  3. Voxl2 Spektrum Receiver error
voxl-2
90 Posts 4 Posters 51.6k Views 3 Watching
    @Chase-Riley said in Voxl2 Spektrum Receiver error:
    ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x00
    Yep, there's the error. That's the correct size but the code is expecting either 0x01 or 0x02 as valid protocols, not 0x00. Does it report 0x00 every single time or does it change? Is this the same transmitter you used earlier? Seems like it must be something different as that one was reporting 0x01, not 0x00. I can build a new version that also allows 0x00 and see if that fixes anything.
    Chase RileyC Offline
    Chase Riley
    wrote on last edited by Chase Riley
    #46
    @Eric-Katzfey it seems to change. I have seen different during testing. Same transmitter.
    • Chase RileyC Chase Riley
      Chase Riley
      #47
      @Chase-Riley Actually it may change with the frame rate in the transmitter. I just ran it 5 times without changing the settings and it stayed as 0x00.
      Update. I powered down the transmitter and when I ran again i received 0x5a
        Eric KatzfeyE Online
        @Chase-Riley Okay, well I'll just make a custom build for you that removes the check on that byte completely but that's probably not the right thing to do. But at least it will get us farther down the road. I'll try to think of some other useful debugging information to output as well.
          @Chase-Riley Seems like maybe the data on the serial line is getting corrupted somehow
            @Chase-Riley Actually, can you start the driver with the -v flag so that it produces more output and send me the log from that?
            Chase RileyC 2 Replies Last reply
              Chase Riley
              @Eric-Katzfey I am out of the office for the night. I will get back to you first thing in the morning EST. If you could try the custom file that would be great. It may help me continue testing while we work on debugging this issue more.
                Chase Riley
                @Eric-Katzfey Here is the log with the -v argument added to the Spektrum Driver Start.
                voxl2:/$ voxl-px4 -d
                Found DSP signature file
                [INFO] Disabling daemon mode
                GPS=AUTODETECT
                RC=SPEKTRUM
                ESC=VOXL_ESC
                POWER MANAGER=VOXLPM
                DISTANCE SENSOR=NONE
                OSD=DISABLE
                DAEMON_MODE=DISABLE
                SENSOR_CAL=ACTUAL
                EXTRA STEPS:
                ______  __   __    ___
                | ___ \ \ \ / /   /   |
                | |_/ /  \ V /   / /| |
                |  __/   /   \  / /_| |
                | |     / /^\ \ \___  |
                \_|     \/   \/     |_/
                px4 starting.
                GPS: AUTODETECT
                RC: SPEKTRUM
                ESC: VOXL_ESC
                POWER MANAGER: VOXLPM
                DISTANCE SENSOR: NONE
                OSD: DISABLE
                EXTRA STEPS:
                Running on M0054
                INFO  [parameters] BSON document size 4125 bytes, decoded 4125 bytes (INT32:57, FLOAT:136)
                INFO  [qshell] Send cmd: 'icm42688p start -s -R 4'
                INFO  [muorb] SLPI: qshell gotten: icm42688p start -s -R 4
                INFO  [muorb] SLPI:   arg3 = '-R'
                INFO  [muorb] SLPI:   arg4 = '4'
                INFO  [muorb] SLPI:  rotation 4
                INFO  [muorb] SLPI: >>> ICM42688P this: 3176cce0
                INFO  [muorb] SLPI:
                INFO  [muorb] SLPI: Ok executing command: icm42688p start -s -R 4
                INFO  [qshell] qshell return value timestamp: 197304564, local time: 197310221
                INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176cce0
                INFO  [muorb] SLPI:
                INFO  [qshell] qshell return value timestamp: 197356803, local time: 197358238
                INFO  [qshell] qshell return value timestamp: 197389684, local time: 197391710
                ERROR [qshell] Command failed
                INFO  [muorb] SLPI:
                INFO  [qshell] qshell return value timestamp: 197437606, local time: 197440108
                INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
                INFO  [qshell] qshell return value timestamp: 197463075, local time: 197465432
                Looking for ncp5623c RGB LED
                INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
                INFO  [muorb] SLPI:  address 0x38
                INFO  [muorb] SLPI:
                INFO  [qshell] qshell return value timestamp: 197515519, local time: 197517065
                Starting VOXL ESC driver
                INFO  [qshell] Send cmd: 'voxl_esc start'
                INFO  [muorb] SLPI: qshell gotten: voxl_esc start
                INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
                INFO  [muorb] SLPI: ubx msg 0x0107 invalid len 46584
                INFO  [muorb] SLPI: Ok executing command: voxl_esc start
                INFO  [muorb] SLPI: Opened UART ESC device
                INFO  [qshell] qshell return value timestamp: 197621321, local time: 197622953
                Starting Spektrum RC
                INFO  [qshell] Send cmd: 'spektrum_rc start -v'
                INFO  [muorb] SLPI: qshell gotten: spektrum_rc start -v
                INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
                INFO  [muorb] SLPI:   arg2 = '-v'
                INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
                INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097644
                INFO  [muorb] SLPI: Ok executing command: spektrum_rc start -v
                INFO  [muorb] SLPI: Spektrum RC: Enabling verbose mode
                INFO  [muorb] SLPI: Spektrum RC: dsm_init succeeded
                INFO  [qshell] qshell return value timestamp: 197674334, local time: 197676244
                INFO  [uORB] Advertising remote topic actuator_outputs_debug
                INFO  [uORB] Advertising remote topic esc_status
                INFO  [muorb] SLPI: Spektrum RC: Read no bytes from UART
                INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
                INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                INFO  [muorb] SLPI:   arg0 = 'voxlpm'
                INFO  [muorb] SLPI:   arg4 = '2'
                INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
                INFO  [muorb] SLPI: Set i2c address 0x6a, fd 4
                INFO  [muorb] SLPI: Set i2c address 0x44, fd 4
                ERROR [muorb] SLPI: Failed to execute command: voxlpm start -X -b 2
                INFO  [qshell] qshell return value timestamp: 197707182, local time: 197710461
                  GPS=AUTODETECT
                  RC=SPEKTRUM
                  ESC=VOXL_ESC
                  OSD=DISABLE
                  DAEMON_MODE=DISABLE
                  SENSOR_CAL=ACTUAL
                  EXTRA STEPS:
                  ______  __   __    ___
                  | ___ \ \ \ / /   /   |
                  | |_/ /  \ V /   / /| |
                  |  __/   /   \  / /_| |
                  | |     / /^\ \ \___  |
                  \_|     \/   \/     |_/
                  px4 starting.
                  GPS: AUTODETECT
                  RC: SPEKTRUM
                  ESC: VOXL_ESC
                  OSD: DISABLE
                  EXTRA STEPS:
                  Running on M0054
                  INFO  [muorb] SLPI:
                  INFO  [muorb] SLPI:
                  INFO  [muorb] SLPI:
                  INFO  [muorb] SLPI:
                  @Chase-Riley Interesting. Okay, so in this case it's always 0x00. But you say you have seen other random values? Can you capture a log with that happening?
                    Chase Riley
                    #54
                    @Eric-Katzfey Here is the log you requested. To get a different value than 0x00 I just powered down and then powered back up the transmitter. I also ran it again after this test and received 0x5a.
                    GPS=AUTODETECT
                    RC=SPEKTRUM
                    ESC=VOXL_ESC
                    OSD=DISABLE
                    DAEMON_MODE=DISABLE
                    SENSOR_CAL=ACTUAL
                    EXTRA STEPS:
                    ______  __   __    ___
                    | ___ \ \ \ / /   /   |
                    | |_/ /  \ V /   / /| |
                    |  __/   /   \  / /_| |
                    | |     / /^\ \ \___  |
                    \_|     \/   \/     |_/
                    px4 starting.
                    GPS: AUTODETECT
                    RC: SPEKTRUM
                    ESC: VOXL_ESC
                    OSD: DISABLE
                    EXTRA STEPS:
                    Running on M0054
                    INFO  [muorb] SLPI: >>> ICM42688P this: 3176ccf0
                    INFO  [muorb] SLPI:
                    INFO  [qshell] qshell return value timestamp: 140652268, local time: 140655765
                    INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ccf0
                    INFO  [muorb] SLPI:
                    INFO  [qshell] qshell return value timestamp: 140688809, local time: 140690531
                    INFO  [qshell] qshell return value timestamp: 140728848, local time: 140731229
                    INFO  [muorb] SLPI:
                    INFO  [qshell] qshell return value timestamp: 140766613, local time: 140767902
                    INFO  [qshell] qshell return value timestamp: 140792157, local time: 140794315
                    INFO  [muorb] SLPI:
                    INFO  [qshell] qshell return value timestamp: 140826063, local time: 140827364
                    INFO  [qshell] qshell return value timestamp: 140915998, local time: 140917432
                    INFO  [qshell] qshell return value timestamp: 140957493, local time: 140958599
                    ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x2d
                    INFO  [uORB] Advertising remote topic battery_status
                    INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
                    INFO  [muorb] SLPI:  address 0x44
                    INFO  [muorb] SLPI:
                    INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                    INFO  [qshell] qshell return value timestamp: 140988963, local time: 140990201
                    INFO  [uORB] Advertising remote topic power_monitor
                      GPS=AUTODETECT
                      RC=SPEKTRUM
                      ESC=VOXL_ESC
                      OSD=DISABLE
                      DAEMON_MODE=DISABLE
                      SENSOR_CAL=ACTUAL
                      EXTRA STEPS:
                      ______  __   __    ___
                      | ___ \ \ \ / /   /   |
                      | |_/ /  \ V /   / /| |
                      |  __/   /   \  / /_| |
                      | |     / /^\ \ \___  |
                      \_|     \/   \/     |_/
                      px4 starting.
                      GPS: AUTODETECT
                      RC: SPEKTRUM
                      ESC: VOXL_ESC
                      OSD: DISABLE
                      EXTRA STEPS:
                      Running on M0054
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI:
                      @Chase-Riley Okay, I'm preparing a new Debian that just completely removes that protocol byte check and, when verbose debug information is selected, will dump the complete frame contents about once a second so we can see what is actually being received at the driver.
                        Chase Riley
                        @Eric-Katzfey Ok. Looking forward to trying it out.
                          @Chase-Riley You can get it with wget https://storage.googleapis.com/modalai_public/forum/voxl-px4_1.14.66-6.0.0_arm64.deb
                            Chase Riley
                            @Eric-Katzfey Here is the log with the new Debian.
                            GPS=AUTODETECT
                            RC=SPEKTRUM
                            ESC=VOXL_ESC
                            OSD=DISABLE
                            DAEMON_MODE=DISABLE
                            SENSOR_CAL=ACTUAL
                            EXTRA STEPS:
                            ______  __   __    ___
                            | ___ \ \ \ / /   /   |
                            | |_/ /  \ V /   / /| |
                            |  __/   /   \  / /_| |
                            | |     / /^\ \ \___  |
                            \_|     \/   \/     |_/
                            px4 starting.
                            GPS: AUTODETECT
                            RC: SPEKTRUM
                            ESC: VOXL_ESC
                            OSD: DISABLE
                            EXTRA STEPS:
                            Running on M0054
                            INFO  [muorb] SLPI: >>> ICM42688P this: 3176ed20
                            INFO  [muorb] SLPI:
                            INFO  [qshell] qshell return value timestamp: 108528422, local time: 108534280
                            INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ed20
                            INFO  [muorb] SLPI:
                            INFO  [qshell] qshell return value timestamp: 108579731, local time: 108582550
                            INFO  [qshell] qshell return value timestamp: 108614169, local time: 108616786
                            INFO  [muorb] SLPI:
                            INFO  [qshell] qshell return value timestamp: 108652161, local time: 108653528
                            INFO  [qshell] qshell return value timestamp: 108678128, local time: 108679924
                            INFO  [muorb] SLPI:
                            INFO  [qshell] qshell return value timestamp: 108709712, local time: 108711831
                            INFO  [qshell] qshell return value timestamp: 108819381, local time: 108821923
                            INFO  [qshell] qshell return value timestamp: 108849790, local time: 108851570
                            INFO  [muorb] SLPI:
                            INFO  [qshell] qshell return value timestamp: 108881654, local time: 108883951
                            ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_GPS_PRIME
                            INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x00
                            INFO  [muorb] SLPI: 0x00 0x00 0x81 0x86 0x39 0x56 0x1c 0x0d
                            INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x61 0x00
                            INFO  [uORB] Advertising remote topic sensors_status_mag
                            INFO  [qshell] qshell return value timestamp: 109070971, local time: 109078977
                            INFO  [uORB] Advertising remote topic input_rc
                            INFO  [muorb] SLPI: Spektrum RC: DSM message parsed successfully
                            INFO  [muorb] SLPI: Spektrum RC: Publishing input_rc
                            INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x63 0x00
                            INFO  [qshell] qshell return value timestamp: 109344658, local time: 109348511
                            INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
                            INFO  [qshell] qshell return value timestamp: 109447440, local time: 109448532
                            INFO  [qshell] qshell return value timestamp: 109490661, local time: 109491803
                            INFO  [qshell] qshell return value timestamp: 109586749, local time: 109589982
                            INFO  [qshell] qshell return value timestamp: 109645064, local time: 109646589
                            INFO  [qshell] qshell return value timestamp: 109687598, local time: 109688691
                            INFO  [muorb] SLPI:   arg0 = 'land_detector'
                            INFO  [muorb] SLPI:   arg2 = 'multicopter'
                            INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x65 0x00
                            INFO  [qshell] qshell return value timestamp: 109739354, local time: 109741061
                            INFO  [uORB] Advertising remote topic vehicle_land_detected
                            INFO  [muorb] SLPI: baudrate set to 9600
                            INFO  [qshell] Send cmd: 'manual_control start'
                            INFO  [muorb] SLPI: qshell gotten: manual_control start
                            INFO  [muorb] SLPI:   arg0 = 'manual_control'
                            INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 1
                            INFO  [muorb] SLPI: Ok executing command: manual_control start
                            INFO  [qshell] qshell return value timestamp: 109801954, local time: 109803502
                            INFO  [uORB] Advertising remote topic manual_control_setpoint
                            INFO  [qshell] Send cmd: 'control_allocator start'
                            INFO  [muorb] SLPI: qshell gotten: control_allocator start
                            INFO  [muorb] SLPI:   arg0 = 'control_allocator'
                            INFO  [uORB] Advertising remote topic control_allocator_status
                            INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
                            INFO  [uORB] Advertising remote topic actuator_motors
                            INFO  [uORB] Advertising remote topic actuator_servos
                            INFO  [uORB] Advertising remote topic actuator_servos_trim
                            INFO  [muorb] SLPI: 0x44 0x00 0x4c 0x00 0x5c 0x00 0x67 0x00
                            INFO  [muorb] SLPI: Ok executing command: control_allocator start
                            INFO  [qshell] qshell return value timestamp: 110087397, local time: 110090284
                            INFO  [qshell] Send cmd: 'load_mon start'
                            INFO  [muorb] SLPI: qshell gotten: load_mon start
                            INFO  [muorb] SLPI:   arg0 = 'load_mon'
                            INFO  [muorb] SLPI: Ok executing command: load_mon start
                            INFO  [uORB] Advertising remote topic cpuload
                            INFO  [qshell] qshell return value timestamp: 110141759, local time: 110143643
                            INFO  [qshell] Send cmd: 'rc_update start'
                            INFO  [muorb] SLPI: qshell gotten: rc_update start
                            INFO  [muorb] SLPI:   arg0 = 'rc_update'
                            INFO  [muorb] SLPI: Ok executing command: rc_update start
                            INFO  [qshell] qshell return value timestamp: 110418193, local time: 110421870
                            INFO  [qshell] Send cmd: 'commander start'
                            INFO  [muorb] SLPI: qshell gotten: commander start
                            INFO  [muorb] SLPI:   arg0 = 'commander'
                            INFO  [muorb] SLPI: Creating pthread commander
                            INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097639
                            INFO  [uORB] Advertising remote topic rc_channels
                              GPS=AUTODETECT
                              RC=SPEKTRUM
                              ESC=VOXL_ESC
                              OSD=DISABLE
                              DAEMON_MODE=DISABLE
                              SENSOR_CAL=ACTUAL
                              EXTRA STEPS:
                              ______  __   __    ___
                              | ___ \ \ \ / /   /   |
                              | |_/ /  \ V /   / /| |
                              |  __/   /   \  / /_| |
                              | |     / /^\ \ \___  |
                              \_|     \/   \/     |_/
                              px4 starting.
                              GPS: AUTODETECT
                              RC: SPEKTRUM
                              ESC: VOXL_ESC
                              OSD: DISABLE
                              EXTRA STEPS:
                              Running on M0054
                              INFO  [muorb] SLPI:
                              INFO  [muorb] SLPI:
                              INFO  [muorb] SLPI:
                              INFO  [muorb] SLPI:
                              INFO  [muorb] SLPI:
                              @Chase-Riley Does it seem to be working now? Can you calibrate RC now?
                                @Eric-Katzfey And can you wait a little longer to get more data in the log? I'd like to see the data dumps of more packets.
                                  Chase Riley
                                  @Eric-Katzfey I am able to calibrate the RC now with that Debian. Here is the log after letting it run a little longer. Let me know if you need more in the log. Would you recommend flying with this Debian File?
                                  INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x03
                                  INFO  [muorb] SLPI: 0x00 0x03 0x81 0x56 0x39 0x56 0x1c 0x0c
                                  INFO  [qshell] qshell return value timestamp: 356493009, local time: 356495308
                                  INFO  [uORB] Advertising remote topic manual_control_input
                                  INFO  [uORB] Advertising remote topic manual_control_switches
                                  INFO  [uORB] Advertising remote topic action_request
                                  INFO  [uORB] Advertising remote topic led_control
                                  INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
                                  INFO  [uORB] Advertising remote topic tune_control
                                  INFO  [muorb] SLPI: Ok executing command: commander start
                                  INFO  [qshell] qshell return value timestamp: 356734246, local time: 356736417
                                  INFO  [uORB] Advertising remote topic event
                                  INFO  [uORB] Advertising remote topic health_report
                                  INFO  [uORB] Advertising remote topic failsafe_flags
                                  INFO  [uORB] Advertising remote topic actuator_armed
                                  INFO  [uORB] Advertising remote topic vehicle_control_mode
                                  INFO  [uORB] Advertising remote topic vehicle_status
                                  INFO  [uORB] Advertising remote topic failure_detector_status
                                  INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
                                  INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
                                  INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
                                  INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
                                  INFO  [qshell] Send cmd: 'flight_mode_manager start'
                                  INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
                                  INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
                                  INFO  [uORB] Advertising remote topic vehicle_command
                                  INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
                                  INFO  [qshell] qshell return value timestamp: 356898624, local time: 356901074
                                  INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
                                  INFO  [muorb] SLPI: Advertising remote topic transponder_report
                                  INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
                                  INFO  [modal_io_bridge] Modal IO Bridge driver starting
                                  INFO  [muorb] SLPI: Advertising remote topic telemetry_status
                                  INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
                                  INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
                                  INFO  [muorb] SLPI: Advertising remote topic timesync_status
                                  INFO  [uORB] Advertising remote topic actuator_controls_status_0
                                  INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
                                  INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
                                  INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
                                  pxh> INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x03
                                  INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 2
                                  INFO  [uORB] Advertising remote topic mavlink_log
                                  ERROR [muorb] SLPI: Preflight Fail: low battery
                                  INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 3
                                  INFO  [muorb] SLPI: u-blox firmware version: SPG 3.01
                                  INFO  [muorb] SLPI: u-blox protocol version: 18.00
                                  INFO  [muorb] SLPI: u-blox module: NEO-M8N-0
                                  INFO  [uORB] Advertising remote topic sensor_gps
                                  INFO  [uORB] Advertising remote topic home_position
                                  INFO  [uORB] Advertising remote topic estimator_gps_status
                                  INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_hgt
                                  INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_pos
                                  INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_vel
                                  INFO  [muorb] SLPI: Advertising remote topic mission_result
                                  INFO  [muorb] SLPI: Advertising remote topic ping
                                    @Chase-Riley Looks like the data is stable. It just doesn't seem the protocol byte to a stable value. Very odd. But I would try a flight with it in a carefully controlled environment in case anything goes wrong. In the worst case it could go out of control and you might not be able to use the kill switch so be safe.
                                      @Chase-Riley Here is a link to the transmitter we use: https://www.horizonhobby.com/product/dx6e-6-channel-dsmx-transmitter-only/SPMR6655.html
                                      Chase RileyC 4 Replies Last reply
                                        Chase Riley
                                        @Eric-Katzfey When getting everything tested to go out and fly I started receiving a failsafe for ESC failure. When we were working with this back in SDK 1.0 in this thread. I had the issue of the actuators tab not showing up in QGC. I can now see the actuators tab on SDK 1.1.2 however I can not test the motors and when I try to arm I receive ESC Failure message. I am not sure if this has something to do with the custom deb file like it did when I couldn't see the actuators tab.
                                        I can upload firmware and params to the ESC fine. Running voxl-esc-scan.py returns no issues. Any thoughts?
                                          Chase Riley
                                          #65
                                          @Eric-Katzfey I was able to solve the ESC issue. It was not linked to the Spektrum issue. After getting the ESC to function I was not able to control throttle on the air vehicle. I am able to calibrate the RC controller and set flight modes and so on. Everything seems normal until a arm the motors (testing in Stabilize). The motors arm and spin up but I am unable to change the speed on the motors with any input of the controller. I checked the Px4 RC params and all match previously good known params. I have inlcluded a snippet of running voxl-px4 -d with Spektrum sill with -v argument. I noticed there was another error with a different value and was also 32 bytes instead of the 16 bytes we have been seeing.
                                          INFO  [muorb] SLPI: 0x21 0x56 0x36 0xaa 0x54 0x00 0x63 0x00
                                          INFO  [muorb] SLPI: Spektrum RC: 16 bytes from UART, protocol byte 0x02
                                          INFO  [muorb] SLPI: 0x00 0x02 0x0b 0xf5 0x2e 0xaa 0x13 0xfe
                                          INFO  [muorb] SLPI: 0x21 0x56 0x36 0xaa 0x54 0x00 0x65 0x00
                                          INFO  [muorb] SLPI: 0x00 0x02 0x0b 0xf5 0x2e 0xaa 0x13 0xff
                                          INFO  [muorb] SLPI: Armed by external command
                                          INFO  [uORB] Advertising remote topic vehicle_command_ack
                                          INFO  [logger] Start file log (type: full)
                                          WARN  [uORB] orb_advertise_multi: failed to set queue size
                                          INFO  [logger] [logger] /data/px4/log/2024-01-23/16_57_27.ulg
                                          WARN  [mavlink] Event dropped (7, 65526)
                                          INFO  [logger] Opened full log file: /data/px4/log/2024-01-23/16_57_27.ulg
                                          INFO  [muorb] SLPI: Advertising remote topic logger_status
                                          WARN  [mavlink] Dropped 65519 events (seq=65526)
                                          INFO  [muorb] SLPI: Takeoff detected
                                          WARN  [mavlink] Event dropped (65527, 7)
                                          WARN  [mavlink] Dropped 7 events (seq=7)
                                          INFO  [muorb] SLPI: Landing detected
                                          ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 32 bytes. Protocol byte 0x02
                                          INFO  [muorb] SLPI: Disarmed by landing
                                          INFO  [uORB] Marking DeviceNode(parameter_server_set_value_request) as advertised in process_remote_topic
                                          INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_value_response) as advertised in process_remote_t
