<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Streaming Stereo Camera]]></title><description><![CDATA[<p dir="auto">Is it possible to stream a stereo/tracking camera on the Seeker (SDK 1.1.2) with voxl-streamer?</p>
]]></description><link>https://forum.modalai.com/topic/3169/streaming-stereo-camera</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 04:24:25 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3169.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Mar 2024 21:08:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 06:02:40 GMT]]></title><description><![CDATA[<p dir="auto">Typically hires is the only pipe with encoding enabled by default, but in this case tracking is being used. Can you make sure encoding is enabled for the tracking camera in voxl-camera-server.conf ?</p>
<p dir="auto">Or, can you just see if hires_enc is working in QGC first? That's what we ship by default on a fresh install hires_enc to QGC should by enabled by default.</p>
]]></description><link>https://forum.modalai.com/post/15046</link><guid isPermaLink="true">https://forum.modalai.com/post/15046</guid><dc:creator><![CDATA[Moderator]]></dc:creator><pubDate>Tue, 05 Mar 2024 06:02:40 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 04:49:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kris" aria-label="Profile: Kris">@<bdi>Kris</bdi></a> , please try the following:</p>
<ul>
<li>verify the ip address of voxl2
<ul>
<li>when you adb into voxl2, the ip address is printed</li>
<li>you can use <code>ifconfig</code> to check the ip address</li>
</ul>
</li>
<li>make sure <code>voxl-streamer</code> is running (it looks like it is based on output of <code>systemctl status voxl-streamer</code></li>
<li>ping your voxl2 ip from your host machine (just to make sure it can reach voxl2)</li>
<li>download ffmpeg / ffplay to your host machine
<ul>
<li>perhaps something in VLC is not working, but ffmpeg / ffplay usually works</li>
<li>on linux OS should be able to do it using <code>apt-get ffmpeg</code></li>
<li>for other OS you can find direct download : <a href="https://www.ffmpeg.org/download.html" rel="nofollow ugc">https://www.ffmpeg.org/download.html</a></li>
</ul>
</li>
</ul>
<p dir="auto">play the video on the host machine (replace <code>voxl2-ip</code> with actual ip address)</p>
<pre><code>ffplay rtsp://&lt;voxl2-ip&gt;:8900/live
]]></description><link>https://forum.modalai.com/post/15045</link><guid isPermaLink="true">https://forum.modalai.com/post/15045</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Tue, 05 Mar 2024 04:49:25 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 01:52:51 GMT]]></title><description><![CDATA[<p dir="auto"><code>voxl-inspect-mavlink mavlink_sys_status</code></p>
<pre><code>|   ID  |      Mavlink MSG Name       |Counter|  Hz  |
|     1 | sys_status                  |    92 |  5.0 |
]]></description><link>https://forum.modalai.com/post/15041</link><guid isPermaLink="true">https://forum.modalai.com/post/15041</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Tue, 05 Mar 2024 01:52:51 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 01:48:46 GMT]]></title><description><![CDATA[<pre><code>voxl:~$ voxl-inspect-sku
family code:   MRB-D0003 (seeker)
compute board: 1 (voxl1)
hw version:    7
cam config:    7
SKU:           MRB-D0003-1-V7-C7
]]></description><link>https://forum.modalai.com/post/15040</link><guid isPermaLink="true">https://forum.modalai.com/post/15040</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Tue, 05 Mar 2024 01:48:46 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 01:39:56 GMT]]></title><description><![CDATA[<pre><code>voxl:~$ systemctl status voxl-mavcam-manager -l
● voxl-mavcam-manager.service - voxl-mavcam-manager
   Loaded: loaded (/usr/bin/voxl-mavcam-manager; enabled; vendor preset: enabled)
   Active: failed (Result: signal) since Tue 2024-03-05 01:18:39 UTC; 20min ago
  Process: 17657 ExecStart=/bin/bash -c /usr/bin/voxl-mavcam-manager (code=killed, signal=ABRT)
 Main PID: 17657 (code=killed, signal=ABRT)
Mar 05 01:18:39 apq8096 bash[17657]: snapshot_pipe_name:        tracking
Mar 05 01:18:39 apq8096 bash[17657]: video_record_pipe_name:    tracking
Mar 05 01:18:39 apq8096 bash[17657]: default_uri:               rtsp://192.168.110.152:8900/live
Mar 05 01:18:39 apq8096 bash[17657]: enable_auto_ip:            0
Mar 05 01:18:39 apq8096 bash[17657]: =================================================================
Mar 05 01:18:39 apq8096 bash[17657]: Camera name for qgc: Camera 0
Mar 05 01:18:39 apq8096 bash[17657]: Mavlink server Connected
Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Main process exited, code=killed, status=6/ABRT
Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Unit entered failed state.
Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Failed with result 'signal'.
]]></description><link>https://forum.modalai.com/post/15039</link><guid isPermaLink="true">https://forum.modalai.com/post/15039</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Tue, 05 Mar 2024 01:39:56 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 01:34:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> This is what I see.</p>
<pre><code>voxl:~$ systemctl status voxl-streamer
● voxl-streamer.service - voxl-streamer
   Loaded: loaded (/usr/bin/voxl-streamer; enabled; vendor preset: enabled)
   Active: active (running) since Tue 2024-03-05 01:18:42 UTC; 13min ago
  Process: 17793 ExecStartPre=/bin/sleep 5 (code=exited, status=0/SUCCESS)
 Main PID: 17800 (voxl-streamer)
   CGroup: /system.slice/voxl-streamer.service
           └─17800 /usr/bin/voxl-streamer
Mar 05 01:31:34 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.11...1
Mar 05 01:31:34 apq8096 voxl-streamer[17800]: Camera server Connected
Mar 05 01:31:34 apq8096 voxl-streamer[17800]: rtsp client disconnected, tota...0
Mar 05 01:31:34 apq8096 voxl-streamer[17800]: no more rtsp clients, closing ...y
Hint: Some lines were ellipsized, use -l to show in full.
<pre><code>voxl:~$ systemctl status voxl-streamer -l
   Active: active (running) since Tue 2024-03-05 01:18:42 UTC; 14min ago
Mar 05 01:33:33 apq8096 voxl-streamer[17800]: no more rtsp clients, closing source pipe intentionally
Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48596(null) has connected, total clients: 1
Mar 05 01:33:33 apq8096 voxl-streamer[17800]: Camera server Connected
Mar 05 01:33:33 apq8096 voxl-streamer[17800]: rtsp client disconnected, total clients: 0
Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48604(null) has connected, total clients: 1
Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48606(null) has connected, total clients: 1
]]></description><link>https://forum.modalai.com/post/15038</link><guid isPermaLink="true">https://forum.modalai.com/post/15038</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Tue, 05 Mar 2024 01:34:04 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 01:30:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kris" aria-label="Profile: Kris">@<bdi>Kris</bdi></a> What do you see with <code>systemctl status voxl-streamer</code>?</p>
]]></description><link>https://forum.modalai.com/post/15037</link><guid isPermaLink="true">https://forum.modalai.com/post/15037</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Tue, 05 Mar 2024 01:30:07 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 01:24:20 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1709601858522-qgc6-resized.jpg" alt="QGC6.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/15036</link><guid isPermaLink="true">https://forum.modalai.com/post/15036</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Tue, 05 Mar 2024 01:24:20 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 01:04:44 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1709600637545-qgc4-resized.png" alt="QGC4.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1709600682778-qgc5-resized.jpg" alt="QGC5.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/15035</link><guid isPermaLink="true">https://forum.modalai.com/post/15035</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Tue, 05 Mar 2024 01:04:44 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 00:51:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a><br />
I am sorry, it is still not working....</p>
<p dir="auto"><img src="/assets/uploads/files/1709599901941-qgc3-resized.png" alt="QGC3.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/15034</link><guid isPermaLink="true">https://forum.modalai.com/post/15034</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Tue, 05 Mar 2024 00:51:45 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 00:43:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> Thank you so much, I just found it and I will try it.</p>
]]></description><link>https://forum.modalai.com/post/15033</link><guid isPermaLink="true">https://forum.modalai.com/post/15033</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Tue, 05 Mar 2024 00:43:00 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 00:41:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kris" aria-label="Profile: Kris">@<bdi>Kris</bdi></a> <img src="/assets/uploads/files/1709599227574-27359e0b-c763-47ba-9635-adf90f5bcca1-image.png" alt="27359e0b-c763-47ba-9635-adf90f5bcca1-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The video stream settings are under "General", you'll want to enter the RTSP URI there</p>
]]></description><link>https://forum.modalai.com/post/15032</link><guid isPermaLink="true">https://forum.modalai.com/post/15032</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Tue, 05 Mar 2024 00:41:00 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 00:36:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a><br />
Yes, I have ran through the <code>voxl-configure-sku</code> and the <code>voxl-configure-mpa</code>.<br />
This is what my video stream seetings look like in QGC, if its the correct location.</p>
<p dir="auto"><img src="/assets/uploads/files/1709598976976-qgc1-resized.jpg" alt="QGC1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1709598991127-qgc2-resized.jpg" alt="QGC2.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/15031</link><guid isPermaLink="true">https://forum.modalai.com/post/15031</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Tue, 05 Mar 2024 00:36:33 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 00:23:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kris" aria-label="Profile: Kris">@<bdi>Kris</bdi></a> Again, you've ran through <code>voxl-configure-sku</code> and <code>voxl-configure-mpa</code> there is no reason to start a service manually. In your first post you could see that <code>voxl-mavcam-manager</code> was already running as a service.</p>
<p dir="auto">What do your video stream settings look like in QGC? Do you have it setup correctly to expect an rtsp stream?</p>
]]></description><link>https://forum.modalai.com/post/15030</link><guid isPermaLink="true">https://forum.modalai.com/post/15030</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Tue, 05 Mar 2024 00:23:00 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Tue, 05 Mar 2024 00:11:39 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1709597497911-voxl-streamer-error-resized.jpg" alt="voxl-streamer error.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/15029</link><guid isPermaLink="true">https://forum.modalai.com/post/15029</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Tue, 05 Mar 2024 00:11:39 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Mon, 04 Mar 2024 23:57:06 GMT]]></title><description><![CDATA[<p dir="auto">I am not able to view any video when executing the voxl-mavcam-manager either.</p>
<pre><code>voxl:~$ voxl-mavcam-manager
enable_auto_ip:            1
Got camera information request
auto-detected RTSP URI: rtsp://192.168.110.152:8900/live
]]></description><link>https://forum.modalai.com/post/15028</link><guid isPermaLink="true">https://forum.modalai.com/post/15028</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Mon, 04 Mar 2024 23:57:06 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Mon, 04 Mar 2024 23:46:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> Thank you.</p>
<p dir="auto">I tried it again without manually running voxl-streamer.<br />
First I made sure it was on by inspecting my services.<br />
When I confirmed that it was on, I tried to input the rtsp://  in the Open Network Stream in VLC, but it failed.<br />
Here is the error message in VLC</p>
<pre><code>Connection failed:
VLC could not connect to "192.168.110.152:8900".
Your input can't be opened:
VLC is unable to open the MRL 'rtsp://192.168.110.152:8900/live'. Check the log for details.
Connection failed:
VLC could not connect to "127.0.0.1:8900".
VLC is unable to open the MRL 'rtsp://127.0.0.1:8900/live'. Check the log for details.
Connection failed:
VLC could not connect to "192.168.110.159:8900".
VLC is unable to open the MRL 'rtsp://192.168.110.159:8900/live'. Check the log for details.
<p dir="auto">Can you confirm that I should be using the rtsp://192.168.110.152:8900/live  for the VLC network stream?<br />
Or should it be rtsp://127.0.0.1:8900/live ?</p>
<pre><code>voxl:~$ voxl-streamer -i tracking
Waiting for pipe tracking to appear
Found Pipe
detected following stats from pipe:
w: 640 h: 480 fps: 30 format: RAW8
Stream available at rtsp://127.0.0.1:8900/live
<p dir="auto">Here is my settings in voxl-mavcam-manager</p>
<pre><code>{
        "snapshot_pipe_name":   "tracking",
        "video_record_pipe_name":       "tracking",
        "default_uri":  "rtsp://192.168.110.152:8900/live",
        "enable_auto_ip":       true
]]></description><link>https://forum.modalai.com/post/15027</link><guid isPermaLink="true">https://forum.modalai.com/post/15027</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Mon, 04 Mar 2024 23:46:39 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Mon, 04 Mar 2024 23:03:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kris" aria-label="Profile: Kris">@<bdi>Kris</bdi></a> It looks like <code>voxl-streamer</code> is already running in the background and then you're running it again in the terminal manually, hence the <code>existing instance of voxl-streamer found, attempting to stop it</code></p>
<p dir="auto">You should be able to pull up the stream if the service is running, no need to run it manually like that</p>
]]></description><link>https://forum.modalai.com/post/15026</link><guid isPermaLink="true">https://forum.modalai.com/post/15026</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Mon, 04 Mar 2024 23:03:46 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Mon, 04 Mar 2024 21:45:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> Thank you for your reply.<br />
This is what I have setup in my voxl-streamer.conf</p>
<pre><code>{
        "input-pipe":   "tracking",
        "bitrate":      1000000,
        "rotation":     0,
        "decimator":    1,
        "port": 8900
<p dir="auto">The services that are running are;</p>
<pre><code>voxl:~$ voxl-inspect-services
Scanning services...
 docker-daemon            | Disabled  | Not Running |
 voxl-camera-server       |  Enabled  |   Running   |     5.1%
 voxl-cpu-monitor         |  Enabled  |   Running   |     1.7%
 voxl-imu-server          |  Enabled  |   Running   |     0.0%
 voxl-mavcam-manager      |  Enabled  |   Running   |     1.7%
 voxl-mavlink-server      |  Enabled  |   Running   |     5.1%
 voxl-portal              |  Enabled  |   Running   |     0.0%
 voxl-qvio-server         |  Enabled  |   Running   |     6.8%
 voxl-streamer            |  Enabled  |   Running   |     0.0%
 voxl-vision-hub          |  Enabled  |   Running   |     3.4%
<p dir="auto">My vision-hub.conf</p>
<pre><code>{
        "config_file_version":  1,
        "en_localhost_mavlink_udp":     false,
        "localhost_udp_port_number":    14551,
        "en_vio":       true,
        "vio_pipe":     "qvio",
        "secondary_vio_pipe":   "ov",
        "vio_warmup_s": 3,
        "send_odom_while_failed":       true,
        "en_set_clock_from_gps":        true,
        "en_force_onboard_mav1_mode":   true,
        "en_reset_px4_on_error":        true,
        "horizon_cal_tolerance":        0.5,
        "offboard_mode":        "trajectory",
        "follow_tag_id":        0,
        "figure_eight_move_home":       false,
        "collision_sampling_dt":        0.1,
        "max_lookahead_distance":       1,
        "en_tag_fixed_frame":   false,
        "fixed_frame_filter_len":       5,
        "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
        "en_voa":       true,
        "voa_upper_bound_m":    -0.15000000596046448,
        "voa_lower_bound_m":    0.15000000596046448,
        "voa_voa_memory_s":     1,
        "voa_max_pc_per_fusion":        100,
        "voa_pie_max_dist_m":   20,
        "voa_pie_min_dist_m":   0.25,
        "voa_pie_under_trim_m": 1,
        "voa_pie_threshold":    3,
        "voa_send_rate_hz":     20,
        "voa_pie_slices":       36,
        "voa_pie_bin_depth_m":  0.15000000596046448,
        "voa_inputs":   [{
                        "enabled":      true,
                        "type": "point_cloud",
                        "input_pipe":   "dfs_point_cloud",
                        "frame":        "stereo_l",
                        "max_depth":    8,
                        "min_depth":    0.300000011920929,
                        "cell_size":    0.079999998211860657,
                        "threshold":    4,
                        "x_fov_deg":    68,
                        "y_fov_deg":    56,
                        "conf_cutoff":  0
                        "enabled":      true,
                        "input_pipe":   "stereo_front_pc",
                        "frame":        "stereo_front_l",
                        "max_depth":    8,
                        "threshold":    4,
                        "x_fov_deg":    68,
                        "y_fov_deg":    56,
                        "conf_cutoff":  0
                        "enabled":      true,
                        "input_pipe":   "stereo_rear_pc",
                        "frame":        "stereo_rear_l",
                        "max_depth":    8,
                        "threshold":    4,
                        "x_fov_deg":    68,
                        "y_fov_deg":    56,
                        "conf_cutoff":  0
                        "enabled":      true,
                        "type": "tof",
                        "input_pipe":   "tof",
                        "frame":        "tof",
                        "max_depth":    6,
                        "min_depth":    0.15000000596046448,
                        "threshold":    3,
                        "x_fov_deg":    106.5,
                        "y_fov_deg":    85.0999984741211,
                        "conf_cutoff":  125
                        "enabled":      true,
                        "type": "rangefinder",
                        "input_pipe":   "rangefinders",
                        "frame":        "body",
                        "max_depth":    8,
                        "threshold":    4,
                        "x_fov_deg":    68,
                        "y_fov_deg":    56,
                        "conf_cutoff":  0
<p dir="auto">Then when I go to run voxl-streamer, it works at first but when I open VLC it does not work.</p>
Found Pipe
A new client rtsp://192.168.110.159:40472(null) has connected, total clients: 1
ERROR:   New frame rejected, status = -2
(voxl-streamer:3746): GLib-GObject-WARNING **: instance with invalid (NULL) class pointer
(voxl-streamer:3746): GLib-GObject-CRITICAL **: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
A new client rtsp://192.168.110.159:40484(null) has connected, total clients: 1
WARNING, _stop_helper_and_remove_pipe timed out joining read thread
A new client rtsp://192.168.110.159:60720(null) has connected, total clients: 1
<p dir="auto">I am not sure why I am not able to do this.</p>
<p dir="auto">192.168.110.152 is my current Seeker IP.<br />
192.168.110.159 is my current host PC IP.</p>
<p dir="auto">What I would really like to do is connect my stereo stream with QGroundControl instead of VLC. But I haven't even gotten VLC to stream it yet....</p>
]]></description><link>https://forum.modalai.com/post/15025</link><guid isPermaLink="true">https://forum.modalai.com/post/15025</guid><dc:creator><![CDATA[Kris]]></dc:creator><pubDate>Mon, 04 Mar 2024 21:45:01 GMT</pubDate></item><item><title><![CDATA[Reply to Streaming Stereo Camera on Mon, 04 Mar 2024 21:11:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kris" aria-label="Profile: Kris">@<bdi>Kris</bdi></a> Yes, take a look at <code>/etc/modalai/voxl-streamer.conf</code> for more info</p>
]]></description><link>https://forum.modalai.com/post/15024</link><guid isPermaLink="true">https://forum.modalai.com/post/15024</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Mon, 04 Mar 2024 21:11:14 GMT</pubDate></item></channel></rss>
