  2. VOXL SDK and Software
  3. Docker daemon fails to start on voxl
40 Posts 11 Posters 27.5k Views 5 Watching
  • K Offline
    K Offline
    kiprock
    I had a battery go pretty low and the system crashed while running mavros in docker last night, after reboot, docker deamon is not responding and I cannot see any images.
    • Eric KatzfeyE Offline
      @kiprock I would reflash the system, setup your IP connection, configure Docker and just verify that it works as expected.
      • K Offline
        K Offline
        kiprock
        just looking at the logs, the docker deamon fails here:
        level=fatal msg="Error starting daemon: Error initializing network controller: could not delete the default bridge network: network bridge has active endpoints"
        Most forums suggest removing the docker network folder: rm -r /var/lib/docker/network
        I did this but still having issues. Just curious if the modalAI setup stores docker files somewhere else?
          @kiprock Everything is stored on /data. But again, I would reflash and start over just to verify Docker operation.
          • K Offline
            K Offline
            kiprock
            rm /data/network/files/local-kv.db
            did the trick. Thanks for providing that missing piece of data!
            LucasWL 1 Reply Last reply
            • K kiprock
              @Chad-Sweet Thanks for the fast response!
              yocto:~# voxl-configure-docker-support.sh
              Stopping original docker service
              Enabling our own services docker-start & docker-prepare
              starting docker-start.service
              loading hello-world docker image
              Cannot connect to the Docker daemon. Is the docker daemon running on this host?
              yocto:~#  systemctl status docker
              ● docker.service - Docker Application Container Engine
                 Loaded: loaded (/lib/systemd/system/docker.service; disabled; vendor preset: enabled)
                 Active: inactive (dead)
                   Docs: http://docs.docker.com
              May 13 15:46:33 apq8096 systemd[1]: Stopped Docker Application Container Engine.
              yocto:~#
              yocto:~#  systemctl start docker
                 Active: failed (Result: exit-code) since Thu 2021-05-13 15:48:03 UTC; 2s ago
                Process: 3678 ExecStart=/usr/bin/docker daemon -H fd:// --raw-logs (code=exited, status=2)
               Main PID: 3678 (code=exited, status=2)
              May 13 15:48:03 apq8096 systemd[1]: Started Docker Application Container Engine.
              May 13 15:48:03 apq8096 docker[3678]: flag provided but not defined: --raw-logs
              May 13 15:48:03 apq8096 docker[3678]: See '/usr/bin/docker daemon --help'.
              May 13 15:48:03 apq8096 systemd[1]: docker.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
              May 13 15:48:03 apq8096 systemd[1]: docker.service: Unit entered failed state.
              May 13 15:48:03 apq8096 systemd[1]: docker.service: Failed with result 'exit-code'.
              yocto:~# docker images
              An error occurred trying to connect: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.21/images/json: read unix @->/var/run/docker.sock: read: connection reset by peer
              S Offline
              S Offline
              shlee853
              @kiprock Hi I have a exactly same issue.
              I flashed image and reset factory configuration on my VOXL, but, It has still issue.
              Did you resolve this problem?
              • K Offline
                K Offline
                kiprock
                @Eric-Katzfey if you cannot start docker images, you can try the command above to clear them. Good luck.
                Eric KatzfeyE S 2 Replies Last reply
                • K kiprock
                  Thanks, but I think you meant to ping @shlee853
                  • K kiprock
                    S Offline
                    S Offline
                    shlee853
                    @kiprock thank you for your reply
                    I’ll try it
                    S 1 Reply Last reply
                    • S shlee853
                      I’ll try it
                      S Offline
                      S Offline
                      shlee853
                      @shlee853
                      Great!
                      I resolved this problem as you mentioned.
                      yocto:/$ rm /data/network/files/local-kv.db
                      yocto:/$ voxl-configure-docker-support.sh
                      successfully loaded hello-world
                      starting docker-prepare service
                      Created symlink from /etc/systemd/system/default.target.wants/docker-autorun.service to /etc/systemd/system/docker-autorun.service.
                      done configuring voxl-docker-support
                      • K kiprock
                        LucasWL Offline
                        LucasWL Offline
                        LucasW
                        @kiprock Thank you for this, that also solved the issue in my case.
                        To be a little more cautious, I simply renamed the existing file, which forced the generation of a new one when running the configuration script voxl-configure-docker-support.sh:
                        voxl:/data/network/files$ mv local-kv.db local-kv_DISABLED.db
                        • modaltbM modaltb
                          What do you see after running voxl-configure-docker.sh ?
                          Should be something like:
                          yocto:/# voxl-configure-docker-support.sh
                          José QuintanillaJ Offline
                          José Quintanilla
                          @modaltb I have a problem, after I write that line, the drone display a message that says: voxl:/$ voxl-configure-docker-suport.sh
                          bash: voxl-configure-docker-suport.sh: command not found
                          voxl:/$
                            @José-Quintanilla Looks like you spelled it wrong
                              @José-Quintanilla You can use [TAB] after you start writing a command to auto-fill
                              José QuintanillaJ 2 Replies Last reply
                                José Quintanilla
                                @tom I think it worked, thanks
                                  José Quintanilla
                                  wrote on last edited by José Quintanilla
                                  #27
                                  @tom It wasn't that, because I need that especific line on my VOXL to work, so I can use properly the sdk
                                    @José-Quintanilla What is not working? Did you run voxl-configure-docker-support.sh?
                                    José QuintanillaJ 1 Reply Last reply
                                      José Quintanilla
                                      @tom That's the line that doesnt let me run, my done say: voxl-configure-docker-support.sh: command not found
                                        @José-Quintanilla What release do you have installed, what does voxl-version say?
                                          José Quintanilla
                                          @tom If I recall is the 0.9 version
