  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 43.6k Views 2 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    wrote on last edited by Kris
    Here are my GCS Serial parameters.
    • KrisK Offline
      KrisK Offline
      Kris
      I am currently on the PX4 ModalAi build Firmware, but I was also getting the Reject Position Control error and 0 values for X & Y in MAVLink Odometry in QCS for the PX4 Mainline build Firmware.
      • KrisK Offline
        KrisK Offline
        Kris
        I have also tried doing the following;
        voxl:~$ voxl-reset-qvio
        Sending hard reset command to voxl-qvio-server
        success
        voxl:~$ systemctl restart voxl-qvio-server
        After executing these commands, the X & Y values did not change from 0.
        • KrisK Offline
          KrisK Offline
          Kris
          Here are my voxl-vision-px4 -o readouts;
          There are definitely errors in the VIO data through the pipe, I just don't know how to fix it.
          If anyone has any ideas to fix this issue, I'm all ears 👂
          voxl:~$ voxl-vision-px4 -o
          loading our own config file
          config_file_version:        1
          MAVLINK IO
          qgc_ip:                     192.168.110.146
          en_secondary_qgc:           0
          qgc_udp_port_number:        14550
          udp_mtu:                    512
          en_localhost_mavlink_udp    1
          VIO
          en_vio:                     1
          vio_pipe:                   qvio
          en_send_vio_to_qgc:         1
          vio_warmup_s:               4.000000
          APQ8096-ONLY FEATURES
          en_set_clock_from_gps:      1
          en_force_onboard_mav1_mode: 1
          en_reset_px4_on_error:      1
          MISC FEATURES
          horizon_cal_tolerance:      0.300000
          OFFBOARD MODE
          offboard_mode:              trajectory
          follow_tag_id:              0
          figure_eight_move_home:     1
          FIXED FRAME RELOCALIZATION
          en_tag_fixed_frame:         0
          fixed_frame_filter_len:     5
          COLLISION PREVENTION (VOA)
          en_voa:                     1
          en_send_voa_to_qgc:         1
          voa_upper_bound_m:          -0.150000
          voa_lower_bound_m:          0.150000
          voa_memory_s:               1.000000
          voa_input #0
              enabled:            1
              type:               point_cloud
              input_pipe:         dfs_point_cloud
              frame:              stereo_l
          voa_input #1
              enabled:            1
              type:               point_cloud
              input_pipe:         stereo_front_pc
              frame:              stereo_front_l
          voa_input #2
              enabled:            1
              type:               point_cloud
              input_pipe:         stereo_rear_pc
              frame:              stereo_rear_l
          voa_input #3
              enabled:            1
              type:               tof
              input_pipe:         tof
              frame:              tof
          voa_input #4
              enabled:            1
              type:               rangefinder
              input_pipe:         rangefinders
              frame:              body
          starting geometry module
          starting px4 monitor
          starting px4 mavlink
          Detected PX4 Mavlink SYSID 1
          starting udp mavlink
          Adding manual QGC IP address to udp connection list: 192.168.110.146
          Added new UDP connection to 192.168.110.146
          starting px4 shell
          starting fixed pose input
          starting vio manager
          Connected to VIO pipe: qvio
          updating to use imu: imu1
          done updating transforms to use imu: imu1
          detected system time has already been set
          starting tag manager
          starting voa manager
          ERROR validating VIO data received through pipe: read partial packet
          read 156 bytes, but it should be a multiple of 324
          Connected to pipe: dfs_point_cloud
          starting horizon cal
          Connected to pipe: tof
          starting offboard trajectory
          ^C
          received SIGINT Ctrl-C
          Starting shutdown sequence
          stopping offboard trajectory
          exiting offboard trajectory thread
          stopping horizon_cal
          stopping voa manager
          exiting VOA thread
          stopping tag manager
          stopping vio manager
          stopping fixed pose in module
          stopping px4 shell module
          Stopping udp mavlink module
          exiting localhost udp listener thread
          exiting QGC udp listener thread
          udp_mavlink stopped
          Stopping uart mavlink module
          waiting for px4 mavlink timer thread to join
          Stopping px4 monitor
          closing remaining client pipes
          closing remaining server pipes
          Removing PID file
          exiting
          voxl:~$
          • KrisK Offline
            KrisK Offline
            Kris
            Could this issue be coming from imu0 and imu1?
            • KrisK Offline
              KrisK Offline
              Kris
              Has anyone had this error message on their system?
              If so, how was it resolved?
              Here is my debug odometry;
              voxl:~$ voxl-vision-px4 --debug_odometry
              MAVLINK IO
              en_secondary_qgc:           0
              udp_mtu:                    512
              VIO
              en_vio:                     1
              vio_pipe:                   qvio
              vio_warmup_s:               3.000000
              MISC FEATURES
              horizon_cal_tolerance:      0.450000
              OFFBOARD MODE
              follow_tag_id:              0
              en_voa:                     1
              voa_input #0
                  enabled:            1
                  type:               point_cloud
                  frame:              stereo_l
              voa_input #1
                  enabled:            1
                  type:               point_cloud
              voa_input #2
                  enabled:            1
                  type:               point_cloud
              voa_input #3
                  enabled:            1
                  type:               tof
                  input_pipe:         tof
                  frame:              tof
              voa_input #4
                  enabled:            1
                  type:               rangefinder
                  frame:              body
              exising instance of voxl-vision-px4 found, attempting to stop it
              starting px4 shell
              WARNING in VOA manager, no attitude data from px4
              There is also one VOA manager WARNING in my odometry debug, with no attitude data from px4....
                From the Troubleshooting VIO docs, can you try these steps?
                QVIO Overlay in voxl-portal
                voxl-inspect-qvio
                KrisK 2 Replies Last reply
                • Chad SweetC Chad Sweet
                  voxl-inspect-qvio
                  KrisK Offline
                  KrisK Offline
                  Kris
                  @Chad-Sweet Yes, I have read through those steps and tried them. All of my cameras are viewable in voxl-portal. I have also ran the voxl-inspect-qvio and the status was ok with no error's.
                    Can you please share the output of those steps?
                    KrisK 1 Reply Last reply
                      voxl-inspect-qvio
                      KrisK Offline
                      KrisK Offline
                      Kris
                      @Chad-Sweet
                      voxl:~$ voxl-inspect-qvio
                      waiting for server
                          T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
                         -0.00    0.00    0.00|  -0.0    0.0   -0.0| OKAY | ^C
                      closing and exiting
                        KrisK Offline
                        KrisK Offline
                        Kris
                        @Chad-Sweet What would you like to see in my voxl portal?
                        • KrisK Offline
                          KrisK Offline
                          Kris
                          Here I have turned the drone about an inch to the left.
                          waiting for server
                             -0.02    0.00    0.03|   0.3  -10.3    1.7| OKAY | ^C
                          closing and exiting
                            The qvio-overlay in voxl-portal is interesting, but from the voxl-inspect-qvio it looks like VIO is working properly. It's mostly likely PX4 is rejecting position mode, usually because it requires a magnetometer.
                            This section covers position mode rejected issues
                            Do you have a magnetometer connected? If not, are you sure PX4 is not expecting one?
                              KrisK Offline
                              KrisK Offline
                              Kris
                              @Chad-Sweet I haven't added anything special to my Seeker setup.
                                KrisK Offline
                                KrisK Offline
                                Kris
                                @Chad-Sweet
                                SYS_HAS_MAG
                                EKF2_MAG_TYPE
                                So, I should enter the 0 value for SYS_HAS_MAG
                                and 5 for the EKF2_MAG_TYPE?
                                  If you are using PX4 1.12 or later, and do not have a magnetometer, and want to use VIO, yes.
                                  KrisK 3 Replies Last reply
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    @Chad-Sweet OK 👍 I’ll try that 😊
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      #20
                                      @Chad-Sweet There is not an option for 5 in EKF2_MAG_TYPE.
                                      Should I leave this at “Automatic” or select “None” ?
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        #21
                                        @Chad-Sweet I selected "None" for the EKF2_MAG_TYPE and entered "0" for the SYS_HAS_MAG.
                                        The Odometry x y values are still at 0.
                                        Do I need to change anything in my voxl-vision-px4.conf files now that I am not using a GPS?
                                        "config_file_version":  1,
                                                "qgc_ip":       "192.168.110.146",
                                                "secondary_qgc_ip":     "192.168.1.214",
                                                "udp_mtu":      512,
                                                "vio_pipe":     "qvio",
                                                "en_vio":       true,
                                                "en_send_vio_to_qgc":   true,
                                                "vio_warmup_s": 3,
                                                "horizon_cal_tolerance":        0.449999988079071,
                                                "offboard_mode":        "trajectory",
                                                "follow_tag_id":        0,
                                                "figure_eight_move_home":       true,
                                                "en_tag_fixed_frame":   false,
                                                "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
                                                "en_voa":       true,
                                                "en_send_voa_to_qgc":   true,
                                                "voa_upper_bound_m":    -0.15000000596046448,
                                                "voa_lower_bound_m":    0.15000000596046448,
                                                "voa_memory_s": 1,
                                                "voa_inputs":   [{
        "enabled":      true,
        "type": "point_cloud",
        "input_pipe":   "dfs_point_cloud",
        "frame":        "stereo_l"
        "enabled":      true,
        "input_pipe":   "stereo_front_pc",
        "frame":        "stereo_front_l"
        "enabled":      true,
        "input_pipe":   "stereo_rear_pc",
        "frame":        "stereo_rear_l"
        "enabled":      true,
        "type": "tof",
        "input_pipe":   "tof",
        "frame":        "tof"
        "enabled":      true,
        "type": "rangefinder",
        "input_pipe":   "rangefinders",
        "frame":        "body"
                                        Should I just unplug the Cirocomm GPS?
                                        • KrisK Offline
                                          KrisK Offline
                                          Kris
                                          I unplugged the GPS from the Seeker. I am still not able to get position control in MAVLink and my Odometry x y values are still at 0.
                                          Maybe the last option to do is to re-calibrate my cameras...
