15:48:03 UTC; 2s ago
      Process: 3678 ExecStart=/usr/bin/docker daemon -H fd:// --raw-logs (code=exited, status=2)
     Main PID: 3678 (code=exited, status=2)
    May 13 15:48:03 apq8096 systemd[1]: Started Docker Application Container Engine.
    May 13 15:48:03 apq8096 docker[3678]: flag provided but not defined: --raw-logs
    May 13 15:48:03 apq8096 docker[3678]: See '/usr/bin/docker daemon --help'.
    May 13 15:48:03 apq8096 systemd[1]: docker.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    May 13 15:48:03 apq8096 systemd[1]: docker.service: Unit entered failed state.
    May 13 15:48:03 apq8096 systemd[1]: docker.service: Failed with result 'exit-code'.
    yocto:~# docker images
    An error occurred trying to connect: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.21/images/json: read unix @->/var/run/docker.sock: read: connection reset by peer
    S 1 Reply Last reply
      Not really sure what state your system is in. This github issue shows it could be related to disk space or needs a reboot. Did you install other Dockers on the image? They are very large and maybe all of the space is consumed
      https://github.com/docker/for-linux/issues/435
      • K Offline
        K Offline
        kiprock
        Just looking at your script, I realized that modal has it's own docker services.. so perhaps this provides a little more info: I have created a few images from the kinetic image
        yocto:~# systemctl disable docker.service
        yocto:~# systemctl enable docker-start.service
        yocto:~# systemctl enable docker-prepare.service
        yocto:~# systemctl status docker-prepare.service
        ● docker-prepare.service
           Loaded: loaded (/etc/systemd/system/docker-prepare.service; enabled; vendor preset: enabled)
           Active: failed (Result: exit-code) since Thu 1970-01-01 00:00:24 UTC; 51 years 4 months ago
         Main PID: 2352 (code=exited, status=1/FAILURE)
        Jan 01 00:00:20 apq8096 docker-prepare.sh[2352]: /usr/bin/docker-prepare.sh: line 17: /sys/fs/cgroup/cpuset/syst...ctory
        Jan 01 00:00:21 apq8096 docker-prepare.sh[2352]: /usr/bin/docker-prepare.sh: line 17: /sys/fs/cgroup/cpuset/syst...ctory
        Jan 01 00:00:22 apq8096 docker-prepare.sh[2352]: /usr/bin/docker-prepare.sh: line 17: /sys/fs/cgroup/cpuset/syst...ctory
        Jan 01 00:00:23 apq8096 docker-prepare.sh[2352]: /usr/bin/docker-prepare.sh: line 17: /sys/fs/cgroup/cpuset/syst...ctory
        Jan 01 00:00:24 apq8096 docker-prepare.sh[2352]: /usr/bin/docker-prepare.sh: line 17: /sys/fs/cgroup/cpuset/syst...ctory
        Jan 01 00:00:24 apq8096 docker-prepare.sh[2352]: failed to see cpuset appear after 15 seconds
        Jan 01 00:00:24 apq8096 systemd[1]: docker-prepare.service: Main process exited, code=exited, status=1/FAILURE
        Jan 01 00:00:24 apq8096 systemd[1]: Failed to start docker-prepare.service.
        Jan 01 00:00:24 apq8096 systemd[1]: docker-prepare.service: Unit entered failed state.
        Jan 01 00:00:24 apq8096 systemd[1]: docker-prepare.service: Failed with result 'exit-code'.
        Hint: Some lines were ellipsized, use -l to show in full.
        yocto:~#
        yocto:~#
        yocto:~# systemctl status docker-start.service
        ● docker-start.service
           Loaded: loaded (/etc/systemd/system/docker-start.service; enabled; vendor preset: enabled)
           Active: failed (Result: exit-code) since Thu 2021-05-13 15:57:11 UTC; 3min 11s ago
         Main PID: 3873 (code=exited, status=1/FAILURE)
        May 13 15:57:11 apq8096 systemd[1]: Started docker-start.service.
        May 13 15:57:11 apq8096 docker[3873]: time="2021-05-13T15:57:11.453820000Z" level=info msg="API listen on /var/....sock"
        May 13 15:57:11 apq8096 docker[3873]: time="2021-05-13T15:57:11.477567000Z" level=info msg="[graphdriver] using...lay\""
        May 13 15:57:11 apq8096 docker[3873]: time="2021-05-13T15:57:11.527540000Z" level=info msg="Firewalld running: false"
        May 13 15:57:11 apq8096 docker[3873]: time="2021-05-13T15:57:11.595538000Z" level=fatal msg="Error starting dae...oints"
        May 13 15:57:11 apq8096 systemd[1]: docker-start.service: Main process exited, code=exited, status=1/FAILURE
        May 13 15:57:11 apq8096 systemd[1]: docker-start.service: Unit entered failed state.
        May 13 15:57:11 apq8096 systemd[1]: docker-start.service: Failed with result 'exit-code'.
        yocto:~#
        yocto:~# df
        Filesystem     1K-blocks    Used Available Use% Mounted on
        /dev/root        2837860 1890496    930980  68% /
        devtmpfs         1861956       0   1861956   0% /dev
        tmpfs            1930660       0   1930660   0% /dev/shm
        tmpfs            1930660   17136   1913524   1% /run
        tmpfs            1930660       0   1930660   0% /sys/fs/cgroup
        tmpfs            1930660       4   1930656   1% /var/volatile
        /dev/sda2           2168      80      1964   4% /persist
        /dev/sde12         12016    4184      7508  36% /dsp
        /dev/sda3          58888      40     57568   1% /cache
        /dev/sde11         97232   33616     63616  35% /firmware
        /dev/sda9       15248568 7060916   8171268  47% /data
        tmpfs             386132       0    386132   0% /run/user/0
        • K Offline
          K Offline
          kiprock
          I had a battery go pretty low and the system crashed while running mavros in docker last night, after reboot, docker deamon is not responding and I cannot see any images.
          • Eric KatzfeyE Offline
            @kiprock I would reflash the system, setup your IP connection, configure Docker and just verify that it works as expected.
            • K Offline
              K Offline
              kiprock
              just looking at the logs, the docker deamon fails here:
              level=fatal msg="Error starting daemon: Error initializing network controller: could not delete the default bridge network: network bridge has active endpoints"
              Most forums suggest removing the docker network folder: rm -r /var/lib/docker/network
              I did this but still having issues. Just curious if the modalAI setup stores docker files somewhere else?
                @kiprock Everything is stored on /data. But again, I would reflash and start over just to verify Docker operation.
                • K Offline
                  K Offline
                  kiprock
                  rm /data/network/files/local-kv.db
                  did the trick. Thanks for providing that missing piece of data!
                  LucasWL 1 Reply Last reply
                  • K kiprock
                    yocto:~#
                    S Offline
                    S Offline
                    shlee853
                    @kiprock Hi I have a exactly same issue.
                    I flashed image and reset factory configuration on my VOXL, but, It has still issue.
                    Did you resolve this problem?
                    • K Offline
                      K Offline
                      kiprock
                      @Eric-Katzfey if you cannot start docker images, you can try the command above to clear them. Good luck.
                      Eric KatzfeyE S 2 Replies Last reply
                      • K kiprock
                        Thanks, but I think you meant to ping @shlee853
                        • K kiprock
                          S Offline
                          S Offline
                          shlee853
                          @kiprock thank you for your reply
                          I’ll try it
                          • S shlee853
                            I’ll try it
                            S Offline
                            S Offline
                            shlee853
                            @shlee853
                            Great!
                            I resolved this problem as you mentioned.
                            yocto:/$ rm /data/network/files/local-kv.db
                            yocto:/$ voxl-configure-docker-support.sh
                            successfully loaded hello-world
                            starting docker-prepare service
                            Created symlink from /etc/systemd/system/default.target.wants/docker-autorun.service to /etc/systemd/system/docker-autorun.service.
                            done configuring voxl-docker-support
                            • K kiprock
                              LucasWL Offline
                              LucasWL Offline
                              LucasW
                              @kiprock Thank you for this, that also solved the issue in my case.
                              To be a little more cautious, I simply renamed the existing file, which forced the generation of a new one when running the configuration script voxl-configure-docker-support.sh:
                              voxl:/data/network/files$ mv local-kv.db local-kv_DISABLED.db
                              • modaltbM modaltb
                                What do you see after running voxl-configure-docker.sh ?
                                Should be something like:
                                José QuintanillaJ Offline
                                José Quintanilla
                                @modaltb I have a problem, after I write that line, the drone display a message that says: voxl:/$ voxl-configure-docker-suport.sh
                                bash: voxl-configure-docker-suport.sh: command not found
                                voxl:/$
                                  @José-Quintanilla Looks like you spelled it wrong
                                    @José-Quintanilla You can use [TAB] after you start writing a command to auto-fill
                                    José QuintanillaJ 2 Replies Last reply
                                      José Quintanilla
                                      @tom I think it worked, thanks
                                        José Quintanilla
                                        wrote on last edited by José Quintanilla
                                        #27
                                        @tom It wasn't that, because I need that especific line on my VOXL to work, so I can use properly the sdk
                                          @José-Quintanilla What is not working? Did you run voxl-configure-docker-support.sh?
                                          José QuintanillaJ 1 Reply Last reply
