  2. VOXL SDK and Software
  3. Docker daemon fails to start on voxl
40 Posts 11 Posters 27.5k Views 5 Watching
  • K kiprock
    @Chad-Sweet Thanks for the fast response!
    yocto:~# voxl-configure-docker-support.sh
    Stopping original docker service
    Enabling our own services docker-start & docker-prepare
    starting docker-start.service
    loading hello-world docker image
    Cannot connect to the Docker daemon. Is the docker daemon running on this host?
    yocto:~#  systemctl status docker
    ● docker.service - Docker Application Container Engine
       Loaded: loaded (/lib/systemd/system/docker.service; disabled; vendor preset: enabled)
       Active: inactive (dead)
         Docs: http://docs.docker.com
    May 13 15:46:33 apq8096 systemd[1]: Stopped Docker Application Container Engine.
    yocto:~#
    yocto:~#  systemctl start docker
       Active: failed (Result: exit-code) since Thu 2021-05-13 15:48:03 UTC; 2s ago
      Process: 3678 ExecStart=/usr/bin/docker daemon -H fd:// --raw-logs (code=exited, status=2)
     Main PID: 3678 (code=exited, status=2)
    May 13 15:48:03 apq8096 systemd[1]: Started Docker Application Container Engine.
    May 13 15:48:03 apq8096 docker[3678]: flag provided but not defined: --raw-logs
    May 13 15:48:03 apq8096 docker[3678]: See '/usr/bin/docker daemon --help'.
    May 13 15:48:03 apq8096 systemd[1]: docker.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    May 13 15:48:03 apq8096 systemd[1]: docker.service: Unit entered failed state.
    May 13 15:48:03 apq8096 systemd[1]: docker.service: Failed with result 'exit-code'.
    yocto:~# docker images
    An error occurred trying to connect: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.21/images/json: read unix @->/var/run/docker.sock: read: connection reset by peer
    S Offline
    S Offline
    shlee853
    @kiprock Hi I have a exactly same issue.
    I flashed image and reset factory configuration on my VOXL, but, It has still issue.
    Did you resolve this problem?
    • K Offline
      K Offline
      kiprock
      @Eric-Katzfey if you cannot start docker images, you can try the command above to clear them. Good luck.
      Eric KatzfeyE S 2 Replies Last reply
      • K kiprock
        Thanks, but I think you meant to ping @shlee853
        • K kiprock
          S Offline
          S Offline
          shlee853
          @kiprock thank you for your reply
          I’ll try it
          S 1 Reply Last reply
          • S shlee853
            I’ll try it
            S Offline
            S Offline
            shlee853
            @shlee853
            Great!
            I resolved this problem as you mentioned.
            yocto:/$ rm /data/network/files/local-kv.db
            yocto:/$ voxl-configure-docker-support.sh
            successfully loaded hello-world
            starting docker-prepare service
            Created symlink from /etc/systemd/system/default.target.wants/docker-autorun.service to /etc/systemd/system/docker-autorun.service.
            done configuring voxl-docker-support
            • K kiprock
              did the trick. Thanks for providing that missing piece of data!
              LucasWL Offline
              LucasWL Offline
              LucasW
              @kiprock Thank you for this, that also solved the issue in my case.
              To be a little more cautious, I simply renamed the existing file, which forced the generation of a new one when running the configuration script voxl-configure-docker-support.sh:
              voxl:/data/network/files$ mv local-kv.db local-kv_DISABLED.db
              • modaltbM modaltb
                What do you see after running voxl-configure-docker.sh ?
                Should be something like:
                yocto:/# voxl-configure-docker-support.sh
                José QuintanillaJ Offline
                José Quintanilla
                @modaltb I have a problem, after I write that line, the drone display a message that says: voxl:/$ voxl-configure-docker-suport.sh
                bash: voxl-configure-docker-suport.sh: command not found
                voxl:/$
                  @José-Quintanilla Looks like you spelled it wrong
                    @José-Quintanilla You can use [TAB] after you start writing a command to auto-fill
                    José QuintanillaJ 2 Replies Last reply
                      José Quintanilla
                      @tom I think it worked, thanks
                        José Quintanilla
                        wrote on last edited by José Quintanilla
                        #27
                        @tom It wasn't that, because I need that especific line on my VOXL to work, so I can use properly the sdk
                          @José-Quintanilla What is not working? Did you run voxl-configure-docker-support.sh?
                          José QuintanillaJ 1 Reply Last reply
                            José Quintanilla
                            @tom That's the line that doesnt let me run, my done say: voxl-configure-docker-support.sh: command not found
                              @José-Quintanilla What release do you have installed, what does voxl-version say?
                                José Quintanilla
                                @tom If I recall is the 0.9 version
                                  @José-Quintanilla When you get a chance post the output of voxl-version. Also what hardware are you on?
                                    José Quintanilla
                                    @tom I confirm that is the voxl 0.9 version on a m500 hardware im using a voxl flight
                                      @José-Quintanilla I was asking because that command also lists installed packages, try without the .sh: voxl-configure-docker-support
                                        José Quintanilla
                                        @tom voxl:/$ voxl-version
                                        system-image: 4.0.0
                                        kernel: #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
                                        hw version: VOXL
                                        voxl-suite: 0.9.4
                                        Packages:
                                        Repo: http://voxl-packages.modalai.com/dists/apq8096/sdk-0.9/binary-arm64/
                                        Last Updated: stat: cannot stat '/var/lib/opkg/lists/modalai': No such file or directory
                                        List:
                                        apq8096-dfs-server 0.3.1
                                        apq8096-imu-server 1.0.3
                                        apq8096-libpng 1.6.38-1
                                        apq8096-system-tweaks 0.1.3
                                        apq8096-tflite 2.8.3-1
                                        libapq8096-io 0.6.0
                                        libmodal-cv 0.2.3
                                        libmodal-exposure 0.0.7
                                        libmodal-journal 0.2.1
                                        libmodal-json 0.4.3
                                        libmodal-pipe 2.6.0
                                        libvoxl-cci-direct 0.1.5
                                        libvoxl-cutils 0.1.1
                                        voxl-camera-calibration 0.2.3
                                        voxl-camera-server 1.3.5
                                        voxl-cpu-monitor 0.3.0
                                        voxl-docker-support 1.2.4
                                        voxl-gphoto2-server 0.0.10
                                        voxl-jpeg-turbo 2.1.3-4
                                        voxl-libgphoto2 0.0.4
                                        voxl-libuvc 1.0.7
                                        voxl-logger 0.3.4
                                        voxl-mavlink 0.1.0
                                        voxl-mavlink-server 0.2.0
                                        voxl-modem 0.16.1
                                        voxl-mongoose 7.7.0-1
                                        voxl-mpa-to-ros 0.3.6
                                        voxl-mpa-tools 0.7.6
                                        voxl-opencv 4.5.5-1
                                        voxl-portal 0.4.2
                                        voxl-qvio-server 0.8.2
                                        voxl-streamer 0.4.1
                                        voxl-suite 0.9.4
                                        voxl-system-image 4.0-r0
                                        voxl-tag-detector 0.0.4
                                        voxl-tflite-server 0.3.1
                                        voxl-utils 1.2.2
                                        voxl-uvc-server 0.1.3
                                        voxl-vision-px4 1.4.0
                                        voxl-vpn 0.0.6
                                        voxl:/$
                                          José Quintanilla
                                          @tom I think I need to use the command with the .sh, I'm following this guide https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-python
                                          and the command you want me to do is referring to this guide: https://docs.modalai.com/docker-on-voxl/
