  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 39.2k Views 2 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    Could this issue be coming from imu0 and imu1?
    • KrisK Offline
      KrisK Offline
      Kris
      wrote on last edited by Kris
      Has anyone had this error message on their system?
      ERROR validating VIO data received through pipe: read partial packet
      read 156 bytes, but it should be a multiple of 324
      If so, how was it resolved?
      Here is my debug odometry;
      voxl:~$ voxl-vision-px4 --debug_odometry
      loading our own config file
      config_file_version:        1
      MAVLINK IO
      qgc_ip:                     192.168.110.146
      en_secondary_qgc:           0
      qgc_udp_port_number:        14550
      udp_mtu:                    512
      en_localhost_mavlink_udp    1
      VIO
      en_vio:                     1
      vio_pipe:                   qvio
      en_send_vio_to_qgc:         1
      vio_warmup_s:               3.000000
      APQ8096-ONLY FEATURES
      en_set_clock_from_gps:      1
      en_force_onboard_mav1_mode: 1
      en_reset_px4_on_error:      1
      MISC FEATURES
      horizon_cal_tolerance:      0.450000
      OFFBOARD MODE
      offboard_mode:              trajectory
      follow_tag_id:              0
      figure_eight_move_home:     1
      FIXED FRAME RELOCALIZATION
      en_tag_fixed_frame:         0
      fixed_frame_filter_len:     5
      COLLISION PREVENTION (VOA)
      en_voa:                     1
      en_send_voa_to_qgc:         1
      voa_upper_bound_m:          -0.150000
      voa_lower_bound_m:          0.150000
      voa_memory_s:               1.000000
      voa_input #0
          enabled:            1
          type:               point_cloud
          input_pipe:         dfs_point_cloud
          frame:              stereo_l
      voa_input #1
          enabled:            1
          type:               point_cloud
          input_pipe:         stereo_front_pc
          frame:              stereo_front_l
      voa_input #2
          enabled:            1
          type:               point_cloud
          input_pipe:         stereo_rear_pc
          frame:              stereo_rear_l
      voa_input #3
          enabled:            1
          type:               tof
          input_pipe:         tof
          frame:              tof
      voa_input #4
          enabled:            1
          type:               rangefinder
          input_pipe:         rangefinders
          frame:              body
      exising instance of voxl-vision-px4 found, attempting to stop it
      starting geometry module
      starting px4 monitor
      starting px4 mavlink
      Detected PX4 Mavlink SYSID 1
      starting udp mavlink
      Adding manual QGC IP address to udp connection list: 192.168.110.146
      Added new UDP connection to 192.168.110.146
      starting px4 shell
      starting fixed pose input
      starting vio manager
      Connected to VIO pipe: qvio
      updating to use imu: imu1
      done updating transforms to use imu: imu1
      starting tag manager
      starting voa manager
      Connected to pipe: dfs_point_cloud
      Connected to pipe: tof
      starting horizon cal
      starting offboard trajectory
      detected system time has already been set
      WARNING in VOA manager, no attitude data from px4
      There is also one VOA manager WARNING in my odometry debug, with no attitude data from px4....
        From the Troubleshooting VIO docs, can you try these steps?
        QVIO Overlay in voxl-portal
        voxl-inspect-qvio
        KrisK 2 Replies Last reply
        • Chad SweetC Chad Sweet
          voxl-inspect-qvio
          KrisK Offline
          KrisK Offline
          Kris
          @Chad-Sweet Yes, I have read through those steps and tried them. All of my cameras are viewable in voxl-portal. I have also ran the voxl-inspect-qvio and the status was ok with no error's.
            Can you please share the output of those steps?
            KrisK 1 Reply Last reply
              voxl-inspect-qvio
              KrisK Offline
              KrisK Offline
              Kris
              @Chad-Sweet
              voxl:~$ voxl-inspect-qvio
              waiting for server
                  T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
                 -0.00    0.00    0.00|  -0.0    0.0   -0.0| OKAY | ^C
              received SIGINT Ctrl-C
              closing and exiting
                KrisK Offline
                KrisK Offline
                Kris
                @Chad-Sweet What would you like to see in my voxl portal?
                • KrisK Offline
                  KrisK Offline
                  Kris
                  Here I have turned the drone about an inch to the left.
                  waiting for server
                     -0.02    0.00    0.03|   0.3  -10.3    1.7| OKAY | ^C
                  closing and exiting
                    The qvio-overlay in voxl-portal is interesting, but from the voxl-inspect-qvio it looks like VIO is working properly. It's mostly likely PX4 is rejecting position mode, usually because it requires a magnetometer.
                    This section covers position mode rejected issues
                    Do you have a magnetometer connected? If not, are you sure PX4 is not expecting one?
                      KrisK Offline
                      KrisK Offline
                      Kris
                      @Chad-Sweet I haven't added anything special to my Seeker setup.
                        KrisK Offline
                        KrisK Offline
                        Kris
                        @Chad-Sweet
                        SYS_HAS_MAG
                        EKF2_MAG_TYPE
                        So, I should enter the 0 value for SYS_HAS_MAG
                        and 5 for the EKF2_MAG_TYPE?
                          If you are using PX4 1.12 or later, and do not have a magnetometer, and want to use VIO, yes.
                          KrisK 3 Replies Last reply
                            KrisK Offline
                            KrisK Offline
                            Kris
                            @Chad-Sweet OK 👍 I’ll try that 😊
                              KrisK Offline
                              KrisK Offline
                              Kris
                              #20
                              @Chad-Sweet There is not an option for 5 in EKF2_MAG_TYPE.
                              Should I leave this at “Automatic” or select “None” ?
                                KrisK Offline
                                KrisK Offline
                                Kris
                                #21
                                @Chad-Sweet I selected "None" for the EKF2_MAG_TYPE and entered "0" for the SYS_HAS_MAG.
                                The Odometry x y values are still at 0.
                                Do I need to change anything in my voxl-vision-px4.conf files now that I am not using a GPS?
                                "config_file_version":  1,
                                        "qgc_ip":       "192.168.110.146",
                                        "secondary_qgc_ip":     "192.168.1.214",
                                        "udp_mtu":      512,
                                        "vio_pipe":     "qvio",
                                        "en_vio":       true,
                                        "en_send_vio_to_qgc":   true,
                                        "vio_warmup_s": 3,
                                        "horizon_cal_tolerance":        0.449999988079071,
                                        "offboard_mode":        "trajectory",
                                        "follow_tag_id":        0,
                                        "figure_eight_move_home":       true,
                                        "en_tag_fixed_frame":   false,
                                        "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
                                        "en_voa":       true,
                                        "en_send_voa_to_qgc":   true,
                                        "voa_upper_bound_m":    -0.15000000596046448,
                                        "voa_lower_bound_m":    0.15000000596046448,
                                        "voa_memory_s": 1,
                                        "voa_inputs":   [{
                                                        "enabled":      true,
        "type": "point_cloud",
        "input_pipe":   "dfs_point_cloud",
        "frame":        "stereo_l"
        "enabled":      true,
        "input_pipe":   "stereo_front_pc",
        "frame":        "stereo_front_l"
        "enabled":      true,
        "input_pipe":   "stereo_rear_pc",
        "frame":        "stereo_rear_l"
        "enabled":      true,
        "type": "tof",
        "input_pipe":   "tof",
        "frame":        "tof"
        "enabled":      true,
        "type": "rangefinder",
        "input_pipe":   "rangefinders",
        "frame":        "body"
                                Should I just unplug the Cirocomm GPS?
                                • KrisK Offline
                                  KrisK Offline
                                  Kris
                                  I unplugged the GPS from the Seeker. I am still not able to get position control in MAVLink and my Odometry x y values are still at 0.
                                  Maybe the last option to do is to re-calibrate my cameras...
                                    #23
                                    If voxl-inspect-qvio shows functioning VIO data, there is no need to calibrate cameras. VIO is working. PX4 is most likely misconfigured.
                                    If you have a GPS, then you likely have a magnetometer?
                                    Seeker should have arrived pre-configured for VIO flight. No need to change anything. VIO is flight tested for 20 minutes before being shipped.
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      @Chad-Sweet
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        @Chad-Sweet
                                        Yes, I have this GPS/Magnetometer that is on the back of the Seeker above the battery compartment.
                                        If my PX4 is possibly misconfigured, should I just remove PX4 and start clean?
                                        Or, is there something you might know that could be causing the problem in PX4?
                                          Here are the default Seeker parameters for PX4 1.11
                                          Here are the helper parameters for Seeker indoor VIO flight
