    Streaming Stereo Camera
    4586
    • KrisK
      Kris
      Is it possible to stream a stereo/tracking camera on the Seeker (SDK 1.1.2) with voxl-streamer?
        tom admin @Kris
        @Kris Yes, take a look at /etc/modalai/voxl-streamer.conf for more info
        KrisK 1 Reply Last reply Reply Quote 0
        • KrisK
          Kris @tom
          @tom Thank you for your reply.
          This is what I have setup in my voxl-streamer.conf
                  "input-pipe":   "tracking",
                  "bitrate":      1000000,
                  "rotation":     0,
                  "decimator":    1,
                  "port": 8900
          The services that are running are;
          voxl:~$ voxl-inspect-services
          Scanning services...
           Service Name             |  Enabled  |   Running   |  CPU Usage
           docker-autorun           | Disabled  | Not Running |
           docker-daemon            | Disabled  | Not Running |
           modallink-relink         | Disabled  | Not Running |
           voxl-camera-server       |  Enabled  |   Running   |     5.1%
           voxl-cpu-monitor         |  Enabled  |   Running   |     1.7%
           voxl-dfs-server          | Disabled  | Not Running |
           voxl-imu-server          |  Enabled  |   Running   |     0.0%
           voxl-lepton-server       | Disabled  | Not Running |
           voxl-mavcam-manager      |  Enabled  |   Running   |     1.7%
           voxl-mavlink-server      |  Enabled  |   Running   |     5.1%
           voxl-modem               | Disabled  | Not Running |
           voxl-portal              |  Enabled  |   Running   |     0.0%
           voxl-qvio-server         |  Enabled  |   Running   |     6.8%
           voxl-rangefinder-server  | Disabled  | Not Running |
           voxl-remote-id           | Disabled  | Not Running |
           voxl-streamer            |  Enabled  |   Running   |     0.0%
           voxl-tag-detector        | Disabled  | Not Running |
           voxl-tflite-server       | Disabled  | Not Running |
           voxl-time-sync           | Disabled  | Not Running |
           voxl-uvc-server          | Disabled  | Not Running |
           voxl-vision-hub          |  Enabled  |   Running   |     3.4%
           voxl-wait-for-fs         |  Enabled  |  Completed  |
          My vision-hub.conf
                  "config_file_version":  1,
                  "en_localhost_mavlink_udp":     false,
                  "en_vio":       true,
                  "vio_pipe":     "qvio",
                  "secondary_vio_pipe":   "ov",
                  "vio_warmup_s": 3,
                  "send_odom_while_failed":       true,
                  "horizon_cal_tolerance":        0.5,
                  "offboard_mode":        "trajectory",
                  "follow_tag_id":        0,
                  "figure_eight_move_home":       false,
                  "robot_radius": 0.300000011920929,
                  "collision_sampling_dt":        0.1,
                  "max_lookahead_distance":       1,
                  "en_tag_fixed_frame":   false,
                  "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
                  "en_voa":       true,
                  "voa_upper_bound_m":    -0.15000000596046448,
                  "voa_lower_bound_m":    0.15000000596046448,
                  "voa_voa_memory_s":     1,
                  "voa_max_pc_per_fusion":        100,
                  "voa_pie_max_dist_m":   20,
                  "voa_pie_min_dist_m":   0.25,
                  "voa_pie_under_trim_m": 1,
                  "voa_pie_threshold":    3,
                  "voa_send_rate_hz":     20,
                  "voa_pie_slices":       36,
                  "voa_pie_bin_depth_m":  0.15000000596046448,
                  "voa_inputs":   [{
                                  "enabled":      true,
                                  "type": "point_cloud",
                                  "input_pipe":   "dfs_point_cloud",
                                  "frame":        "stereo_l",
                                  "max_depth":    8,
                                  "min_depth":    0.300000011920929,
                                  "cell_size":    0.079999998211860657,
                                  "threshold":    4,
                                  "x_fov_deg":    68,
                                  "y_fov_deg":    56,
                                  "conf_cutoff":  0
                                  "enabled":      true,
                                  "input_pipe":   "stereo_front_pc",
                                  "frame":        "stereo_front_l",
                                  "max_depth":    8,
                                  "threshold":    4,
                                  "x_fov_deg":    68,
                                  "y_fov_deg":    56,
                                  "conf_cutoff":  0
                                  "enabled":      true,
                                  "input_pipe":   "stereo_rear_pc",
                                  "frame":        "stereo_rear_l",
                                  "max_depth":    8,
                                  "threshold":    4,
                                  "x_fov_deg":    68,
                                  "y_fov_deg":    56,
                                  "conf_cutoff":  0
                                  "enabled":      true,
                                  "type": "tof",
                                  "input_pipe":   "tof",
                                  "frame":        "tof",
                                  "max_depth":    6,
                                  "min_depth":    0.15000000596046448,
                                  "threshold":    3,
                                  "x_fov_deg":    106.5,
                                  "y_fov_deg":    85.0999984741211,
                                  "conf_cutoff":  125
                                  "enabled":      true,
                                  "type": "rangefinder",
                                  "input_pipe":   "rangefinders",
                                  "frame":        "body",
                                  "max_depth":    8,
                                  "threshold":    4,
                                  "x_fov_deg":    68,
                                  "y_fov_deg":    56,
                                  "conf_cutoff":  0
          Then when I go to run voxl-streamer, it works at first but when I open VLC it does not work.
          voxl:~$ voxl-streamer -i tracking
          existing instance of voxl-streamer found, attempting to stop it
          Waiting for pipe tracking to appear
          Found Pipe
          detected following stats from pipe:
          w: 640 h: 480 fps: 30 format: RAW8
          Stream available at rtsp://127.0.0.1:8900/live
          A new client rtsp://192.168.110.159:40472(null) has connected, total clients: 1
          Camera server Connected
          ERROR:   New frame rejected, status = -2
          rtsp client disconnected, total clients: 0
          no more rtsp clients, closing source pipe intentionally
          (voxl-streamer:3746): GLib-GObject-WARNING **: instance with invalid (NULL) class pointer
          (voxl-streamer:3746): GLib-GObject-CRITICAL **: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
          A new client rtsp://192.168.110.159:40484(null) has connected, total clients: 1
          WARNING, _stop_helper_and_remove_pipe timed out joining read thread
          A new client rtsp://192.168.110.159:60720(null) has connected, total clients: 1
          I am not sure why I am not able to do this.
          192.168.110.152 is my current Seeker IP.
          192.168.110.159 is my current host PC IP.
          What I would really like to do is connect my stereo stream with QGroundControl instead of VLC. But I haven't even gotten VLC to stream it yet....
            tom admin @Kris
            @Kris It looks like voxl-streamer is already running in the background and then you're running it again in the terminal manually, hence the existing instance of voxl-streamer found, attempting to stop it
            You should be able to pull up the stream if the service is running, no need to run it manually like that
            • KrisK
              Kris @tom
              @tom Thank you.
              I tried it again without manually running voxl-streamer.
              First I made sure it was on by inspecting my services.
              When I confirmed that it was on, I tried to input the rtsp:// in the Open Network Stream in VLC, but it failed.
              Here is the error message in VLC
              Connection failed:
              VLC could not connect to "192.168.110.152:8900".
              Your input can't be opened:
              VLC is unable to open the MRL 'rtsp://192.168.110.152:8900/live'. Check the log for details.
              Connection failed:
              VLC could not connect to "127.0.0.1:8900".
              VLC is unable to open the MRL 'rtsp://127.0.0.1:8900/live'. Check the log for details.
              Connection failed:
              VLC could not connect to "192.168.110.159:8900".
              VLC is unable to open the MRL 'rtsp://192.168.110.159:8900/live'. Check the log for details.
              Can you confirm that I should be using the rtsp://192.168.110.152:8900/live for the VLC network stream?
              Or should it be rtsp://127.0.0.1:8900/live ?
              Found Pipe
              Here is my settings in voxl-mavcam-manager
                      "snapshot_pipe_name":   "tracking",
                      "video_record_pipe_name":       "tracking",
                      "default_uri":  "rtsp://192.168.110.152:8900/live",
                      "enable_auto_ip":       true
              • KrisK
                Kris @Kris
                I am not able to view any video when executing the voxl-mavcam-manager either.
                voxl:~$ voxl-mavcam-manager
                snapshot_pipe_name:        tracking
                video_record_pipe_name:    tracking
                default_uri:               rtsp://192.168.110.152:8900/live
                enable_auto_ip:            1
                Camera name for qgc: Camera 0
                Mavlink server Connected
                Got camera information request
                auto-detected RTSP URI: rtsp://192.168.110.152:8900/live
                • KrisK
                  Kris @Kris
                    tom admin @Kris
                    @Kris Again, you've ran through voxl-configure-sku and voxl-configure-mpa there is no reason to start a service manually. In your first post you could see that voxl-mavcam-manager was already running as a service.
                    What do your video stream settings look like in QGC? Do you have it setup correctly to expect an rtsp stream?
                    • KrisK
                      Kris @tom
                      Yes, I have ran through the voxl-configure-sku and the voxl-configure-mpa.
                      This is what my video stream seetings look like in QGC, if its the correct location.
                        tom admin @Kris
                        The video stream settings are under "General", you'll want to enter the RTSP URI there
                        KrisK 3 Replies Last reply Reply Quote 0
                        • KrisK
                          Kris @tom
                          @tom Thank you so much, I just found it and I will try it.
                          • KrisK
                            Kris @tom
                            I am sorry, it is still not working....
                            • KrisK
                              Kris @Kris
                              • KrisK
                                Kris @tom
                                  tom admin @Kris
                                  @Kris What do you see with systemctl status voxl-streamer?
                                  KrisK 4 Replies Last reply Reply Quote 0
                                  • KrisK
                                    Kris @tom
                                    @tom This is what I see.
                                    voxl:~$ systemctl status voxl-streamer
                                    ● voxl-streamer.service - voxl-streamer
                                       Loaded: loaded (/usr/bin/voxl-streamer; enabled; vendor preset: enabled)
                                       Active: active (running) since Tue 2024-03-05 01:18:42 UTC; 13min ago
                                      Process: 17793 ExecStartPre=/bin/sleep 5 (code=exited, status=0/SUCCESS)
                                     Main PID: 17800 (voxl-streamer)
                                       CGroup: /system.slice/voxl-streamer.service
                                               └─17800 /usr/bin/voxl-streamer
                                    Mar 05 01:31:34 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.11...1
                                    Mar 05 01:31:34 apq8096 voxl-streamer[17800]: Camera server Connected
                                    Mar 05 01:31:34 apq8096 voxl-streamer[17800]: rtsp client disconnected, tota...0
                                    Mar 05 01:31:34 apq8096 voxl-streamer[17800]: no more rtsp clients, closing ...y
                                    Hint: Some lines were ellipsized, use -l to show in full.
                                    voxl:~$ systemctl status voxl-streamer -l
                                       Active: active (running) since Tue 2024-03-05 01:18:42 UTC; 14min ago
                                    Mar 05 01:33:33 apq8096 voxl-streamer[17800]: no more rtsp clients, closing source pipe intentionally
                                    Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48596(null) has connected, total clients: 1
                                    Mar 05 01:33:33 apq8096 voxl-streamer[17800]: Camera server Connected
                                    Mar 05 01:33:33 apq8096 voxl-streamer[17800]: rtsp client disconnected, total clients: 0
                                    Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48604(null) has connected, total clients: 1
                                    Mar 05 01:33:33 apq8096 voxl-streamer[17800]: A new client rtsp://192.168.110.159:48606(null) has connected, total clients: 1
                                    • KrisK
                                      Kris @tom
                                      voxl:~$ systemctl status voxl-mavcam-manager -l
                                      ● voxl-mavcam-manager.service - voxl-mavcam-manager
                                         Loaded: loaded (/usr/bin/voxl-mavcam-manager; enabled; vendor preset: enabled)
                                         Active: failed (Result: signal) since Tue 2024-03-05 01:18:39 UTC; 20min ago
                                        Process: 17657 ExecStart=/bin/bash -c /usr/bin/voxl-mavcam-manager (code=killed, signal=ABRT)
                                       Main PID: 17657 (code=killed, signal=ABRT)
                                      Mar 05 01:18:39 apq8096 bash[17657]: snapshot_pipe_name:        tracking
                                      Mar 05 01:18:39 apq8096 bash[17657]: video_record_pipe_name:    tracking
                                      Mar 05 01:18:39 apq8096 bash[17657]: default_uri:               rtsp://192.168.110.152:8900/live
                                      Mar 05 01:18:39 apq8096 bash[17657]: enable_auto_ip:            0
                                      Mar 05 01:18:39 apq8096 bash[17657]: =================================================================
                                      Mar 05 01:18:39 apq8096 bash[17657]: Camera name for qgc: Camera 0
                                      Mar 05 01:18:39 apq8096 bash[17657]: Mavlink server Connected
                                      Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Main process exited, code=killed, status=6/ABRT
                                      Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Unit entered failed state.
                                      Mar 05 01:18:39 apq8096 systemd[1]: voxl-mavcam-manager.service: Failed with result 'signal'.
                                      • KrisK
                                        Kris @tom
                                        voxl:~$ voxl-inspect-sku
                                        family code:   MRB-D0003 (seeker)
                                        compute board: 1 (voxl1)
                                        hw version:    7
                                        cam config:    7
                                        SKU:           MRB-D0003-1-V7-C7
                                        • KrisK
                                          Kris @tom
                                          voxl-inspect-mavlink mavlink_sys_status
                                          |   ID  |      Mavlink MSG Name       |Counter|  Hz  |
                                          |     1 | sys_status                  |    92 |  5.0 |
                                            Alex Kushleyev ModalAI Team @Kris
                                            @Kris , please try the following:
                                            • verify the ip address of voxl2
                                              • when you adb into voxl2, the ip address is printed
                                              • you can use ifconfig to check the ip address
                                            • make sure voxl-streamer is running (it looks like it is based on output of systemctl status voxl-streamer
                                            • ping your voxl2 ip from your host machine (just to make sure it can reach voxl2)
                                            • download ffmpeg / ffplay to your host machine
                                              • perhaps something in VLC is not working, but ffmpeg / ffplay usually works
                                              • on linux OS should be able to do it using apt-get ffmpeg
                                              • for other OS you can find direct download : https://www.ffmpeg.org/download.html
                                            play the video on the host machine (replace voxl2-ip with actual ip address)
                                            ffplay rtsp://<voxl2-ip>:8900/live
