    MAVLink Odometry X Y value 0
    25467
    • KrisK
      Kris
      I am not able to get any X/Y values in my MAVLink Odometry or in my LOCAL_POSITION_NED.
      I have done research into this issue, but could not find a solution for my setup.
      Could someone please point out my problem?
      voxl:~$ voxl-version
      system-image: 3.8.0
      kernel:       #1 SMP PREEMPT Tue Apr 26 18:08:39 UTC 2022 3.18.71-perf
      hw version:   VOXL
      voxl-suite:   0.8.1
      0.7.0
       Service Name             |  Version  |  Enabled  |   Running   |  CPU Usage
       docker-autorun           |    1.2.4  | Disabled  | Not Running |
       docker-daemon            |    1.2.4  | Disabled  | Not Running |
       modallink-relink         |   0.15.1  | Disabled  | Not Running |
       voxl-camera-server       |    0.9.1  |  Enabled  |   Running   |    16.6
       voxl-cpu-monitor         |    0.2.5  |  Enabled  |   Running   |     0.0
       voxl-dfs-server          |    0.2.6  |  Enabled  |   Running   |     8.3
       voxl-imu-server          |    1.0.1  |  Enabled  |   Running   |     2.0
       voxl-mavlink-server      |    0.1.3  |  Enabled  |   Running   |     0.0
       voxl-modem               |   0.15.1  | Disabled  | Not Running |
       voxl-portal              |    0.2.6  |  Enabled  |   Running   |     0.0
       voxl-qvio-server         |    0.4.6  |  Enabled  |   Running   |     8.3
       voxl-rangefinder-server  |    0.1.2  | Disabled  | Not Running |
       voxl-streamer            |    0.3.6  | Disabled  | Not Running |
       voxl-tag-detector        |    0.0.4  | Disabled  | Not Running |
       voxl-tflite-server       |    0.2.3  | Disabled  | Not Running |
       voxl-time-sync           |    1.1.4  |  Enabled  |  Completed  |
       voxl-vision-px4          |    1.2.0  |  Enabled  |   Running   |     2.0
       voxl-wait-for-fs         |    1.1.4  |  Enabled  |  Completed  |
      voxl:~$ opkg list-installed | grep "voxl"
      libvoxl-cutils - 0.1.1
      voxl-camera-calibration - 0.2.2
      voxl-ceres-solver - 1.14.0-7
      voxl-cpu-monitor - 0.2.5
      voxl-docker-support - 1.2.4
      voxl-gphoto2-server - 0.0.10
      voxl-jpeg-turbo - 2.1.3-4
      voxl-libgphoto2 - 0.0.4
      voxl-libuvc - 1.0.6
      voxl-logger - 0.1.2
      voxl-mapper - 0.0.7
      voxl-mavlink - 0.1.0
      voxl-mavlink-server - 0.1.3
      voxl-modem - 0.15.1
      voxl-mongoose - 7.6.0
      voxl-mpa-to-ros - 0.3.2
      voxl-mpa-tools - 0.6.3
      voxl-nlopt - 2.5.0-4
      voxl-opencv - 4.5.5-1
      voxl-portal - 0.2.6
      voxl-qvio-server - 0.4.6
      voxl-streamer - 0.3.6
      voxl-suite - 0.7.0
      voxl-tag-detector - 0.0.4
      voxl-tflite-server - 0.2.3
      voxl-utils - 1.1.4
      voxl-uvc-server - 0.1.1
      voxl-vision-px4 - 1.2.0
      voxl-voxblox - 1.0.4
      voxl-vpn - 0.0.6
      voxl:~$ opkg list-installed | grep "modal"
      libmodal-cv - 0.1.0
      libmodal-exposure - 0.0.7
      libmodal-json - 0.4.2
      libmodal-pipe - 2.4.0
       "config_file_version":  1,
              "qgc_ip":       "192.168.110.146",
              "en_secondary_qgc":     false,
              "secondary_qgc_ip":     "192.168.1.214",
              "qgc_udp_port_number":  14550,
              "udp_mtu":      512,
              "en_localhost_mavlink_udp":     true,
              "localhost_udp_port_number":    14551,
              "en_vio":       true,
              "en_voa":       true,
              "en_send_vio_to_qgc":   true,
              "en_send_voa_to_qgc":   true,
              "voa_upper_bound_m":    -0.15000000596046448,
              "voa_lower_bound_m":    0.15000000596046448,
              "en_set_clock_from_gps":        true,
              "en_force_onboard_mav1_mode":   true,
              "en_reset_px4_on_error":        true,
              "horizon_cal_tolerance":        0.300000011920929,
              "offboard_mode":        "trajectory",
              "follow_tag_id":        0,
              "figure_eight_move_home":       true,
              "en_tag_fixed_frame":   false,
              "fixed_frame_filter_len":       5,
              "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
              "vio_pipe":     "qvio",
              "vio_warmup_s": 3,
              "voa_memory_s": 1,
              "voa_inputs":   [{
                              "enabled":      true,
                                                      "type": "point_cloud",
                                                      "input_pipe":   "dfs_point_cloud",
                                                      "frame":        "stereo_l"
                                                      "enabled":      true,
                                                      "input_pipe":   "stereo_front_pc",
                                                      "frame":        "stereo_front_l"
                                                      "enabled":      true,
                                                      "input_pipe":   "stereo_rear_pc",
                                                      "frame":        "stereo_rear_l"
                                                      "enabled":      true,
                                                      "type": "tof",
                                                      "input_pipe":   "tof",
                                                      "frame":        "tof"
                                                      "enabled":      true,
                                                      "type": "rangefinder",
                                                      "input_pipe":   "rangefinders",
                                                      "frame":        "body"
      voxl:~$ voxl-inspect-extrinsics
      #0:
          parent:                imu0
          child:                 tracking
          T_child_wrt_parent:    0.014   0.005   0.005
          RPY_parent_to_child: -45.0     0.0     0.0
          R_child_to_parent:     1.000  -0.000   0.000
                                 0.000   0.707   0.707
                                -0.000  -0.707   0.707
      #1:
          parent:                imu1
          child:                 tracking
          T_child_wrt_parent:   -0.034   0.030   0.005
                                 0.000   0.707   0.707
                                -0.000  -0.707   0.707
      #2:
          parent:                body
          child:                 imu0
          T_child_wrt_parent:    0.050  -0.015   0.016
          RPY_parent_to_child:   0.0    90.0    90.0
          R_child_to_parent:     0.000  -0.000   1.000
                                 1.000   0.000  -0.000
                                -0.000   1.000   0.000
      #3:
          parent:                body
          child:                 imu1
          T_child_wrt_parent:    0.046   0.033  -0.013
                                 1.000   0.000  -0.000
                                -0.000   1.000   0.000
      #4:
          parent:                body
          child:                 stereo_l
          T_child_wrt_parent:    0.055  -0.040   0.000
                                 1.000   0.000  -0.000
                                -0.000   1.000   0.000
      #5:
          parent:                body
          child:                 ground
          T_child_wrt_parent:    0.000   0.000   0.045
          RPY_parent_to_child:   0.0     0.0     0.0
                                 0.000   1.000  -0.000
                                 0.000   0.000   1.000
      #6:
          parent:                imu1
          child:                 imu0
          T_child_wrt_parent:   -0.048   0.037   0.002
                                 0.000   1.000  -0.000
                                 0.000   0.000   1.000
      #7:
          parent:                body
          child:                 tof
          T_child_wrt_parent:    0.055   0.000   0.000
          RPY_parent_to_child:   0.0    90.0   -90.0
          R_child_to_parent:     0.000   0.000   1.000
                                -1.000   0.000  -0.000
                                -0.000  -1.000   0.000
      • KrisK
        Kris
        There is no position control for indoor flights.
        COM_OBS_AVOID
        CP_DIST
        I am having trouble figuring this one out.
        • KrisK
          Kris
          Here are my GCS Serial parameters.
          • KrisK
            Kris
            I am currently on the PX4 ModalAi build Firmware, but I was also getting the Reject Position Control error and 0 values for X & Y in MAVLink Odometry in QCS for the PX4 Mainline build Firmware.
            • KrisK
              Kris
              I have also tried doing the following;
              voxl:~$ voxl-reset-qvio
              Sending hard reset command to voxl-qvio-server
              success
              voxl:~$ systemctl restart voxl-qvio-server
              After executing these commands, the X & Y values did not change from 0.
              • KrisK
                Kris
                Here are my voxl-vision-px4 -o readouts;
                There are definitely errors in the VIO data through the pipe, I just don't know how to fix it.
                If anyone has any ideas to fix this issue, I'm all ears ๐Ÿ‘‚
                voxl:~$ voxl-vision-px4 -o
                loading our own config file
                config_file_version:        1
                MAVLINK IO
                qgc_ip:                     192.168.110.146
                en_secondary_qgc:           0
                secondary_qgc_ip:           192.168.1.214
                qgc_udp_port_number:        14550
                udp_mtu:                    512
                en_localhost_mavlink_udp    1
                localhost_udp_port_number:  14551
                VIO
                en_vio:                     1
                vio_pipe:                   qvio
                en_send_vio_to_qgc:         1
                en_reset_vio_if_initialized_inverted: 1
                vio_warmup_s:               4.000000
                APQ8096-ONLY FEATURES
                en_set_clock_from_gps:      1
                en_force_onboard_mav1_mode: 1
                en_reset_px4_on_error:      1
                MISC FEATURES
                horizon_cal_tolerance:      0.300000
                OFFBOARD MODE
                offboard_mode:              trajectory
                follow_tag_id:              0
                figure_eight_move_home:     1
                FIXED FRAME RELOCALIZATION
                en_tag_fixed_frame:         0
                fixed_frame_filter_len:     5
                COLLISION PREVENTION (VOA)
                en_voa:                     1
                en_send_voa_to_qgc:         1
                voa_upper_bound_m:          -0.150000
                voa_lower_bound_m:          0.150000
                voa_memory_s:               1.000000
                voa_input #0
                    enabled:            1
                    type:               point_cloud
                    input_pipe:         dfs_point_cloud
                    frame:              stereo_l
                voa_input #1
                    enabled:            1
                    type:               point_cloud
                    input_pipe:         stereo_front_pc
                    frame:              stereo_front_l
                voa_input #2
                    enabled:            1
                    type:               point_cloud
                    input_pipe:         stereo_rear_pc
                    frame:              stereo_rear_l
                voa_input #3
                    enabled:            1
                    type:               tof
                    input_pipe:         tof
                    frame:              tof
                voa_input #4
                    enabled:            1
                    type:               rangefinder
                    input_pipe:         rangefinders
                    frame:              body
                loading extrinsics config file
                starting geometry module
                starting px4 monitor
                starting px4 mavlink
                Connected to voxl-mavlink-server
                Detected PX4 Mavlink SYSID 1
                starting udp mavlink
                Adding manual QGC IP address to udp connection list: 192.168.110.146
                Added new UDP connection to 192.168.110.146
                starting px4 shell
                starting fixed pose input
                starting vio manager
                Connected to VIO pipe: qvio
                updating to use imu: imu1
                done updating transforms to use imu: imu1
                detected system time has already been set
                starting tag manager
                starting voa manager
                ERROR validating VIO data received through pipe: read partial packet
                read 156 bytes, but it should be a multiple of 324
                Connected to pipe: dfs_point_cloud
                starting horizon cal
                Connected to pipe: tof
                starting offboard trajectory
                ^C
                received SIGINT Ctrl-C
                Starting shutdown sequence
                stopping offboard trajectory
                exiting offboard trajectory thread
                stopping horizon_cal
                stopping voa manager
                exiting VOA thread
                stopping tag manager
                stopping vio manager
                stopping fixed pose in module
                stopping px4 shell module
                Stopping udp mavlink module
                exiting localhost udp listener thread
                exiting QGC udp listener thread
                udp_mavlink stopped
                Stopping uart mavlink module
                waiting for px4 mavlink timer thread to join
                Stopping px4 monitor
                closing remaining client pipes
                closing remaining server pipes
                Removing PID file
                exiting
                voxl:~$
                • KrisK
                  Kris
                  Could this issue be coming from imu0 and imu1?
                  • KrisK
                    Kris
                    Has anyone had this error message on their system?
                    If so, how was it resolved?
                    Here is my debug odometry;
                    voxl:~$ voxl-vision-px4 --debug_odometry
                    MAVLINK IO
                    en_secondary_qgc:           0
                    udp_mtu:                    512
                    VIO
                    en_vio:                     1
                    vio_pipe:                   qvio
                    vio_warmup_s:               3.000000
                    MISC FEATURES
                    horizon_cal_tolerance:      0.450000
                    OFFBOARD MODE
                    follow_tag_id:              0
                    en_voa:                     1
                    voa_input #0
                        enabled:            1
                        type:               point_cloud
                        frame:              stereo_l
                    voa_input #1
                        enabled:            1
                        type:               point_cloud
                    voa_input #2
                        enabled:            1
                        type:               point_cloud
                    voa_input #3
                        enabled:            1
                        type:               tof
                        input_pipe:         tof
                        frame:              tof
                    voa_input #4
                        enabled:            1
                        type:               rangefinder
                        frame:              body
                    exising instance of voxl-vision-px4 found, attempting to stop it
                    starting px4 shell
                    WARNING in VOA manager, no attitude data from px4
                    There is also one VOA manager WARNING in my odometry debug, with no attitude data from px4....
                    ๐Ÿ˜–
                    • Chad SweetC
                      Chad Sweet ModalAI Team
                      From the Troubleshooting VIO docs, can you try these steps?
                      QVIO Overlay in voxl-portal
                      voxl-inspect-qvio
                      KrisK 2 Replies Last reply Reply Quote 0
                      • KrisK
                        Kris @Chad Sweet
                        @Chad-Sweet Yes, I have read through those steps and tried them. All of my cameras are viewable in voxl-portal. I have also ran the voxl-inspect-qvio and the status was ok with no error's.
                        • Chad SweetC
                          Can you please share the output of those steps?
                          KrisK 1 Reply Last reply Reply Quote 0
                          • KrisK
                            Kris @Chad Sweet
                            @Chad-Sweet
                            voxl:~$ voxl-inspect-qvio
                            waiting for server
                                T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
                               -0.00    0.00    0.00|  -0.0    0.0   -0.0| OKAY | ^C
                            closing and exiting
                            • KrisK
                              Kris @Chad Sweet
                              @Chad-Sweet What would you like to see in my voxl portal?
                              • KrisK
                                Kris
                                Here I have turned the drone about an inch to the left.
                                waiting for server
                                   -0.02    0.00    0.03|   0.3  -10.3    1.7| OKAY | ^C
                                closing and exiting
                                • Chad SweetC
                                  The qvio-overlay in voxl-portal is interesting, but from the voxl-inspect-qvio it looks like VIO is working properly. It's mostly likely PX4 is rejecting position mode, usually because it requires a magnetometer.
                                  This section covers position mode rejected issues
                                  Do you have a magnetometer connected? If not, are you sure PX4 is not expecting one?
                                  • KrisK
                                    Kris @Chad Sweet
                                    @Chad-Sweet I haven't added anything special to my Seeker setup.
                                    • KrisK
                                      Kris @Chad Sweet
                                      @Chad-Sweet
                                      SYS_HAS_MAG
                                      EKF2_MAG_TYPE
                                      So, I should enter the 0 value for SYS_HAS_MAG
                                      and 5 for the EKF2_MAG_TYPE?
                                      • Chad SweetC
                                        If you are using PX4 1.12 or later, and do not have a magnetometer, and want to use VIO, yes.
                                        KrisK 3 Replies Last reply Reply Quote 0
                                        • KrisK
                                          Kris @Chad Sweet
                                          @Chad-Sweet OK ๐Ÿ‘ Iโ€™ll try that ๐Ÿ˜Š
                                          • KrisK
                                            Kris @Chad Sweet
                                            @Chad-Sweet There is not an option for 5 in EKF2_MAG_TYPE.
                                            Should I leave this at โ€œAutomaticโ€ or select โ€œNoneโ€ ?
