  3. Streaming Stereo Camera
21 Posts 4 Posters 6.3k Views 3 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    Is it possible to stream a stereo/tracking camera on the Seeker (SDK 1.1.2) with voxl-streamer?
    • KrisK Kris
      @Kris Yes, take a look at /etc/modalai/voxl-streamer.conf for more info
      KrisK 1 Reply Last reply
        KrisK Offline
        KrisK Offline
        Kris
        wrote on last edited by Kris
        @tom Thank you for your reply.
        This is what I have setup in my voxl-streamer.conf
                "input-pipe":   "tracking",
                "bitrate":      1000000,
                "rotation":     0,
                "decimator":    1,
                "port": 8900
        The services that are running are;
        voxl:~$ voxl-inspect-services
        Scanning services...
         Service Name             |  Enabled  |   Running   |  CPU Usage
         docker-autorun           | Disabled  | Not Running |
         docker-daemon            | Disabled  | Not Running |
         modallink-relink         | Disabled  | Not Running |
         voxl-camera-server       |  Enabled  |   Running   |     5.1%
         voxl-cpu-monitor         |  Enabled  |   Running   |     1.7%
         voxl-dfs-server          | Disabled  | Not Running |
         voxl-imu-server          |  Enabled  |   Running   |     0.0%
         voxl-lepton-server       | Disabled  | Not Running |
         voxl-mavcam-manager      |  Enabled  |   Running   |     1.7%
         voxl-mavlink-server      |  Enabled  |   Running   |     5.1%
         voxl-modem               | Disabled  | Not Running |
         voxl-portal              |  Enabled  |   Running   |     0.0%
         voxl-qvio-server         |  Enabled  |   Running   |     6.8%
         voxl-rangefinder-server  | Disabled  | Not Running |
         voxl-remote-id           | Disabled  | Not Running |
         voxl-streamer            |  Enabled  |   Running   |     0.0%
         voxl-tag-detector        | Disabled  | Not Running |
         voxl-tflite-server       | Disabled  | Not Running |
         voxl-time-sync           | Disabled  | Not Running |
         voxl-uvc-server          | Disabled  | Not Running |
         voxl-vision-hub          |  Enabled  |   Running   |     3.4%
         voxl-wait-for-fs         |  Enabled  |  Completed  |
        My vision-hub.conf
                "config_file_version":  1,
                "en_localhost_mavlink_udp":     false,
                "en_vio":       true,
                "vio_pipe":     "qvio",
                "secondary_vio_pipe":   "ov",
                "vio_warmup_s": 3,
                "send_odom_while_failed":       true,
                "horizon_cal_tolerance":        0.5,
                "offboard_mode":        "trajectory",
                "follow_tag_id":        0,
                "figure_eight_move_home":       false,
                "robot_radius": 0.300000011920929,
                "collision_sampling_dt":        0.1,
                "max_lookahead_distance":       1,
                "en_tag_fixed_frame":   false,
                "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
                "en_voa":       true,
                "voa_upper_bound_m":    -0.15000000596046448,
                "voa_lower_bound_m":    0.15000000596046448,
                "voa_voa_memory_s":     1,
                "voa_max_pc_per_fusion":        100,
                "voa_pie_max_dist_m":   20,
                "voa_pie_min_dist_m":   0.25,
                "voa_pie_under_trim_m": 1,
                "voa_pie_threshold":    3,
                "voa_send_rate_hz":     20,
                "voa_pie_slices":       36,
                "voa_pie_bin_depth_m":  0.15000000596046448,
                "voa_inputs":   [{
                                "enabled":      true,
                                "type": "point_cloud",
                                "input_pipe":   "dfs_point_cloud",
                                "frame":        "stereo_l",
                                "max_depth":    8,
                                "min_depth":    0.300000011920929,
                                "cell_size":    0.079999998211860657,
                                "threshold":    4,
                                "x_fov_deg":    68,
                                "y_fov_deg":    56,
                                "conf_cutoff":  0
                                "enabled":      true,
                                "input_pipe":   "stereo_front_pc",
                                "frame":        "stereo_front_l",
                                "max_depth":    8,
                                "threshold":    4,
                                "x_fov_deg":    68,
                                "y_fov_deg":    56,
                                "conf_cutoff":  0
                                "enabled":      true,
                                "input_pipe":   "stereo_rear_pc",
                                "frame":        "stereo_rear_l",
                                "max_depth":    8,
                                "threshold":    4,
                                "x_fov_deg":    68,
                                "y_fov_deg":    56,
                                "conf_cutoff":  0
                                "enabled":      true,
                                "type": "tof",
                                "input_pipe":   "tof",
                                "frame":        "tof",
                                "max_depth":    6,
                                "min_depth":    0.15000000596046448,
                                "threshold":    3,
                                "x_fov_deg":    106.5,
                                "y_fov_deg":    85.0999984741211,
                                "conf_cutoff":  125
                                "enabled":      true,
                                "type": "rangefinder",
                                "input_pipe":   "rangefinders",
                                "frame":        "body",
                                "max_depth":    8,
                                "threshold":    4,
                                "x_fov_deg":    68,
                                "y_fov_deg":    56,
                                "conf_cutoff":  0
        Then when I go to run voxl-streamer, it works at first but when I open VLC it does not work.
        voxl:~$ voxl-streamer -i tracking
        existing instance of voxl-streamer found, attempting to stop it
        Waiting for pipe tracking to appear
        Found Pipe
        detected following stats from pipe:
        w: 640 h: 480 fps: 30 format: RAW8
        Stream available at rtsp://127.0.0.1:8900/live
        A new client rtsp://192.168.110.159:40472(null) has connected, total clients: 1
        Camera server Connected
        ERROR:   New frame rejected, status = -2
        rtsp client disconnected, total clients: 0
        no more rtsp clients, closing source pipe intentionally
        (voxl-streamer:3746): GLib-GObject-WARNING **: instance with invalid (NULL) class pointer
        (voxl-streamer:3746): GLib-GObject-CRITICAL **: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
        A new client rtsp://192.168.110.159:40484(null) has connected, total clients: 1
        WARNING, _stop_helper_and_remove_pipe timed out joining read thread
        A new client rtsp://192.168.110.159:60720(null) has connected, total clients: 1
        I am not sure why I am not able to do this.
        192.168.110.152 is my current Seeker IP.
        192.168.110.159 is my current host PC IP.
        What I would really like to do is connect my stereo stream with QGroundControl instead of VLC. But I haven't even gotten VLC to stream it yet....
        • KrisK Kris
                  "bitrate":      1000000,
                  "rotation":     0,
                  "decimator":    1,
                  "port": 8900
          My vision-hub.conf
                  "en_vio":       true,
                  "vio_pipe":     "qvio",
                  "vio_warmup_s": 3,
                  "follow_tag_id":        0,
                  "en_voa":       true,
                  "voa_inputs":   [{
                                  "enabled":      true,
                                  "max_depth":    8,
                                  "threshold":    4,
                                  "x_fov_deg":    68,
                                  "y_fov_deg":    56,
                                  "conf_cutoff":  0
                                  "enabled":      true,
                                  "max_depth":    8,
                                  "threshold":    4,
                                  "x_fov_deg":    68,
                                  "y_fov_deg":    56,
                                  "conf_cutoff":  0
                                  "enabled":      true,
                                  "max_depth":    8,
                                  "threshold":    4,
                                  "x_fov_deg":    68,
                                  "y_fov_deg":    56,
                                  "conf_cutoff":  0
                                  "enabled":      true,
                                  "type": "tof",
                                  "frame":        "tof",
                                  "max_depth":    6,
                                  "threshold":    3,
                                  "x_fov_deg":    106.5,
                                  "conf_cutoff":  125
                                  "enabled":      true,
                                  "frame":        "body",
                                  "max_depth":    8,
                                  "threshold":    4,
                                  "x_fov_deg":    68,
                                  "y_fov_deg":    56,
                                  "conf_cutoff":  0
          Found Pipe
          @Kris It looks like voxl-streamer is already running in the background and then you're running it again in the terminal manually, hence the existing instance of voxl-streamer found, attempting to stop it
          You should be able to pull up the stream if the service is running, no need to run it manually like that
            KrisK Offline
            KrisK Offline
            Kris
            @tom Thank you.
            I tried it again without manually running voxl-streamer.
            First I made sure it was on by inspecting my services.
            When I confirmed that it was on, I tried to input the rtsp:// in the Open Network Stream in VLC, but it failed.
            Here is the error message in VLC
            Connection failed:
            VLC could not connect to "192.168.110.152:8900".
            Your input can't be opened:
            VLC is unable to open the MRL 'rtsp://192.168.110.152:8900/live'. Check the log for details.
            Connection failed:
            VLC could not connect to "127.0.0.1:8900".
            VLC is unable to open the MRL 'rtsp://127.0.0.1:8900/live'. Check the log for details.
            Connection failed:
            VLC could not connect to "192.168.110.159:8900".
            VLC is unable to open the MRL 'rtsp://192.168.110.159:8900/live'. Check the log for details.
            Can you confirm that I should be using the rtsp://192.168.110.152:8900/live for the VLC network stream?
            Or should it be rtsp://127.0.0.1:8900/live ?
            Found Pipe
            Here is my settings in voxl-mavcam-manager
                    "snapshot_pipe_name":   "tracking",
                    "video_record_pipe_name":       "tracking",
                    "default_uri":  "rtsp://192.168.110.152:8900/live",
                    "enable_auto_ip":       true
            • KrisK Kris
              @tom Thank you.
              Connection failed:
              Connection failed:
              Connection failed:
              Found Pipe
              KrisK Offline
              KrisK Offline
              Kris
              I am not able to view any video when executing the voxl-mavcam-manager either.
              voxl:~$ voxl-mavcam-manager
              snapshot_pipe_name:        tracking
              video_record_pipe_name:    tracking
              default_uri:               rtsp://192.168.110.152:8900/live
              enable_auto_ip:            1
              Camera name for qgc: Camera 0
              Mavlink server Connected
              Got camera information request
              auto-detected RTSP URI: rtsp://192.168.110.152:8900/live
              • KrisK Kris
                enable_auto_ip:            1
                KrisK Offline
                KrisK Offline
                Kris
                • KrisK Kris
                  @Kris Again, you've ran through voxl-configure-sku and voxl-configure-mpa there is no reason to start a service manually. In your first post you could see that voxl-mavcam-manager was already running as a service.
                  What do your video stream settings look like in QGC? Do you have it setup correctly to expect an rtsp stream?
                    KrisK Offline
                    KrisK Offline
                    Kris
                    Yes, I have ran through the voxl-configure-sku and the voxl-configure-mpa.
                    This is what my video stream seetings look like in QGC, if its the correct location.
                    • KrisK Kris
                      The video stream settings are under "General", you'll want to enter the RTSP URI there
                      KrisK 3 Replies Last reply
                        KrisK Offline
                        KrisK Offline
                        Kris
                        @tom Thank you so much, I just found it and I will try it.
                          KrisK Offline
                          KrisK Offline
                          Kris
                          I am sorry, it is still not working....
                          • KrisK Kris
                            KrisK Offline
                            KrisK Offline
                            Kris
                              KrisK Offline
                              KrisK Offline
                              Kris
                              • KrisK Kris
                                @Kris What do you see with systemctl status voxl-streamer?
                                KrisK 4 Replies Last reply
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  #16
                                  @tom This is what I see.
                                  voxl:~$ systemctl status voxl-streamer
                                  ● voxl-streamer.service - voxl-streamer
                                     Loaded: loaded (/usr/bin/voxl-streamer; enabled; vendor preset: enabled)
                                     Active: active (running) since Tue 2024-03-05 01:18:42 UTC; 13min ago
                                    Process: 17793 ExecStartPre=/bin/sleep 5 (code=exited, status=0/SUCCESS)
                                   Main PID: 17800 (voxl-streamer)
                                     CGroup: /system.slice/voxl-streamer.service
                                             └─17800 /usr/bin/voxl-streamer
                                  Mar 05 01:31:34 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.11...1
                                  Mar 05 01:31:34 apq8096 voxl-streamer[17800]: Camera server Connected
                                  Mar 05 01:31:34 apq8096 voxl-streamer[17800]: rtsp client disconnected, tota...0
                                  Mar 05 01:31:34 apq8096 voxl-streamer[17800]: no more rtsp clients, closing ...y
                                  Hint: Some lines were ellipsized, use -l to show in full.
                                  voxl:~$ systemctl status voxl-streamer -l
                                     Active: active (running) since Tue 2024-03-05 01:18:42 UTC; 14min ago
                                  Mar 05 01:33:33 apq8096 voxl-streamer[17800]: no more rtsp clients, closing source pipe intentionally
                                  Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48596(null) has connected, total clients: 1
                                  Mar 05 01:33:33 apq8096 voxl-streamer[17800]: Camera server Connected
                                  Mar 05 01:33:33 apq8096 voxl-streamer[17800]: rtsp client disconnected, total clients: 0
                                  Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48604(null) has connected, total clients: 1
                                  Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48606(null) has connected, total clients: 1
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    voxl:~$ systemctl status voxl-mavcam-manager -l
                                    ● voxl-mavcam-manager.service - voxl-mavcam-manager
                                       Loaded: loaded (/usr/bin/voxl-mavcam-manager; enabled; vendor preset: enabled)
                                       Active: failed (Result: signal) since Tue 2024-03-05 01:18:39 UTC; 20min ago
                                      Process: 17657 ExecStart=/bin/bash -c /usr/bin/voxl-mavcam-manager (code=killed, signal=ABRT)
                                     Main PID: 17657 (code=killed, signal=ABRT)
                                    Mar 05 01:18:39 apq8096 bash[17657]: snapshot_pipe_name:        tracking
                                    Mar 05 01:18:39 apq8096 bash[17657]: video_record_pipe_name:    tracking
                                    Mar 05 01:18:39 apq8096 bash[17657]: default_uri:               rtsp://192.168.110.152:8900/live
                                    Mar 05 01:18:39 apq8096 bash[17657]: enable_auto_ip:            0
                                    Mar 05 01:18:39 apq8096 bash[17657]: =================================================================
                                    Mar 05 01:18:39 apq8096 bash[17657]: Camera name for qgc: Camera 0
                                    Mar 05 01:18:39 apq8096 bash[17657]: Mavlink server Connected
                                    Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Main process exited, code=killed, status=6/ABRT
                                    Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Unit entered failed state.
                                    Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Failed with result 'signal'.
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      voxl:~$ voxl-inspect-sku
                                      family code:   MRB-D0003 (seeker)
                                      compute board: 1 (voxl1)
                                      hw version:    7
                                      cam config:    7
                                      SKU:           MRB-D0003-1-V7-C7
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        voxl-inspect-mavlink mavlink_sys_status
                                        |   ID  |      Mavlink MSG Name       |Counter|  Hz  |
                                        |     1 | sys_status                  |    92 |  5.0 |
                                        • KrisK Kris
                                          #20
                                          @Kris , please try the following:
                                          • verify the ip address of voxl2
                                            • when you adb into voxl2, the ip address is printed
                                            • you can use ifconfig to check the ip address
                                          • make sure voxl-streamer is running (it looks like it is based on output of systemctl status voxl-streamer
                                          • ping your voxl2 ip from your host machine (just to make sure it can reach voxl2)
                                          • download ffmpeg / ffplay to your host machine
                                            • perhaps something in VLC is not working, but ffmpeg / ffplay usually works
                                            • on linux OS should be able to do it using apt-get ffmpeg
                                            • for other OS you can find direct download : https://www.ffmpeg.org/download.html
                                          play the video on the host machine (replace voxl2-ip with actual ip address)
                                          ffplay rtsp://<voxl2-ip>:8900/live
                                          ModeratorM 1 Reply Last reply
