  2. VOXL SDK and Software
  3. Docker daemon fails to start on voxl
40 Posts 11 Posters 27.5k Views 5 Watching
  • Eric KatzfeyE Offline
    @kiprock I would reflash the system, setup your IP connection, configure Docker and just verify that it works as expected.
    • K Offline
      K Offline
      kiprock
      just looking at the logs, the docker deamon fails here:
      level=fatal msg="Error starting daemon: Error initializing network controller: could not delete the default bridge network: network bridge has active endpoints"
      Most forums suggest removing the docker network folder: rm -r /var/lib/docker/network
      I did this but still having issues. Just curious if the modalAI setup stores docker files somewhere else?
        @kiprock Everything is stored on /data. But again, I would reflash and start over just to verify Docker operation.
        • K Offline
          K Offline
          kiprock
          rm /data/network/files/local-kv.db
          did the trick. Thanks for providing that missing piece of data!
          LucasWL 1 Reply Last reply
          • K kiprock
            @Chad-Sweet Thanks for the fast response!
            yocto:~# voxl-configure-docker-support.sh
            Stopping original docker service
            Enabling our own services docker-start & docker-prepare
            starting docker-start.service
            loading hello-world docker image
            Cannot connect to the Docker daemon. Is the docker daemon running on this host?
            yocto:~#  systemctl status docker
            ● docker.service - Docker Application Container Engine
               Loaded: loaded (/lib/systemd/system/docker.service; disabled; vendor preset: enabled)
               Active: inactive (dead)
                 Docs: http://docs.docker.com
            May 13 15:46:33 apq8096 systemd[1]: Stopped Docker Application Container Engine.
            yocto:~#
            yocto:~#  systemctl start docker
               Active: failed (Result: exit-code) since Thu 2021-05-13 15:48:03 UTC; 2s ago
              Process: 3678 ExecStart=/usr/bin/docker daemon -H fd:// --raw-logs (code=exited, status=2)
             Main PID: 3678 (code=exited, status=2)
            May 13 15:48:03 apq8096 systemd[1]: Started Docker Application Container Engine.
            May 13 15:48:03 apq8096 docker[3678]: flag provided but not defined: --raw-logs
            May 13 15:48:03 apq8096 docker[3678]: See '/usr/bin/docker daemon --help'.
            May 13 15:48:03 apq8096 systemd[1]: docker.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
            May 13 15:48:03 apq8096 systemd[1]: docker.service: Unit entered failed state.
            May 13 15:48:03 apq8096 systemd[1]: docker.service: Failed with result 'exit-code'.
            yocto:~# docker images
            An error occurred trying to connect: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.21/images/json: read unix @->/var/run/docker.sock: read: connection reset by peer
            S Offline
            S Offline
            shlee853
            @kiprock Hi I have a exactly same issue.
            I flashed image and reset factory configuration on my VOXL, but, It has still issue.
            Did you resolve this problem?
            • K Offline
              K Offline
              kiprock
              @Eric-Katzfey if you cannot start docker images, you can try the command above to clear them. Good luck.
              Eric KatzfeyE S 2 Replies Last reply
              • K kiprock
                Thanks, but I think you meant to ping @shlee853
                • K kiprock
                  S Offline
                  S Offline
                  shlee853
                  @kiprock thank you for your reply
                  I’ll try it
                  S 1 Reply Last reply
                  • S shlee853
                    I’ll try it
                    S Offline
                    S Offline
                    shlee853
                    @shlee853
                    Great!
                    I resolved this problem as you mentioned.
                    yocto:/$ rm /data/network/files/local-kv.db
                    yocto:/$ voxl-configure-docker-support.sh
                    successfully loaded hello-world
                    starting docker-prepare service
                    Created symlink from /etc/systemd/system/default.target.wants/docker-autorun.service to /etc/systemd/system/docker-autorun.service.
                    done configuring voxl-docker-support
                    • K kiprock
                      LucasWL Offline
                      LucasWL Offline
                      LucasW
                      @kiprock Thank you for this, that also solved the issue in my case.
                      To be a little more cautious, I simply renamed the existing file, which forced the generation of a new one when running the configuration script voxl-configure-docker-support.sh:
                      voxl:/data/network/files$ mv local-kv.db local-kv_DISABLED.db
                      • modaltbM modaltb
                        What do you see after running voxl-configure-docker.sh ?
                        Should be something like:
                        yocto:/# voxl-configure-docker-support.sh
                        José QuintanillaJ Offline
                        José Quintanilla
                        @modaltb I have a problem, after I write that line, the drone display a message that says: voxl:/$ voxl-configure-docker-suport.sh
                        bash: voxl-configure-docker-suport.sh: command not found
                        voxl:/$
                          @José-Quintanilla Looks like you spelled it wrong
                            @José-Quintanilla You can use [TAB] after you start writing a command to auto-fill
                            José QuintanillaJ 2 Replies Last reply
                              José Quintanilla
                              @tom I think it worked, thanks
                                José Quintanilla
                                wrote on last edited by José Quintanilla
                                #27
                                @tom It wasn't that, because I need that especific line on my VOXL to work, so I can use properly the sdk
                                  @José-Quintanilla What is not working? Did you run voxl-configure-docker-support.sh?
                                  José QuintanillaJ 1 Reply Last reply
                                    José Quintanilla
                                    @tom That's the line that doesnt let me run, my done say: voxl-configure-docker-support.sh: command not found
                                      @José-Quintanilla What release do you have installed, what does voxl-version say?
                                        José Quintanilla
                                        @tom If I recall is the 0.9 version
                                          @José-Quintanilla When you get a chance post the output of voxl-version. Also what hardware are you on?
