  3. MAVLink Odometry X Y value 0
78 Posts 4 Posters 43.6k Views 2 Watching
  • James StrawsonJ Offline
    James Strawson
    Hi Kris
    It looks like the voxl-vision-px4 and voxl-qvio-server versions have gotten out of sync, likely voxl-vision-px4 has been updated but voxl-qvio-server was not.
    Do you mind proving the output from the following 3 commands so I can check the state of the opkg package manager
    cat /etc/opkg/opkg.conf
    opkg info voxl-vision-px4
    opkg info voxl-qvio-server
    James
    KrisK 1 Reply Last reply
      Hi Kris
      James
      KrisK Offline
      KrisK Offline
      Kris
      wrote on last edited by Kris
      #68
      Hi @James-Strawson , thank you. Here are the outputs you have requested.
      ## This file has been automatically generated.
      ## Please use voxl-configure-opkg to modify it.
      dest root /
      option lists_dir /var/lib/opkg/lists
      arch all 1
      arch arm64 7
      src/gz modalai http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64/
      voxl:~$ opkg info voxl-vision-px4
      Package: voxl-vision-px4
      Version: 1.2.0
      Depends: librc-math, libmodal-pipe (>= 2.4.0), libmodal-json, voxl-mpa-tools (>= 0.2.5), voxl-mavlink-server, libmodal-cv (>= 0.1.0)
      Section: base
      Architecture: arm64
      Maintainer: James Strawson <james@modalai.com>
      MD5Sum: 4bcff955596c2a5964d68cacf60d08a8
      Filename: voxl-vision-px4_1.2.0.ipk
      Description: Interface between VOXL's computer vision services and PX4
      Installed-Time: 1661276328
      voxl:~$ opkg info voxl-qvio-server
      Package: voxl-qvio-server
      Version: 0.7.1
      Depends: libmodal-pipe (>= 2.4.0), libmodal-json (>= 0.4.0), voxl-mpa-tools (>= 0.7.0)
      Section: base
      Architecture: arm64
      Maintainer: james@modalai.com
      MD5Sum: 2ccb793c2d7059217d9d32b54564352b
      Filename: voxl-qvio-server_0.7.1.ipk
      Description: publishes QVIO data over named pipe interface
      Version: 0.4.6
      Depends: libmodal-pipe (>= 2.0.0), libmodal-json (>= 0.4.0), voxl-mpa-tools
      Status: install ok installed
      Architecture: arm64
      Installed-Time: 6815
      qvio-server version 0.7.1 status: unknown ok not-installed
      voxl:~$ opkg list-installed | grep "libmodal"
      libmodal-cv - 0.1.0
      libmodal-exposure - 0.0.7
      libmodal-json - 0.4.2
      libmodal-pipe - 2.4.0
        James Strawson
        wrote on last edited by James Strawson
        #69
        Yes, It seems your installed voxl-vision-px4 and libmodal_pipe versions are from SDK 0.8 wheras your voxl-qvio-server is from SDK 0.7, that is the source of the mismatch.
        You can upgrade qvio server with opkg install voxl-qvio-server to fix the mismatch quickly but I would recommend just flashing back to the SDK 0.7 platform release since SDK 0.8 does not support TOF on VOXL1. The platform releases are tested as a whole an include a set of packages all known to work together. When individual packages get upgraded instead of the whole SDK together then things tend to break.
        KrisK 2 Replies Last reply
          KrisK Offline
          KrisK Offline
          Kris
          @James-Strawson
          Thank you, I will try this 👍
            KrisK Offline
            KrisK Offline
            Kris
            #71
            @James-Strawson could you please help me with flashing back to SDK 0.7 or provide a link explaining how to flash back to a lower SDK?
            This can be done over ssh right? Or do I need to ADB into voxl?
              James Strawson
              Instructions here: https://docs.modalai.com/flash-system-image/
              The latest platform release for voxl1 is voxl_platform_3.8.0-0.7.tar available for download here https://developer.modalai.com/asset/1
                KrisK Offline
                KrisK Offline
                Kris
                @James-Strawson oh ok, now I remember 🤣
                Cheers mate! 👍
                • KrisK Offline
                  KrisK Offline
                  Kris
                  @Chad-Sweet @Adrian-Hidalgo @James-Strawson
                  Everything is working now! THANK YOU so much for all your help!!!
                  • KrisK Offline
                    KrisK Offline
                    Kris
                    #75
                    • KrisK Offline
                      KrisK Offline
                      Kris
                      #76
                      • KrisK Offline
                        KrisK Offline
                        Kris
                        • KrisK Offline
                          KrisK Offline
                          Kris
                          • D DavideColetti referenced this topic on
