  3. Voxl2 Spektrum Receiver error
90 Posts 4 Posters 49.8k Views 3 Watching
  • Chase RileyC Chase Riley
    @Eric-Katzfey said in Voxl2 Spektrum Receiver error:
    @Chase-Riley I made version 1.14.0-2.0.54 with the Spektrum RC changes in it. You can get it with wget http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.14.0-2.0.54-202310161035_arm64.deb. Can you try it out and see if it fixes your issue?
    @Eric-Katzfey do you still have the version of px4 you referenced here. The link now gives a 404 error?
    Eric KatzfeyE Online
    @Chase-Riley Yeah, that's was in our dev repo that has a lot of churn. But you can grab this one: http://voxl-packages.modalai.com/dists/qrb5165/sdk-1.0/binary-arm64/voxl-px4_1.14.0-2.0.55_arm64.deb if you want something close to that. But latest SDK 1.1.2 also has those changes and you should be on the latest.
      Chase RileyC Offline
      Chase Riley
      @Eric-Katzfey This error still exist in SDK 1.1.2. I have tried multiple settings on the DX8 for binding. I have tried other Receivers as well.
        @Chase-Riley So the first deb you tried fixed the Spektrum issue but now with 1.1.2 it's back? That was a very simple change that went into the codebase and it is still there so not sure what happened. Can you send the output of journalctl -b -u voxl-px4 so I can see if there are any error messages?
          Chase Riley
          @Eric-Katzfey I had to trim the output to fit into a forum post.
          voxl2:/$ journalctl -b -u voxl-px4
          -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Thu 2023-03-02 13:13:00 UTC. --
          Mar 02 12:58:05 m0054 systemd[1]: Starting px4...
          Mar 02 12:58:07 m0054 systemd[1]: Started px4.
          Mar 02 12:58:07 m0054 voxl-px4[1878]: [INFO] Reading from /etc/modalai/voxl-px4.conf
          Mar 02 12:58:07 m0054 voxl-px4[1878]: Found DSP signature file
          Mar 02 12:58:07 m0054 voxl-px4[1878]: [INFO] Daemon mode enabled
          Mar 02 12:58:07 m0054 voxl-px4[1878]: *************************
          Mar 02 12:58:07 m0054 voxl-px4[1878]: GPS=AUTODETECT
          Mar 02 12:58:07 m0054 voxl-px4[1878]: RC=SPEKTRUM
          Mar 02 12:58:07 m0054 voxl-px4[1878]: ESC=VOXL_ESC
          Mar 02 12:58:07 m0054 voxl-px4[1878]: POWER MANAGER=VOXLPM
          Mar 02 12:58:07 m0054 voxl-px4[1878]: DISTANCE SENSOR=NONE
          Mar 02 12:58:07 m0054 voxl-px4[1878]: OSD=DISABLE
          Mar 02 12:58:07 m0054 voxl-px4[1878]: DAEMON_MODE=ENABLE
          Mar 02 12:58:07 m0054 voxl-px4[1878]: SENSOR_CAL=ACTUAL
          Mar 02 12:58:07 m0054 voxl-px4[1878]: EXTRA STEPS:
          Mar 02 12:58:07 m0054 voxl-px4[1878]: INFO  [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
          Mar 02 12:58:07 m0054 voxl-px4[1878]: INFO  [px4] assuming working directory is rootfs, no symlinks needed.
          Mar 02 12:58:07 m0054 voxl-px4[1878]: INFO  [muorb] Got muorb init command
          Mar 02 12:58:07 m0054 voxl-px4[1878]: Sending initialization request
          Mar 02 12:58:07 m0054 voxl-px4[1878]: Got topic data before configuration complete
          Mar 02 12:58:07 m0054 voxl-px4[1878]: GPS: AUTODETECT
          Mar 02 12:58:07 m0054 voxl-px4[1878]: RC: SPEKTRUM
          Mar 02 12:58:07 m0054 voxl-px4[1878]: ESC: VOXL_ESC
          Mar 02 12:58:07 m0054 voxl-px4[1878]: POWER MANAGER: VOXLPM
          Mar 02 12:58:07 m0054 voxl-px4[1878]: DISTANCE SENSOR: NONE
          Mar 02 12:58:07 m0054 voxl-px4[1878]: OSD: DISABLE
          Mar 02 12:58:07 m0054 voxl-px4[1878]: Running on M0054
          Mar 02 12:58:08 m0054 voxl-px4[1878]: INFO  [param] selected parameter default file /data/px4/param/parameters
          Mar 02 12:58:10 m0054 voxl-px4[1878]: INFO  [parameters] BSON document size 4125 bytes, decoded 4125 bytes (INT32:57, FLOAT:136)
          Mar 02 12:58:10 m0054 voxl-px4[1878]: Starting IMU driver with no rotation
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'icm42688p start -s -R 4'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11587369, local time: 11593616
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11630444, local time: 11631222
          Mar 02 12:58:11 m0054 voxl-px4[1878]: Looking for qmc5883l magnetometer
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: muorb aggregator thread running
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] muorb protobuf initalize method succeeded
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did ADVERTISE_TEST_TYPE
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread test_MUORB
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did SUBSCRIBE_TEST_TYPE
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did TOPIC_TEST_TYPE
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] muorb test passed
          Mar 02 12:58:11 m0054 voxl-px4[1878]: ______  __   __    ___
          Mar 02 12:58:11 m0054 voxl-px4[1878]: | ___ \ \ \ / /   /   |
          Mar 02 12:58:11 m0054 voxl-px4[1878]: | |_/ /  \ V /   / /| |
          Mar 02 12:58:11 m0054 voxl-px4[1878]: |  __/   /   \  / /_| |
          Mar 02 12:58:11 m0054 voxl-px4[1878]: | |     / /^\ \ \___  |
          Mar 02 12:58:11 m0054 voxl-px4[1878]: \_|     \/   \/     |_/
          Mar 02 12:58:11 m0054 voxl-px4[1878]: px4 starting.
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Advertising remote topic log_message
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [parameters] Starting param sync THREAD
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Starting param sync THREAD
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: before starting the qshell_entry task
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread qshell
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell entry.....
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Init app map initialized
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: after starting the qshell_entry task
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Advertising remote topic parameter_update
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_topic
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_topic
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [logger] logger started (mode=all)
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: icm42688p start -s -R 4
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'icm42688p'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg1 = 'start'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-s'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg3 = '-R'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '4'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_accel
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_gyro
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: ICM42688P::probe successful!
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: on SPI bus 1
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  rotation 4
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: >>> ICM42688P this: 3176ecd0
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: icm42688p start -s -R 4
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic qshell_retval
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ecd0
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_gyro_fifo
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_accel_fifo
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic imu_server
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'icp101xx'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-I'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg3 = '-b'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '5'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: icp101xx #0 on I2C bus 5
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0x63
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in procesINFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] cmd returned with: -1
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11661692, local time: 11664384
          Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [qshell] Command failed
          Mar 02 12:58:11 m0054 voxl-px4[1878]: Looking for ist8310 magnetometer
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11691188, local time: 11692742
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'gps start'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11724704, local time: 11726454
          Mar 02 12:58:11 m0054 voxl-px4[1878]: Looking for ncp5623c RGB LED
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11752678, local time: 11753969
          Mar 02 12:58:11 m0054 voxl-px4[1878]: Starting VOXL ESC driver
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'voxl_esc start'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11835821, local time: 11838037
          Mar 02 12:58:11 m0054 voxl-px4[1878]: Starting Spektrum RC
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'spektrum_rc start'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11886393, local time: 11888078
          Mar 02 12:58:11 m0054 voxl-px4[1878]: s_remote_topic
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: qmc5883l start -R 10 -X -b 1
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'qmc5883l'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-R'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg3 = '10'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '-X'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg5 = '-b'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg6 = '1'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0x80d09 527625
          Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: i2c probe failed
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: PX4_qshell: no instance started (no device on bus?)
          Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Failed to execute command: qmc5883l start -R 10 -X -b 1
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'ist8310'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0x60e09 396809
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: ist8310 #0 on I2C bus 1
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  (external)
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0xE
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  rotation 10
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: gps start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'gps'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread gps
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: gps start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'rgbled_ncp5623c'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-X'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '1'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg5 = '-f'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg6 = '400'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg7 = '-a'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg8 = '56'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0x38
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_mag
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: voxl_esc start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic actuator_outputs
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: voxl_esc start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Opened UART ESC device
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_baro
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: spektrum_rc start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097644
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: spektrum_rc start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic actuator_outputs_debug
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic esc_status
          Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x00
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'voxlpm'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '2'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Set i2c address 0x6a, fd 4
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Set i2c addINFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11923833, local time: 11926013
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'sensors start'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12118075, local time: 12122006
          Mar 02 12:58:11 m0054 voxl-px4[1878]: ress 0x44, fd 4
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic battery_status
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0x44
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic power_monitor
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: sensors start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'sensors'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_selection
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensors_status_imu
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_acceleration
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_angular_velocity
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_combined
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_air_data
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_gps_position
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensors_status_baro
          Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for CAL_MAG_COMP_TYP
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_magnetometer
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_preflight_mag
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_imu
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_imu_status
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: sensors start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensors_status_mag
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: ekf2 start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'ekf2'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Spektrum RCINFO  [qshell] Send cmd: 'ekf2 start'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12374104, local time: 12378323
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_pos_control start'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12482484, local time: 12483852
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_att_control start'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12525883, local time: 12527670
          Mar 02 12:58:11 m0054 voxl-px4[1878]: : Invalid DSM frame. 16 bytes. Protocol byte 0x00
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_attitude
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_local_position
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_event_flags
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_innovation_test_ratios
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_innovation_variances
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_innovations
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_sensor_bias
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_states
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_status_flags
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: ekf2 start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic ekf2_timestamps
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_odometry
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_baro_hgt
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_fake_pos
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_fake_hgt
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_gravity
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_pos_control'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic takeoff_status
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_att_control start
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_att_control'
          Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_att_control start
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertisedINFO  [qshell] Send cmd: 'mc_rate_control start'
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12616998, local time: 12618394
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12678757, local time: 12680493
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_autotune_attitude_control start'
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12721830, local time: 12722851
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'land_detector start multicopter'
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12767035, local time: 12769446
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'manual_control start'
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12821435, local time: 12823707
          Mar 02 12:58:12 m0054 voxl-px4[1878]:  in process_remote_topic
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_rate_control'
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg1 = 'start'
          Mar 02 12:58:12 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x00
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic rate_ctrl_status
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_hover_thrust_estimator'
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_autotune_attitude_control'
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic autotune_attitude_control_status
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'land_detector'
          Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = 'multicopter'
            @Chase-Riley said in Voxl2 Spektrum Receiver error:
            Yep, there's the error. That's the correct size but the code is expecting either 0x01 or 0x02 as valid protocols, not 0x00. Does it report 0x00 every single time or does it change? Is this the same transmitter you used earlier? Seems like it must be something different as that one was reporting 0x01, not 0x00. I can build a new version that also allows 0x00 and see if that fixes anything.
              Chase Riley
              wrote on last edited by Chase Riley
              #46
              @Eric-Katzfey it seems to change. I have seen different during testing. Same transmitter.
                Chase Riley
                #47
                @Chase-Riley Actually it may change with the frame rate in the transmitter. I just ran it 5 times without changing the settings and it stayed as 0x00.
                Update. I powered down the transmitter and when I ran again i received 0x5a
                  @Chase-Riley Okay, well I'll just make a custom build for you that removes the check on that byte completely but that's probably not the right thing to do. But at least it will get us farther down the road. I'll try to think of some other useful debugging information to output as well.
                    @Chase-Riley Seems like maybe the data on the serial line is getting corrupted somehow
                      @Chase-Riley Actually, can you start the driver with the -v flag so that it produces more output and send me the log from that?
                      Chase RileyC 2 Replies Last reply
                        Chase Riley
                        @Eric-Katzfey I am out of the office for the night. I will get back to you first thing in the morning EST. If you could try the custom file that would be great. It may help me continue testing while we work on debugging this issue more.
                          Chase Riley
                          @Eric-Katzfey Here is the log with the -v argument added to the Spektrum Driver Start.
                          voxl2:/$ voxl-px4 -d
                          [INFO] Disabling daemon mode
                          GPS=AUTODETECT
                          RC=SPEKTRUM
                          ESC=VOXL_ESC
                          OSD=DISABLE
                          DAEMON_MODE=DISABLE
                          SENSOR_CAL=ACTUAL
                          EXTRA STEPS:
                          ______  __   __    ___
                          | ___ \ \ \ / /   /   |
                          | |_/ /  \ V /   / /| |
                          |  __/   /   \  / /_| |
                          | |     / /^\ \ \___  |
                          \_|     \/   \/     |_/
                          px4 starting.
                          GPS: AUTODETECT
                          RC: SPEKTRUM
                          ESC: VOXL_ESC
                          OSD: DISABLE
                          EXTRA STEPS:
                          Running on M0054
                          INFO  [muorb] SLPI: >>> ICM42688P this: 3176cce0
                          INFO  [muorb] SLPI:
                          INFO  [qshell] qshell return value timestamp: 197304564, local time: 197310221
                          INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176cce0
                          INFO  [muorb] SLPI:
                          INFO  [qshell] qshell return value timestamp: 197356803, local time: 197358238
                          INFO  [qshell] qshell return value timestamp: 197389684, local time: 197391710
                          INFO  [muorb] SLPI:
                          INFO  [qshell] qshell return value timestamp: 197437606, local time: 197440108
                          INFO  [qshell] qshell return value timestamp: 197463075, local time: 197465432
                          INFO  [muorb] SLPI:
                          INFO  [qshell] qshell return value timestamp: 197515519, local time: 197517065
                          INFO  [muorb] SLPI: ubx msg 0x0107 invalid len 46584
                          INFO  [qshell] qshell return value timestamp: 197621321, local time: 197622953
                          INFO  [qshell] Send cmd: 'spektrum_rc start -v'
                          INFO  [muorb] SLPI: qshell gotten: spektrum_rc start -v
                          INFO  [muorb] SLPI:   arg2 = '-v'
                          INFO  [muorb] SLPI: Ok executing command: spektrum_rc start -v
                          INFO  [muorb] SLPI: Spektrum RC: Enabling verbose mode
                          INFO  [muorb] SLPI: Spektrum RC: dsm_init succeeded
                          INFO  [qshell] qshell return value timestamp: 197674334, local time: 197676244
                          INFO  [muorb] SLPI: Spektrum RC: Read no bytes from UART
                          INFO  [muorb] SLPI: Set i2c address 0x44, fd 4
                          ERROR [muorb] SLPI: Failed to execute command: voxlpm start -X -b 2
                          INFO  [qshell] qshell return value timestamp: 197707182, local time: 197710461
                            GPS=AUTODETECT
                            RC=SPEKTRUM
                            ESC=VOXL_ESC
                            OSD=DISABLE
                            DAEMON_MODE=DISABLE
                            SENSOR_CAL=ACTUAL
                            EXTRA STEPS:
                            ______  __   __    ___
                            | ___ \ \ \ / /   /   |
                            | |_/ /  \ V /   / /| |
                            |  __/   /   \  / /_| |
                            | |     / /^\ \ \___  |
                            \_|     \/   \/     |_/
                            px4 starting.
                            GPS: AUTODETECT
                            RC: SPEKTRUM
                            ESC: VOXL_ESC
                            OSD: DISABLE
                            EXTRA STEPS:
                            Running on M0054
                            INFO  [muorb] SLPI:
                            INFO  [muorb] SLPI:
                            INFO  [muorb] SLPI:
                            INFO  [muorb] SLPI:
                            @Chase-Riley Interesting. Okay, so in this case it's always 0x00. But you say you have seen other random values? Can you capture a log with that happening?
                              Chase Riley
                              #54
                              @Eric-Katzfey Here is the log you requested. To get a different value than 0x00 I just powered down and then powered back up the transmitter. I also ran it again after this test and received 0x5a.
                              GPS=AUTODETECT
                              RC=SPEKTRUM
                              ESC=VOXL_ESC
                              OSD=DISABLE
                              DAEMON_MODE=DISABLE
                              SENSOR_CAL=ACTUAL
                              EXTRA STEPS:
                              ______  __   __    ___
                              | ___ \ \ \ / /   /   |
                              | |_/ /  \ V /   / /| |
                              |  __/   /   \  / /_| |
                              | |     / /^\ \ \___  |
                              \_|     \/   \/     |_/
                              px4 starting.
                              GPS: AUTODETECT
                              RC: SPEKTRUM
                              ESC: VOXL_ESC
                              OSD: DISABLE
                              EXTRA STEPS:
                              Running on M0054
                              INFO  [muorb] SLPI: >>> ICM42688P this: 3176ccf0
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 140652268, local time: 140655765
                              INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ccf0
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 140688809, local time: 140690531
                              INFO  [qshell] qshell return value timestamp: 140728848, local time: 140731229
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 140766613, local time: 140767902
                              INFO  [qshell] qshell return value timestamp: 140792157, local time: 140794315
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 140826063, local time: 140827364
                              INFO  [qshell] qshell return value timestamp: 140915998, local time: 140917432
                              INFO  [qshell] qshell return value timestamp: 140957493, local time: 140958599
                              ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x2d
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 140988963, local time: 140990201
                                GPS=AUTODETECT
                                RC=SPEKTRUM
                                ESC=VOXL_ESC
                                OSD=DISABLE
                                DAEMON_MODE=DISABLE
                                SENSOR_CAL=ACTUAL
                                EXTRA STEPS:
                                ______  __   __    ___
                                | ___ \ \ \ / /   /   |
                                | |_/ /  \ V /   / /| |
                                |  __/   /   \  / /_| |
                                | |     / /^\ \ \___  |
                                \_|     \/   \/     |_/
                                px4 starting.
                                GPS: AUTODETECT
                                RC: SPEKTRUM
                                ESC: VOXL_ESC
                                OSD: DISABLE
                                EXTRA STEPS:
                                Running on M0054
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                @Chase-Riley Okay, I'm preparing a new Debian that just completely removes that protocol byte check and, when verbose debug information is selected, will dump the complete frame contents about once a second so we can see what is actually being received at the driver.
                                  Chase Riley
                                  @Eric-Katzfey Ok. Looking forward to trying it out.
                                    @Chase-Riley You can get it with wget https://storage.googleapis.com/modalai_public/forum/voxl-px4_1.14.66-6.0.0_arm64.deb
                                      Chase Riley
                                      @Eric-Katzfey Here is the log with the new Debian.
                                      GPS=AUTODETECT
                                      RC=SPEKTRUM
                                      ESC=VOXL_ESC
                                      OSD=DISABLE
                                      DAEMON_MODE=DISABLE
                                      SENSOR_CAL=ACTUAL
                                      EXTRA STEPS:
                                      ______  __   __    ___
                                      | ___ \ \ \ / /   /   |
                                      | |_/ /  \ V /   / /| |
                                      |  __/   /   \  / /_| |
                                      | |     / /^\ \ \___  |
                                      \_|     \/   \/     |_/
                                      px4 starting.
                                      GPS: AUTODETECT
                                      RC: SPEKTRUM
                                      ESC: VOXL_ESC
                                      OSD: DISABLE
                                      EXTRA STEPS:
                                      Running on M0054
                                      INFO  [muorb] SLPI: >>> ICM42688P this: 3176ed20
                                      INFO  [muorb] SLPI:
                                      INFO  [qshell] qshell return value timestamp: 108528422, local time: 108534280
                                      INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ed20
                                      INFO  [muorb] SLPI:
                                      INFO  [qshell] qshell return value timestamp: 108579731, local time: 108582550
                                      INFO  [qshell] qshell return value timestamp: 108614169, local time: 108616786
                                      INFO  [muorb] SLPI:
                                      INFO  [qshell] qshell return value timestamp: 108652161, local time: 108653528
                                      INFO  [qshell] qshell return value timestamp: 108678128, local time: 108679924
                                      INFO  [muorb] SLPI:
                                      INFO  [qshell] qshell return value timestamp: 108709712, local time: 108711831
                                      INFO  [qshell] qshell return value timestamp: 108819381, local time: 108821923
                                      INFO  [qshell] qshell return value timestamp: 108849790, local time: 108851570
                                      INFO  [muorb] SLPI:
                                      INFO  [qshell] qshell return value timestamp: 108881654, local time: 108883951
                                      ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_GPS_PRIME
                                      INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x00
                                      INFO  [muorb] SLPI: 0x00 0x00 0x81 0x86 0x39 0x56 0x1c 0x0d
                                      INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x61 0x00
                                      INFO  [qshell] qshell return value timestamp: 109070971, local time: 109078977
                                      INFO  [uORB] Advertising remote topic input_rc
                                      INFO  [muorb] SLPI: Spektrum RC: DSM message parsed successfully
                                      INFO  [muorb] SLPI: Spektrum RC: Publishing input_rc
                                      INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x63 0x00
                                      INFO  [qshell] qshell return value timestamp: 109344658, local time: 109348511
                                      INFO  [qshell] qshell return value timestamp: 109447440, local time: 109448532
                                      INFO  [qshell] qshell return value timestamp: 109490661, local time: 109491803
                                      INFO  [qshell] qshell return value timestamp: 109586749, local time: 109589982
                                      INFO  [qshell] qshell return value timestamp: 109645064, local time: 109646589
                                      INFO  [qshell] qshell return value timestamp: 109687598, local time: 109688691
                                      INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x65 0x00
                                      INFO  [muorb] SLPI: Ok executing command: land_detector start multicopter
                                      INFO  [qshell] qshell return value timestamp: 109739354, local time: 109741061
                                      INFO  [uORB] Advertising remote topic vehicle_land_detected
                                      INFO  [muorb] SLPI: baudrate set to 9600
                                      INFO  [muorb] SLPI: qshell gotten: manual_control start
                                      INFO  [muorb] SLPI:   arg0 = 'manual_control'
                                      INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 1
                                      INFO  [muorb] SLPI: Ok executing command: manual_control start
                                      INFO  [qshell] qshell return value timestamp: 109801954, local time: 109803502
                                      INFO  [uORB] Advertising remote topic manual_control_setpoint
                                      INFO  [qshell] Send cmd: 'control_allocator start'
                                      INFO  [muorb] SLPI: qshell gotten: control_allocator start
                                      INFO  [muorb] SLPI:   arg0 = 'control_allocator'
                                      INFO  [uORB] Advertising remote topic control_allocator_status
                                      INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
                                      INFO  [uORB] Advertising remote topic actuator_motors
                                      INFO  [uORB] Advertising remote topic actuator_servos
                                      INFO  [uORB] Advertising remote topic actuator_servos_trim
                                      INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x67 0x00
                                      INFO  [muorb] SLPI: Ok executing command: control_allocator start
                                      INFO  [qshell] qshell return value timestamp: 110087397, local time: 110090284
                                      INFO  [qshell] Send cmd: 'load_mon start'
                                      INFO  [muorb] SLPI: qshell gotten: load_mon start
                                      INFO  [muorb] SLPI:   arg0 = 'load_mon'
                                      INFO  [muorb] SLPI: Ok executing command: load_mon start
                                      INFO  [uORB] Advertising remote topic cpuload
                                      INFO  [qshell] qshell return value timestamp: 110141759, local time: 110143643
                                      INFO  [qshell] Send cmd: 'rc_update start'
                                      INFO  [muorb] SLPI: qshell gotten: rc_update start
                                      INFO  [muorb] SLPI:   arg0 = 'rc_update'
                                      INFO  [muorb] SLPI: Ok executing command: rc_update start
                                      INFO  [qshell] qshell return value timestamp: 110418193, local time: 110421870
                                      INFO  [qshell] Send cmd: 'commander start'
                                      INFO  [muorb] SLPI: qshell gotten: commander start
                                      INFO  [muorb] SLPI:   arg0 = 'commander'
                                      INFO  [muorb] SLPI: Creating pthread commander
                                      INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097639
                                      INFO  [uORB] Advertising remote topic rc_channels
                                        GPS=AUTODETECT
                                        RC=SPEKTRUM
                                        ESC=VOXL_ESC
                                        OSD=DISABLE
                                        DAEMON_MODE=DISABLE
                                        SENSOR_CAL=ACTUAL
                                        EXTRA STEPS:
                                        ______  __   __    ___
                                        | ___ \ \ \ / /   /   |
                                        | |_/ /  \ V /   / /| |
                                        |  __/   /   \  / /_| |
                                        | |     / /^\ \ \___  |
                                        \_|     \/   \/     |_/
                                        px4 starting.
                                        GPS: AUTODETECT
                                        RC: SPEKTRUM
                                        ESC: VOXL_ESC
                                        OSD: DISABLE
                                        EXTRA STEPS:
                                        Running on M0054
                                        INFO  [muorb] SLPI:
                                        INFO  [muorb] SLPI:
                                        INFO  [muorb] SLPI:
                                        INFO  [muorb] SLPI:
                                        INFO  [muorb] SLPI:
                                        @Chase-Riley Does it seem to be working now? Can you calibrate RC now?
                                          @Eric-Katzfey And can you wait a little longer to get more data in the log? I'd like to see the data dumps of more packets.
