  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 43.6k Views 2 Watching
    @Kris Can you post a pic of QGC under MavLink Inspector, go to the tab that says Local_Position_Ned and see what the X, Y, Z show. I want to verify how those numbers are numerating.
    Normally if the X & Y are zeroed out, VIO hasn't started yet or has blown up. A power-cycle can fix this, but I would think you've already attempted that. Looks like you've already attempted resetting voxl-vision-px4 & qvio.
    You may want to try reconfiguring mpa:
    voxl-configure-mpa -p -f seeker -b blue -c 7 --fc yes
    Power-cycle afterwards. You'll have to set your qgc-ip again since mpa will reset it to factory.
    KrisK Offline
    KrisK Offline
    Kris
    @Adrian-Hidalgo
    Unfortunatly that didnt work either 😢
      KrisK Offline
      KrisK Offline
      Kris
      @Adrian-Hidalgo @Chad-Sweet , Is there anything else you would like to look at on my end or something else I can try to resolve this issue?
      • Adrian HidalgoA Offline
        Adrian Hidalgo
        @Kris what version of PX4 are you using?
        This forum may have similar issues and it was resolved by updating PX4
        KrisK 2 Replies Last reply
          KrisK Offline
          KrisK Offline
          Kris
          @Adrian-Hidalgo I honestly don't remember which one I installed. Could you please remind me how to check for the version?
            KrisK Offline
            KrisK Offline
            Kris
              Adrian Hidalgo
              @Kris select the Q, should say in the menu selection below application settings
              KrisK 1 Reply Last reply
                Adrian Hidalgo
                @Kris you could try loading a previous sys-image & sdk. Did it work before updating?
                  KrisK Offline
                  KrisK Offline
                  Kris
                  @Adrian-Hidalgo I have not had it for very long. I have not gotten it to work before.
                    Adrian Hidalgo
                    @Kris all Seekers get test flown before shipping to validate functionality. They are loaded with VOXL Platform 3.3.0-0.5.0, test flown with px4 platform 1.11 seeker & helper files for seeker ekf_2_indoor & spektrum_dx6e_config.
                    You can try loading the platform 1.12 seeker to see if that helps
                      KrisK Offline
                      KrisK Offline
                      Kris
                      @Adrian-Hidalgo
                      I dont see where the version is listed.
                      Also, this message keeps popping up everytime I open QGC, about a newer version.
                      Adrian HidalgoA 2 Replies Last reply
                      • KrisK Kris
                        @Adrian-Hidalgo
                        Adrian Hidalgo
                        @Kris in the page, scroll to the bottom
                        • KrisK Kris
                          @Adrian-Hidalgo
                          Adrian Hidalgo
                          @Kris wouldn't hurt to update QGC with the latest
                            KrisK Offline
                            KrisK Offline
                            Kris
                            @Adrian-Hidalgo Oh, ok sorry.
                            Adrian HidalgoA 1 Reply Last reply
                            • KrisK Kris
                              Adrian Hidalgo
                              @Kris yeah, that's an older version of QGC. Would recommend updating, could be a mismatch of settings.
                              After updating, check again local_position_ned
                              If that doesn't work, try loading platform 1.12 seeker parameters
                              If that doesn't work, try I'd shift to system_image 3.3.0 to see if that would change it. Be sure to save the data partition when asks to wipe.
                                KrisK Offline
                                KrisK Offline
                                Kris
                                @Adrian-Hidalgo Ok, I will try that.
                                Thank you so much for helping me with this.
                                I will post back here with the results.
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  @Adrian-Hidalgo Sorry to bother you.
                                  When I started the new version of PX4 v4.2.3 it was ok.
                                  Then I started the Seeker and tons of errors started to happen.
                                  [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCApplication.cc:281 - "Settings location "/home/kris/.config/QGroundControl.org/QGroundControl.ini" Is writable?: true"
                                  [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCLoggingCategory.cc:120 - "Filter rules "*Log.debug=false\nGStreamerAPILog.debug=true\nqt.qml.connections=false""
                                  [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCApplication.cc:384 - "System reported locale: QLocale(English, Latin, United States) ; Name "en_US" ; Preffered (used in maps):  "en-US""
                                  [D] at ../../qgroundcontrol/qgroundcontrol/src/Vehicle/MAVLinkLogManager.cc:360 - "MAVLink logs directory: "/home/kris/Documents/QGroundControl/Logs""
                                  [D] at ../../qgroundcontrol/qgroundcontrol/src/QtLocationPlugin/QGCMapEngine.cpp:164 - "Map Cache in: "/home/kris/.cache/QGCMapCache300" / "qgcMapCache.db""
                                  [D] at qrc:/qml/MainRootWindow.qml:51 - "QGCCorePlugin(0x55bb212c6fa0) []"
                                  [D] at ../../qgroundcontrol/qgroundcontrol/src/MissionManager/MissionController.cc:2371 - "setCurrentPlanViewSeqNum"
                                  [E] at ../../qgroundcontrol/qgroundcontrol/src/VideoReceiver/GstVideoReceiver.cc:284 - "Stop called on empty URI"
                                  [D] at ../../qgroundcontrol/qgroundcontrol/src/MissionManager/MissionController.cc:1272 - "_recalcFlightPathSegments homePositionValid false"
                                  [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCApplication.cc:848 - ""v4.2.0""
                                  [!] at :0 - "Unable to start the client: "org.freedesktop.DBus.Error.AccessDenied" "Geolocation disabled for UID 1000""
                                  [E] at ../../qgroundcontrol/qgroundcontrol/src/PositionManager/PositionManager.cpp:188 - "QGCPositionManager error 0"
                                  [D] at ../../qgroundcontrol/qgroundcontrol/src/comm/UDPLink.cc:205 - "Adding target QHostAddress("192.168.110.152") 14550"
                                  [E] at qrc:/qml/QGroundControl/FlightDisplay/ObstacleDistanceOverlayMap.qml:42 - "qrc:/qml/QGroundControl/FlightDisplay/ObstacleDistanceOverlayMap.qml:42: Error: createRadialGradient(): Incorrect arguments"
                                  [I] at ../../qgroundcontrol/qgroundcontrol/src/FactSystem/ParameterManager.cc:829 - "Attemping load from cache"
                                  [I] at ../../qgroundcontrol/qgroundcontrol/src/FactSystem/ParameterManager.cc:919 - "Parameters cache match failed /home/kris/.config/QGroundControl.org/ParamCache/1_1.v2"
                                  [E] at ../../qgroundcontrol/qgroundcontrol/src/comm/UDPLink.cc:167 - "Error writing to QHostAddress("192.168.110.152") 14550"
                                  • KrisK Offline
                                    KrisK Offline
                                    Kris
                                    wrote on last edited by Kris
                                    #47
                                    The errors are continuous and eventually everything freezes. When QGC finally closes, I lose my internet connection on my host PC.
                                    I dont know what's going on.
                                    Maybe its because of the settings from voxl...
                                      Adrian Hidalgo
                                      @Kris before turning on the Seeker, QGC works fine? Are you able to navigate around the gui?
                                      Hmm...You could try deleting the px4 parameters that were loaded onto the voxl. You'll have to calibrate all the sensors and load the correct parameters if you do choose to go this route.
                                      It kinda seems like there's something with the obstacle avoidance. May first want to try disabling en_voa in vvpx4 (marking it false) as well as disabling dfs server before deleting px4 parameters
                                        I think Kris is printing out errors from QGC, which we do not have any influence of
                                        The original issue was that PX4 is not incorporating VIO data.
                                        For that, please try the parameters recommended for Seeker
                                        Here are the default Seeker parameters for PX4 1.11:
                                        https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/platforms/v1.11/Seeker_v1_param_rev_A.params
                                        https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/seeker/ekf2_indoor_vio.params
                                        • KrisK Offline
                                          KrisK Offline
                                          Kris
                                          @Adrian-Hidalgo @Chad-Sweet , Thank you.
                                          I reverted back to v4.0.11 and QGC loaded normally with the drone.
                                          Maybe when I removed the QGC the first time and installed the newest version v4.2.3, I might have done it wrong.
                                          I am researching into it now. I will try again soon with the v4.2.3
                                          Any ideas on what is wrong?
