  3. Streaming Stereo Camera
21 Posts 4 Posters 6.9k Views 3 Watching
  • KrisK Kris
    @tom Thank you for your reply.
    This is what I have setup in my voxl-streamer.conf
            "input-pipe":   "tracking",
            "bitrate":      1000000,
            "rotation":     0,
            "decimator":    1,
            "port": 8900
    The services that are running are;
    voxl:~$ voxl-inspect-services
    Scanning services...
     Service Name             |  Enabled  |   Running   |  CPU Usage
     docker-autorun           | Disabled  | Not Running |
     docker-daemon            | Disabled  | Not Running |
     modallink-relink         | Disabled  | Not Running |
     voxl-camera-server       |  Enabled  |   Running   |     5.1%
     voxl-cpu-monitor         |  Enabled  |   Running   |     1.7%
     voxl-dfs-server          | Disabled  | Not Running |
     voxl-imu-server          |  Enabled  |   Running   |     0.0%
     voxl-lepton-server       | Disabled  | Not Running |
     voxl-mavcam-manager      |  Enabled  |   Running   |     1.7%
     voxl-mavlink-server      |  Enabled  |   Running   |     5.1%
     voxl-modem               | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.0%
     voxl-qvio-server         |  Enabled  |   Running   |     6.8%
     voxl-rangefinder-server  | Disabled  | Not Running |
     voxl-remote-id           | Disabled  | Not Running |
     voxl-streamer            |  Enabled  |   Running   |     0.0%
     voxl-tag-detector        | Disabled  | Not Running |
     voxl-tflite-server       | Disabled  | Not Running |
     voxl-time-sync           | Disabled  | Not Running |
     voxl-uvc-server          | Disabled  | Not Running |
     voxl-vision-hub          |  Enabled  |   Running   |     3.4%
     voxl-wait-for-fs         |  Enabled  |  Completed  |
    My vision-hub.conf
            "config_file_version":  1,
            "en_localhost_mavlink_udp":     false,
            "en_vio":       true,
            "vio_pipe":     "qvio",
            "secondary_vio_pipe":   "ov",
            "vio_warmup_s": 3,
            "send_odom_while_failed":       true,
            "horizon_cal_tolerance":        0.5,
            "offboard_mode":        "trajectory",
            "follow_tag_id":        0,
            "figure_eight_move_home":       false,
            "robot_radius": 0.300000011920929,
            "collision_sampling_dt":        0.1,
            "max_lookahead_distance":       1,
            "en_tag_fixed_frame":   false,
            "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
            "en_voa":       true,
            "voa_upper_bound_m":    -0.15000000596046448,
            "voa_lower_bound_m":    0.15000000596046448,
            "voa_voa_memory_s":     1,
            "voa_max_pc_per_fusion":        100,
            "voa_pie_max_dist_m":   20,
            "voa_pie_min_dist_m":   0.25,
            "voa_pie_under_trim_m": 1,
            "voa_pie_threshold":    3,
            "voa_send_rate_hz":     20,
            "voa_pie_slices":       36,
            "voa_pie_bin_depth_m":  0.15000000596046448,
            "voa_inputs":   [{
                            "enabled":      true,
                            "type": "point_cloud",
                            "input_pipe":   "dfs_point_cloud",
                            "frame":        "stereo_l",
                            "max_depth":    8,
                            "min_depth":    0.300000011920929,
                            "cell_size":    0.079999998211860657,
                            "threshold":    4,
                            "x_fov_deg":    68,
                            "y_fov_deg":    56,
                            "conf_cutoff":  0
                            "enabled":      true,
                            "input_pipe":   "stereo_front_pc",
                            "frame":        "stereo_front_l",
                            "max_depth":    8,
                            "threshold":    4,
                            "x_fov_deg":    68,
                            "y_fov_deg":    56,
                            "conf_cutoff":  0
                            "enabled":      true,
                            "input_pipe":   "stereo_rear_pc",
                            "frame":        "stereo_rear_l",
                            "max_depth":    8,
                            "threshold":    4,
                            "x_fov_deg":    68,
                            "y_fov_deg":    56,
                            "conf_cutoff":  0
                            "enabled":      true,
                            "type": "tof",
                            "input_pipe":   "tof",
                            "frame":        "tof",
                            "max_depth":    6,
                            "min_depth":    0.15000000596046448,
                            "threshold":    3,
                            "x_fov_deg":    106.5,
                            "y_fov_deg":    85.0999984741211,
                            "conf_cutoff":  125
                            "enabled":      true,
                            "type": "rangefinder",
                            "input_pipe":   "rangefinders",
                            "frame":        "body",
                            "max_depth":    8,
                            "threshold":    4,
                            "x_fov_deg":    68,
                            "y_fov_deg":    56,
                            "conf_cutoff":  0
    Then when I go to run voxl-streamer, it works at first but when I open VLC it does not work.
    voxl:~$ voxl-streamer -i tracking
    existing instance of voxl-streamer found, attempting to stop it
    Waiting for pipe tracking to appear
    Found Pipe
    detected following stats from pipe:
    w: 640 h: 480 fps: 30 format: RAW8
    Stream available at rtsp://127.0.0.1:8900/live
    A new client rtsp://192.168.110.159:40472(null) has connected, total clients: 1
    Camera server Connected
    ERROR:   New frame rejected, status = -2
    rtsp client disconnected, total clients: 0
    no more rtsp clients, closing source pipe intentionally
    (voxl-streamer:3746): GLib-GObject-WARNING **: instance with invalid (NULL) class pointer
    (voxl-streamer:3746): GLib-GObject-CRITICAL **: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    A new client rtsp://192.168.110.159:40484(null) has connected, total clients: 1
    WARNING, _stop_helper_and_remove_pipe timed out joining read thread
    A new client rtsp://192.168.110.159:60720(null) has connected, total clients: 1
    I am not sure why I am not able to do this.
    192.168.110.152 is my current Seeker IP.
    192.168.110.159 is my current host PC IP.
    What I would really like to do is connect my stereo stream with QGroundControl instead of VLC. But I haven't even gotten VLC to stream it yet....
    @Kris It looks like voxl-streamer is already running in the background and then you're running it again in the terminal manually, hence the existing instance of voxl-streamer found, attempting to stop it
    You should be able to pull up the stream if the service is running, no need to run it manually like that
    KrisK 1 Reply Last reply
      KrisK Offline
      KrisK Offline
      Kris
      wrote on last edited by Kris
      @tom Thank you.
      I tried it again without manually running voxl-streamer.
      First I made sure it was on by inspecting my services.
      When I confirmed that it was on, I tried to input the rtsp:// in the Open Network Stream in VLC, but it failed.
      Here is the error message in VLC
      Connection failed:
      VLC could not connect to "192.168.110.152:8900".
      Your input can't be opened:
      VLC is unable to open the MRL 'rtsp://192.168.110.152:8900/live'. Check the log for details.
      Connection failed:
      VLC could not connect to "127.0.0.1:8900".
      VLC is unable to open the MRL 'rtsp://127.0.0.1:8900/live'. Check the log for details.
      Connection failed:
      VLC could not connect to "192.168.110.159:8900".
      VLC is unable to open the MRL 'rtsp://192.168.110.159:8900/live'. Check the log for details.
      Can you confirm that I should be using the rtsp://192.168.110.152:8900/live for the VLC network stream?
      Or should it be rtsp://127.0.0.1:8900/live ?
      Found Pipe
      Here is my settings in voxl-mavcam-manager
              "snapshot_pipe_name":   "tracking",
              "video_record_pipe_name":       "tracking",
              "default_uri":  "rtsp://192.168.110.152:8900/live",
              "enable_auto_ip":       true
      • KrisK Kris
        @tom Thank you.
        Connection failed:
        Connection failed:
        Connection failed:
        Found Pipe
        KrisK Offline
        KrisK Offline
        Kris
        I am not able to view any video when executing the voxl-mavcam-manager either.
        voxl:~$ voxl-mavcam-manager
        snapshot_pipe_name:        tracking
        video_record_pipe_name:    tracking
        default_uri:               rtsp://192.168.110.152:8900/live
        enable_auto_ip:            1
        Camera name for qgc: Camera 0
        Mavlink server Connected
        Got camera information request
        auto-detected RTSP URI: rtsp://192.168.110.152:8900/live
        • KrisK Kris
          enable_auto_ip:            1
          KrisK Offline
          KrisK Offline
          Kris
          • KrisK Kris
            @Kris Again, you've ran through voxl-configure-sku and voxl-configure-mpa there is no reason to start a service manually. In your first post you could see that voxl-mavcam-manager was already running as a service.
            What do your video stream settings look like in QGC? Do you have it setup correctly to expect an rtsp stream?
              KrisK Offline
              KrisK Offline
              Kris
              Yes, I have ran through the voxl-configure-sku and the voxl-configure-mpa.
              This is what my video stream seetings look like in QGC, if its the correct location.
              • KrisK Kris
                The video stream settings are under "General", you'll want to enter the RTSP URI there
                KrisK 3 Replies Last reply
                  KrisK Offline
                  KrisK Offline
                  Kris
                  @tom Thank you so much, I just found it and I will try it.
                    KrisK Offline
                    KrisK Offline
                    Kris
                    I am sorry, it is still not working....
                    • KrisK Kris
                      KrisK Offline
                      KrisK Offline
                      Kris
                        KrisK Offline
                        KrisK Offline
                        Kris
                        • KrisK Kris
                          @Kris What do you see with systemctl status voxl-streamer?
                          KrisK 4 Replies Last reply
                            KrisK Offline
                            KrisK Offline
                            Kris
                            #16
                            @tom This is what I see.
                            voxl:~$ systemctl status voxl-streamer
                            ● voxl-streamer.service - voxl-streamer
                               Loaded: loaded (/usr/bin/voxl-streamer; enabled; vendor preset: enabled)
                               Active: active (running) since Tue 2024-03-05 01:18:42 UTC; 13min ago
                              Process: 17793 ExecStartPre=/bin/sleep 5 (code=exited, status=0/SUCCESS)
                             Main PID: 17800 (voxl-streamer)
                               CGroup: /system.slice/voxl-streamer.service
                                       └─17800 /usr/bin/voxl-streamer
                            Mar 05 01:31:34 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.11...1
                            Mar 05 01:31:34 apq8096 voxl-streamer[17800]: Camera server Connected
                            Mar 05 01:31:34 apq8096 voxl-streamer[17800]: rtsp client disconnected, tota...0
                            Mar 05 01:31:34 apq8096 voxl-streamer[17800]: no more rtsp clients, closing ...y
                            Hint: Some lines were ellipsized, use -l to show in full.
                            voxl:~$ systemctl status voxl-streamer -l
                               Active: active (running) since Tue 2024-03-05 01:18:42 UTC; 14min ago
                            Mar 05 01:33:33 apq8096 voxl-streamer[17800]: no more rtsp clients, closing source pipe intentionally
                            Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48596(null) has connected, total clients: 1
                            Mar 05 01:33:33 apq8096 voxl-streamer[17800]: Camera server Connected
                            Mar 05 01:33:33 apq8096 voxl-streamer[17800]: rtsp client disconnected, total clients: 0
                            Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48604(null) has connected, total clients: 1
                            Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48606(null) has connected, total clients: 1
                              KrisK Offline
                              KrisK Offline
                              Kris
                              voxl:~$ systemctl status voxl-mavcam-manager -l
                              ● voxl-mavcam-manager.service - voxl-mavcam-manager
                                 Loaded: loaded (/usr/bin/voxl-mavcam-manager; enabled; vendor preset: enabled)
                                 Active: failed (Result: signal) since Tue 2024-03-05 01:18:39 UTC; 20min ago
                                Process: 17657 ExecStart=/bin/bash -c /usr/bin/voxl-mavcam-manager (code=killed, signal=ABRT)
                               Main PID: 17657 (code=killed, signal=ABRT)
                              Mar 05 01:18:39 apq8096 bash[17657]: snapshot_pipe_name:        tracking
                              Mar 05 01:18:39 apq8096 bash[17657]: video_record_pipe_name:    tracking
                              Mar 05 01:18:39 apq8096 bash[17657]: default_uri:               rtsp://192.168.110.152:8900/live
                              Mar 05 01:18:39 apq8096 bash[17657]: enable_auto_ip:            0
                              Mar 05 01:18:39 apq8096 bash[17657]: =================================================================
                              Mar 05 01:18:39 apq8096 bash[17657]: Camera name for qgc: Camera 0
                              Mar 05 01:18:39 apq8096 bash[17657]: Mavlink server Connected
                              Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Main process exited, code=killed, status=6/ABRT
                              Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Unit entered failed state.
                              Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Failed with result 'signal'.
                                KrisK Offline
                                KrisK Offline
                                Kris
                                voxl:~$ voxl-inspect-sku
                                family code:   MRB-D0003 (seeker)
                                compute board: 1 (voxl1)
                                hw version:    7
                                cam config:    7
                                SKU:           MRB-D0003-1-V7-C7
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  voxl-inspect-mavlink mavlink_sys_status
                                  |   ID  |      Mavlink MSG Name       |Counter|  Hz  |
                                  |     1 | sys_status                  |    92 |  5.0 |
                                  • KrisK Kris
                                    #20
                                    @Kris , please try the following:
                                    • verify the ip address of voxl2
                                      • when you adb into voxl2, the ip address is printed
                                      • you can use ifconfig to check the ip address
                                    • make sure voxl-streamer is running (it looks like it is based on output of systemctl status voxl-streamer
                                    • ping your voxl2 ip from your host machine (just to make sure it can reach voxl2)
                                    • download ffmpeg / ffplay to your host machine
                                      • perhaps something in VLC is not working, but ffmpeg / ffplay usually works
                                      • on linux OS should be able to do it using apt-get ffmpeg
                                      • for other OS you can find direct download : https://www.ffmpeg.org/download.html
                                    play the video on the host machine (replace voxl2-ip with actual ip address)
                                    ffplay rtsp://<voxl2-ip>:8900/live
                                    ModeratorM 1 Reply Last reply
                                      Typically hires is the only pipe with encoding enabled by default, but in this case tracking is being used. Can you make sure encoding is enabled for the tracking camera in voxl-camera-server.conf ?
                                      Or, can you just see if hires_enc is working in QGC first? That's what we ship by default on a fresh install hires_enc to QGC should by enabled by default.
