  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 39.2k Views 2 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    wrote on last edited by Kris
    There is no position control for indoor flights.
    COM_OBS_AVOID
    CP_DIST
    I am having trouble figuring this one out.
    • KrisK Offline
      KrisK Offline
      Kris
      Here are my GCS Serial parameters.
      • KrisK Offline
        KrisK Offline
        Kris
        I am currently on the PX4 ModalAi build Firmware, but I was also getting the Reject Position Control error and 0 values for X & Y in MAVLink Odometry in QCS for the PX4 Mainline build Firmware.
        • KrisK Offline
          KrisK Offline
          Kris
          I have also tried doing the following;
          voxl:~$ voxl-reset-qvio
          Sending hard reset command to voxl-qvio-server
          success
          voxl:~$ systemctl restart voxl-qvio-server
          After executing these commands, the X & Y values did not change from 0.
          • KrisK Offline
            KrisK Offline
            Kris
            Here are my voxl-vision-px4 -o readouts;
            There are definitely errors in the VIO data through the pipe, I just don't know how to fix it.
            If anyone has any ideas to fix this issue, I'm all ears 👂
            voxl:~$ voxl-vision-px4 -o
            loading our own config file
            config_file_version:        1
            MAVLINK IO
            qgc_ip:                     192.168.110.146
            en_secondary_qgc:           0
            qgc_udp_port_number:        14550
            udp_mtu:                    512
            en_localhost_mavlink_udp    1
            VIO
            en_vio:                     1
            vio_pipe:                   qvio
            en_send_vio_to_qgc:         1
            vio_warmup_s:               4.000000
            APQ8096-ONLY FEATURES
            en_set_clock_from_gps:      1
            en_force_onboard_mav1_mode: 1
            en_reset_px4_on_error:      1
            MISC FEATURES
            horizon_cal_tolerance:      0.300000
            OFFBOARD MODE
            offboard_mode:              trajectory
            follow_tag_id:              0
            figure_eight_move_home:     1
            FIXED FRAME RELOCALIZATION
            en_tag_fixed_frame:         0
            fixed_frame_filter_len:     5
            COLLISION PREVENTION (VOA)
            en_voa:                     1
            en_send_voa_to_qgc:         1
            voa_upper_bound_m:          -0.150000
            voa_lower_bound_m:          0.150000
            voa_memory_s:               1.000000
            voa_input #0
                enabled:            1
                type:               point_cloud
                input_pipe:         dfs_point_cloud
                frame:              stereo_l
            voa_input #1
                enabled:            1
                type:               point_cloud
                input_pipe:         stereo_front_pc
                frame:              stereo_front_l
            voa_input #2
                enabled:            1
                type:               point_cloud
                input_pipe:         stereo_rear_pc
                frame:              stereo_rear_l
            voa_input #3
                enabled:            1
                type:               tof
                input_pipe:         tof
                frame:              tof
            voa_input #4
                enabled:            1
                type:               rangefinder
                input_pipe:         rangefinders
                frame:              body
            starting geometry module
            starting px4 monitor
            starting px4 mavlink
            Detected PX4 Mavlink SYSID 1
            starting udp mavlink
            Adding manual QGC IP address to udp connection list: 192.168.110.146
            Added new UDP connection to 192.168.110.146
            starting px4 shell
            starting fixed pose input
            starting vio manager
            Connected to VIO pipe: qvio
            updating to use imu: imu1
            done updating transforms to use imu: imu1
            detected system time has already been set
            starting tag manager
            starting voa manager
            ERROR validating VIO data received through pipe: read partial packet
            read 156 bytes, but it should be a multiple of 324
            Connected to pipe: dfs_point_cloud
            starting horizon cal
            Connected to pipe: tof
            starting offboard trajectory
            ^C
            received SIGINT Ctrl-C
            Starting shutdown sequence
            stopping offboard trajectory
            exiting offboard trajectory thread
            stopping horizon_cal
            stopping voa manager
            exiting VOA thread
            stopping tag manager
            stopping vio manager
            stopping fixed pose in module
            stopping px4 shell module
            Stopping udp mavlink module
            exiting localhost udp listener thread
            exiting QGC udp listener thread
            udp_mavlink stopped
            Stopping uart mavlink module
            waiting for px4 mavlink timer thread to join
            Stopping px4 monitor
            closing remaining client pipes
            closing remaining server pipes
            Removing PID file
            exiting
            voxl:~$
            • KrisK Offline
              KrisK Offline
              Kris
              Could this issue be coming from imu0 and imu1?
              • KrisK Offline
                KrisK Offline
                Kris
                Has anyone had this error message on their system?
                If so, how was it resolved?
                Here is my debug odometry;
                voxl:~$ voxl-vision-px4 --debug_odometry
                MAVLINK IO
                en_secondary_qgc:           0
                udp_mtu:                    512
                VIO
                en_vio:                     1
                vio_pipe:                   qvio
                vio_warmup_s:               3.000000
                MISC FEATURES
                horizon_cal_tolerance:      0.450000
                OFFBOARD MODE
                follow_tag_id:              0
                en_voa:                     1
                voa_input #0
                    enabled:            1
                    type:               point_cloud
                    frame:              stereo_l
                voa_input #1
                    enabled:            1
                    type:               point_cloud
                voa_input #2
                    enabled:            1
                    type:               point_cloud
                voa_input #3
                    enabled:            1
                    type:               tof
                    input_pipe:         tof
                    frame:              tof
                voa_input #4
                    enabled:            1
                    type:               rangefinder
                    frame:              body
                exising instance of voxl-vision-px4 found, attempting to stop it
                starting px4 shell
                WARNING in VOA manager, no attitude data from px4
                There is also one VOA manager WARNING in my odometry debug, with no attitude data from px4....
                  From the Troubleshooting VIO docs, can you try these steps?
                  QVIO Overlay in voxl-portal
                  voxl-inspect-qvio
                  KrisK 2 Replies Last reply
                  • Chad SweetC Chad Sweet
                    voxl-inspect-qvio
                    KrisK Offline
                    KrisK Offline
                    Kris
                    @Chad-Sweet Yes, I have read through those steps and tried them. All of my cameras are viewable in voxl-portal. I have also ran the voxl-inspect-qvio and the status was ok with no error's.
                      Can you please share the output of those steps?
                      KrisK 1 Reply Last reply
                        voxl-inspect-qvio
                        KrisK Offline
                        KrisK Offline
                        Kris
                        @Chad-Sweet
                        voxl:~$ voxl-inspect-qvio
                        waiting for server
                            T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
                           -0.00    0.00    0.00|  -0.0    0.0   -0.0| OKAY | ^C
                        closing and exiting
                          KrisK Offline
                          KrisK Offline
                          Kris
                          @Chad-Sweet What would you like to see in my voxl portal?
                          • KrisK Offline
                            KrisK Offline
                            Kris
                            Here I have turned the drone about an inch to the left.
                            waiting for server
                               -0.02    0.00    0.03|   0.3  -10.3    1.7| OKAY | ^C
                            closing and exiting
                              The qvio-overlay in voxl-portal is interesting, but from the voxl-inspect-qvio it looks like VIO is working properly. It's mostly likely PX4 is rejecting position mode, usually because it requires a magnetometer.
                              This section covers position mode rejected issues
                              Do you have a magnetometer connected? If not, are you sure PX4 is not expecting one?
                                KrisK Offline
                                KrisK Offline
                                Kris
                                @Chad-Sweet I haven't added anything special to my Seeker setup.
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  @Chad-Sweet
                                  SYS_HAS_MAG
                                  EKF2_MAG_TYPE
                                  So, I should enter the 0 value for SYS_HAS_MAG
                                  and 5 for the EKF2_MAG_TYPE?
                                    If you are using PX4 1.12 or later, and do not have a magnetometer, and want to use VIO, yes.
                                    KrisK 3 Replies Last reply
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      @Chad-Sweet OK 👍 I’ll try that 😊
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        #20
                                        @Chad-Sweet There is not an option for 5 in EKF2_MAG_TYPE.
                                        Should I leave this at “Automatic” or select “None” ?
                                          KrisK Offline
                                          KrisK Offline
                                          Kris
                                          #21
                                          @Chad-Sweet I selected "None" for the EKF2_MAG_TYPE and entered "0" for the SYS_HAS_MAG.
                                          The Odometry x y values are still at 0.
                                          Do I need to change anything in my voxl-vision-px4.conf files now that I am not using a GPS?
                                          "config_file_version":  1,
                                                  "qgc_ip":       "192.168.110.146",
                                                  "secondary_qgc_ip":     "192.168.1.214",
                                                  "udp_mtu":      512,
                                                  "vio_pipe":     "qvio",
                                                  "en_vio":       true,
                                                  "en_send_vio_to_qgc":   true,
                                                  "vio_warmup_s": 3,
                                                  "horizon_cal_tolerance":        0.449999988079071,
                                                  "offboard_mode":        "trajectory",
                                                  "follow_tag_id":        0,
                                                  "figure_eight_move_home":       true,
                                                  "en_tag_fixed_frame":   false,
                                                  "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
                                                  "en_voa":       true,
                                                  "en_send_voa_to_qgc":   true,
                                                  "voa_upper_bound_m":    -0.15000000596046448,
                                                  "voa_lower_bound_m":    0.15000000596046448,
                                                  "voa_memory_s": 1,
                                                  "voa_inputs":   [{
        "enabled":      true,
        "type": "point_cloud",
        "input_pipe":   "dfs_point_cloud",
        "frame":        "stereo_l"
        "enabled":      true,
        "input_pipe":   "stereo_front_pc",
        "frame":        "stereo_front_l"
        "enabled":      true,
        "input_pipe":   "stereo_rear_pc",
        "frame":        "stereo_rear_l"
        "enabled":      true,
        "type": "tof",
        "input_pipe":   "tof",
        "frame":        "tof"
        "enabled":      true,
        "type": "rangefinder",
        "input_pipe":   "rangefinders",
        "frame":        "body"
                                          Should I just unplug the Cirocomm GPS?
