  3. Voxl2 Spektrum Receiver error
voxl-2
90 Posts 4 Posters 51.6k Views 3 Watching
    @Chase-Riley Actually, can you start the driver with the -v flag so that it produces more output and send me the log from that?
    Chase RileyC Offline
    Chase Riley
    @Eric-Katzfey I am out of the office for the night. I will get back to you first thing in the morning EST. If you could try the custom file that would be great. It may help me continue testing while we work on debugging this issue more.
      Chase Riley
      @Eric-Katzfey Here is the log with the -v argument added to the Spektrum Driver Start.
      voxl2:/$ voxl-px4 -d
      Found DSP signature file
      [INFO] Disabling daemon mode
      GPS=AUTODETECT
      RC=SPEKTRUM
      ESC=VOXL_ESC
      POWER MANAGER=VOXLPM
      DISTANCE SENSOR=NONE
      OSD=DISABLE
      DAEMON_MODE=DISABLE
      SENSOR_CAL=ACTUAL
      EXTRA STEPS:
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      GPS: AUTODETECT
      RC: SPEKTRUM
      ESC: VOXL_ESC
      POWER MANAGER: VOXLPM
      DISTANCE SENSOR: NONE
      OSD: DISABLE
      EXTRA STEPS:
      Running on M0054
      INFO  [parameters] BSON document size 4125 bytes, decoded 4125 bytes (INT32:57, FLOAT:136)
      INFO  [qshell] Send cmd: 'icm42688p start -s -R 4'
      INFO  [muorb] SLPI: qshell gotten: icm42688p start -s -R 4
      INFO  [muorb] SLPI:   arg3 = '-R'
      INFO  [muorb] SLPI:   arg4 = '4'
      INFO  [muorb] SLPI:  rotation 4
      INFO  [muorb] SLPI: >>> ICM42688P this: 3176cce0
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI: Ok executing command: icm42688p start -s -R 4
      INFO  [qshell] qshell return value timestamp: 197304564, local time: 197310221
      INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176cce0
      INFO  [muorb] SLPI:
      INFO  [qshell] qshell return value timestamp: 197356803, local time: 197358238
      INFO  [qshell] qshell return value timestamp: 197389684, local time: 197391710
      ERROR [qshell] Command failed
      INFO  [muorb] SLPI:
      INFO  [qshell] qshell return value timestamp: 197437606, local time: 197440108
      INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
      INFO  [qshell] qshell return value timestamp: 197463075, local time: 197465432
      Looking for ncp5623c RGB LED
      INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
      INFO  [muorb] SLPI:  address 0x38
      INFO  [muorb] SLPI:
      INFO  [qshell] qshell return value timestamp: 197515519, local time: 197517065
      Starting VOXL ESC driver
      INFO  [qshell] Send cmd: 'voxl_esc start'
      INFO  [muorb] SLPI: qshell gotten: voxl_esc start
      INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
      INFO  [muorb] SLPI: ubx msg 0x0107 invalid len 46584
      INFO  [muorb] SLPI: Ok executing command: voxl_esc start
      INFO  [muorb] SLPI: Opened UART ESC device
      INFO  [qshell] qshell return value timestamp: 197621321, local time: 197622953
      Starting Spektrum RC
      INFO  [qshell] Send cmd: 'spektrum_rc start -v'
      INFO  [muorb] SLPI: qshell gotten: spektrum_rc start -v
      INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
      INFO  [muorb] SLPI:   arg2 = '-v'
      INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
      INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097644
      INFO  [muorb] SLPI: Ok executing command: spektrum_rc start -v
      INFO  [muorb] SLPI: Spektrum RC: Enabling verbose mode
      INFO  [muorb] SLPI: Spektrum RC: dsm_init succeeded
      INFO  [qshell] qshell return value timestamp: 197674334, local time: 197676244
      INFO  [uORB] Advertising remote topic actuator_outputs_debug
      INFO  [uORB] Advertising remote topic esc_status
      INFO  [muorb] SLPI: Spektrum RC: Read no bytes from UART
      ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x00
      INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
      INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
      INFO  [muorb] SLPI:   arg0 = 'voxlpm'
      INFO  [muorb] SLPI:   arg4 = '2'
      INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
      INFO  [muorb] SLPI: Set i2c address 0x6a, fd 4
      INFO  [muorb] SLPI: Set i2c address 0x44, fd 4
      ERROR [muorb] SLPI: Failed to execute command: voxlpm start -X -b 2
      INFO  [qshell] qshell return value timestamp: 197707182, local time: 197710461
      • Chase RileyC Chase Riley
        GPS=AUTODETECT
        RC=SPEKTRUM
        ESC=VOXL_ESC
        OSD=DISABLE
        DAEMON_MODE=DISABLE
        SENSOR_CAL=ACTUAL
        EXTRA STEPS:
        ______  __   __    ___
        | ___ \ \ \ / /   /   |
        | |_/ /  \ V /   / /| |
        |  __/   /   \  / /_| |
        | |     / /^\ \ \___  |
        \_|     \/   \/     |_/
        px4 starting.
        GPS: AUTODETECT
        RC: SPEKTRUM
        ESC: VOXL_ESC
        OSD: DISABLE
        EXTRA STEPS:
        Running on M0054
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI:
        Eric KatzfeyE Online
        @Chase-Riley Interesting. Okay, so in this case it's always 0x00. But you say you have seen other random values? Can you capture a log with that happening?
          Chase Riley
          wrote on last edited by Chase Riley
          #54
          @Eric-Katzfey Here is the log you requested. To get a different value than 0x00 I just powered down and then powered back up the transmitter. I also ran it again after this test and received 0x5a.
          GPS=AUTODETECT
          RC=SPEKTRUM
          ESC=VOXL_ESC
          OSD=DISABLE
          DAEMON_MODE=DISABLE
          SENSOR_CAL=ACTUAL
          EXTRA STEPS:
          ______  __   __    ___
          | ___ \ \ \ / /   /   |
          | |_/ /  \ V /   / /| |
          |  __/   /   \  / /_| |
          | |     / /^\ \ \___  |
          \_|     \/   \/     |_/
          px4 starting.
          GPS: AUTODETECT
          RC: SPEKTRUM
          ESC: VOXL_ESC
          OSD: DISABLE
          EXTRA STEPS:
          Running on M0054
          INFO  [muorb] SLPI: >>> ICM42688P this: 3176ccf0
          INFO  [muorb] SLPI:
          INFO  [qshell] qshell return value timestamp: 140652268, local time: 140655765
          INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ccf0
          INFO  [muorb] SLPI:
          INFO  [qshell] qshell return value timestamp: 140688809, local time: 140690531
          INFO  [qshell] qshell return value timestamp: 140728848, local time: 140731229
          INFO  [muorb] SLPI:
          INFO  [qshell] qshell return value timestamp: 140766613, local time: 140767902
          INFO  [qshell] qshell return value timestamp: 140792157, local time: 140794315
          INFO  [muorb] SLPI:
          INFO  [qshell] qshell return value timestamp: 140826063, local time: 140827364
          INFO  [qshell] qshell return value timestamp: 140915998, local time: 140917432
          INFO  [qshell] qshell return value timestamp: 140957493, local time: 140958599
          ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x2d
          INFO  [uORB] Advertising remote topic battery_status
          INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
          INFO  [muorb] SLPI:  address 0x44
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
          INFO  [qshell] qshell return value timestamp: 140988963, local time: 140990201
          INFO  [uORB] Advertising remote topic power_monitor
            GPS=AUTODETECT
            RC=SPEKTRUM
            ESC=VOXL_ESC
            OSD=DISABLE
            DAEMON_MODE=DISABLE
            SENSOR_CAL=ACTUAL
            EXTRA STEPS:
            ______  __   __    ___
            | ___ \ \ \ / /   /   |
            | |_/ /  \ V /   / /| |
            |  __/   /   \  / /_| |
            | |     / /^\ \ \___  |
            \_|     \/   \/     |_/
            px4 starting.
            GPS: AUTODETECT
            RC: SPEKTRUM
            ESC: VOXL_ESC
            OSD: DISABLE
            EXTRA STEPS:
            Running on M0054
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI:
            @Chase-Riley Okay, I'm preparing a new Debian that just completely removes that protocol byte check and, when verbose debug information is selected, will dump the complete frame contents about once a second so we can see what is actually being received at the driver.
              Chase Riley
              @Eric-Katzfey Ok. Looking forward to trying it out.
                @Chase-Riley You can get it with wget https://storage.googleapis.com/modalai_public/forum/voxl-px4_1.14.66-6.0.0_arm64.deb
                  Chase Riley
                  @Eric-Katzfey Here is the log with the new Debian.
                  GPS=AUTODETECT
                  RC=SPEKTRUM
                  ESC=VOXL_ESC
                  OSD=DISABLE
                  DAEMON_MODE=DISABLE
                  SENSOR_CAL=ACTUAL
                  EXTRA STEPS:
                  ______  __   __    ___
                  | ___ \ \ \ / /   /   |
                  | |_/ /  \ V /   / /| |
                  |  __/   /   \  / /_| |
                  | |     / /^\ \ \___  |
                  \_|     \/   \/     |_/
                  px4 starting.
                  GPS: AUTODETECT
                  RC: SPEKTRUM
                  ESC: VOXL_ESC
                  OSD: DISABLE
                  EXTRA STEPS:
                  Running on M0054
                  INFO  [muorb] SLPI: >>> ICM42688P this: 3176ed20
                  INFO  [muorb] SLPI:
                  INFO  [qshell] qshell return value timestamp: 108528422, local time: 108534280
                  INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ed20
                  INFO  [muorb] SLPI:
                  INFO  [qshell] qshell return value timestamp: 108579731, local time: 108582550
                  INFO  [qshell] qshell return value timestamp: 108614169, local time: 108616786
                  INFO  [muorb] SLPI:
                  INFO  [qshell] qshell return value timestamp: 108652161, local time: 108653528
                  INFO  [qshell] qshell return value timestamp: 108678128, local time: 108679924
                  INFO  [muorb] SLPI:
                  INFO  [qshell] qshell return value timestamp: 108709712, local time: 108711831
                  INFO  [qshell] qshell return value timestamp: 108819381, local time: 108821923
                  INFO  [qshell] qshell return value timestamp: 108849790, local time: 108851570
                  INFO  [muorb] SLPI:
                  INFO  [qshell] qshell return value timestamp: 108881654, local time: 108883951
                  ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_GPS_PRIME
                  INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x00
                  INFO  [muorb] SLPI: 0x00 0x00 0x81 0x86 0x39 0x56 0x1c 0x0d
                  INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x61 0x00
                  INFO  [uORB] Advertising remote topic sensors_status_mag
                  INFO  [qshell] qshell return value timestamp: 109070971, local time: 109078977
                  INFO  [uORB] Advertising remote topic input_rc
                  INFO  [muorb] SLPI: Spektrum RC: DSM message parsed successfully
                  INFO  [muorb] SLPI: Spektrum RC: Publishing input_rc
                  INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x63 0x00
                  INFO  [qshell] qshell return value timestamp: 109344658, local time: 109348511
                  INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
                  INFO  [qshell] qshell return value timestamp: 109447440, local time: 109448532
                  INFO  [qshell] qshell return value timestamp: 109490661, local time: 109491803
                  INFO  [qshell] qshell return value timestamp: 109586749, local time: 109589982
                  INFO  [qshell] qshell return value timestamp: 109645064, local time: 109646589
                  INFO  [qshell] qshell return value timestamp: 109687598, local time: 109688691
                  INFO  [muorb] SLPI:   arg0 = 'land_detector'
                  INFO  [muorb] SLPI:   arg2 = 'multicopter'
                  INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x65 0x00
                  INFO  [qshell] qshell return value timestamp: 109739354, local time: 109741061
                  INFO  [uORB] Advertising remote topic vehicle_land_detected
                  INFO  [muorb] SLPI: baudrate set to 9600
                  INFO  [qshell] Send cmd: 'manual_control start'
                  INFO  [muorb] SLPI: qshell gotten: manual_control start
                  INFO  [muorb] SLPI:   arg0 = 'manual_control'
                  INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 1
                  INFO  [muorb] SLPI: Ok executing command: manual_control start
                  INFO  [qshell] qshell return value timestamp: 109801954, local time: 109803502
                  INFO  [uORB] Advertising remote topic manual_control_setpoint
                  INFO  [qshell] Send cmd: 'control_allocator start'
                  INFO  [muorb] SLPI: qshell gotten: control_allocator start
                  INFO  [muorb] SLPI:   arg0 = 'control_allocator'
                  INFO  [uORB] Advertising remote topic control_allocator_status
                  INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
                  INFO  [uORB] Advertising remote topic actuator_motors
                  INFO  [uORB] Advertising remote topic actuator_servos
                  INFO  [uORB] Advertising remote topic actuator_servos_trim
                  INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x67 0x00
                  INFO  [muorb] SLPI: Ok executing command: control_allocator start
                  INFO  [qshell] qshell return value timestamp: 110087397, local time: 110090284
                  INFO  [qshell] Send cmd: 'load_mon start'
                  INFO  [muorb] SLPI: qshell gotten: load_mon start
                  INFO  [muorb] SLPI:   arg0 = 'load_mon'
                  INFO  [muorb] SLPI: Ok executing command: load_mon start
                  INFO  [uORB] Advertising remote topic cpuload
                  INFO  [qshell] qshell return value timestamp: 110141759, local time: 110143643
                  INFO  [qshell] Send cmd: 'rc_update start'
                  INFO  [muorb] SLPI: qshell gotten: rc_update start
                  INFO  [muorb] SLPI:   arg0 = 'rc_update'
                  INFO  [muorb] SLPI: Ok executing command: rc_update start
                  INFO  [qshell] qshell return value timestamp: 110418193, local time: 110421870
                  INFO  [qshell] Send cmd: 'commander start'
                  INFO  [muorb] SLPI: qshell gotten: commander start
                  INFO  [muorb] SLPI:   arg0 = 'commander'
                  INFO  [muorb] SLPI: Creating pthread commander
                  INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097639
                  INFO  [uORB] Advertising remote topic rc_channels
                    GPS=AUTODETECT
                    RC=SPEKTRUM
                    ESC=VOXL_ESC
                    OSD=DISABLE
                    DAEMON_MODE=DISABLE
                    SENSOR_CAL=ACTUAL
                    EXTRA STEPS:
                    ______  __   __    ___
                    | ___ \ \ \ / /   /   |
                    | |_/ /  \ V /   / /| |
                    |  __/   /   \  / /_| |
                    | |     / /^\ \ \___  |
                    \_|     \/   \/     |_/
                    px4 starting.
                    GPS: AUTODETECT
                    RC: SPEKTRUM
                    ESC: VOXL_ESC
                    OSD: DISABLE
                    EXTRA STEPS:
                    Running on M0054
                    INFO  [muorb] SLPI:
                    INFO  [muorb] SLPI:
                    INFO  [muorb] SLPI:
                    INFO  [muorb] SLPI:
                    INFO  [muorb] SLPI:
                    @Chase-Riley Does it seem to be working now? Can you calibrate RC now?
                      @Eric-Katzfey And can you wait a little longer to get more data in the log? I'd like to see the data dumps of more packets.
                        Chase Riley
                        @Eric-Katzfey I am able to calibrate the RC now with that Debian. Here is the log after letting it run a little longer. Let me know if you need more in the log. Would you recommend flying with this Debian File?
                        INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x03
                        INFO  [muorb] SLPI: 0x00 0x03 0x81 0x56 0x39 0x56 0x1c 0x0c
                        INFO  [qshell] qshell return value timestamp: 356493009, local time: 356495308
                        INFO  [uORB] Advertising remote topic manual_control_input
                        INFO  [uORB] Advertising remote topic manual_control_switches
                        INFO  [uORB] Advertising remote topic action_request
                        INFO  [uORB] Advertising remote topic led_control
                        INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
                        INFO  [uORB] Advertising remote topic tune_control
                        INFO  [muorb] SLPI: Ok executing command: commander start
                        INFO  [qshell] qshell return value timestamp: 356734246, local time: 356736417
                        INFO  [uORB] Advertising remote topic event
                        INFO  [uORB] Advertising remote topic health_report
                        INFO  [uORB] Advertising remote topic failsafe_flags
                        INFO  [uORB] Advertising remote topic actuator_armed
                        INFO  [uORB] Advertising remote topic vehicle_control_mode
                        INFO  [uORB] Advertising remote topic vehicle_status
                        INFO  [uORB] Advertising remote topic failure_detector_status
                        INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
                        INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
                        INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
                        INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
                        INFO  [qshell] Send cmd: 'flight_mode_manager start'
                        INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
                        INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
                        INFO  [uORB] Advertising remote topic vehicle_command
                        INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
                        INFO  [qshell] qshell return value timestamp: 356898624, local time: 356901074
                        INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
                        INFO  [muorb] SLPI: Advertising remote topic transponder_report
                        INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
                        INFO  [modal_io_bridge] Modal IO Bridge driver starting
                        INFO  [muorb] SLPI: Advertising remote topic telemetry_status
                        INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
                        INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
                        INFO  [muorb] SLPI: Advertising remote topic timesync_status
                        INFO  [uORB] Advertising remote topic actuator_controls_status_0
                        INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
                        INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
                        INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
                        pxh> INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x03
                        INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 2
                        INFO  [uORB] Advertising remote topic mavlink_log
                        ERROR [muorb] SLPI: Preflight Fail: low battery
                        INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 3
                        INFO  [muorb] SLPI: u-blox firmware version: SPG 3.01
                        INFO  [muorb] SLPI: u-blox protocol version: 18.00
                        INFO  [muorb] SLPI: u-blox module: NEO-M8N-0
                        INFO  [uORB] Advertising remote topic sensor_gps
                        INFO  [uORB] Advertising remote topic home_position
                        INFO  [uORB] Advertising remote topic estimator_gps_status
                        INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_hgt
                        INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_pos
                        INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_vel
                        INFO  [muorb] SLPI: Advertising remote topic mission_result
                        INFO  [muorb] SLPI: Advertising remote topic ping
                          @Chase-Riley Looks like the data is stable. It just doesn't seem the protocol byte to a stable value. Very odd. But I would try a flight with it in a carefully controlled environment in case anything goes wrong. In the worst case it could go out of control and you might not be able to use the kill switch so be safe.
                            @Chase-Riley Here is a link to the transmitter we use: https://www.horizonhobby.com/product/dx6e-6-channel-dsmx-transmitter-only/SPMR6655.html
                            Chase RileyC 4 Replies Last reply
                              Chase Riley
                              @Eric-Katzfey When getting everything tested to go out and fly I started receiving a failsafe for ESC failure. When we were working with this back in SDK 1.0 in this thread. I had the issue of the actuators tab not showing up in QGC. I can now see the actuators tab on SDK 1.1.2 however I can not test the motors and when I try to arm I receive ESC Failure message. I am not sure if this has something to do with the custom deb file like it did when I couldn't see the actuators tab.
                              I can upload firmware and params to the ESC fine. Running voxl-esc-scan.py returns no issues. Any thoughts?
                                Chase Riley
                                #65
                                @Eric-Katzfey I was able to solve the ESC issue. It was not linked to the Spektrum issue. After getting the ESC to function I was not able to control throttle on the air vehicle. I am able to calibrate the RC controller and set flight modes and so on. Everything seems normal until a arm the motors (testing in Stabilize). The motors arm and spin up but I am unable to change the speed on the motors with any input of the controller. I checked the Px4 RC params and all match previously good known params. I have inlcluded a snippet of running voxl-px4 -d with Spektrum sill with -v argument. I noticed there was another error with a different value and was also 32 bytes instead of the 16 bytes we have been seeing.
                                INFO  [muorb] SLPI: 0x21 0x56 0x36 0xaa 0x54 0x00 0x63 0x00
                                INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x02
                                INFO  [muorb] SLPI: 0x00 0x02 0x0b 0xf5 0x2e 0xaa 0x13 0xfe
                                INFO  [muorb] SLPI: 0x21 0x56 0x36 0xaa 0x54 0x00 0x65 0x00
                                INFO  [muorb] SLPI: 0x00 0x02 0x0b 0xf5 0x2e 0xaa 0x13 0xff
                                INFO  [muorb] SLPI: Armed by external command
                                INFO  [uORB] Advertising remote topic vehicle_command_ack
                                INFO  [logger] Start file log (type: full)
                                WARN  [uORB] orb_advertise_multi: failed to set queue size
                                INFO  [logger] [logger] /data/px4/log/2024-01-23/16_57_27.ulg
                                WARN  [mavlink] Event dropped (7, 65526)
                                INFO  [logger] Opened full log file: /data/px4/log/2024-01-23/16_57_27.ulg
                                INFO  [muorb] SLPI: Advertising remote topic logger_status
                                WARN  [mavlink] Dropped 65519 events (seq=65526)
                                INFO  [muorb] SLPI: Takeoff detected
                                WARN  [mavlink] Event dropped (65527, 7)
                                WARN  [mavlink] Dropped 7 events (seq=7)
                                INFO  [muorb] SLPI: Landing detected
                                ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 32 bytes. Protocol byte 0x02
                                INFO  [muorb] SLPI: Disarmed by landing
                                INFO  [uORB] Marking DeviceNode(parameter_server_set_value_request) as advertised in process_remote_topic
                                INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_value_response) as advertised in process_remote_t
                                  Chase Riley
                                  #66
                                  @Eric-Katzfey I am also getting my hands on a DX6e for me to test. I should be able to try that in the morning. I still would like to figure out the DX8 as well though since we already have a bunch on hand in our lab.
                                    @Chase-Riley Did you analyze the flight log?
                                      @Chase-Riley For the DX8 there are some configuration options on the transmitter. There is DSMX versus DSM2. That may need to be changed. Have you tried the different options yet?
                                        Chase Riley
                                        @Eric-Katzfey I have tried all of the options in the DX8. 11, 22 and DSM2, DSMX. They all seemed to produce the same results in the logs.
                                          Chase Riley
                                          @Eric-Katzfey Here is a voxl-px4 log while testing with a DX6e this morning. I was able to bind and calibrate no problem. I am just not able to control the motors. Flight mode and kill switch seem to be working fine. So seems to have the same behavior as the DX8 with a error in the log for 32 bytes and 0x00.
                                          INFO  [muorb] SLPI: 0x00 0x00 0x8c 0x05 0x01 0x56 0x14 0x00
                                          INFO  [muorb] SLPI: 0x1b 0xf5 0x2e 0xaa 0x3c 0x00 0x34 0x00
                                          INFO  [muorb] SLPI: 0x1b 0xf6 0x2e 0xaa 0x3c 0x00 0x34 0x00
                                          ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 32 bytes. Protocol byte 0x00
                                          INFO  [logger] [logger] /data/px4/log/2024-01-24/19_14_37.ulg
                                          INFO  [logger] Opened full log file: /data/px4/log/2024-01-24/19_14_37.ulg
                                          WARN  [mavlink] Event dropped (297, 65527)
                                          WARN  [mavlink] Dropped 65230 events (seq=65527)
