  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 43.6k Views 2 Watching
    @Kris what version of PX4 are you using?
    This forum may have similar issues and it was resolved by updating PX4
    KrisK Offline
    KrisK Offline
    Kris
    @Adrian-Hidalgo I honestly don't remember which one I installed. Could you please remind me how to check for the version?
      KrisK Offline
      KrisK Offline
      Kris
      • Adrian HidalgoA Offline
        Adrian Hidalgo
        @Kris select the Q, should say in the menu selection below application settings
        KrisK 1 Reply Last reply
          Adrian Hidalgo
          @Kris you could try loading a previous sys-image & sdk. Did it work before updating?
            KrisK Offline
            KrisK Offline
            Kris
            @Adrian-Hidalgo I have not had it for very long. I have not gotten it to work before.
              Adrian Hidalgo
              @Kris all Seekers get test flown before shipping to validate functionality. They are loaded with VOXL Platform 3.3.0-0.5.0, test flown with px4 platform 1.11 seeker & helper files for seeker ekf_2_indoor & spektrum_dx6e_config.
              You can try loading the platform 1.12 seeker to see if that helps
                KrisK Offline
                KrisK Offline
                Kris
                @Adrian-Hidalgo
                I dont see where the version is listed.
                Also, this message keeps popping up everytime I open QGC, about a newer version.
                Adrian HidalgoA 2 Replies Last reply
                • KrisK Kris
                  @Adrian-Hidalgo
                  Adrian Hidalgo
                  @Kris in the page, scroll to the bottom
                  • KrisK Kris
                    @Adrian-Hidalgo
                    Adrian Hidalgo
                    @Kris wouldn't hurt to update QGC with the latest
                      KrisK Offline
                      KrisK Offline
                      Kris
                      @Adrian-Hidalgo Oh, ok sorry.
                      Adrian HidalgoA 1 Reply Last reply
                      • KrisK Kris
                        Adrian Hidalgo
                        @Kris yeah, that's an older version of QGC. Would recommend updating, could be a mismatch of settings.
                        After updating, check again local_position_ned
                        If that doesn't work, try loading platform 1.12 seeker parameters
                        If that doesn't work, try I'd shift to system_image 3.3.0 to see if that would change it. Be sure to save the data partition when asks to wipe.
                        KrisK 2 Replies Last reply
                          KrisK Offline
                          KrisK Offline
                          Kris
                          @Adrian-Hidalgo Ok, I will try that.
                          Thank you so much for helping me with this.
                          I will post back here with the results.
                            KrisK Offline
                            KrisK Offline
                            Kris
                            @Adrian-Hidalgo Sorry to bother you.
                            When I started the new version of PX4 v4.2.3 it was ok.
                            Then I started the Seeker and tons of errors started to happen.
                            [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCApplication.cc:281 - "Settings location "/home/kris/.config/QGroundControl.org/QGroundControl.ini" Is writable?: true"
                            [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCLoggingCategory.cc:120 - "Filter rules "*Log.debug=false\nGStreamerAPILog.debug=true\nqt.qml.connections=false""
                            [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCApplication.cc:384 - "System reported locale: QLocale(English, Latin, United States) ; Name "en_US" ; Preffered (used in maps):  "en-US""
                            [D] at ../../qgroundcontrol/qgroundcontrol/src/Vehicle/MAVLinkLogManager.cc:360 - "MAVLink logs directory: "/home/kris/Documents/QGroundControl/Logs""
                            [D] at ../../qgroundcontrol/qgroundcontrol/src/QtLocationPlugin/QGCMapEngine.cpp:164 - "Map Cache in: "/home/kris/.cache/QGCMapCache300" / "qgcMapCache.db""
                            [D] at qrc:/qml/MainRootWindow.qml:51 - "QGCCorePlugin(0x55bb212c6fa0) []"
                            [D] at ../../qgroundcontrol/qgroundcontrol/src/MissionManager/MissionController.cc:2371 - "setCurrentPlanViewSeqNum"
                            [E] at ../../qgroundcontrol/qgroundcontrol/src/VideoReceiver/GstVideoReceiver.cc:284 - "Stop called on empty URI"
                            [D] at ../../qgroundcontrol/qgroundcontrol/src/MissionManager/MissionController.cc:1272 - "_recalcFlightPathSegments homePositionValid false"
                            [D] at ../../qgroundcontrol/qgroundcontrol/src/QGCApplication.cc:848 - ""v4.2.0""
                            [!] at :0 - "Unable to start the client: "org.freedesktop.DBus.Error.AccessDenied" "Geolocation disabled for UID 1000""
                            [E] at ../../qgroundcontrol/qgroundcontrol/src/PositionManager/PositionManager.cpp:188 - "QGCPositionManager error 0"
                            [D] at ../../qgroundcontrol/qgroundcontrol/src/comm/UDPLink.cc:205 - "Adding target QHostAddress("192.168.110.152") 14550"
                            [E] at qrc:/qml/QGroundControl/FlightDisplay/ObstacleDistanceOverlayMap.qml:42 - "qrc:/qml/QGroundControl/FlightDisplay/ObstacleDistanceOverlayMap.qml:42: Error: createRadialGradient(): Incorrect arguments"
                            [I] at ../../qgroundcontrol/qgroundcontrol/src/FactSystem/ParameterManager.cc:829 - "Attemping load from cache"
                            [I] at ../../qgroundcontrol/qgroundcontrol/src/FactSystem/ParameterManager.cc:919 - "Parameters cache match failed /home/kris/.config/QGroundControl.org/ParamCache/1_1.v2"
                            [E] at ../../qgroundcontrol/qgroundcontrol/src/comm/UDPLink.cc:167 - "Error writing to QHostAddress("192.168.110.152") 14550"
                            • KrisK Offline
                              KrisK Offline
                              Kris
                              wrote on last edited by Kris
                              #47
                              The errors are continuous and eventually everything freezes. When QGC finally closes, I lose my internet connection on my host PC.
                              I dont know what's going on.
                              Maybe its because of the settings from voxl...
                                Adrian Hidalgo
                                @Kris before turning on the Seeker, QGC works fine? Are you able to navigate around the gui?
                                Hmm...You could try deleting the px4 parameters that were loaded onto the voxl. You'll have to calibrate all the sensors and load the correct parameters if you do choose to go this route.
                                It kinda seems like there's something with the obstacle avoidance. May first want to try disabling en_voa in vvpx4 (marking it false) as well as disabling dfs server before deleting px4 parameters
                                  I think Kris is printing out errors from QGC, which we do not have any influence of
                                  The original issue was that PX4 is not incorporating VIO data.
                                  For that, please try the parameters recommended for Seeker
                                  Here are the default Seeker parameters for PX4 1.11:
                                  https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/platforms/v1.11/Seeker_v1_param_rev_A.params
                                  https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/seeker/ekf2_indoor_vio.params
                                  • KrisK Offline
                                    KrisK Offline
                                    Kris
                                    @Adrian-Hidalgo @Chad-Sweet , Thank you.
                                    I reverted back to v4.0.11 and QGC loaded normally with the drone.
                                    Maybe when I removed the QGC the first time and installed the newest version v4.2.3, I might have done it wrong.
                                    I am researching into it now. I will try again soon with the v4.2.3
                                    Any ideas on what is wrong?
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      @Adrian-Hidalgo yes, v4.2.3 was working fine before turning on the drone. As soon as I turned it on, the drone connected then disconnected a couple of times. finally disconnecting and eventually freezing PX4.
                                      • KrisK Offline
                                        KrisK Offline
                                        Kris
                                        #52
                                        Ok, I got PX4 v4.2.3 to work.
                                        The Odometry and the LOCAL_POSITION_NED are still reading 0 value for x and y.
                                        So, I will try to restart some services in voxl.
                                          If voxl-inspect-qvio is showing good VIO data, there should be no need to change things on VOXL. the VOXL services are working properly.
                                          You are most likely having issues with PX4 which runs on Flight Core. Please load the parameter files recommended and report back the result.
                                          KrisK 4 Replies Last reply
