  3. Streaming Stereo Camera
21 Posts 4 Posters 6.3k Views 3 Watching
  • KrisK Kris
    I am not able to view any video when executing the voxl-mavcam-manager either.
    voxl:~$ voxl-mavcam-manager
    snapshot_pipe_name:        tracking
    video_record_pipe_name:    tracking
    default_uri:               rtsp://192.168.110.152:8900/live
    enable_auto_ip:            1
    Camera name for qgc: Camera 0
    Mavlink server Connected
    Got camera information request
    auto-detected RTSP URI: rtsp://192.168.110.152:8900/live
    KrisK Offline
    KrisK Offline
    Kris
    • KrisK Kris
      @Kris Again, you've ran through voxl-configure-sku and voxl-configure-mpa there is no reason to start a service manually. In your first post you could see that voxl-mavcam-manager was already running as a service.
      What do your video stream settings look like in QGC? Do you have it setup correctly to expect an rtsp stream?
      KrisK 1 Reply Last reply
        KrisK Offline
        KrisK Offline
        Kris
        Yes, I have ran through the voxl-configure-sku and the voxl-configure-mpa.
        This is what my video stream seetings look like in QGC, if its the correct location.
        • KrisK Kris
          The video stream settings are under "General", you'll want to enter the RTSP URI there
          KrisK 3 Replies Last reply
            KrisK Offline
            KrisK Offline
            Kris
            @tom Thank you so much, I just found it and I will try it.
              KrisK Offline
              KrisK Offline
              Kris
              I am sorry, it is still not working....
              • KrisK Kris
                KrisK Offline
                KrisK Offline
                Kris
                  KrisK Offline
                  KrisK Offline
                  Kris
                  • KrisK Kris
                    @Kris What do you see with systemctl status voxl-streamer?
                    KrisK 4 Replies Last reply
                      KrisK Offline
                      KrisK Offline
                      Kris
                      wrote on last edited by Kris
                      #16
                      @tom This is what I see.
                      voxl:~$ systemctl status voxl-streamer
                      ● voxl-streamer.service - voxl-streamer
                         Loaded: loaded (/usr/bin/voxl-streamer; enabled; vendor preset: enabled)
                         Active: active (running) since Tue 2024-03-05 01:18:42 UTC; 13min ago
                        Process: 17793 ExecStartPre=/bin/sleep 5 (code=exited, status=0/SUCCESS)
                       Main PID: 17800 (voxl-streamer)
                         CGroup: /system.slice/voxl-streamer.service
                                 └─17800 /usr/bin/voxl-streamer
                      Mar 05 01:31:34 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.11...1
                      Mar 05 01:31:34 apq8096 voxl-streamer[17800]: Camera server Connected
                      Mar 05 01:31:34 apq8096 voxl-streamer[17800]: rtsp client disconnected, tota...0
                      Mar 05 01:31:34 apq8096 voxl-streamer[17800]: no more rtsp clients, closing ...y
                      Hint: Some lines were ellipsized, use -l to show in full.
                      voxl:~$ systemctl status voxl-streamer -l
                         Active: active (running) since Tue 2024-03-05 01:18:42 UTC; 14min ago
                      Mar 05 01:33:33 apq8096 voxl-streamer[17800]: no more rtsp clients, closing source pipe intentionally
                      Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48596(null) has connected, total clients: 1
                      Mar 05 01:33:33 apq8096 voxl-streamer[17800]: Camera server Connected
                      Mar 05 01:33:33 apq8096 voxl-streamer[17800]: rtsp client disconnected, total clients: 0
                      Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48604(null) has connected, total clients: 1
                      Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48606(null) has connected, total clients: 1
                        KrisK Offline
                        KrisK Offline
                        Kris
                        voxl:~$ systemctl status voxl-mavcam-manager -l
                        ● voxl-mavcam-manager.service - voxl-mavcam-manager
                           Loaded: loaded (/usr/bin/voxl-mavcam-manager; enabled; vendor preset: enabled)
                           Active: failed (Result: signal) since Tue 2024-03-05 01:18:39 UTC; 20min ago
                          Process: 17657 ExecStart=/bin/bash -c /usr/bin/voxl-mavcam-manager (code=killed, signal=ABRT)
                         Main PID: 17657 (code=killed, signal=ABRT)
                        Mar 05 01:18:39 apq8096 bash[17657]: snapshot_pipe_name:        tracking
                        Mar 05 01:18:39 apq8096 bash[17657]: video_record_pipe_name:    tracking
                        Mar 05 01:18:39 apq8096 bash[17657]: default_uri:               rtsp://192.168.110.152:8900/live
                        Mar 05 01:18:39 apq8096 bash[17657]: enable_auto_ip:            0
                        Mar 05 01:18:39 apq8096 bash[17657]: =================================================================
                        Mar 05 01:18:39 apq8096 bash[17657]: Camera name for qgc: Camera 0
                        Mar 05 01:18:39 apq8096 bash[17657]: Mavlink server Connected
                        Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Main process exited, code=killed, status=6/ABRT
                        Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Unit entered failed state.
                        Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Failed with result 'signal'.
                          KrisK Offline
                          KrisK Offline
                          Kris
                          voxl:~$ voxl-inspect-sku
                          family code:   MRB-D0003 (seeker)
                          compute board: 1 (voxl1)
                          hw version:    7
                          cam config:    7
                          SKU:           MRB-D0003-1-V7-C7
                            KrisK Offline
                            KrisK Offline
                            Kris
                            voxl-inspect-mavlink mavlink_sys_status
                            |   ID  |      Mavlink MSG Name       |Counter|  Hz  |
                            |     1 | sys_status                  |    92 |  5.0 |
                            • KrisK Kris
                              #20
                              @Kris , please try the following:
                              • verify the ip address of voxl2
                                • when you adb into voxl2, the ip address is printed
                                • you can use ifconfig to check the ip address
                              • make sure voxl-streamer is running (it looks like it is based on output of systemctl status voxl-streamer
                              • ping your voxl2 ip from your host machine (just to make sure it can reach voxl2)
                              • download ffmpeg / ffplay to your host machine
                                • perhaps something in VLC is not working, but ffmpeg / ffplay usually works
                                • on linux OS should be able to do it using apt-get ffmpeg
                                • for other OS you can find direct download : https://www.ffmpeg.org/download.html
                              play the video on the host machine (replace voxl2-ip with actual ip address)
                              ffplay rtsp://<voxl2-ip>:8900/live
                              ModeratorM 1 Reply Last reply
                                Typically hires is the only pipe with encoding enabled by default, but in this case tracking is being used. Can you make sure encoding is enabled for the tracking camera in voxl-camera-server.conf ?
                                Or, can you just see if hires_enc is working in QGC first? That's what we ship by default on a fresh install hires_enc to QGC should by enabled by default.
