  3. Voxl2 Spektrum Receiver error
voxl-2
90 Posts 4 Posters 49.8k Views 3 Watching
    @Chase-Riley Interesting. Okay, so in this case it's always 0x00. But you say you have seen other random values? Can you capture a log with that happening?
    Chase RileyC Offline
    Chase Riley
    wrote on last edited by Chase Riley
    #54
    @Eric-Katzfey Here is the log you requested. To get a different value than 0x00 I just powered down and then powered back up the transmitter. I also ran it again after this test and received 0x5a.
    voxl2:/$ voxl-px4 -d
    Found DSP signature file
    [INFO] Disabling daemon mode
    GPS=AUTODETECT
    RC=SPEKTRUM
    ESC=VOXL_ESC
    POWER MANAGER=VOXLPM
    DISTANCE SENSOR=NONE
    OSD=DISABLE
    DAEMON_MODE=DISABLE
    SENSOR_CAL=ACTUAL
    EXTRA STEPS:
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    GPS: AUTODETECT
    RC: SPEKTRUM
    ESC: VOXL_ESC
    POWER MANAGER: VOXLPM
    DISTANCE SENSOR: NONE
    OSD: DISABLE
    EXTRA STEPS:
    Running on M0054
    INFO  [parameters] BSON document size 4125 bytes, decoded 4125 bytes (INT32:57, FLOAT:136)
    INFO  [qshell] Send cmd: 'icm42688p start -s -R 4'
    INFO  [muorb] SLPI: qshell gotten: icm42688p start -s -R 4
    INFO  [muorb] SLPI:   arg3 = '-R'
    INFO  [muorb] SLPI:   arg4 = '4'
    INFO  [muorb] SLPI:  rotation 4
    INFO  [muorb] SLPI: >>> ICM42688P this: 3176ccf0
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: icm42688p start -s -R 4
    INFO  [qshell] qshell return value timestamp: 140652268, local time: 140655765
    INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ccf0
    INFO  [muorb] SLPI:
    INFO  [qshell] qshell return value timestamp: 140688809, local time: 140690531
    INFO  [qshell] qshell return value timestamp: 140728848, local time: 140731229
    ERROR [qshell] Command failed
    INFO  [muorb] SLPI:
    INFO  [qshell] qshell return value timestamp: 140766613, local time: 140767902
    INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
    INFO  [qshell] qshell return value timestamp: 140792157, local time: 140794315
    Looking for ncp5623c RGB LED
    INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
    INFO  [muorb] SLPI:  address 0x38
    INFO  [muorb] SLPI:
    INFO  [qshell] qshell return value timestamp: 140826063, local time: 140827364
    Starting VOXL ESC driver
    INFO  [qshell] Send cmd: 'voxl_esc start'
    INFO  [muorb] SLPI: qshell gotten: voxl_esc start
    INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
    INFO  [muorb] SLPI: Ok executing command: voxl_esc start
    INFO  [muorb] SLPI: Opened UART ESC device
    INFO  [qshell] qshell return value timestamp: 140915998, local time: 140917432
    Starting Spektrum RC
    INFO  [qshell] Send cmd: 'spektrum_rc start -v'
    INFO  [muorb] SLPI: qshell gotten: spektrum_rc start -v
    INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
    INFO  [muorb] SLPI:   arg2 = '-v'
    INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
    INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097644
    INFO  [muorb] SLPI: Ok executing command: spektrum_rc start -v
    INFO  [muorb] SLPI: Spektrum RC: Enabling verbose mode
    INFO  [muorb] SLPI: Spektrum RC: dsm_init succeeded
    INFO  [qshell] qshell return value timestamp: 140957493, local time: 140958599
    INFO  [muorb] SLPI: Spektrum RC: Read no bytes from UART
    ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x2d
    INFO  [uORB] Advertising remote topic actuator_outputs_debug
    INFO  [uORB] Advertising remote topic esc_status
    INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
    INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
    INFO  [muorb] SLPI:   arg0 = 'voxlpm'
    INFO  [muorb] SLPI:   arg4 = '2'
    INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
    INFO  [muorb] SLPI: Set i2c address 0x6a, fd 4
    INFO  [muorb] SLPI: Set i2c address 0x44, fd 4
    INFO  [uORB] Advertising remote topic battery_status
    INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
    INFO  [muorb] SLPI:  address 0x44
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
    INFO  [qshell] qshell return value timestamp: 140988963, local time: 140990201
    INFO  [uORB] Advertising remote topic power_monitor
    • Chase RileyC Chase Riley
      GPS=AUTODETECT
      RC=SPEKTRUM
      ESC=VOXL_ESC
      OSD=DISABLE
      DAEMON_MODE=DISABLE
      SENSOR_CAL=ACTUAL
      EXTRA STEPS:
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      GPS: AUTODETECT
      RC: SPEKTRUM
      ESC: VOXL_ESC
      OSD: DISABLE
      EXTRA STEPS:
      Running on M0054
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      Eric KatzfeyE Online
      @Chase-Riley Okay, I'm preparing a new Debian that just completely removes that protocol byte check and, when verbose debug information is selected, will dump the complete frame contents about once a second so we can see what is actually being received at the driver.
        Chase Riley
        @Eric-Katzfey Ok. Looking forward to trying it out.
          @Chase-Riley You can get it with wget https://storage.googleapis.com/modalai_public/forum/voxl-px4_1.14.66-6.0.0_arm64.deb
            Chase Riley
            @Eric-Katzfey Here is the log with the new Debian.
            GPS=AUTODETECT
            RC=SPEKTRUM
            ESC=VOXL_ESC
            OSD=DISABLE
            DAEMON_MODE=DISABLE
            SENSOR_CAL=ACTUAL
            EXTRA STEPS:
            ______  __   __    ___
            | ___ \ \ \ / /   /   |
            | |_/ /  \ V /   / /| |
            |  __/   /   \  / /_| |
            | |     / /^\ \ \___  |
            \_|     \/   \/     |_/
            px4 starting.
            GPS: AUTODETECT
            RC: SPEKTRUM
            ESC: VOXL_ESC
            OSD: DISABLE
            EXTRA STEPS:
            Running on M0054
            INFO  [muorb] SLPI: >>> ICM42688P this: 3176ed20
            INFO  [muorb] SLPI:
            INFO  [qshell] qshell return value timestamp: 108528422, local time: 108534280
            INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ed20
            INFO  [muorb] SLPI:
            INFO  [qshell] qshell return value timestamp: 108579731, local time: 108582550
            INFO  [qshell] qshell return value timestamp: 108614169, local time: 108616786
            INFO  [muorb] SLPI:
            INFO  [qshell] qshell return value timestamp: 108652161, local time: 108653528
            INFO  [qshell] qshell return value timestamp: 108678128, local time: 108679924
            INFO  [muorb] SLPI:
            INFO  [qshell] qshell return value timestamp: 108709712, local time: 108711831
            INFO  [qshell] qshell return value timestamp: 108819381, local time: 108821923
            INFO  [qshell] qshell return value timestamp: 108849790, local time: 108851570
            INFO  [muorb] SLPI:
            INFO  [qshell] qshell return value timestamp: 108881654, local time: 108883951
            ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_GPS_PRIME
            INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x00
            INFO  [muorb] SLPI: 0x00 0x00 0x81 0x86 0x39 0x56 0x1c 0x0d
            INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x61 0x00
            INFO  [uORB] Advertising remote topic sensors_status_mag
            INFO  [qshell] qshell return value timestamp: 109070971, local time: 109078977
            INFO  [uORB] Advertising remote topic input_rc
            INFO  [muorb] SLPI: Spektrum RC: DSM message parsed successfully
            INFO  [muorb] SLPI: Spektrum RC: Publishing input_rc
            INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x63 0x00
            INFO  [qshell] qshell return value timestamp: 109344658, local time: 109348511
            INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
            INFO  [qshell] qshell return value timestamp: 109447440, local time: 109448532
            INFO  [qshell] qshell return value timestamp: 109490661, local time: 109491803
            INFO  [qshell] qshell return value timestamp: 109586749, local time: 109589982
            INFO  [qshell] qshell return value timestamp: 109645064, local time: 109646589
            INFO  [qshell] qshell return value timestamp: 109687598, local time: 109688691
            INFO  [muorb] SLPI:   arg0 = 'land_detector'
            INFO  [muorb] SLPI:   arg2 = 'multicopter'
            INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x65 0x00
            INFO  [qshell] qshell return value timestamp: 109739354, local time: 109741061
            INFO  [uORB] Advertising remote topic vehicle_land_detected
            INFO  [muorb] SLPI: baudrate set to 9600
            INFO  [qshell] Send cmd: 'manual_control start'
            INFO  [muorb] SLPI: qshell gotten: manual_control start
            INFO  [muorb] SLPI:   arg0 = 'manual_control'
            INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 1
            INFO  [muorb] SLPI: Ok executing command: manual_control start
            INFO  [qshell] qshell return value timestamp: 109801954, local time: 109803502
            INFO  [uORB] Advertising remote topic manual_control_setpoint
            INFO  [qshell] Send cmd: 'control_allocator start'
            INFO  [muorb] SLPI: qshell gotten: control_allocator start
            INFO  [muorb] SLPI:   arg0 = 'control_allocator'
            INFO  [uORB] Advertising remote topic control_allocator_status
            INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
            INFO  [uORB] Advertising remote topic actuator_motors
            INFO  [uORB] Advertising remote topic actuator_servos
            INFO  [uORB] Advertising remote topic actuator_servos_trim
            INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x67 0x00
            INFO  [muorb] SLPI: Ok executing command: control_allocator start
            INFO  [qshell] qshell return value timestamp: 110087397, local time: 110090284
            INFO  [qshell] Send cmd: 'load_mon start'
            INFO  [muorb] SLPI: qshell gotten: load_mon start
            INFO  [muorb] SLPI:   arg0 = 'load_mon'
            INFO  [muorb] SLPI: Ok executing command: load_mon start
            INFO  [uORB] Advertising remote topic cpuload
            INFO  [qshell] qshell return value timestamp: 110141759, local time: 110143643
            INFO  [qshell] Send cmd: 'rc_update start'
            INFO  [muorb] SLPI: qshell gotten: rc_update start
            INFO  [muorb] SLPI:   arg0 = 'rc_update'
            INFO  [muorb] SLPI: Ok executing command: rc_update start
            INFO  [qshell] qshell return value timestamp: 110418193, local time: 110421870
            INFO  [qshell] Send cmd: 'commander start'
            INFO  [muorb] SLPI: qshell gotten: commander start
            INFO  [muorb] SLPI:   arg0 = 'commander'
            INFO  [muorb] SLPI: Creating pthread commander
            INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097639
            INFO  [uORB] Advertising remote topic rc_channels
              GPS=AUTODETECT
              RC=SPEKTRUM
              ESC=VOXL_ESC
              OSD=DISABLE
              DAEMON_MODE=DISABLE
              SENSOR_CAL=ACTUAL
              EXTRA STEPS:
              ______  __   __    ___
              | ___ \ \ \ / /   /   |
              | |_/ /  \ V /   / /| |
              |  __/   /   \  / /_| |
              | |     / /^\ \ \___  |
              \_|     \/   \/     |_/
              px4 starting.
              GPS: AUTODETECT
              RC: SPEKTRUM
              ESC: VOXL_ESC
              OSD: DISABLE
              EXTRA STEPS:
              Running on M0054
              INFO  [muorb] SLPI:
              INFO  [muorb] SLPI:
              INFO  [muorb] SLPI:
              INFO  [muorb] SLPI:
              INFO  [muorb] SLPI:
              @Chase-Riley Does it seem to be working now? Can you calibrate RC now?
                @Eric-Katzfey And can you wait a little longer to get more data in the log? I'd like to see the data dumps of more packets.
                  Chase Riley
                  @Eric-Katzfey I am able to calibrate the RC now with that Debian. Here is the log after letting it run a little longer. Let me know if you need more in the log. Would you recommend flying with this Debian File?
                  INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x03
                  INFO  [muorb] SLPI: 0x00 0x03 0x81 0x56 0x39 0x56 0x1c 0x0c
                  INFO  [qshell] qshell return value timestamp: 356493009, local time: 356495308
                  INFO  [uORB] Advertising remote topic manual_control_input
                  INFO  [uORB] Advertising remote topic manual_control_switches
                  INFO  [uORB] Advertising remote topic action_request
                  INFO  [uORB] Advertising remote topic led_control
                  INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
                  INFO  [uORB] Advertising remote topic tune_control
                  INFO  [muorb] SLPI: Ok executing command: commander start
                  INFO  [qshell] qshell return value timestamp: 356734246, local time: 356736417
                  INFO  [uORB] Advertising remote topic event
                  INFO  [uORB] Advertising remote topic health_report
                  INFO  [uORB] Advertising remote topic failsafe_flags
                  INFO  [uORB] Advertising remote topic actuator_armed
                  INFO  [uORB] Advertising remote topic vehicle_control_mode
                  INFO  [uORB] Advertising remote topic vehicle_status
                  INFO  [uORB] Advertising remote topic failure_detector_status
                  INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
                  INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
                  INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
                  INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
                  INFO  [qshell] Send cmd: 'flight_mode_manager start'
                  INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
                  INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
                  INFO  [uORB] Advertising remote topic vehicle_command
                  INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
                  INFO  [qshell] qshell return value timestamp: 356898624, local time: 356901074
                  INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
                  INFO  [muorb] SLPI: Advertising remote topic transponder_report
                  INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
                  INFO  [modal_io_bridge] Modal IO Bridge driver starting
                  INFO  [muorb] SLPI: Advertising remote topic telemetry_status
                  INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
                  INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
                  INFO  [muorb] SLPI: Advertising remote topic timesync_status
                  INFO  [uORB] Advertising remote topic actuator_controls_status_0
                  INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
                  INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
                  INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
                  pxh> INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x03
                  INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 2
                  INFO  [uORB] Advertising remote topic mavlink_log
                  ERROR [muorb] SLPI: Preflight Fail: low battery
                  INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 3
                  INFO  [muorb] SLPI: u-blox firmware version: SPG 3.01
                  INFO  [muorb] SLPI: u-blox protocol version: 18.00
                  INFO  [muorb] SLPI: u-blox module: NEO-M8N-0
                  INFO  [uORB] Advertising remote topic sensor_gps
                  INFO  [uORB] Advertising remote topic home_position
                  INFO  [uORB] Advertising remote topic estimator_gps_status
                  INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_hgt
                  INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_pos
                  INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_vel
                  INFO  [muorb] SLPI: Advertising remote topic mission_result
                  INFO  [muorb] SLPI: Advertising remote topic ping
                    @Chase-Riley Looks like the data is stable. It just doesn't seem the protocol byte to a stable value. Very odd. But I would try a flight with it in a carefully controlled environment in case anything goes wrong. In the worst case it could go out of control and you might not be able to use the kill switch so be safe.
                      @Chase-Riley Here is a link to the transmitter we use: https://www.horizonhobby.com/product/dx6e-6-channel-dsmx-transmitter-only/SPMR6655.html
                      Chase RileyC 4 Replies Last reply
                        Chase Riley
                        @Eric-Katzfey When getting everything tested to go out and fly I started receiving a failsafe for ESC failure. When we were working with this back in SDK 1.0 in this thread. I had the issue of the actuators tab not showing up in QGC. I can now see the actuators tab on SDK 1.1.2 however I can not test the motors and when I try to arm I receive ESC Failure message. I am not sure if this has something to do with the custom deb file like it did when I couldn't see the actuators tab.
                        I can upload firmware and params to the ESC fine. Running voxl-esc-scan.py returns no issues. Any thoughts?
                          Chase Riley
                          #65
                          @Eric-Katzfey I was able to solve the ESC issue. It was not linked to the Spektrum issue. After getting the ESC to function I was not able to control throttle on the air vehicle. I am able to calibrate the RC controller and set flight modes and so on. Everything seems normal until a arm the motors (testing in Stabilize). The motors arm and spin up but I am unable to change the speed on the motors with any input of the controller. I checked the Px4 RC params and all match previously good known params. I have inlcluded a snippet of running voxl-px4 -d with Spektrum sill with -v argument. I noticed there was another error with a different value and was also 32 bytes instead of the 16 bytes we have been seeing.
                          INFO  [muorb] SLPI: 0x21 0x56 0x36 0xaa 0x54 0x00 0x63 0x00
                          INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x02
                          INFO  [muorb] SLPI: 0x00 0x02 0x0b 0xf5 0x2e 0xaa 0x13 0xfe
                          INFO  [muorb] SLPI: 0x21 0x56 0x36 0xaa 0x54 0x00 0x65 0x00
                          INFO  [muorb] SLPI: 0x00 0x02 0x0b 0xf5 0x2e 0xaa 0x13 0xff
                          INFO  [muorb] SLPI: Armed by external command
                          INFO  [uORB] Advertising remote topic vehicle_command_ack
                          INFO  [logger] Start file log (type: full)
                          WARN  [uORB] orb_advertise_multi: failed to set queue size
                          INFO  [logger] [logger] /data/px4/log/2024-01-23/16_57_27.ulg
                          WARN  [mavlink] Event dropped (7, 65526)
                          INFO  [logger] Opened full log file: /data/px4/log/2024-01-23/16_57_27.ulg
                          INFO  [muorb] SLPI: Advertising remote topic logger_status
                          WARN  [mavlink] Dropped 65519 events (seq=65526)
                          INFO  [muorb] SLPI: Takeoff detected
                          WARN  [mavlink] Event dropped (65527, 7)
                          WARN  [mavlink] Dropped 7 events (seq=7)
                          INFO  [muorb] SLPI: Landing detected
                          ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 32 bytes. Protocol byte 0x02
                          INFO  [muorb] SLPI: Disarmed by landing
                          INFO  [uORB] Marking DeviceNode(parameter_server_set_value_request) as advertised in process_remote_topic
                          INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_value_response) as advertised in process_remote_t
                            Chase Riley
                            #66
                            @Eric-Katzfey I am also getting my hands on a DX6e for me to test. I should be able to try that in the morning. I still would like to figure out the DX8 as well though since we already have a bunch on hand in our lab.
                              @Chase-Riley Did you analyze the flight log?
                                @Chase-Riley For the DX8 there are some configuration options on the transmitter. There is DSMX versus DSM2. That may need to be changed. Have you tried the different options yet?
                                  Chase Riley
                                  @Eric-Katzfey I have tried all of the options in the DX8. 11, 22 and DSM2, DSMX. They all seemed to produce the same results in the logs.
                                    Chase Riley
                                    @Eric-Katzfey Here is a voxl-px4 log while testing with a DX6e this morning. I was able to bind and calibrate no problem. I am just not able to control the motors. Flight mode and kill switch seem to be working fine. So seems to have the same behavior as the DX8 with a error in the log for 32 bytes and 0x00.
                                    INFO  [muorb] SLPI: 0x00 0x00 0x8c 0x05 0x01 0x56 0x14 0x00
                                    INFO  [muorb] SLPI: 0x1b 0xf5 0x2e 0xaa 0x3c 0x00 0x34 0x00
                                    INFO  [muorb] SLPI: 0x1b 0xf6 0x2e 0xaa 0x3c 0x00 0x34 0x00
                                    ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 32 bytes. Protocol byte 0x00
                                    INFO  [logger] [logger] /data/px4/log/2024-01-24/19_14_37.ulg
                                    INFO  [logger] Opened full log file: /data/px4/log/2024-01-24/19_14_37.ulg
                                    WARN  [mavlink] Event dropped (297, 65527)
                                    WARN  [mavlink] Dropped 65230 events (seq=65527)
                                      @Chase-Riley Huh, that still doesn't look right. When you calibrate you can move each stick and it shows properly in QGC? And listener input_rc shows the values moving properly when you move the sticks? What is the value of the parameter COM_RC_IN_MODE?
                                        Chase Riley
                                        @Eric-Katzfey yes, each stick moves correctly in QGC. listener input_rc shows all sticks move correctly. I have tested with COM_RC_IN_MODE set to 0 and 2 and both yield the same results.
                                          @Chase-Riley And they are mapped correctly such that throttle is on the stick you want? Can you do listener on manual_control_setpoint and see the throttle value move when you move the throttle stick?
