  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 43.6k Views 2 Watching
  • Chad SweetC Chad Sweet
    The QVIO overlay looks good, so VIO is working. There is nothing wrong with the image sensor and VOXL setup if VIO is working.
    TOF and stereo have nothing to do with VIO.
    VIO is publishing valid data, but PX4 is not receiving it for some reason
    KrisK Offline
    KrisK Offline
    Kris
    @Chad-Sweet below is some data I have collected.
    voxl-inspect-points tof_pc
    timestamp(ms)| # points | # bytes |     1st point     | Format
          436351 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
          438151 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
          440885 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
          442417 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
          448818 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
          453484 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
          454684 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ
          461952 |    38528 |  462336 |   0.0   0.0   0.0 | Float XYZ^C
    received SIGINT Ctrl-C
    closing and exiting
    I moved the drone around and placed my hand and objects in front of the tof, but I was still not able to get any values.
    voxl-inspect-points voa_pc_out
          534219 |      438 |    5256 |   0.2   0.1   0.1 | Float XYZ
          534353 |      438 |    5256 |   0.2   0.1   0.1 | Float XYZ
          534488 |      437 |    5244 |   0.2   0.1   0.1 | Float XYZ
          534587 |      440 |    5280 |   0.2   0.1   0.1 | Float XYZ
          534720 |      438 |    5256 |   0.2   0.1   0.1 | Float XYZ
          534853 |      427 |    5124 |   0.2   0.1   0.1 | Float XYZ
          534986 |      436 |    5232 |   0.2   0.1   0.1 | Float XYZ
          535086 |      447 |    5364 |   0.2   0.1   0.1 | Float XYZ
          535219 |      453 |    5436 |   0.2   0.1   0.1 | Float XYZ
          535352 |      445 |    5340 |   0.2   0.1   0.1 | Float XYZ
          535619 |      465 |    5580 |   0.2   0.1   0.1 | Float XYZ
          535752 |      455 |    5460 |   0.2   0.1   0.1 | Float XYZ
          535886 |      456 |    5472 |   2.9   1.7  -1.3 | Float XYZ
          536019 |      450 |    5400 |   0.2   0.1   0.1 | Float XYZ
          536186 |      439 |    5268 |   0.2   0.1   0.1 | Float XYZ
          536286 |      437 |    5244 |   0.2   0.1   0.1 | Float XYZ
          536419 |      446 |    5352 |   0.2   0.1   0.1 | Float XYZ
          536586 |      450 |    5400 |   0.2   0.1   0.1 | Float XYZ
          536719 |      448 |    5376 |   0.2   0.1   0.1 | Float XYZ
          536853 |      438 |    5256 |   0.2   0.1   0.1 | Float XYZ
          536986 |      448 |    5376 |   0.2   0.1   0.1 | Float XYZ
          537153 |      459 |    5508 |   0.2   0.1   0.1 | Float XYZ
          537287 |      462 |    5544 |   0.2   0.1   0.1 | Float XYZ
          537419 |      459 |    5508 |   0.2   0.1   0.1 | Float XYZ
          537586 |      464 |    5568 |   2.9   1.7  -1.3 | Float XYZ
          537719 |      453 |    5436 |   0.2   0.1   0.1 | Float XYZ
          537886 |      446 |    5352 |   0.2   0.1   0.1 | Float XYZ
          538019 |      443 |    5316 |   0.2   0.1   0.1 | Float XYZ
          538152 |      440 |    5280 |   0.2   0.1   0.1 | Float XYZ
          538285 |      444 |    5328 |   0.2   0.1   0.1 | Float XYZ
          538419 |      448 |    5376 |   0.2   0.1   0.1 | Float XYZ
          538586 |      469 |    5628 |   0.2   0.1   0.1 | Float XYZ
          573252 |       42 |     504 |   0.2   0.1   0.1 | Float XYZ
          573385 |       43 |     516 |   0.2   0.1   0.1 | Float XYZ
          573552 |       44 |     528 |   0.2   0.1   0.1 | Float XYZ
          573718 |       49 |     588 |   0.2   0.1   0.1 | Float XYZ
          574019 |       47 |     564 |   0.2   0.1   0.1 | Float XYZ
          594519 |      452 |    5424 |   0.2   0.1   0.1 | Float XYZ
          595052 |      421 |    5052 |   0.2   0.1   0.1 | Float XYZ
          595552 |      422 |    5064 |   0.2   0.1   0.1 | Float XYZ
          603719 |      451 |    5412 |   0.2   0.1   0.1 | Float XYZ^C
    closing and exiting
    Nothing was in front of the drone at the beginning and those were the values that I was receiving. the point values remained at "0.2 0.1 0.1" then every 2 seconds or so the values would flash "2.9 1.7 -1.3" for a split second. Then towards the end I placed my hand in front of the tof cam (about 3~5 inches away) and recieved those 40's. When I removed my hand the values changed back to the 400's.
    voxl-inspect-points dfs_disparity
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: 314570
    invalid metadata, magic number=0, expected 1448040524
    ^C
    closing and exiting
    voxl-inspect-points dfs_disparity_scaled
    ^C
    closing and exiting
    voxl-inspect-points dfs_point_cloud
         1534485 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1535687 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1538019 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1539718 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1541220 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1542219 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1543217 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1544216 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1545218 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1545718 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1548718 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1549551 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1550051 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1550784 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ
         1553650 |     4800 |   57600 |  -inf  -inf 10000.0 | Float XYZ^C
    closing and exiting
    I moved the drone around and also placed my hand in front of the voxl, but only the timestamp was working.
    voxl-inspect-points tof_noise
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: 112726
    ^C
    closing and exiting
    • KrisK Offline
      KrisK Offline
      Kris
      voxl-inspect-points tof_ir
      invalid metadata, magic number=1, expected 1448040524
      invalid metadata, magic number=65536, expected 1448040524
      invalid metadata, magic number=16842752, expected 1448040524
      invalid metadata, magic number=16777216, expected 1448040524
      invalid metadata, magic number=256, expected 1448040524
      invalid metadata, magic number=16777472, expected 1448040524
      invalid metadata, magic number=65537, expected 1448040524
      ^C
      closing and exiting
      voxl-inspect-points tof_conf
      ^C
      closing and exiting
      voxl-inspect-points tof_depth
      ^C
      closing and exiting
      voxl-inspect-points qvio
      ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11172
      ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11178
      ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11174
      ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11173
      ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11170
      ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11171
      ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11177
      ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11175
      ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11176
      ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11179
      ^C
      closing and exiting
      voxl-inspect-points qvio_overlay
      ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: 356524
      ^C
      closing and exiting
      • KrisK Offline
        KrisK Offline
        Kris
        @Chad-Sweet
        So, what do you think the problem might be?
        I’ll be taking a more detailed look at PX4 next.
        If you feel that is where the issue is for the VIO.
        • KrisK Offline
          KrisK Offline
          Kris
          wrote on last edited by Kris
          #64
          @Chad-Sweet
          I really do appreciate you helping me with this.
          Thank you! 🙏
          • KrisK Offline
            KrisK Offline
            Kris
            If the problem is coming from PX4, how should I go about resolving it? Should I be speaking with PX4 support instead of ModalAi?
            • KrisK Offline
              KrisK Offline
              Kris
              #66
              @Chad-Sweet @Adrian-Hidalgo ,
              For PX4 confirmation, here is my voxl vision status.
              voxl:~$ systemctl status voxl-vision-px4 -l
              ● voxl-vision-px4.service - voxl-vision-px4
                 Loaded: loaded (/usr/bin/voxl-vision-px4; enabled; vendor preset: enabled)
                 Active: active (running) since Thu 1970-01-01 00:00:06 UTC; 52 years 8 months ago
               Main PID: 2073 (voxl-vision-px4)
                 CGroup: /system.slice/voxl-vision-px4.service
                         └─2073 /usr/bin/voxl-vision-px4
              Sep 02 16:25:57 apq8096 voxl-vision-px4[2073]: ERROR validating VIO data received through pipe: read partial packet
              Sep 02 16:25:57 apq8096 voxl-vision-px4[2073]: read 156 bytes, but it should be a multiple of 324
              voxl:~$
              Could this be a time/clock, or a watchdog timer issue?
              • James StrawsonJ Offline
                James Strawson
                Hi Kris
                It looks like the voxl-vision-px4 and voxl-qvio-server versions have gotten out of sync, likely voxl-vision-px4 has been updated but voxl-qvio-server was not.
                Do you mind proving the output from the following 3 commands so I can check the state of the opkg package manager
                cat /etc/opkg/opkg.conf
                opkg info voxl-vision-px4
                opkg info voxl-qvio-server
                James
                KrisK 1 Reply Last reply
                  Hi Kris
                  James
                  KrisK Offline
                  KrisK Offline
                  Kris
                  #68
                  Hi @James-Strawson , thank you. Here are the outputs you have requested.
                  ## This file has been automatically generated.
                  ## Please use voxl-configure-opkg to modify it.
                  dest root /
                  option lists_dir /var/lib/opkg/lists
                  arch all 1
                  arch arm64 7
                  src/gz modalai http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64/
                  voxl:~$ opkg info voxl-vision-px4
                  Package: voxl-vision-px4
                  Version: 1.2.0
                  Depends: librc-math, libmodal-pipe (>= 2.4.0), libmodal-json, voxl-mpa-tools (>= 0.2.5), voxl-mavlink-server, libmodal-cv (>= 0.1.0)
                  Section: base
                  Architecture: arm64
                  Maintainer: James Strawson <james@modalai.com>
                  MD5Sum: 4bcff955596c2a5964d68cacf60d08a8
                  Filename: voxl-vision-px4_1.2.0.ipk
                  Description: Interface between VOXL's computer vision services and PX4
                  Installed-Time: 1661276328
                  voxl:~$ opkg info voxl-qvio-server
                  Package: voxl-qvio-server
                  Version: 0.7.1
                  Depends: libmodal-pipe (>= 2.4.0), libmodal-json (>= 0.4.0), voxl-mpa-tools (>= 0.7.0)
                  Status: unknown ok not-installed
                  Section: base
                  Architecture: arm64
                  Maintainer: james@modalai.com
                  MD5Sum: 2ccb793c2d7059217d9d32b54564352b
                  Filename: voxl-qvio-server_0.7.1.ipk
                  Description: publishes QVIO data over named pipe interface
                  Version: 0.4.6
                  Depends: libmodal-pipe (>= 2.0.0), libmodal-json (>= 0.4.0), voxl-mpa-tools
                  Status: install ok installed
                  Architecture: arm64
                  Installed-Time: 6815
                  qvio-server version 0.7.1 status: unknown ok not-installed
                  voxl:~$ opkg list-installed | grep "libmodal"
                  libmodal-cv - 0.1.0
                  libmodal-exposure - 0.0.7
                  libmodal-json - 0.4.2
                  libmodal-pipe - 2.4.0
                    James Strawson
                    wrote on last edited by James Strawson
                    #69
                    Yes, It seems your installed voxl-vision-px4 and libmodal_pipe versions are from SDK 0.8 wheras your voxl-qvio-server is from SDK 0.7, that is the source of the mismatch.
                    You can upgrade qvio server with opkg install voxl-qvio-server to fix the mismatch quickly but I would recommend just flashing back to the SDK 0.7 platform release since SDK 0.8 does not support TOF on VOXL1. The platform releases are tested as a whole an include a set of packages all known to work together. When individual packages get upgraded instead of the whole SDK together then things tend to break.
                    KrisK 2 Replies Last reply
                      KrisK Offline
                      KrisK Offline
                      Kris
                      @James-Strawson
                      Thank you, I will try this 👍
                        KrisK Offline
                        KrisK Offline
                        Kris
                        #71
                        @James-Strawson could you please help me with flashing back to SDK 0.7 or provide a link explaining how to flash back to a lower SDK?
                        This can be done over ssh right? Or do I need to ADB into voxl?
                          James Strawson
                          Instructions here: https://docs.modalai.com/flash-system-image/
                          The latest platform release for voxl1 is voxl_platform_3.8.0-0.7.tar available for download here https://developer.modalai.com/asset/1
                            KrisK Offline
                            KrisK Offline
                            Kris
                            @James-Strawson oh ok, now I remember 🤣
                            Cheers mate! 👍
                            • KrisK Offline
                              KrisK Offline
                              Kris
                              @Chad-Sweet @Adrian-Hidalgo @James-Strawson
                              Everything is working now! THANK YOU so much for all your help!!!
                              • KrisK Offline
                                KrisK Offline
                                Kris
                                #75
                                • KrisK Offline
                                  KrisK Offline
                                  Kris
                                  #76
                                  • KrisK Offline
                                    KrisK Offline
                                    Kris
                                    • KrisK Offline
                                      KrisK Offline
                                      Kris
                                      • D DavideColetti referenced this topic on
