  3. Voxl2 Spektrum Receiver error
voxl-2
90 Posts 4 Posters 51.6k Views 3 Watching
  • Chase RileyC Chase Riley
    @Eric-Katzfey I had to trim the output to fit into a forum post.
    voxl2:/$ journalctl -b -u voxl-px4
    -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Thu 2023-03-02 13:13:00 UTC. --
    Mar 02 12:58:05 m0054 systemd[1]: Starting px4...
    Mar 02 12:58:07 m0054 systemd[1]: Started px4.
    Mar 02 12:58:07 m0054 voxl-px4[1878]: [INFO] Reading from /etc/modalai/voxl-px4.conf
    Mar 02 12:58:07 m0054 voxl-px4[1878]: Found DSP signature file
    Mar 02 12:58:07 m0054 voxl-px4[1878]: [INFO] Daemon mode enabled
    Mar 02 12:58:07 m0054 voxl-px4[1878]: *************************
    Mar 02 12:58:07 m0054 voxl-px4[1878]: GPS=AUTODETECT
    Mar 02 12:58:07 m0054 voxl-px4[1878]: RC=SPEKTRUM
    Mar 02 12:58:07 m0054 voxl-px4[1878]: ESC=VOXL_ESC
    Mar 02 12:58:07 m0054 voxl-px4[1878]: POWER MANAGER=VOXLPM
    Mar 02 12:58:07 m0054 voxl-px4[1878]: DISTANCE SENSOR=NONE
    Mar 02 12:58:07 m0054 voxl-px4[1878]: OSD=DISABLE
    Mar 02 12:58:07 m0054 voxl-px4[1878]: DAEMON_MODE=ENABLE
    Mar 02 12:58:07 m0054 voxl-px4[1878]: SENSOR_CAL=ACTUAL
    Mar 02 12:58:07 m0054 voxl-px4[1878]: EXTRA STEPS:
    Mar 02 12:58:07 m0054 voxl-px4[1878]: INFO  [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
    Mar 02 12:58:07 m0054 voxl-px4[1878]: INFO  [px4] assuming working directory is rootfs, no symlinks needed.
    Mar 02 12:58:07 m0054 voxl-px4[1878]: INFO  [muorb] Got muorb init command
    Mar 02 12:58:07 m0054 voxl-px4[1878]: Sending initialization request
    Mar 02 12:58:07 m0054 voxl-px4[1878]: Got topic data before configuration complete
    Mar 02 12:58:07 m0054 voxl-px4[1878]: GPS: AUTODETECT
    Mar 02 12:58:07 m0054 voxl-px4[1878]: RC: SPEKTRUM
    Mar 02 12:58:07 m0054 voxl-px4[1878]: ESC: VOXL_ESC
    Mar 02 12:58:07 m0054 voxl-px4[1878]: POWER MANAGER: VOXLPM
    Mar 02 12:58:07 m0054 voxl-px4[1878]: DISTANCE SENSOR: NONE
    Mar 02 12:58:07 m0054 voxl-px4[1878]: OSD: DISABLE
    Mar 02 12:58:07 m0054 voxl-px4[1878]: Running on M0054
    Mar 02 12:58:08 m0054 voxl-px4[1878]: INFO  [param] selected parameter default file /data/px4/param/parameters
    Mar 02 12:58:10 m0054 voxl-px4[1878]: INFO  [parameters] BSON document size 4125 bytes, decoded 4125 bytes (INT32:57, FLOAT:136)
    Mar 02 12:58:10 m0054 voxl-px4[1878]: Starting IMU driver with no rotation
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'icm42688p start -s -R 4'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11587369, local time: 11593616
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11630444, local time: 11631222
    Mar 02 12:58:11 m0054 voxl-px4[1878]: Looking for qmc5883l magnetometer
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: muorb aggregator thread running
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] muorb protobuf initalize method succeeded
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did ADVERTISE_TEST_TYPE
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread test_MUORB
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did SUBSCRIBE_TEST_TYPE
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did TOPIC_TEST_TYPE
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] muorb test passed
    Mar 02 12:58:11 m0054 voxl-px4[1878]: ______  __   __    ___
    Mar 02 12:58:11 m0054 voxl-px4[1878]: | ___ \ \ \ / /   /   |
    Mar 02 12:58:11 m0054 voxl-px4[1878]: | |_/ /  \ V /   / /| |
    Mar 02 12:58:11 m0054 voxl-px4[1878]: |  __/   /   \  / /_| |
    Mar 02 12:58:11 m0054 voxl-px4[1878]: | |     / /^\ \ \___  |
    Mar 02 12:58:11 m0054 voxl-px4[1878]: \_|     \/   \/     |_/
    Mar 02 12:58:11 m0054 voxl-px4[1878]: px4 starting.
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Advertising remote topic log_message
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [parameters] Starting param sync THREAD
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Starting param sync THREAD
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: before starting the qshell_entry task
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread qshell
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell entry.....
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Init app map initialized
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: after starting the qshell_entry task
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Advertising remote topic parameter_update
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_topic
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_topic
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [logger] logger started (mode=all)
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: icm42688p start -s -R 4
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'icm42688p'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg1 = 'start'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-s'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg3 = '-R'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '4'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_accel
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_gyro
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: ICM42688P::probe successful!
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: on SPI bus 1
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  rotation 4
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: >>> ICM42688P this: 3176ecd0
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: icm42688p start -s -R 4
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic qshell_retval
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ecd0
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_gyro_fifo
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_accel_fifo
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic imu_server
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'icp101xx'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-I'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg3 = '-b'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '5'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: icp101xx #0 on I2C bus 5
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0x63
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in procesINFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] cmd returned with: -1
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11661692, local time: 11664384
    Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [qshell] Command failed
    Mar 02 12:58:11 m0054 voxl-px4[1878]: Looking for ist8310 magnetometer
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11691188, local time: 11692742
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'gps start'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11724704, local time: 11726454
    Mar 02 12:58:11 m0054 voxl-px4[1878]: Looking for ncp5623c RGB LED
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11752678, local time: 11753969
    Mar 02 12:58:11 m0054 voxl-px4[1878]: Starting VOXL ESC driver
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'voxl_esc start'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11835821, local time: 11838037
    Mar 02 12:58:11 m0054 voxl-px4[1878]: Starting Spektrum RC
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'spektrum_rc start'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11886393, local time: 11888078
    Mar 02 12:58:11 m0054 voxl-px4[1878]: s_remote_topic
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: qmc5883l start -R 10 -X -b 1
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'qmc5883l'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-R'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg3 = '10'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '-X'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg5 = '-b'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg6 = '1'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0x80d09 527625
    Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: i2c probe failed
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: PX4_qshell: no instance started (no device on bus?)
    Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Failed to execute command: qmc5883l start -R 10 -X -b 1
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'ist8310'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0x60e09 396809
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: ist8310 #0 on I2C bus 1
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  (external)
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0xE
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  rotation 10
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: gps start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'gps'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread gps
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: gps start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'rgbled_ncp5623c'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-X'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '1'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg5 = '-f'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg6 = '400'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg7 = '-a'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg8 = '56'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0x38
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_mag
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: voxl_esc start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic actuator_outputs
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: voxl_esc start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Opened UART ESC device
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_baro
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: spektrum_rc start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097644
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: spektrum_rc start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic actuator_outputs_debug
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic esc_status
    Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x00
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'voxlpm'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '2'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Set i2c address 0x6a, fd 4
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Set i2c addINFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11923833, local time: 11926013
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'sensors start'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12118075, local time: 12122006
    Mar 02 12:58:11 m0054 voxl-px4[1878]: ress 0x44, fd 4
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic battery_status
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0x44
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic power_monitor
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: sensors start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'sensors'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_selection
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensors_status_imu
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_acceleration
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_angular_velocity
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_combined
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_air_data
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_gps_position
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensors_status_baro
    Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for CAL_MAG_COMP_TYP
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_magnetometer
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_preflight_mag
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_imu
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_imu_status
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: sensors start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensors_status_mag
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: ekf2 start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'ekf2'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Spektrum RCINFO  [qshell] Send cmd: 'ekf2 start'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12374104, local time: 12378323
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_pos_control start'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12482484, local time: 12483852
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_att_control start'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12525883, local time: 12527670
    Mar 02 12:58:11 m0054 voxl-px4[1878]: : Invalid DSM frame. 16 bytes. Protocol byte 0x00
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_attitude
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_local_position
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_event_flags
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_innovation_test_ratios
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_innovation_variances
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_innovations
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_sensor_bias
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_states
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_status_flags
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: ekf2 start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic ekf2_timestamps
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_odometry
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_baro_hgt
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_fake_pos
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_fake_hgt
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_gravity
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_pos_control'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic takeoff_status
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_att_control start
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_att_control'
    Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_att_control start
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertisedINFO  [qshell] Send cmd: 'mc_rate_control start'
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12616998, local time: 12618394
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12678757, local time: 12680493
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_autotune_attitude_control start'
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12721830, local time: 12722851
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'land_detector start multicopter'
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12767035, local time: 12769446
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'manual_control start'
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12821435, local time: 12823707
    Mar 02 12:58:12 m0054 voxl-px4[1878]:  in process_remote_topic
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_rate_control'
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg1 = 'start'
    Mar 02 12:58:12 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x00
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic rate_ctrl_status
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_hover_thrust_estimator'
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_autotune_attitude_control'
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic autotune_attitude_control_status
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'land_detector'
    Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = 'multicopter'
    Eric KatzfeyE Online
    @Chase-Riley said in Voxl2 Spektrum Receiver error:
    Yep, there's the error. That's the correct size but the code is expecting either 0x01 or 0x02 as valid protocols, not 0x00. Does it report 0x00 every single time or does it change? Is this the same transmitter you used earlier? Seems like it must be something different as that one was reporting 0x01, not 0x00. I can build a new version that also allows 0x00 and see if that fixes anything.
      Chase RileyC Offline
      Chase Riley
      wrote on last edited by Chase Riley
      #46
      @Eric-Katzfey it seems to change. I have seen different during testing. Same transmitter.
        Chase Riley
        #47
        @Chase-Riley Actually it may change with the frame rate in the transmitter. I just ran it 5 times without changing the settings and it stayed as 0x00.
        Update. I powered down the transmitter and when I ran again i received 0x5a
          @Chase-Riley Okay, well I'll just make a custom build for you that removes the check on that byte completely but that's probably not the right thing to do. But at least it will get us farther down the road. I'll try to think of some other useful debugging information to output as well.
            @Chase-Riley Seems like maybe the data on the serial line is getting corrupted somehow
              @Chase-Riley Actually, can you start the driver with the -v flag so that it produces more output and send me the log from that?
              Chase RileyC 2 Replies Last reply
                Chase Riley
                @Eric-Katzfey I am out of the office for the night. I will get back to you first thing in the morning EST. If you could try the custom file that would be great. It may help me continue testing while we work on debugging this issue more.
                  Chase Riley
                  @Eric-Katzfey Here is the log with the -v argument added to the Spektrum Driver Start.
                  voxl2:/$ voxl-px4 -d
                  [INFO] Disabling daemon mode
                  GPS=AUTODETECT
                  RC=SPEKTRUM
                  ESC=VOXL_ESC
                  OSD=DISABLE
                  DAEMON_MODE=DISABLE
                  SENSOR_CAL=ACTUAL
                  EXTRA STEPS:
                  ______  __   __    ___
                  | ___ \ \ \ / /   /   |
                  | |_/ /  \ V /   / /| |
                  |  __/   /   \  / /_| |
                  | |     / /^\ \ \___  |
                  \_|     \/   \/     |_/
                  px4 starting.
                  GPS: AUTODETECT
                  RC: SPEKTRUM
                  ESC: VOXL_ESC
                  OSD: DISABLE
                  EXTRA STEPS:
                  Running on M0054
                  INFO  [muorb] SLPI: >>> ICM42688P this: 3176cce0
                  INFO  [muorb] SLPI:
                  INFO  [qshell] qshell return value timestamp: 197304564, local time: 197310221
                  INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176cce0
                  INFO  [muorb] SLPI:
                  INFO  [qshell] qshell return value timestamp: 197356803, local time: 197358238
                  INFO  [qshell] qshell return value timestamp: 197389684, local time: 197391710
                  INFO  [muorb] SLPI:
                  INFO  [qshell] qshell return value timestamp: 197437606, local time: 197440108
                  INFO  [qshell] qshell return value timestamp: 197463075, local time: 197465432
                  INFO  [muorb] SLPI:
                  INFO  [qshell] qshell return value timestamp: 197515519, local time: 197517065
                  INFO  [muorb] SLPI: ubx msg 0x0107 invalid len 46584
                  INFO  [qshell] qshell return value timestamp: 197621321, local time: 197622953
                  INFO  [qshell] Send cmd: 'spektrum_rc start -v'
                  INFO  [muorb] SLPI: qshell gotten: spektrum_rc start -v
                  INFO  [muorb] SLPI:   arg2 = '-v'
                  INFO  [muorb] SLPI: Ok executing command: spektrum_rc start -v
                  INFO  [muorb] SLPI: Spektrum RC: Enabling verbose mode
                  INFO  [muorb] SLPI: Spektrum RC: dsm_init succeeded
                  INFO  [qshell] qshell return value timestamp: 197674334, local time: 197676244
                  INFO  [muorb] SLPI: Spektrum RC: Read no bytes from UART
                  INFO  [muorb] SLPI: Set i2c address 0x44, fd 4
                  ERROR [muorb] SLPI: Failed to execute command: voxlpm start -X -b 2
                  INFO  [qshell] qshell return value timestamp: 197707182, local time: 197710461
                    GPS=AUTODETECT
                    RC=SPEKTRUM
                    ESC=VOXL_ESC
                    OSD=DISABLE
                    DAEMON_MODE=DISABLE
                    SENSOR_CAL=ACTUAL
                    EXTRA STEPS:
                    ______  __   __    ___
                    | ___ \ \ \ / /   /   |
                    | |_/ /  \ V /   / /| |
                    |  __/   /   \  / /_| |
                    | |     / /^\ \ \___  |
                    \_|     \/   \/     |_/
                    px4 starting.
                    GPS: AUTODETECT
                    RC: SPEKTRUM
                    ESC: VOXL_ESC
                    OSD: DISABLE
                    EXTRA STEPS:
                    Running on M0054
                    INFO  [muorb] SLPI:
                    INFO  [muorb] SLPI:
                    INFO  [muorb] SLPI:
                    INFO  [muorb] SLPI:
                    @Chase-Riley Interesting. Okay, so in this case it's always 0x00. But you say you have seen other random values? Can you capture a log with that happening?
                      Chase Riley
                      #54
                      @Eric-Katzfey Here is the log you requested. To get a different value than 0x00 I just powered down and then powered back up the transmitter. I also ran it again after this test and received 0x5a.
                      GPS=AUTODETECT
                      RC=SPEKTRUM
                      ESC=VOXL_ESC
                      OSD=DISABLE
                      DAEMON_MODE=DISABLE
                      SENSOR_CAL=ACTUAL
                      EXTRA STEPS:
                      ______  __   __    ___
                      | ___ \ \ \ / /   /   |
                      | |_/ /  \ V /   / /| |
                      |  __/   /   \  / /_| |
                      | |     / /^\ \ \___  |
                      \_|     \/   \/     |_/
                      px4 starting.
                      GPS: AUTODETECT
                      RC: SPEKTRUM
                      ESC: VOXL_ESC
                      OSD: DISABLE
                      EXTRA STEPS:
                      Running on M0054
                      INFO  [muorb] SLPI: >>> ICM42688P this: 3176ccf0
                      INFO  [muorb] SLPI:
                      INFO  [qshell] qshell return value timestamp: 140652268, local time: 140655765
                      INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ccf0
                      INFO  [muorb] SLPI:
                      INFO  [qshell] qshell return value timestamp: 140688809, local time: 140690531
                      INFO  [qshell] qshell return value timestamp: 140728848, local time: 140731229
                      INFO  [muorb] SLPI:
                      INFO  [qshell] qshell return value timestamp: 140766613, local time: 140767902
                      INFO  [qshell] qshell return value timestamp: 140792157, local time: 140794315
                      INFO  [muorb] SLPI:
                      INFO  [qshell] qshell return value timestamp: 140826063, local time: 140827364
                      INFO  [qshell] qshell return value timestamp: 140915998, local time: 140917432
                      INFO  [qshell] qshell return value timestamp: 140957493, local time: 140958599
                      ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x2d
                      INFO  [muorb] SLPI:
                      INFO  [qshell] qshell return value timestamp: 140988963, local time: 140990201
                        GPS=AUTODETECT
                        RC=SPEKTRUM
                        ESC=VOXL_ESC
                        OSD=DISABLE
                        DAEMON_MODE=DISABLE
                        SENSOR_CAL=ACTUAL
                        EXTRA STEPS:
                        ______  __   __    ___
                        | ___ \ \ \ / /   /   |
                        | |_/ /  \ V /   / /| |
                        |  __/   /   \  / /_| |
                        | |     / /^\ \ \___  |
                        \_|     \/   \/     |_/
                        px4 starting.
                        GPS: AUTODETECT
                        RC: SPEKTRUM
                        ESC: VOXL_ESC
                        OSD: DISABLE
                        EXTRA STEPS:
                        Running on M0054
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI:
                        @Chase-Riley Okay, I'm preparing a new Debian that just completely removes that protocol byte check and, when verbose debug information is selected, will dump the complete frame contents about once a second so we can see what is actually being received at the driver.
                          Chase Riley
                          @Eric-Katzfey Ok. Looking forward to trying it out.
                            @Chase-Riley You can get it with wget https://storage.googleapis.com/modalai_public/forum/voxl-px4_1.14.66-6.0.0_arm64.deb
                              Chase Riley
                              @Eric-Katzfey Here is the log with the new Debian.
                              GPS=AUTODETECT
                              RC=SPEKTRUM
                              ESC=VOXL_ESC
                              OSD=DISABLE
                              DAEMON_MODE=DISABLE
                              SENSOR_CAL=ACTUAL
                              EXTRA STEPS:
                              ______  __   __    ___
                              | ___ \ \ \ / /   /   |
                              | |_/ /  \ V /   / /| |
                              |  __/   /   \  / /_| |
                              | |     / /^\ \ \___  |
                              \_|     \/   \/     |_/
                              px4 starting.
                              GPS: AUTODETECT
                              RC: SPEKTRUM
                              ESC: VOXL_ESC
                              OSD: DISABLE
                              EXTRA STEPS:
                              Running on M0054
                              INFO  [muorb] SLPI: >>> ICM42688P this: 3176ed20
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 108528422, local time: 108534280
                              INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ed20
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 108579731, local time: 108582550
                              INFO  [qshell] qshell return value timestamp: 108614169, local time: 108616786
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 108652161, local time: 108653528
                              INFO  [qshell] qshell return value timestamp: 108678128, local time: 108679924
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 108709712, local time: 108711831
                              INFO  [qshell] qshell return value timestamp: 108819381, local time: 108821923
                              INFO  [qshell] qshell return value timestamp: 108849790, local time: 108851570
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 108881654, local time: 108883951
                              ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_GPS_PRIME
                              INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x00
                              INFO  [muorb] SLPI: 0x00 0x00 0x81 0x86 0x39 0x56 0x1c 0x0d
                              INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x61 0x00
                              INFO  [qshell] qshell return value timestamp: 109070971, local time: 109078977
                              INFO  [uORB] Advertising remote topic input_rc
                              INFO  [muorb] SLPI: Spektrum RC: DSM message parsed successfully
                              INFO  [muorb] SLPI: Spektrum RC: Publishing input_rc
                              INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x63 0x00
                              INFO  [qshell] qshell return value timestamp: 109344658, local time: 109348511
                              INFO  [qshell] qshell return value timestamp: 109447440, local time: 109448532
                              INFO  [qshell] qshell return value timestamp: 109490661, local time: 109491803
                              INFO  [qshell] qshell return value timestamp: 109586749, local time: 109589982
                              INFO  [qshell] qshell return value timestamp: 109645064, local time: 109646589
                              INFO  [qshell] qshell return value timestamp: 109687598, local time: 109688691
                              INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x65 0x00
                              INFO  [qshell] qshell return value timestamp: 109739354, local time: 109741061
                              INFO  [uORB] Advertising remote topic vehicle_land_detected
                              INFO  [muorb] SLPI: baudrate set to 9600
                              INFO  [muorb] SLPI: qshell gotten: manual_control start
                              INFO  [muorb] SLPI:   arg0 = 'manual_control'
                              INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 1
                              INFO  [muorb] SLPI: Ok executing command: manual_control start
                              INFO  [qshell] qshell return value timestamp: 109801954, local time: 109803502
                              INFO  [uORB] Advertising remote topic manual_control_setpoint
                              INFO  [qshell] Send cmd: 'control_allocator start'
                              INFO  [muorb] SLPI: qshell gotten: control_allocator start
                              INFO  [muorb] SLPI:   arg0 = 'control_allocator'
                              INFO  [uORB] Advertising remote topic control_allocator_status
                              INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
                              INFO  [uORB] Advertising remote topic actuator_motors
                              INFO  [uORB] Advertising remote topic actuator_servos
                              INFO  [uORB] Advertising remote topic actuator_servos_trim
                              INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x67 0x00
                              INFO  [muorb] SLPI: Ok executing command: control_allocator start
                              INFO  [qshell] qshell return value timestamp: 110087397, local time: 110090284
                              INFO  [qshell] Send cmd: 'load_mon start'
                              INFO  [muorb] SLPI: qshell gotten: load_mon start
                              INFO  [muorb] SLPI:   arg0 = 'load_mon'
                              INFO  [muorb] SLPI: Ok executing command: load_mon start
                              INFO  [uORB] Advertising remote topic cpuload
                              INFO  [qshell] qshell return value timestamp: 110141759, local time: 110143643
                              INFO  [qshell] Send cmd: 'rc_update start'
                              INFO  [muorb] SLPI: qshell gotten: rc_update start
                              INFO  [muorb] SLPI:   arg0 = 'rc_update'
                              INFO  [muorb] SLPI: Ok executing command: rc_update start
                              INFO  [qshell] qshell return value timestamp: 110418193, local time: 110421870
                              INFO  [qshell] Send cmd: 'commander start'
                              INFO  [muorb] SLPI: qshell gotten: commander start
                              INFO  [muorb] SLPI:   arg0 = 'commander'
                              INFO  [muorb] SLPI: Creating pthread commander
                              INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097639
                              INFO  [uORB] Advertising remote topic rc_channels
                                GPS=AUTODETECT
                                RC=SPEKTRUM
                                ESC=VOXL_ESC
                                OSD=DISABLE
                                DAEMON_MODE=DISABLE
                                SENSOR_CAL=ACTUAL
                                EXTRA STEPS:
                                ______  __   __    ___
                                | ___ \ \ \ / /   /   |
                                | |_/ /  \ V /   / /| |
                                |  __/   /   \  / /_| |
                                | |     / /^\ \ \___  |
                                \_|     \/   \/     |_/
                                px4 starting.
                                GPS: AUTODETECT
                                RC: SPEKTRUM
                                ESC: VOXL_ESC
                                OSD: DISABLE
                                EXTRA STEPS:
                                Running on M0054
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI:
                                @Chase-Riley Does it seem to be working now? Can you calibrate RC now?
                                  @Eric-Katzfey And can you wait a little longer to get more data in the log? I'd like to see the data dumps of more packets.
                                    Chase Riley
                                    @Eric-Katzfey I am able to calibrate the RC now with that Debian. Here is the log after letting it run a little longer. Let me know if you need more in the log. Would you recommend flying with this Debian File?
                                    INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x03
                                    INFO  [muorb] SLPI: 0x00 0x03 0x81 0x56 0x39 0x56 0x1c 0x0c
                                    INFO  [qshell] qshell return value timestamp: 356493009, local time: 356495308
                                    INFO  [uORB] Advertising remote topic manual_control_input
                                    INFO  [uORB] Advertising remote topic manual_control_switches
                                    INFO  [uORB] Advertising remote topic action_request
                                    INFO  [uORB] Advertising remote topic led_control
                                    INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
                                    INFO  [uORB] Advertising remote topic tune_control
                                    INFO  [muorb] SLPI: Ok executing command: commander start
                                    INFO  [qshell] qshell return value timestamp: 356734246, local time: 356736417
                                    INFO  [uORB] Advertising remote topic event
                                    INFO  [uORB] Advertising remote topic health_report
                                    INFO  [uORB] Advertising remote topic failsafe_flags
                                    INFO  [uORB] Advertising remote topic actuator_armed
                                    INFO  [uORB] Advertising remote topic vehicle_control_mode
                                    INFO  [uORB] Advertising remote topic vehicle_status
                                    INFO  [uORB] Advertising remote topic failure_detector_status
                                    INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
                                    INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
                                    INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
                                    INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
                                    INFO  [qshell] Send cmd: 'flight_mode_manager start'
                                    INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
                                    INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
                                    INFO  [uORB] Advertising remote topic vehicle_command
                                    INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
                                    INFO  [qshell] qshell return value timestamp: 356898624, local time: 356901074
                                    INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
                                    INFO  [muorb] SLPI: Advertising remote topic transponder_report
                                    INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
                                    INFO  [modal_io_bridge] Modal IO Bridge driver starting
                                    INFO  [muorb] SLPI: Advertising remote topic telemetry_status
                                    INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
                                    INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
                                    INFO  [muorb] SLPI: Advertising remote topic timesync_status
                                    INFO  [uORB] Advertising remote topic actuator_controls_status_0
                                    INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
                                    INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
                                    INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
                                    pxh> INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x03
                                    INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 2
                                    INFO  [uORB] Advertising remote topic mavlink_log
                                    ERROR [muorb] SLPI: Preflight Fail: low battery
                                    INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 3
                                    INFO  [muorb] SLPI: u-blox firmware version: SPG 3.01
                                    INFO  [muorb] SLPI: u-blox protocol version: 18.00
                                    INFO  [muorb] SLPI: u-blox module: NEO-M8N-0
                                    INFO  [uORB] Advertising remote topic sensor_gps
                                    INFO  [uORB] Advertising remote topic home_position
                                    INFO  [uORB] Advertising remote topic estimator_gps_status
                                    INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_hgt
                                    INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_pos
                                    INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_vel
                                    INFO  [muorb] SLPI: Advertising remote topic mission_result
                                    INFO  [muorb] SLPI: Advertising remote topic ping
                                      @Chase-Riley Looks like the data is stable. It just doesn't seem the protocol byte to a stable value. Very odd. But I would try a flight with it in a carefully controlled environment in case anything goes wrong. In the worst case it could go out of control and you might not be able to use the kill switch so be safe.
                                        @Chase-Riley Here is a link to the transmitter we use: https://www.horizonhobby.com/product/dx6e-6-channel-dsmx-transmitter-only/SPMR6655.html
                                        Chase RileyC 4 Replies Last reply
                                          Chase Riley
                                          @Eric-Katzfey When getting everything tested to go out and fly I started receiving a failsafe for ESC failure. When we were working with this back in SDK 1.0 in this thread. I had the issue of the actuators tab not showing up in QGC. I can now see the actuators tab on SDK 1.1.2 however I can not test the motors and when I try to arm I receive ESC Failure message. I am not sure if this has something to do with the custom deb file like it did when I couldn't see the actuators tab.
                                          I can upload firmware and params to the ESC fine. Running voxl-esc-scan.py returns no issues. Any thoughts?
