  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 36.2k Views 2 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    wrote on last edited by Kris
    I am not able to get any X/Y values in my MAVLink Odometry or in my LOCAL_POSITION_NED.
    I have done research into this issue, but could not find a solution for my setup.
    Could someone please point out my problem?
    voxl:~$ voxl-version
    system-image: 3.8.0
    kernel:       #1 SMP PREEMPT Tue Apr 26 18:08:39 UTC 2022 3.18.71-perf
    hw version:   VOXL
    voxl-suite:   0.8.1
    0.7.0
     Service Name             |  Version  |  Enabled  |   Running   |  CPU Usage
     docker-autorun           |    1.2.4  | Disabled  | Not Running |
     docker-daemon            |    1.2.4  | Disabled  | Not Running |
     modallink-relink         |   0.15.1  | Disabled  | Not Running |
     voxl-camera-server       |    0.9.1  |  Enabled  |   Running   |    16.6
     voxl-cpu-monitor         |    0.2.5  |  Enabled  |   Running   |     0.0
     voxl-dfs-server          |    0.2.6  |  Enabled  |   Running   |     8.3
     voxl-imu-server          |    1.0.1  |  Enabled  |   Running   |     2.0
     voxl-mavlink-server      |    0.1.3  |  Enabled  |   Running   |     0.0
     voxl-modem               |   0.15.1  | Disabled  | Not Running |
     voxl-portal              |    0.2.6  |  Enabled  |   Running   |     0.0
     voxl-qvio-server         |    0.4.6  |  Enabled  |   Running   |     8.3
     voxl-rangefinder-server  |    0.1.2  | Disabled  | Not Running |
     voxl-streamer            |    0.3.6  | Disabled  | Not Running |
     voxl-tag-detector        |    0.0.4  | Disabled  | Not Running |
     voxl-tflite-server       |    0.2.3  | Disabled  | Not Running |
     voxl-time-sync           |    1.1.4  |  Enabled  |  Completed  |
     voxl-vision-px4          |    1.2.0  |  Enabled  |   Running   |     2.0
     voxl-wait-for-fs         |    1.1.4  |  Enabled  |  Completed  |
    voxl:~$ opkg list-installed | grep "voxl"
    libvoxl-cutils - 0.1.1
    voxl-camera-calibration - 0.2.2
    voxl-ceres-solver - 1.14.0-7
    voxl-cpu-monitor - 0.2.5
    voxl-docker-support - 1.2.4
    voxl-gphoto2-server - 0.0.10
    voxl-jpeg-turbo - 2.1.3-4
    voxl-libgphoto2 - 0.0.4
    voxl-libuvc - 1.0.6
    voxl-logger - 0.1.2
    voxl-mapper - 0.0.7
    voxl-mavlink - 0.1.0
    voxl-mavlink-server - 0.1.3
    voxl-modem - 0.15.1
    voxl-mongoose - 7.6.0
    voxl-mpa-to-ros - 0.3.2
    voxl-mpa-tools - 0.6.3
    voxl-nlopt - 2.5.0-4
    voxl-opencv - 4.5.5-1
    voxl-portal - 0.2.6
    voxl-qvio-server - 0.4.6
    voxl-streamer - 0.3.6
    voxl-suite - 0.7.0
    voxl-tag-detector - 0.0.4
    voxl-tflite-server - 0.2.3
    voxl-utils - 1.1.4
    voxl-uvc-server - 0.1.1
    voxl-vision-px4 - 1.2.0
    voxl-voxblox - 1.0.4
    voxl-vpn - 0.0.6
    voxl:~$ opkg list-installed | grep "modal"
    libmodal-cv - 0.1.0
    libmodal-exposure - 0.0.7
    libmodal-json - 0.4.2
    libmodal-pipe - 2.4.0
     "config_file_version":  1,
            "qgc_ip":       "192.168.110.146",
            "secondary_qgc_ip":     "192.168.1.214",
            "udp_mtu":      512,
            "en_vio":       true,
            "en_voa":       true,
            "en_send_vio_to_qgc":   true,
            "en_send_voa_to_qgc":   true,
            "voa_upper_bound_m":    -0.15000000596046448,
            "voa_lower_bound_m":    0.15000000596046448,
            "horizon_cal_tolerance":        0.300000011920929,
            "offboard_mode":        "trajectory",
            "follow_tag_id":        0,
            "figure_eight_move_home":       true,
            "en_tag_fixed_frame":   false,
            "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
            "vio_pipe":     "qvio",
            "vio_warmup_s": 3,
            "voa_memory_s": 1,
            "voa_inputs":   [{
                            "enabled":      true,
                                                    "type": "point_cloud",
                                                    "input_pipe":   "dfs_point_cloud",
                                                    "frame":        "stereo_l"
                                                    "enabled":      true,
                                                    "input_pipe":   "stereo_front_pc",
                                                    "frame":        "stereo_front_l"
                                                    "enabled":      true,
                                                    "input_pipe":   "stereo_rear_pc",
                                                    "frame":        "stereo_rear_l"
                                                    "enabled":      true,
                                                    "type": "tof",
                                                    "input_pipe":   "tof",
                                                    "frame":        "tof"
                                                    "enabled":      true,
                                                    "type": "rangefinder",
                                                    "input_pipe":   "rangefinders",
                                                    "frame":        "body"
    voxl:~$ voxl-inspect-extrinsics
    #0:
        parent:                imu0
        child:                 tracking
        T_child_wrt_parent:    0.014   0.005   0.005
        RPY_parent_to_child: -45.0     0.0     0.0
        R_child_to_parent:     1.000  -0.000   0.000
                               0.000   0.707   0.707
                              -0.000  -0.707   0.707
    #1:
        parent:                imu1
        child:                 tracking
        T_child_wrt_parent:   -0.034   0.030   0.005
                               0.000   0.707   0.707
                              -0.000  -0.707   0.707
    #2:
        parent:                body
        child:                 imu0
        T_child_wrt_parent:    0.050  -0.015   0.016
        RPY_parent_to_child:   0.0    90.0    90.0
        R_child_to_parent:     0.000  -0.000   1.000
                               1.000   0.000  -0.000
                              -0.000   1.000   0.000
    #3:
        parent:                body
        child:                 imu1
        T_child_wrt_parent:    0.046   0.033  -0.013
                               1.000   0.000  -0.000
                              -0.000   1.000   0.000
    #4:
        parent:                body
        child:                 stereo_l
        T_child_wrt_parent:    0.055  -0.040   0.000
                               1.000   0.000  -0.000
                              -0.000   1.000   0.000
    #5:
        parent:                body
        child:                 ground
        T_child_wrt_parent:    0.000   0.000   0.045
        RPY_parent_to_child:   0.0     0.0     0.0
                               0.000   1.000  -0.000
                               0.000   0.000   1.000
    #6:
        parent:                imu1
        child:                 imu0
        T_child_wrt_parent:   -0.048   0.037   0.002
                               0.000   1.000  -0.000
                               0.000   0.000   1.000
    #7:
        parent:                body
        child:                 tof
        T_child_wrt_parent:    0.055   0.000   0.000
        RPY_parent_to_child:   0.0    90.0   -90.0
        R_child_to_parent:     0.000   0.000   1.000
                              -1.000   0.000  -0.000
                              -0.000  -1.000   0.000
    • KrisK Offline
      KrisK Offline
      Kris
      There is no position control for indoor flights.
      COM_OBS_AVOID
      CP_DIST
      I am having trouble figuring this one out.
      • KrisK Offline
        KrisK Offline
        Kris
        Here are my GCS Serial parameters.
        • KrisK Offline
          KrisK Offline
          Kris
          I am currently on the PX4 ModalAi build Firmware, but I was also getting the Reject Position Control error and 0 values for X & Y in MAVLink Odometry in QCS for the PX4 Mainline build Firmware.
          • KrisK Offline
            KrisK Offline
            Kris
            I have also tried doing the following;
            voxl:~$ voxl-reset-qvio
            Sending hard reset command to voxl-qvio-server
            success
            voxl:~$ systemctl restart voxl-qvio-server
            After executing these commands, the X & Y values did not change from 0.
            • KrisK Offline
              KrisK Offline
              Kris
              Here are my voxl-vision-px4 -o readouts;
              There are definitely errors in the VIO data through the pipe, I just don't know how to fix it.
              If anyone has any ideas to fix this issue, I'm all ears 👂
              voxl:~$ voxl-vision-px4 -o
              loading our own config file
              config_file_version:        1
              MAVLINK IO
              qgc_ip:                     192.168.110.146
              en_secondary_qgc:           0
              qgc_udp_port_number:        14550
              udp_mtu:                    512
              en_localhost_mavlink_udp    1
              VIO
              en_vio:                     1
              vio_pipe:                   qvio
              en_send_vio_to_qgc:         1
              vio_warmup_s:               4.000000
              APQ8096-ONLY FEATURES
              en_set_clock_from_gps:      1
              en_force_onboard_mav1_mode: 1
              en_reset_px4_on_error:      1
              MISC FEATURES
              horizon_cal_tolerance:      0.300000
              OFFBOARD MODE
              offboard_mode:              trajectory
              follow_tag_id:              0
              figure_eight_move_home:     1
              FIXED FRAME RELOCALIZATION
              en_tag_fixed_frame:         0
              fixed_frame_filter_len:     5
              COLLISION PREVENTION (VOA)
              en_voa:                     1
              en_send_voa_to_qgc:         1
              voa_upper_bound_m:          -0.150000
              voa_lower_bound_m:          0.150000
              voa_memory_s:               1.000000
              voa_input #0
                  enabled:            1
                  type:               point_cloud
                  input_pipe:         dfs_point_cloud
                  frame:              stereo_l
              voa_input #1
                  enabled:            1
                  type:               point_cloud
                  input_pipe:         stereo_front_pc
                  frame:              stereo_front_l
              voa_input #2
                  enabled:            1
                  type:               point_cloud
                  input_pipe:         stereo_rear_pc
                  frame:              stereo_rear_l
              voa_input #3
                  enabled:            1
                  type:               tof
                  input_pipe:         tof
                  frame:              tof
              voa_input #4
                  enabled:            1
                  type:               rangefinder
                  input_pipe:         rangefinders
                  frame:              body
              starting geometry module
              starting px4 monitor
              starting px4 mavlink
              Detected PX4 Mavlink SYSID 1
              starting udp mavlink
              Adding manual QGC IP address to udp connection list: 192.168.110.146
              Added new UDP connection to 192.168.110.146
              starting px4 shell
              starting fixed pose input
              starting vio manager
              Connected to VIO pipe: qvio
              updating to use imu: imu1
              done updating transforms to use imu: imu1
              detected system time has already been set
              starting tag manager
              starting voa manager
              ERROR validating VIO data received through pipe: read partial packet
              read 156 bytes, but it should be a multiple of 324
              Connected to pipe: dfs_point_cloud
              starting horizon cal
              Connected to pipe: tof
              starting offboard trajectory
              ^C
              received SIGINT Ctrl-C
              Starting shutdown sequence
              stopping offboard trajectory
              exiting offboard trajectory thread
              stopping horizon_cal
              stopping voa manager
              exiting VOA thread
              stopping tag manager
              stopping vio manager
              stopping fixed pose in module
              stopping px4 shell module
              Stopping udp mavlink module
              exiting localhost udp listener thread
              exiting QGC udp listener thread
              udp_mavlink stopped
              Stopping uart mavlink module
              waiting for px4 mavlink timer thread to join
              Stopping px4 monitor
              closing remaining client pipes
              closing remaining server pipes
              Removing PID file
              exiting
              voxl:~$
              • KrisK Offline
                KrisK Offline
                Kris
                Could this issue be coming from imu0 and imu1?
                • KrisK Offline
                  KrisK Offline
                  Kris
                  Has anyone had this error message on their system?
                  If so, how was it resolved?
                  Here is my debug odometry;
                  voxl:~$ voxl-vision-px4 --debug_odometry
                  MAVLINK IO
                  en_secondary_qgc:           0
                  udp_mtu:                    512
                  VIO
                  en_vio:                     1
                  vio_pipe:                   qvio
                  vio_warmup_s:               3.000000
                  MISC FEATURES
                  horizon_cal_tolerance:      0.450000
                  OFFBOARD MODE
                  follow_tag_id:              0
                  en_voa:                     1
                  voa_input #0
                      enabled:            1
                      type:               point_cloud
                      frame:              stereo_l
                  voa_input #1
                      enabled:            1
                      type:               point_cloud
                  voa_input #2
                      enabled:            1
                      type:               point_cloud
                  voa_input #3
                      enabled:            1
                      type:               tof
                      input_pipe:         tof
                      frame:              tof
                  voa_input #4
                      enabled:            1
                      type:               rangefinder
                      frame:              body
                  exising instance of voxl-vision-px4 found, attempting to stop it
                  starting px4 shell
                  WARNING in VOA manager, no attitude data from px4
                  There is also one VOA manager WARNING in my odometry debug, with no attitude data from px4....
                    From the Troubleshooting VIO docs, can you try these steps?
                    QVIO Overlay in voxl-portal
                    voxl-inspect-qvio
                    KrisK 2 Replies Last reply
                    • Chad SweetC Chad Sweet
                      voxl-inspect-qvio
                      KrisK Offline
                      KrisK Offline
                      Kris
                      @Chad-Sweet Yes, I have read through those steps and tried them. All of my cameras are viewable in voxl-portal. I have also ran the voxl-inspect-qvio and the status was ok with no error's.
                        Can you please share the output of those steps?
                        KrisK 1 Reply Last reply
                          voxl-inspect-qvio
                          KrisK Offline
                          KrisK Offline
                          Kris
                          @Chad-Sweet
                          voxl:~$ voxl-inspect-qvio
                          waiting for server
                              T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
                             -0.00    0.00    0.00|  -0.0    0.0   -0.0| OKAY | ^C
                          closing and exiting
                            KrisK Offline
                            KrisK Offline
                            Kris
                            @Chad-Sweet What would you like to see in my voxl portal?
                            • KrisK Offline
                              KrisK Offline
                              Kris
                              Here I have turned the drone about an inch to the left.
                              waiting for server
                                 -0.02    0.00    0.03|   0.3  -10.3    1.7| OKAY | ^C
                              closing and exiting
                                The qvio-overlay in voxl-portal is interesting, but from the voxl-inspect-qvio it looks like VIO is working properly. It's mostly likely PX4 is rejecting position mode, usually because it requires a magnetometer.
                                This section covers position mode rejected issues
                                Do you have a magnetometer connected? If not, are you sure PX4 is not expecting one?
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  @Chad-Sweet I haven't added anything special to my Seeker setup.
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    @Chad-Sweet
                                    SYS_HAS_MAG
                                    EKF2_MAG_TYPE
                                    So, I should enter the 0 value for SYS_HAS_MAG
                                    and 5 for the EKF2_MAG_TYPE?
                                      If you are using PX4 1.12 or later, and do not have a magnetometer, and want to use VIO, yes.
                                      KrisK 3 Replies Last reply
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        @Chad-Sweet OK 👍 I’ll try that 😊
                                          KrisK Offline
                                          KrisK Offline
                                          Kris
                                          #20
                                          @Chad-Sweet There is not an option for 5 in EKF2_MAG_TYPE.
                                          Should I leave this at “Automatic” or select “None” ?
