  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 41.0k Views 2 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    voxl-inspect-points tof_ir
    timestamp(ms)| # points | # bytes |     1st point     | Format
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: 112726
    invalid metadata, magic number=0, expected 1448040524
    invalid metadata, magic number=1, expected 1448040524
    invalid metadata, magic number=65536, expected 1448040524
    invalid metadata, magic number=16842752, expected 1448040524
    invalid metadata, magic number=16777216, expected 1448040524
    invalid metadata, magic number=256, expected 1448040524
    invalid metadata, magic number=16777472, expected 1448040524
    invalid metadata, magic number=65537, expected 1448040524
    ^C
    received SIGINT Ctrl-C
    closing and exiting
    voxl-inspect-points tof_conf
    ^C
    closing and exiting
    voxl-inspect-points tof_depth
    ^C
    closing and exiting
    voxl-inspect-points qvio
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11172
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11178
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11174
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11173
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11170
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11171
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11177
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11175
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11176
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: -11179
    ^C
    closing and exiting
    voxl-inspect-points qvio_overlay
    ERROR in pipe_point_cloud_meta_to_size_bytes, invalid point cloud format: 356524
    ^C
    closing and exiting
    • KrisK Offline
      KrisK Offline
      Kris
      @Chad-Sweet
      So, what do you think the problem might be?
      I’ll be taking a more detailed look at PX4 next.
      If you feel that is where the issue is for the VIO.
      • KrisK Offline
        KrisK Offline
        Kris
        wrote on last edited by Kris
        #64
        @Chad-Sweet
        I really do appreciate you helping me with this.
        Thank you! 🙏
        • KrisK Offline
          KrisK Offline
          Kris
          If the problem is coming from PX4, how should I go about resolving it? Should I be speaking with PX4 support instead of ModalAi?
          • KrisK Offline
            KrisK Offline
            Kris
            #66
            @Chad-Sweet @Adrian-Hidalgo ,
            For PX4 confirmation, here is my voxl vision status.
            voxl:~$ systemctl status voxl-vision-px4 -l
            ● voxl-vision-px4.service - voxl-vision-px4
               Loaded: loaded (/usr/bin/voxl-vision-px4; enabled; vendor preset: enabled)
               Active: active (running) since Thu 1970-01-01 00:00:06 UTC; 52 years 8 months ago
             Main PID: 2073 (voxl-vision-px4)
               CGroup: /system.slice/voxl-vision-px4.service
                       └─2073 /usr/bin/voxl-vision-px4
            Sep 02 16:25:57 apq8096 voxl-vision-px4[2073]: ERROR validating VIO data received through pipe: read partial packet
            Sep 02 16:25:57 apq8096 voxl-vision-px4[2073]: read 156 bytes, but it should be a multiple of 324
            voxl:~$
            Could this be a time/clock, or a watchdog timer issue?
            • James StrawsonJ Offline
              James Strawson
              Hi Kris
              It looks like the voxl-vision-px4 and voxl-qvio-server versions have gotten out of sync, likely voxl-vision-px4 has been updated but voxl-qvio-server was not.
              Do you mind proving the output from the following 3 commands so I can check the state of the opkg package manager
              cat /etc/opkg/opkg.conf
              opkg info voxl-vision-px4
              opkg info voxl-qvio-server
              James
              KrisK 1 Reply Last reply
                Hi Kris
                James
                KrisK Offline
                KrisK Offline
                Kris
                #68
                Hi @James-Strawson , thank you. Here are the outputs you have requested.
                ## This file has been automatically generated.
                ## Please use voxl-configure-opkg to modify it.
                dest root /
                option lists_dir /var/lib/opkg/lists
                arch all 1
                arch arm64 7
                src/gz modalai http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64/
                voxl:~$ opkg info voxl-vision-px4
                Package: voxl-vision-px4
                Version: 1.2.0
                Depends: librc-math, libmodal-pipe (>= 2.4.0), libmodal-json, voxl-mpa-tools (>= 0.2.5), voxl-mavlink-server, libmodal-cv (>= 0.1.0)
                Section: base
                Architecture: arm64
                Maintainer: James Strawson <james@modalai.com>
                MD5Sum: 4bcff955596c2a5964d68cacf60d08a8
                Filename: voxl-vision-px4_1.2.0.ipk
                Description: Interface between VOXL's computer vision services and PX4
                Installed-Time: 1661276328
                voxl:~$ opkg info voxl-qvio-server
                Package: voxl-qvio-server
                Version: 0.7.1
                Depends: libmodal-pipe (>= 2.4.0), libmodal-json (>= 0.4.0), voxl-mpa-tools (>= 0.7.0)
                Section: base
                Architecture: arm64
                Maintainer: james@modalai.com
                MD5Sum: 2ccb793c2d7059217d9d32b54564352b
                Filename: voxl-qvio-server_0.7.1.ipk
                Description: publishes QVIO data over named pipe interface
                Version: 0.4.6
                Depends: libmodal-pipe (>= 2.0.0), libmodal-json (>= 0.4.0), voxl-mpa-tools
                Status: install ok installed
                Architecture: arm64
                Installed-Time: 6815
                qvio-server version 0.7.1 status: unknown ok not-installed
                voxl:~$ opkg list-installed | grep "libmodal"
                libmodal-cv - 0.1.0
                libmodal-exposure - 0.0.7
                libmodal-json - 0.4.2
                libmodal-pipe - 2.4.0
                  James Strawson
                  wrote on last edited by James Strawson
                  #69
                  Yes, It seems your installed voxl-vision-px4 and libmodal_pipe versions are from SDK 0.8 wheras your voxl-qvio-server is from SDK 0.7, that is the source of the mismatch.
                  You can upgrade qvio server with opkg install voxl-qvio-server to fix the mismatch quickly but I would recommend just flashing back to the SDK 0.7 platform release since SDK 0.8 does not support TOF on VOXL1. The platform releases are tested as a whole an include a set of packages all known to work together. When individual packages get upgraded instead of the whole SDK together then things tend to break.
                  KrisK 2 Replies Last reply
                    KrisK Offline
                    KrisK Offline
                    Kris
                    @James-Strawson
                    Thank you, I will try this 👍
                      KrisK Offline
                      KrisK Offline
                      Kris
                      #71
                      @James-Strawson could you please help me with flashing back to SDK 0.7 or provide a link explaining how to flash back to a lower SDK?
                      This can be done over ssh right? Or do I need to ADB into voxl?
                        James Strawson
                        Instructions here: https://docs.modalai.com/flash-system-image/
                        The latest platform release for voxl1 is voxl_platform_3.8.0-0.7.tar available for download here https://developer.modalai.com/asset/1
                          KrisK Offline
                          KrisK Offline
                          Kris
                          @James-Strawson oh ok, now I remember 🤣
                          Cheers mate! 👍
                          • KrisK Offline
                            KrisK Offline
                            Kris
                            @Chad-Sweet @Adrian-Hidalgo @James-Strawson
                            Everything is working now! THANK YOU so much for all your help!!!
                            • KrisK Offline
                              KrisK Offline
                              Kris
                              #75
                              • KrisK Offline
                                KrisK Offline
                                Kris
                                #76
                                • KrisK Offline
                                  KrisK Offline
                                  Kris
                                  • KrisK Offline
                                    KrisK Offline
                                    Kris
                                    • D DavideColetti referenced this topic on
