  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 43.6k Views 2 Watching
  • Chad SweetC Chad Sweet
    From the Troubleshooting VIO docs, can you try these steps?
    QVIO Overlay in voxl-portal
    voxl-inspect-qvio
    KrisK Offline
    KrisK Offline
    Kris
    @Chad-Sweet
    voxl:~$ voxl-inspect-qvio
    waiting for server
        T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
       -0.00    0.00    0.00|  -0.0    0.0   -0.0| OKAY | ^C
    received SIGINT Ctrl-C
    closing and exiting
      Can you please share the output of those steps?
      KrisK Offline
      KrisK Offline
      Kris
      @Chad-Sweet What would you like to see in my voxl portal?
      • KrisK Offline
        KrisK Offline
        Kris
        Here I have turned the drone about an inch to the left.
        waiting for server
           -0.02    0.00    0.03|   0.3  -10.3    1.7| OKAY | ^C
        closing and exiting
          The qvio-overlay in voxl-portal is interesting, but from the voxl-inspect-qvio it looks like VIO is working properly. It's mostly likely PX4 is rejecting position mode, usually because it requires a magnetometer.
          This section covers position mode rejected issues
          Do you have a magnetometer connected? If not, are you sure PX4 is not expecting one?
          KrisK 2 Replies Last reply
            KrisK Offline
            KrisK Offline
            Kris
            @Chad-Sweet I haven't added anything special to my Seeker setup.
              KrisK Offline
              KrisK Offline
              Kris
              @Chad-Sweet
              SYS_HAS_MAG
              EKF2_MAG_TYPE
              So, I should enter the 0 value for SYS_HAS_MAG
              and 5 for the EKF2_MAG_TYPE?
                If you are using PX4 1.12 or later, and do not have a magnetometer, and want to use VIO, yes.
                KrisK 3 Replies Last reply
                  KrisK Offline
                  KrisK Offline
                  Kris
                  @Chad-Sweet OK 👍 I’ll try that 😊
                    KrisK Offline
                    KrisK Offline
                    Kris
                    wrote on last edited by Kris
                    #20
                    @Chad-Sweet There is not an option for 5 in EKF2_MAG_TYPE.
                    Should I leave this at “Automatic” or select “None” ?
                      KrisK Offline
                      KrisK Offline
                      Kris
                      #21
                      @Chad-Sweet I selected "None" for the EKF2_MAG_TYPE and entered "0" for the SYS_HAS_MAG.
                      The Odometry x y values are still at 0.
                      Do I need to change anything in my voxl-vision-px4.conf files now that I am not using a GPS?
                      "config_file_version":  1,
                              "qgc_ip":       "192.168.110.146",
                              "secondary_qgc_ip":     "192.168.1.214",
                              "udp_mtu":      512,
                              "vio_pipe":     "qvio",
                              "en_vio":       true,
                              "en_send_vio_to_qgc":   true,
                              "vio_warmup_s": 3,
                              "horizon_cal_tolerance":        0.449999988079071,
                              "offboard_mode":        "trajectory",
                              "follow_tag_id":        0,
                              "figure_eight_move_home":       true,
                              "en_tag_fixed_frame":   false,
                              "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
                              "en_voa":       true,
                              "en_send_voa_to_qgc":   true,
                              "voa_upper_bound_m":    -0.15000000596046448,
                              "voa_lower_bound_m":    0.15000000596046448,
                              "voa_memory_s": 1,
                              "voa_inputs":   [{
                                              "enabled":      true,
        "type": "point_cloud",
        "input_pipe":   "dfs_point_cloud",
        "frame":        "stereo_l"
        "enabled":      true,
        "input_pipe":   "stereo_front_pc",
        "frame":        "stereo_front_l"
        "enabled":      true,
        "input_pipe":   "stereo_rear_pc",
        "frame":        "stereo_rear_l"
        "enabled":      true,
        "type": "tof",
        "input_pipe":   "tof",
        "frame":        "tof"
        "enabled":      true,
        "type": "rangefinder",
        "input_pipe":   "rangefinders",
        "frame":        "body"
                      Should I just unplug the Cirocomm GPS?
                      • KrisK Offline
                        KrisK Offline
                        Kris
                        I unplugged the GPS from the Seeker. I am still not able to get position control in MAVLink and my Odometry x y values are still at 0.
                        Maybe the last option to do is to re-calibrate my cameras...
                          #23
                          If voxl-inspect-qvio shows functioning VIO data, there is no need to calibrate cameras. VIO is working. PX4 is most likely misconfigured.
                          If you have a GPS, then you likely have a magnetometer?
                          Seeker should have arrived pre-configured for VIO flight. No need to change anything. VIO is flight tested for 20 minutes before being shipped.
                            KrisK Offline
                            KrisK Offline
                            Kris
                            @Chad-Sweet
                              KrisK Offline
                              KrisK Offline
                              Kris
                              @Chad-Sweet
                              Yes, I have this GPS/Magnetometer that is on the back of the Seeker above the battery compartment.
                              If my PX4 is possibly misconfigured, should I just remove PX4 and start clean?
                              Or, is there something you might know that could be causing the problem in PX4?
                                Here are the default Seeker parameters for PX4 1.11
                                Here are the helper parameters for Seeker indoor VIO flight
                                KrisK 1 Reply Last reply
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  @Chad-Sweet Thank you 🙏
                                  I will load these into PX4 and test it.
                                  • Adrian HidalgoA Offline
                                    Adrian Hidalgo
                                    @Kris Can you post a pic of QGC under MavLink Inspector, go to the tab that says Local_Position_Ned and see what the X, Y, Z show. I want to verify how those numbers are numerating.
                                    Normally if the X & Y are zeroed out, VIO hasn't started yet or has blown up. A power-cycle can fix this, but I would think you've already attempted that. Looks like you've already attempted resetting voxl-vision-px4 & qvio.
                                    You may want to try reconfiguring mpa:
                                    voxl-configure-mpa -p -f seeker -b blue -c 7 --fc yes
                                    Power-cycle afterwards. You'll have to set your qgc-ip again since mpa will reset it to factory.
                                    KrisK 4 Replies Last reply
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      @Adrian-Hidalgo
                                      Ok, I will try that now.
                                      My position is still being rejected after resetting PX4 and loading the new paremeter files.
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        @Adrian-Hidalgo
                                        I have actually reconfigured mpa before, but I will try it again after I have loaded these new PX4 parameters.
                                          KrisK Offline
                                          KrisK Offline
                                          Kris
                                          @Adrian-Hidalgo
                                          Unfortunatly that didnt work either 😢
