  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 43.6k Views 2 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    Here I have turned the drone about an inch to the left.
    voxl:~$ voxl-inspect-qvio
    waiting for server
        T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
       -0.02    0.00    0.03|   0.3  -10.3    1.7| OKAY | ^C
    received SIGINT Ctrl-C
    closing and exiting
      The qvio-overlay in voxl-portal is interesting, but from the voxl-inspect-qvio it looks like VIO is working properly. It's mostly likely PX4 is rejecting position mode, usually because it requires a magnetometer.
      This section covers position mode rejected issues
      Do you have a magnetometer connected? If not, are you sure PX4 is not expecting one?
      KrisK 2 Replies Last reply
      • Chad SweetC Chad Sweet
        KrisK Offline
        KrisK Offline
        Kris
        @Chad-Sweet I haven't added anything special to my Seeker setup.
          KrisK Offline
          KrisK Offline
          Kris
          @Chad-Sweet
          SYS_HAS_MAG
          EKF2_MAG_TYPE
          So, I should enter the 0 value for SYS_HAS_MAG
          and 5 for the EKF2_MAG_TYPE?
            If you are using PX4 1.12 or later, and do not have a magnetometer, and want to use VIO, yes.
            KrisK 3 Replies Last reply
              KrisK Offline
              KrisK Offline
              Kris
              @Chad-Sweet OK 👍 I’ll try that 😊
                KrisK Offline
                KrisK Offline
                Kris
                wrote on last edited by Kris
                #20
                @Chad-Sweet There is not an option for 5 in EKF2_MAG_TYPE.
                Should I leave this at “Automatic” or select “None” ?
                  KrisK Offline
                  KrisK Offline
                  Kris
                  #21
                  @Chad-Sweet I selected "None" for the EKF2_MAG_TYPE and entered "0" for the SYS_HAS_MAG.
                  The Odometry x y values are still at 0.
                  Do I need to change anything in my voxl-vision-px4.conf files now that I am not using a GPS?
                  "config_file_version":  1,
                          "qgc_ip":       "192.168.110.146",
                          "secondary_qgc_ip":     "192.168.1.214",
                          "udp_mtu":      512,
                          "vio_pipe":     "qvio",
                          "en_vio":       true,
                          "en_send_vio_to_qgc":   true,
                          "vio_warmup_s": 3,
                          "horizon_cal_tolerance":        0.449999988079071,
                          "offboard_mode":        "trajectory",
                          "follow_tag_id":        0,
                          "figure_eight_move_home":       true,
                          "en_tag_fixed_frame":   false,
                          "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
                          "en_voa":       true,
                          "en_send_voa_to_qgc":   true,
                          "voa_upper_bound_m":    -0.15000000596046448,
                          "voa_lower_bound_m":    0.15000000596046448,
                          "voa_memory_s": 1,
                          "voa_inputs":   [{
                                          "enabled":      true,
        "type": "point_cloud",
        "input_pipe":   "dfs_point_cloud",
        "frame":        "stereo_l"
        "enabled":      true,
        "input_pipe":   "stereo_front_pc",
        "frame":        "stereo_front_l"
        "enabled":      true,
        "input_pipe":   "stereo_rear_pc",
        "frame":        "stereo_rear_l"
        "enabled":      true,
        "type": "tof",
        "input_pipe":   "tof",
        "frame":        "tof"
        "enabled":      true,
        "type": "rangefinder",
        "input_pipe":   "rangefinders",
        "frame":        "body"
                  Should I just unplug the Cirocomm GPS?
                  • KrisK Offline
                    KrisK Offline
                    Kris
                    I unplugged the GPS from the Seeker. I am still not able to get position control in MAVLink and my Odometry x y values are still at 0.
                    Maybe the last option to do is to re-calibrate my cameras...
                      #23
                      If voxl-inspect-qvio shows functioning VIO data, there is no need to calibrate cameras. VIO is working. PX4 is most likely misconfigured.
                      If you have a GPS, then you likely have a magnetometer?
                      Seeker should have arrived pre-configured for VIO flight. No need to change anything. VIO is flight tested for 20 minutes before being shipped.
                        KrisK Offline
                        KrisK Offline
                        Kris
                        @Chad-Sweet
                          KrisK Offline
                          KrisK Offline
                          Kris
                          @Chad-Sweet
                          Yes, I have this GPS/Magnetometer that is on the back of the Seeker above the battery compartment.
                          If my PX4 is possibly misconfigured, should I just remove PX4 and start clean?
                          Or, is there something you might know that could be causing the problem in PX4?
                            Here are the default Seeker parameters for PX4 1.11
                            Here are the helper parameters for Seeker indoor VIO flight
                            KrisK 1 Reply Last reply
                              KrisK Offline
                              KrisK Offline
                              Kris
                              @Chad-Sweet Thank you 🙏
                              I will load these into PX4 and test it.
                              • Adrian HidalgoA Offline
                                Adrian Hidalgo
                                @Kris Can you post a pic of QGC under MavLink Inspector, go to the tab that says Local_Position_Ned and see what the X, Y, Z show. I want to verify how those numbers are numerating.
                                Normally if the X & Y are zeroed out, VIO hasn't started yet or has blown up. A power-cycle can fix this, but I would think you've already attempted that. Looks like you've already attempted resetting voxl-vision-px4 & qvio.
                                You may want to try reconfiguring mpa:
                                voxl-configure-mpa -p -f seeker -b blue -c 7 --fc yes
                                Power-cycle afterwards. You'll have to set your qgc-ip again since mpa will reset it to factory.
                                KrisK 4 Replies Last reply
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  @Adrian-Hidalgo
                                  Ok, I will try that now.
                                  My position is still being rejected after resetting PX4 and loading the new paremeter files.
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    @Adrian-Hidalgo
                                    I have actually reconfigured mpa before, but I will try it again after I have loaded these new PX4 parameters.
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      @Adrian-Hidalgo
                                      Unfortunatly that didnt work either 😢
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        @Adrian-Hidalgo @Chad-Sweet , Is there anything else you would like to look at on my end or something else I can try to resolve this issue?
                                          Adrian Hidalgo
                                          @Kris what version of PX4 are you using?
                                          This forum may have similar issues and it was resolved by updating PX4
