  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 43.6k Views 2 Watching
    If you are using PX4 1.12 or later, and do not have a magnetometer, and want to use VIO, yes.
    KrisK 3 Replies Last reply
    • Chad SweetC Chad Sweet
      KrisK Offline
      KrisK Offline
      Kris
      @Chad-Sweet OK 👍 I’ll try that 😊
        KrisK Offline
        KrisK Offline
        Kris
        wrote on last edited by Kris
        #20
        @Chad-Sweet There is not an option for 5 in EKF2_MAG_TYPE.
        Should I leave this at “Automatic” or select “None” ?
          KrisK Offline
          KrisK Offline
          Kris
          #21
          @Chad-Sweet I selected "None" for the EKF2_MAG_TYPE and entered "0" for the SYS_HAS_MAG.
          The Odometry x y values are still at 0.
          Do I need to change anything in my voxl-vision-px4.conf files now that I am not using a GPS?
          "config_file_version":  1,
                  "qgc_ip":       "192.168.110.146",
                  "secondary_qgc_ip":     "192.168.1.214",
                  "udp_mtu":      512,
                  "vio_pipe":     "qvio",
                  "en_vio":       true,
                  "en_send_vio_to_qgc":   true,
                  "vio_warmup_s": 3,
                  "horizon_cal_tolerance":        0.449999988079071,
                  "offboard_mode":        "trajectory",
                  "follow_tag_id":        0,
                  "figure_eight_move_home":       true,
                  "en_tag_fixed_frame":   false,
                  "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
                  "en_voa":       true,
                  "en_send_voa_to_qgc":   true,
                  "voa_upper_bound_m":    -0.15000000596046448,
                  "voa_lower_bound_m":    0.15000000596046448,
                  "voa_memory_s": 1,
                  "voa_inputs":   [{
                                  "enabled":      true,
                                                          "type": "point_cloud",
                                                          "input_pipe":   "dfs_point_cloud",
                                                          "frame":        "stereo_l"
                                                          "enabled":      true,
                                                          "input_pipe":   "stereo_front_pc",
                                                          "frame":        "stereo_front_l"
                                                          "enabled":      true,
                                                          "input_pipe":   "stereo_rear_pc",
                                                          "frame":        "stereo_rear_l"
                                                          "enabled":      true,
                                                          "type": "tof",
                                                          "input_pipe":   "tof",
                                                          "frame":        "tof"
                                                          "enabled":      true,
                                                          "type": "rangefinder",
                                                          "input_pipe":   "rangefinders",
                                                          "frame":        "body"
          Should I just unplug the Cirocomm GPS?
          • KrisK Offline
            KrisK Offline
            Kris
            I unplugged the GPS from the Seeker. I am still not able to get position control in MAVLink and my Odometry x y values are still at 0.
            Maybe the last option to do is to re-calibrate my cameras...
              #23
              If voxl-inspect-qvio shows functioning VIO data, there is no need to calibrate cameras. VIO is working. PX4 is most likely misconfigured.
              If you have a GPS, then you likely have a magnetometer?
              Seeker should have arrived pre-configured for VIO flight. No need to change anything. VIO is flight tested for 20 minutes before being shipped.
              KrisK 2 Replies Last reply
                KrisK Offline
                KrisK Offline
                Kris
                @Chad-Sweet
                  KrisK Offline
                  KrisK Offline
                  Kris
                  @Chad-Sweet
                  Yes, I have this GPS/Magnetometer that is on the back of the Seeker above the battery compartment.
                  If my PX4 is possibly misconfigured, should I just remove PX4 and start clean?
                  Or, is there something you might know that could be causing the problem in PX4?
                    Here are the default Seeker parameters for PX4 1.11
                    Here are the helper parameters for Seeker indoor VIO flight
                    KrisK 1 Reply Last reply
                      KrisK Offline
                      KrisK Offline
                      Kris
                      @Chad-Sweet Thank you 🙏
                      I will load these into PX4 and test it.
                      • Adrian HidalgoA Offline
                        Adrian Hidalgo
                        @Kris Can you post a pic of QGC under MavLink Inspector, go to the tab that says Local_Position_Ned and see what the X, Y, Z show. I want to verify how those numbers are numerating.
                        Normally if the X & Y are zeroed out, VIO hasn't started yet or has blown up. A power-cycle can fix this, but I would think you've already attempted that. Looks like you've already attempted resetting voxl-vision-px4 & qvio.
                        You may want to try reconfiguring mpa:
                        voxl-configure-mpa -p -f seeker -b blue -c 7 --fc yes
                        Power-cycle afterwards. You'll have to set your qgc-ip again since mpa will reset it to factory.
                        KrisK 4 Replies Last reply
                          KrisK Offline
                          KrisK Offline
                          Kris
                          @Adrian-Hidalgo
                          Ok, I will try that now.
                          My position is still being rejected after resetting PX4 and loading the new paremeter files.
                            KrisK Offline
                            KrisK Offline
                            Kris
                            @Adrian-Hidalgo
                            I have actually reconfigured mpa before, but I will try it again after I have loaded these new PX4 parameters.
                              KrisK Offline
                              KrisK Offline
                              Kris
                              @Adrian-Hidalgo
                              Unfortunatly that didnt work either 😢
                                KrisK Offline
                                KrisK Offline
                                Kris
                                @Adrian-Hidalgo @Chad-Sweet , Is there anything else you would like to look at on my end or something else I can try to resolve this issue?
                                  Adrian Hidalgo
                                  @Kris what version of PX4 are you using?
                                  This forum may have similar issues and it was resolved by updating PX4
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    @Adrian-Hidalgo I honestly don't remember which one I installed. Could you please remind me how to check for the version?
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                        Adrian Hidalgo
                                        @Kris select the Q, should say in the menu selection below application settings
                                          Adrian Hidalgo
                                          @Kris you could try loading a previous sys-image & sdk. Did it work before updating?
