  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 38.7k Views 2 Watching
  • KrisK Kris
    @Adrian-Hidalgo
    I dont see where the version is listed.
    Also, this message keeps popping up everytime I open QGC, about a newer version.
    Adrian HidalgoA Offline
    Adrian Hidalgo
    @Kris in the page, scroll to the bottom
    KrisK 1 Reply Last reply
    • KrisK Kris
      @Adrian-Hidalgo
      Adrian Hidalgo
      @Kris wouldn't hurt to update QGC with the latest
        KrisK Offline
        KrisK Offline
        Kris
        @Adrian-Hidalgo Oh, ok sorry.
        Adrian HidalgoA 1 Reply Last reply
        • KrisK Kris
          Adrian Hidalgo
          @Kris yeah, that's an older version of QGC. Would recommend updating, could be a mismatch of settings.
          After updating, check again local_position_ned
          If that doesn't work, try loading platform 1.12 seeker parameters
          If that doesn't work, try I'd shift to system_image 3.3.0 to see if that would change it. Be sure to save the data partition when asks to wipe.
          KrisK 2 Replies Last reply
            KrisK Offline
            KrisK Offline
            Kris
            @Adrian-Hidalgo Ok, I will try that.
            Thank you so much for helping me with this.
            I will post back here with the results.
              KrisK Offline
              KrisK Offline
              Kris
              @Adrian-Hidalgo Sorry to bother you.
              When I started the new version of PX4 v4.2.3 it was ok.
              Then I started the Seeker and tons of errors started to happen.
              [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCApplication.cc:281 - "Settings location "/home/kris/.config/QGroundControl.org/QGroundControl.ini" Is writable?: true"
              [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCLoggingCategory.cc:120 - "Filter rules "*Log.debug=false\nGStreamerAPILog.debug=true\nqt.qml.connections=false""
              [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCApplication.cc:384 - "System reported locale: QLocale(English, Latin, United States) ; Name "en_US" ; Preffered (used in maps):  "en-US""
              [D] at ../../qgroundcontrol/qgroundcontrol/src/Vehicle/MAVLinkLogManager.cc:360 - "MAVLink logs directory: "/home/kris/Documents/QGroundControl/Logs""
              [D] at ../../qgroundcontrol/qgroundcontrol/src/QtLocationPlugin/QGCMapEngine.cpp:164 - "Map Cache in: "/home/kris/.cache/QGCMapCache300" / "qgcMapCache.db""
              [D] at qrc:/qml/MainRootWindow.qml:51 - "QGCCorePlugin(0x55bb212c6fa0) []"
              [D] at ../../qgroundcontrol/qgroundcontrol/src/MissionManager/MissionController.cc:2371 - "setCurrentPlanViewSeqNum"
              [E] at ../../qgroundcontrol/qgroundcontrol/src/VideoReceiver/GstVideoReceiver.cc:284 - "Stop called on empty URI"
              [D] at ../../qgroundcontrol/qgroundcontrol/src/MissionManager/MissionController.cc:1272 - "_recalcFlightPathSegments homePositionValid false"
              [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCApplication.cc:848 - ""v4.2.0""
              [!] at :0 - "Unable to start the client: "org.freedesktop.DBus.Error.AccessDenied" "Geolocation disabled for UID 1000""
              [E] at ../../qgroundcontrol/qgroundcontrol/src/PositionManager/PositionManager.cpp:188 - "QGCPositionManager error 0"
              [D] at ../../qgroundcontrol/qgroundcontrol/src/comm/UDPLink.cc:205 - "Adding target QHostAddress("192.168.110.152") 14550"
              [E] at qrc:/qml/QGroundControl/FlightDisplay/ObstacleDistanceOverlayMap.qml:42 - "qrc:/qml/QGroundControl/FlightDisplay/ObstacleDistanceOverlayMap.qml:42: Error: createRadialGradient(): Incorrect arguments"
              [I] at ../../qgroundcontrol/qgroundcontrol/src/FactSystem/ParameterManager.cc:829 - "Attemping load from cache"
              [I] at ../../qgroundcontrol/qgroundcontrol/src/FactSystem/ParameterManager.cc:919 - "Parameters cache match failed /home/kris/.config/QGroundControl.org/ParamCache/1_1.v2"
              [E] at ../../qgroundcontrol/qgroundcontrol/src/comm/UDPLink.cc:167 - "Error writing to QHostAddress("192.168.110.152") 14550"
              • KrisK Offline
                KrisK Offline
                Kris
                wrote on last edited by Kris
                #47
                The errors are continuous and eventually everything freezes. When QGC finally closes, I lose my internet connection on my host PC.
                I dont know what's going on.
                Maybe its because of the settings from voxl...
                • Adrian HidalgoA Offline
                  Adrian Hidalgo
                  @Kris before turning on the Seeker, QGC works fine? Are you able to navigate around the gui?
                  Hmm...You could try deleting the px4 parameters that were loaded onto the voxl. You'll have to calibrate all the sensors and load the correct parameters if you do choose to go this route.
                  It kinda seems like there's something with the obstacle avoidance. May first want to try disabling en_voa in vvpx4 (marking it false) as well as disabling dfs server before deleting px4 parameters
                    I think Kris is printing out errors from QGC, which we do not have any influence of
                    The original issue was that PX4 is not incorporating VIO data.
                    For that, please try the parameters recommended for Seeker
                    Here are the default Seeker parameters for PX4 1.11:
                    https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/platforms/v1.11/Seeker_v1_param_rev_A.params
                    https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/seeker/ekf2_indoor_vio.params
                    • KrisK Offline
                      KrisK Offline
                      Kris
                      @Adrian-Hidalgo @Chad-Sweet , Thank you.
                      I reverted back to v4.0.11 and QGC loaded normally with the drone.
                      Maybe when I removed the QGC the first time and installed the newest version v4.2.3, I might have done it wrong.
                      I am researching into it now. I will try again soon with the v4.2.3
                      Any ideas on what is wrong?
                        KrisK Offline
                        KrisK Offline
                        Kris
                        @Adrian-Hidalgo yes, v4.2.3 was working fine before turning on the drone. As soon as I turned it on, the drone connected then disconnected a couple of times. finally disconnecting and eventually freezing PX4.
                        • KrisK Offline
                          KrisK Offline
                          Kris
                          #52
                          Ok, I got PX4 v4.2.3 to work.
                          The Odometry and the LOCAL_POSITION_NED are still reading 0 value for x and y.
                          So, I will try to restart some services in voxl.
                            If voxl-inspect-qvio is showing good VIO data, there should be no need to change things on VOXL. the VOXL services are working properly.
                            You are most likely having issues with PX4 which runs on Flight Core. Please load the parameter files recommended and report back the result.
                            KrisK 4 Replies Last reply
                            • Chad SweetC Chad Sweet
                              KrisK Offline
                              KrisK Offline
                              Kris
                              #54
                              @Chad-Sweet I tried loading those two files again, but they are the same as what I already have loaded in PX4.
                              I got this message for both of the files (Seeker_v1_param_rev_A) and (ekf2_indoor_vio).
                                KrisK Offline
                                KrisK Offline
                                Kris
                                @Chad-Sweet
                                PX4 Sensor Status
                                • KrisK Offline
                                  KrisK Offline
                                  Kris
                                  #56
                                  I suppose I can disable voa and only have vio enabled in voxl-vision-px4.conf file and see if that gets the vio to work.
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    @Chad-Sweet
                                    I think the QVIO data looks a little blurry on the right side.
                                    Could this be the cause?
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      #58
                                      @Chad-Sweet
                                      I ran the commandvoxl-inspect-cam qvioand these are the results.
                                      | Pipe Name |size(bytes)| height | width  |exposure(ms)| gain | frame id |latency(ms)|Framt
                                      ERROR: received unreasonably large camera frame size
                                      ERROR: only read 1520 bytes of data, expected 983401498
                                      ERROR: only read 1520 bytes of data, expected 983149407
                                      ERROR: only read 1520 bytes of data, expected 983930947
                                      ERROR: only read 1520 bytes of data, expected 983422103
                                      ERROR: only read 1520 bytes of data, expected 983595126
                                      ERROR: only read 1520 bytes of data, expected 983464840
                                      ERROR: only read 1520 bytes of data, expected 983415196
                                      ERROR: only read 1520 bytes of data, expected 983527753
                                      ERROR: only read 1520 bytes of data, expected 983349143
                                      ERROR: only read 1520 bytes of data, expected 983865918
                                      ERROR: only read 1520 bytes of data, expected 983142625
                                      ERROR: only read 1520 bytes of data, expected 983727796
                                      ERROR: only read 1520 bytes of data, expected 983669901
                                      ERROR: only read 1520 bytes of data, expected 983405545
                                      ERROR: only read 1520 bytes of data, expected 983563131
                                      ERROR: only read 1520 bytes of data, expected 984096255
                                      ERROR: only read 1520 bytes of data, expected 983959335
                                      ERROR: only read 1520 bytes of data, expected 983599080
                                      ERROR: only read 1520 bytes of data, expected 983627034
                                      ERROR: only read 1520 bytes of data, expected 983492744
                                      ERROR: only read 1520 bytes of data, expected 983316928
                                      ERROR: only read 1520 bytes of data, expected 983339417
                                      ERROR: only read 1520 bytes of data, expected 982167476
                                      ERROR: only read 1520 bytes of data, expected 983328375
                                      ERROR: only read 1520 bytes of data, expected 982822047
                                      ERROR: only read 1520 bytes of data, expected 982820284
                                      ERROR: only read 1520 bytes of data, expected 982943181
                                      ERROR: only read 1520 bytes of data, expected 983051188
                                      ERROR: only read 1520 bytes of data, expected 982898929
                                      ERROR: only read 1520 bytes of data, expected 983097249
                                      ERROR: only read 1520 bytes of data, expected 983276539
                                      ERROR: only read 1520 bytes of data, expected 983529139
                                      ^C
                                      received SIGINT Ctrl-C
                                      ERROR: only read 896 bytes of data, expected 983179045
                                      This is what I get for tracking;
                                      |  tracking |   307200  |    480 |    640 |       7.50 |  150 |   45466  |      13.5 |    8
                                      This is what I get for stereo;
                                      |    stereo |   614400  |    480 |    640 |       2.92 |  100 |   47266  |      46.3 |    8
                                      and this is what I get for tof;
                                      |       tof |        0  |      0 |      0 |       0.00 |    0 |       0  |      18.1 |    8
                                      ERROR: invalid metadata, magic number=0, expected 1448040524
                                      It looks like the problem is coming from the tof right?
                                      So I ran the command voxl-inspect-tofand was only receiving 0.0 in the values. So I waved my hand back in forth in front of the tof cam (roughly 3 inches away from tof) and 0.2 was the highest value I could get.
                                      timestamp(ms)| center point (m)
                                           1979507 | -0.0   0.0   0.2^C
                                      However the voxl-inspect-qvio appears to be fine.
                                      voxl:~$ voxl-inspect-qvio
                                      waiting for server
                                          T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
                                          0.00   -0.00   -0.00|   0.0   -0.0   -0.0| OKAY |
                                          0.00   -0.00   -0.00|  -0.0   -0.0    0.0| OKAY |
                                          0.00    0.00    0.00|  -0.0   -0.2    0.1| OKAY |
                                          0.00   -0.00   -0.00|  -0.0   -0.2    0.1| OKAY |
                                         -0.00   -0.00   -0.00|  -0.2    0.8   -0.2| OKAY |
                                          0.01   -0.01   -0.00|  -0.4    4.1    7.9| OKAY |
                                         -0.00   -0.03    0.01|  -0.9   -1.3  -10.3| OKAY |
                                          0.01   -0.00   -0.01|   0.0    3.7   -0.6| OKAY |
                                          0.01   -0.00   -0.01|  -0.0    3.7   -0.6| OKAY | ^C
                                      I rotated the voxl slightly to the left and to the right to obtain those values.
                                        #59
                                        The QVIO overlay looks good, so VIO is working. There is nothing wrong with the image sensor and VOXL setup if VIO is working.
                                        TOF and stereo have nothing to do with VIO.
                                        VIO is publishing valid data, but PX4 is not receiving it for some reason
                                          KrisK Offline
                                          KrisK Offline
                                          Kris
                                          #60
                                          @Chad-Sweet I have been working on putting together some information/data. I will be posting it here soon.
