  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 43.6k Views 2 Watching
    @Kris before turning on the Seeker, QGC works fine? Are you able to navigate around the gui?
    Hmm...You could try deleting the px4 parameters that were loaded onto the voxl. You'll have to calibrate all the sensors and load the correct parameters if you do choose to go this route.
    It kinda seems like there's something with the obstacle avoidance. May first want to try disabling en_voa in vvpx4 (marking it false) as well as disabling dfs server before deleting px4 parameters
    KrisK Offline
    KrisK Offline
    Kris
    @Adrian-Hidalgo yes, v4.2.3 was working fine before turning on the drone. As soon as I turned it on, the drone connected then disconnected a couple of times. finally disconnecting and eventually freezing PX4.
    • KrisK Offline
      KrisK Offline
      Kris
      wrote on last edited by Kris
      #52
      @Adrian-Hidalgo @Chad-Sweet
      Ok, I got PX4 v4.2.3 to work.
      The Odometry and the LOCAL_POSITION_NED are still reading 0 value for x and y.
      So, I will try to restart some services in voxl.
        If voxl-inspect-qvio is showing good VIO data, there should be no need to change things on VOXL. the VOXL services are working properly.
        You are most likely having issues with PX4 which runs on Flight Core. Please load the parameter files recommended and report back the result.
        KrisK 4 Replies Last reply
        • Chad SweetC Chad Sweet
          KrisK Offline
          KrisK Offline
          Kris
          #54
          @Chad-Sweet I tried loading those two files again, but they are the same as what I already have loaded in PX4.
          I got this message for both of the files (Seeker_v1_param_rev_A) and (ekf2_indoor_vio).
            KrisK Offline
            KrisK Offline
            Kris
            @Chad-Sweet
            PX4 Sensor Status
            • KrisK Offline
              KrisK Offline
              Kris
              #56
              I suppose I can disable voa and only have vio enabled in voxl-vision-px4.conf file and see if that gets the vio to work.
                KrisK Offline
                KrisK Offline
                Kris
                @Chad-Sweet
                I think the QVIO data looks a little blurry on the right side.
                Could this be the cause?
                  KrisK Offline
                  KrisK Offline
                  Kris
                  #58
                  @Chad-Sweet
                  I ran the commandvoxl-inspect-cam qvioand these are the results.
                  | Pipe Name |size(bytes)| height | width  |exposure(ms)| gain | frame id |latency(ms)|Framt
                  ERROR: received unreasonably large camera frame size
                  ERROR: only read 1520 bytes of data, expected 983401498
                  ERROR: only read 1520 bytes of data, expected 983149407
                  ERROR: only read 1520 bytes of data, expected 983930947
                  ERROR: only read 1520 bytes of data, expected 983422103
                  ERROR: only read 1520 bytes of data, expected 983595126
                  ERROR: only read 1520 bytes of data, expected 983464840
                  ERROR: only read 1520 bytes of data, expected 983415196
                  ERROR: only read 1520 bytes of data, expected 983527753
                  ERROR: only read 1520 bytes of data, expected 983349143
                  ERROR: only read 1520 bytes of data, expected 983865918
                  ERROR: only read 1520 bytes of data, expected 983142625
                  ERROR: only read 1520 bytes of data, expected 983727796
                  ERROR: only read 1520 bytes of data, expected 983669901
                  ERROR: only read 1520 bytes of data, expected 983405545
                  ERROR: only read 1520 bytes of data, expected 983563131
                  ERROR: only read 1520 bytes of data, expected 984096255
                  ERROR: only read 1520 bytes of data, expected 983959335
                  ERROR: only read 1520 bytes of data, expected 983599080
                  ERROR: only read 1520 bytes of data, expected 983627034
                  ERROR: only read 1520 bytes of data, expected 983492744
                  ERROR: only read 1520 bytes of data, expected 983316928
                  ERROR: only read 1520 bytes of data, expected 983339417
                  ERROR: only read 1520 bytes of data, expected 982167476
                  ERROR: only read 1520 bytes of data, expected 983328375
                  ERROR: only read 1520 bytes of data, expected 982822047
                  ERROR: only read 1520 bytes of data, expected 982820284
                  ERROR: only read 1520 bytes of data, expected 982943181
                  ERROR: only read 1520 bytes of data, expected 983051188
                  ERROR: only read 1520 bytes of data, expected 982898929
                  ERROR: only read 1520 bytes of data, expected 983097249
                  ERROR: only read 1520 bytes of data, expected 983276539
                  ERROR: only read 1520 bytes of data, expected 983529139
                  ^C
                  received SIGINT Ctrl-C
                  ERROR: only read 896 bytes of data, expected 983179045
                  This is what I get for tracking;
                  |  tracking |   307200  |    480 |    640 |       7.50 |  150 |   45466  |      13.5 |    8
                  This is what I get for stereo;
                  |    stereo |   614400  |    480 |    640 |       2.92 |  100 |   47266  |      46.3 |    8
                  and this is what I get for tof;
                  |       tof |        0  |      0 |      0 |       0.00 |    0 |       0  |      18.1 |    8
                  ERROR: invalid metadata, magic number=0, expected 1448040524
                  It looks like the problem is coming from the tof right?
                  So I ran the command voxl-inspect-tofand was only receiving 0.0 in the values. So I waved my hand back in forth in front of the tof cam (roughly 3 inches away from tof) and 0.2 was the highest value I could get.
                  timestamp(ms)| center point (m)
                       1979507 | -0.0   0.0   0.2^C
                  However the voxl-inspect-qvio appears to be fine.
                  voxl:~$ voxl-inspect-qvio
                  waiting for server
                      T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
                      0.00   -0.00   -0.00|   0.0   -0.0   -0.0| OKAY |
                      0.00   -0.00   -0.00|  -0.0   -0.0    0.0| OKAY |
                      0.00    0.00    0.00|  -0.0   -0.2    0.1| OKAY |
                      0.00   -0.00   -0.00|  -0.0   -0.2    0.1| OKAY |
                     -0.00   -0.00   -0.00|  -0.2    0.8   -0.2| OKAY |
                      0.01   -0.01   -0.00|  -0.4    4.1    7.9| OKAY |
                     -0.00   -0.03    0.01|  -0.9   -1.3  -10.3| OKAY |
                      0.01   -0.00   -0.01|   0.0    3.7   -0.6| OKAY |
                      0.01   -0.00   -0.01|  -0.0    3.7   -0.6| OKAY | ^C
                  I rotated the voxl slightly to the left and to the right to obtain those values.
                    #59
                    The QVIO overlay looks good, so VIO is working. There is nothing wrong with the image sensor and VOXL setup if VIO is working.
                    TOF and stereo have nothing to do with VIO.
                    VIO is publishing valid data, but PX4 is not receiving it for some reason
                    KrisK 2 Replies Last reply
                      KrisK Offline
                      KrisK Offline
                      Kris
                      #60
                      @Chad-Sweet I have been working on putting together some information/data. I will be posting it here soon.
                        KrisK Offline
                        KrisK Offline
                        Kris
                        @Chad-Sweet below is some data I have collected.
                        voxl-inspect-points tof_pc
                        timestamp(ms)| # points | # bytes |     1st point     | Format
                              436351 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
                              438151 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
                              440885 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
                              442417 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
                              448818 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
                              453484 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
                              454684 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
                              461952 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ^C
                        closing and exiting
                        I moved the drone around and placed my hand and objects in front of the tof, but I was still not able to get any values.
                        voxl-inspect-points voa_pc_out
                              534219 |      438 |    5256 |   0.2   0.1   0.1 | Float XYZ
                              534353 |      438 |    5256 |   0.2   0.1   0.1 | Float XYZ
                              534488 |      437 |    5244 |   0.2   0.1   0.1 | Float XYZ
                              534587 |      440 |    5280 |   0.2   0.1   0.1 | Float XYZ
                              534720 |      438 |    5256 |   0.2   0.1   0.1 | Float XYZ
                              534853 |      427 |    5124 |   0.2   0.1   0.1 | Float XYZ
                              534986 |      436 |    5232 |   0.2   0.1   0.1 | Float XYZ
                              535086 |      447 |    5364 |   0.2   0.1   0.1 | Float XYZ
                              535219 |      453 |    5436 |   0.2   0.1   0.1 | Float XYZ
                              535352 |      445 |    5340 |   0.2   0.1   0.1 | Float XYZ
                              535619 |      465 |    5580 |   0.2   0.1   0.1 | Float XYZ
                              535752 |      455 |    5460 |   0.2   0.1   0.1 | Float XYZ
                              535886 |      456 |    5472 |   2.9   1.7  -1.3 | Float XYZ
                              536019 |      450 |    5400 |   0.2   0.1   0.1 | Float XYZ
                              536186 |      439 |    5268 |   0.2   0.1   0.1 | Float XYZ
                              536286 |      437 |    5244 |   0.2   0.1   0.1 | Float XYZ
                              536419 |      446 |    5352 |   0.2   0.1   0.1 | Float XYZ
                              536586 |      450 |    5400 |   0.2   0.1   0.1 | Float XYZ
                              536719 |      448 |    5376 |   0.2   0.1   0.1 | Float XYZ
                              536853 |      438 |    5256 |   0.2   0.1   0.1 | Float XYZ
                              536986 |      448 |    5376 |   0.2   0.1   0.1 | Float XYZ
                              537153 |      459 |    5508 |   0.2   0.1   0.1 | Float XYZ
                              537287 |      462 |    5544 |   0.2   0.1   0.1 | Float XYZ
                              537419 |      459 |    5508 |   0.2   0.1   0.1 | Float XYZ
                              537586 |      464 |    5568 |   2.9   1.7  -1.3 | Float XYZ
                              537719 |      453 |    5436 |   0.2   0.1   0.1 | Float XYZ
                              537886 |      446 |    5352 |   0.2   0.1   0.1 | Float XYZ
                              538019 |      443 |    5316 |   0.2   0.1   0.1 | Float XYZ
                              538152 |      440 |    5280 |   0.2   0.1   0.1 | Float XYZ
                              538285 |      444 |    5328 |   0.2   0.1   0.1 | Float XYZ
                              538419 |      448 |    5376 |   0.2   0.1   0.1 | Float XYZ
                              538586 |      469 |    5628 |   0.2   0.1   0.1 | Float XYZ
                              573252 |       42 |     504 |   0.2   0.1   0.1 | Float XYZ
                              573385 |       43 |     516 |   0.2   0.1   0.1 | Float XYZ
                              573552 |       44 |     528 |   0.2   0.1   0.1 | Float XYZ
                              573718 |       49 |     588 |   0.2   0.1   0.1 | Float XYZ
                              574019 |       47 |     564 |   0.2   0.1   0.1 | Float XYZ
                              594519 |      452 |    5424 |   0.2   0.1   0.1 | Float XYZ
                              595052 |      421 |    5052 |   0.2   0.1   0.1 | Float XYZ
                              595552 |      422 |    5064 |   0.2   0.1   0.1 | Float XYZ
                              603719 |      451 |    5412 |   0.2   0.1   0.1 | Float XYZ^C
                        closing and exiting
                        Nothing was in front of the drone at the beginning and those were the values that I was receiving. the point values remained at "0.2 0.1 0.1" then every 2 seconds or so the values would flash "2.9 1.7 -1.3" for a split second. Then towards the end I placed my hand in front of the tof cam (about 3~5 inches away) and recieved those 40's. When I removed my hand the values changed back to the 400's.
                        voxl-inspect-points dfs_disparity
                        ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: 314570
                        ^C
                        closing and exiting
                        voxl-inspect-points dfs_disparity_scaled
                        ^C
                        closing and exiting
                        voxl-inspect-points dfs_point_cloud
                             1534485 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1535687 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1538019 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1539718 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1541220 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1542219 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1543217 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1544216 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1545218 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1545718 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1548718 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1549551 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1550051 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1550784 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
                             1553650 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ^C
                        closing and exiting
                        I moved the drone around and also placed my hand in front of the voxl, but only the timestamp was working.
                        voxl-inspect-points tof_noise
                        ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: 112726
                        ^C
                        closing and exiting
                        • KrisK Offline
                          KrisK Offline
                          Kris
                          voxl-inspect-points tof_ir
                          invalid metadata, magic number=1, expected 1448040524
                          invalid metadata, magic number=65536, expected 1448040524
                          invalid metadata, magic number=16842752, expected 1448040524
                          invalid metadata, magic number=16777216, expected 1448040524
                          invalid metadata, magic number=256, expected 1448040524
                          invalid metadata, magic number=16777472, expected 1448040524
                          invalid metadata, magic number=65537, expected 1448040524
                          ^C
                          closing and exiting
                          voxl-inspect-points tof_conf
                          ^C
                          closing and exiting
                          voxl-inspect-points tof_depth
                          ^C
                          closing and exiting
                          voxl-inspect-points qvio
                          ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11172
                          ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11178
                          ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11174
                          ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11173
                          ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11170
                          ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11171
                          ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11177
                          ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11175
                          ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11176
                          ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11179
                          ^C
                          closing and exiting
                          voxl-inspect-points qvio_overlay
                          ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: 356524
                          ^C
                          closing and exiting
                          • KrisK Offline
                            KrisK Offline
                            Kris
                            @Chad-Sweet
                            So, what do you think the problem might be?
                            I’ll be taking a more detailed look at PX4 next.
                            If you feel that is where the issue is for the VIO.
                            • KrisK Offline
                              KrisK Offline
                              Kris
                              #64
                              @Chad-Sweet
                              I really do appreciate you helping me with this.
                              Thank you! 🙏
                              • KrisK Offline
                                KrisK Offline
                                Kris
                                If the problem is coming from PX4, how should I go about resolving it? Should I be speaking with PX4 support instead of ModalAi?
                                • KrisK Offline
                                  KrisK Offline
                                  Kris
                                  #66
                                  @Chad-Sweet @Adrian-Hidalgo ,
                                  For PX4 confirmation, here is my voxl vision status.
                                  voxl:~$ systemctl status voxl-vision-px4 -l
                                  ● voxl-vision-px4.service - voxl-vision-px4
                                     Loaded: loaded (/usr/bin/voxl-vision-px4; enabled; vendor preset: enabled)
                                     Active: active (running) since Thu 1970-01-01 00:00:06 UTC; 52 years 8 months ago
                                   Main PID: 2073 (voxl-vision-px4)
                                     CGroup: /system.slice/voxl-vision-px4.service
                                             └─2073 /usr/bin/voxl-vision-px4
                                  Sep 02 16:25:57 apq8096 voxl-vision-px4[2073]: ERROR validating VIO data received through pipe: read partial packet
                                  Sep 02 16:25:57 apq8096 voxl-vision-px4[2073]: read 156 bytes, but it should be a multiple of 324
                                  voxl:~$
                                  Could this be a time/clock, or a watchdog timer issue?
                                  • James StrawsonJ Offline
                                    James Strawson
                                    Hi Kris
                                    It looks like the voxl-vision-px4 and voxl-qvio-server versions have gotten out of sync, likely voxl-vision-px4 has been updated but voxl-qvio-server was not.
                                    Do you mind proving the output from the following 3 commands so I can check the state of the opkg package manager
                                    cat /etc/opkg/opkg.conf
                                    opkg info voxl-vision-px4
                                    opkg info voxl-qvio-server
                                    James
                                    KrisK 1 Reply Last reply
                                      Hi Kris
                                      James
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      #68
                                      Hi @James-Strawson , thank you. Here are the outputs you have requested.
                                      ## This file has been automatically generated.
                                      ## Please use voxl-configure-opkg to modify it.
                                      dest root /
                                      option lists_dir /var/lib/opkg/lists
                                      arch all 1
                                      arch arm64 7
                                      src/gz modalai http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64/
                                      voxl:~$ opkg info voxl-vision-px4
                                      Package: voxl-vision-px4
                                      Version: 1.2.0
                                      Depends: librc-math, libmodal-pipe (>= 2.4.0), libmodal-json, voxl-mpa-tools (>= 0.2.5), voxl-mavlink-server, libmodal-cv (>= 0.1.0)
                                      Section: base
                                      Architecture: arm64
                                      Maintainer: James Strawson <james@modalai.com>
                                      MD5Sum: 4bcff955596c2a5964d68cacf60d08a8
                                      Filename: voxl-vision-px4_1.2.0.ipk
                                      Description: Interface between VOXL's computer vision services and PX4
                                      Installed-Time: 1661276328
                                      voxl:~$ opkg info voxl-qvio-server
                                      Package: voxl-qvio-server
                                      Version: 0.7.1
                                      Depends: libmodal-pipe (>= 2.4.0), libmodal-json (>= 0.4.0), voxl-mpa-tools (>= 0.7.0)
                                      Section: base
                                      Architecture: arm64
                                      Maintainer: james@modalai.com
                                      MD5Sum: 2ccb793c2d7059217d9d32b54564352b
                                      Filename: voxl-qvio-server_0.7.1.ipk
                                      Description: publishes QVIO data over named pipe interface
                                      Version: 0.4.6
                                      Depends: libmodal-pipe (>= 2.0.0), libmodal-json (>= 0.4.0), voxl-mpa-tools
                                      Status: install ok installed
                                      Architecture: arm64
                                      Installed-Time: 6815
                                      qvio-server version 0.7.1 status: unknown ok not-installed
                                      voxl:~$ opkg list-installed | grep "libmodal"
                                      libmodal-cv - 0.1.0
                                      libmodal-exposure - 0.0.7
                                      libmodal-json - 0.4.2
                                      libmodal-pipe - 2.4.0
                                        James Strawson
                                        wrote on last edited by James Strawson
                                        #69
                                        Yes, It seems your installed voxl-vision-px4 and libmodal_pipe versions are from SDK 0.8 wheras your voxl-qvio-server is from SDK 0.7, that is the source of the mismatch.
                                        You can upgrade qvio server with opkg install voxl-qvio-server to fix the mismatch quickly but I would recommend just flashing back to the SDK 0.7 platform release since SDK 0.8 does not support TOF on VOXL1. The platform releases are tested as a whole an include a set of packages all known to work together. When individual packages get upgraded instead of the whole SDK together then things tend to break.
                                          KrisK Offline
                                          KrisK Offline
                                          Kris
                                          @James-Strawson
                                          Thank you, I will try this 👍
