  3. Voxl2 Spektrum Receiver error
voxl-2
90 Posts 4 Posters 47.9k Views 3 Watching
    @Chase-Riley I started from scratch and flashed SDK 1.0.0 and could see the actuators tab on QGC 4.2.4. I then upgraded voxl-px4 to voxl-px4_1.14.0-2.0.54-202310161035_arm64.deb. I still see the actuators tab. Since Ben's Debian was based on an older px4 that didn't yet properly support the actuators tab it's possible that something got corrupted in that change.
    Chase RileyC Offline
    Chase Riley
    @Eric-Katzfey I will try that out and report back.
      Chase Riley
      @Eric-Katzfey Would you suggest flashing my Voxl to SDK .0.9.5 and then back to 1.0.0 and start from there?
      • Chase RileyC Chase Riley
        @Chase-Riley No, but I would recommend deleting /data/px4/param/parameters before doing the SDK 1.0.0 flash.
          Chase Riley
          @Eric-Katzfey So delete that file and then flash SDK 1.0.0. Once SDK 1.0.0 flash is complete then upgrade to voxl-px4_1.14.0-2.0.54-202310161035_arm64.deb?
            @Chase-Riley Yep! That should get everything going.
            Chase RileyC 2 Replies Last reply
              Chase Riley
              wrote on last edited by Chase Riley
              #37
              @Eric-Katzfey I was able to delete the parameters file, flash SDK 1.0.0, and then upgrade to voxl-px4_1.14.0-2.0.54-202310161035_arm64.deb. I still am having the same issue. Spektrum works well however no actuators tab for the ESC. I did a quick test by downgrading back to voxl-px4_1.14.0-2.0.34_arm64.deb and the actuators tab appeared right away, however no Spektrum.
              To sum it up I am still having the same problem.
                Chase Riley
                @Eric-Katzfey can you help me out with this?
                  @Chase-Riley I wan;t able to reproduce this and I had some other team members try and they couldn't either. It worked fine for all of us. So I'm guessing that something in your file system got corrupted somehow. The files for the actuator tab are stored in /data/px4/etc/extras. Can you take a look at those files with both the working version and the non-working version and see if they are the same?
                    @Chase-Riley I made version 1.14.0-2.0.54 with the Spektrum RC changes in it. You can get it with wget http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.14.0-2.0.54-202310161035_arm64.deb. Can you try it out and see if it fixes your issue?
                    Chase Riley
                    @Eric-Katzfey said in Voxl2 Spektrum Receiver error:
                    @Eric-Katzfey do you still have the version of px4 you referenced here. The link now gives a 404 error?
                      @Chase-Riley Yeah, that's was in our dev repo that has a lot of churn. But you can grab this one: http://voxl-packages.modalai.com/dists/qrb5165/sdk-1.0/binary-arm64/voxl-px4_1.14.0-2.0.55_arm64.deb if you want something close to that. But latest SDK 1.1.2 also has those changes and you should be on the latest.
                        Chase Riley
                        @Eric-Katzfey This error still exist in SDK 1.1.2. I have tried multiple settings on the DX8 for binding. I have tried other Receivers as well.
                          @Chase-Riley So the first deb you tried fixed the Spektrum issue but now with 1.1.2 it's back? That was a very simple change that went into the codebase and it is still there so not sure what happened. Can you send the output of journalctl -b -u voxl-px4 so I can see if there are any error messages?
                            Chase Riley
                            @Eric-Katzfey I had to trim the output to fit into a forum post.
                            voxl2:/$ journalctl -b -u voxl-px4
                            -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Thu 2023-03-02 13:13:00 UTC. --
                            Mar 02 12:58:05 m0054 systemd[1]: Starting px4...
                            Mar 02 12:58:07 m0054 systemd[1]: Started px4.
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: [INFO] Reading from /etc/modalai/voxl-px4.conf
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: Found DSP signature file
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: [INFO] Daemon mode enabled
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: *************************
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: GPS=AUTODETECT
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: RC=SPEKTRUM
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: ESC=VOXL_ESC
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: POWER MANAGER=VOXLPM
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: DISTANCE SENSOR=NONE
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: OSD=DISABLE
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: DAEMON_MODE=ENABLE
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: SENSOR_CAL=ACTUAL
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: EXTRA STEPS:
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: INFO  [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: INFO  [px4] assuming working directory is rootfs, no symlinks needed.
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: INFO  [muorb] Got muorb init command
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: Sending initialization request
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: Got topic data before configuration complete
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: GPS: AUTODETECT
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: RC: SPEKTRUM
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: ESC: VOXL_ESC
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: POWER MANAGER: VOXLPM
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: DISTANCE SENSOR: NONE
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: OSD: DISABLE
                            Mar 02 12:58:07 m0054 voxl-px4[1878]: Running on M0054
                            Mar 02 12:58:08 m0054 voxl-px4[1878]: INFO  [param] selected parameter default file /data/px4/param/parameters
                            Mar 02 12:58:10 m0054 voxl-px4[1878]: INFO  [parameters] BSON document size 4125 bytes, decoded 4125 bytes (INT32:57, FLOAT:136)
                            Mar 02 12:58:10 m0054 voxl-px4[1878]: Starting IMU driver with no rotation
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'icm42688p start -s -R 4'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11587369, local time: 11593616
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11630444, local time: 11631222
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: Looking for qmc5883l magnetometer
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: muorb aggregator thread running
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] muorb protobuf initalize method succeeded
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did ADVERTISE_TEST_TYPE
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread test_MUORB
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did SUBSCRIBE_TEST_TYPE
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did TOPIC_TEST_TYPE
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] muorb test passed
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: ______  __   __    ___
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: | ___ \ \ \ / /   /   |
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: | |_/ /  \ V /   / /| |
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: |  __/   /   \  / /_| |
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: | |     / /^\ \ \___  |
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: \_|     \/   \/     |_/
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: px4 starting.
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Advertising remote topic log_message
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [parameters] Starting param sync THREAD
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Starting param sync THREAD
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: before starting the qshell_entry task
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread qshell
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell entry.....
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Init app map initialized
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: after starting the qshell_entry task
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Advertising remote topic parameter_update
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_topic
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_topic
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [logger] logger started (mode=all)
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: icm42688p start -s -R 4
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'icm42688p'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg1 = 'start'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-s'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg3 = '-R'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '4'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_accel
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_gyro
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: ICM42688P::probe successful!
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: on SPI bus 1
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  rotation 4
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: >>> ICM42688P this: 3176ecd0
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: icm42688p start -s -R 4
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic qshell_retval
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176ecd0
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_gyro_fifo
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_accel_fifo
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic imu_server
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'icp101xx'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-I'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg3 = '-b'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '5'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: icp101xx #0 on I2C bus 5
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0x63
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in procesINFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] cmd returned with: -1
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11661692, local time: 11664384
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [qshell] Command failed
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: Looking for ist8310 magnetometer
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11691188, local time: 11692742
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'gps start'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11724704, local time: 11726454
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: Looking for ncp5623c RGB LED
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11752678, local time: 11753969
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: Starting VOXL ESC driver
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'voxl_esc start'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11835821, local time: 11838037
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: Starting Spektrum RC
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'spektrum_rc start'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11886393, local time: 11888078
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: s_remote_topic
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: qmc5883l start -R 10 -X -b 1
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'qmc5883l'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-R'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg3 = '10'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '-X'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg5 = '-b'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg6 = '1'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0x80d09 527625
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: i2c probe failed
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: PX4_qshell: no instance started (no device on bus?)
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Failed to execute command: qmc5883l start -R 10 -X -b 1
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'ist8310'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0x60e09 396809
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: ist8310 #0 on I2C bus 1
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  (external)
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0xE
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  rotation 10
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: gps start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'gps'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread gps
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: gps start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'rgbled_ncp5623c'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = '-X'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '1'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg5 = '-f'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg6 = '400'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg7 = '-a'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg8 = '56'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0x38
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_mag
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: voxl_esc start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic actuator_outputs
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: voxl_esc start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Opened UART ESC device
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_baro
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: spektrum_rc start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097644
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: spektrum_rc start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic actuator_outputs_debug
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic esc_status
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x00
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'voxlpm'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg4 = '2'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Set i2c address 0x6a, fd 4
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Set i2c addINFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 11923833, local time: 11926013
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'sensors start'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12118075, local time: 12122006
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: ress 0x44, fd 4
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic battery_status
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:  address 0x44
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic power_monitor
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: sensors start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'sensors'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_selection
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensors_status_imu
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_acceleration
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_angular_velocity
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_combined
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_air_data
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_gps_position
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensors_status_baro
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for CAL_MAG_COMP_TYP
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_magnetometer
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensor_preflight_mag
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_imu
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_imu_status
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: sensors start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic sensors_status_mag
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: ekf2 start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'ekf2'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Spektrum RCINFO  [qshell] Send cmd: 'ekf2 start'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12374104, local time: 12378323
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_pos_control start'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12482484, local time: 12483852
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_att_control start'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12525883, local time: 12527670
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: : Invalid DSM frame. 16 bytes. Protocol byte 0x00
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_attitude
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_local_position
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_event_flags
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_innovation_test_ratios
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_innovation_variances
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_innovations
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_sensor_bias
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_states
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_status_flags
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: ekf2 start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic ekf2_timestamps
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic vehicle_odometry
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_baro_hgt
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_fake_pos
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_fake_hgt
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_gravity
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_pos_control'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic takeoff_status
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_att_control start
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_att_control'
                            Mar 02 12:58:11 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_att_control start
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertisedINFO  [qshell] Send cmd: 'mc_rate_control start'
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12616998, local time: 12618394
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12678757, local time: 12680493
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'mc_autotune_attitude_control start'
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12721830, local time: 12722851
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'land_detector start multicopter'
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12767035, local time: 12769446
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] Send cmd: 'manual_control start'
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [qshell] qshell return value timestamp: 12821435, local time: 12823707
                            Mar 02 12:58:12 m0054 voxl-px4[1878]:  in process_remote_topic
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_rate_control'
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg1 = 'start'
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: ERROR [muorb] SLPI: Spektrum RC: Invalid DSM frame. 16 bytes. Protocol byte 0x00
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic rate_ctrl_status
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_hover_thrust_estimator'
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'mc_autotune_attitude_control'
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [uORB] Advertising remote topic autotune_attitude_control_status
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg0 = 'land_detector'
                            Mar 02 12:58:12 m0054 voxl-px4[1878]: INFO  [muorb] SLPI:   arg2 = 'multicopter'
                              @Chase-Riley said in Voxl2 Spektrum Receiver error:
                              Yep, there's the error. That's the correct size but the code is expecting either 0x01 or 0x02 as valid protocols, not 0x00. Does it report 0x00 every single time or does it change? Is this the same transmitter you used earlier? Seems like it must be something different as that one was reporting 0x01, not 0x00. I can build a new version that also allows 0x00 and see if that fixes anything.
                                Chase Riley
                                #46
                                @Eric-Katzfey it seems to change. I have seen different during testing. Same transmitter.
                                  Chase Riley
                                  #47
                                  @Chase-Riley Actually it may change with the frame rate in the transmitter. I just ran it 5 times without changing the settings and it stayed as 0x00.
                                  Update. I powered down the transmitter and when I ran again i received 0x5a
                                    @Chase-Riley Okay, well I'll just make a custom build for you that removes the check on that byte completely but that's probably not the right thing to do. But at least it will get us farther down the road. I'll try to think of some other useful debugging information to output as well.
                                      @Chase-Riley Seems like maybe the data on the serial line is getting corrupted somehow
                                        @Chase-Riley Actually, can you start the driver with the -v flag so that it produces more output and send me the log from that?
                                          Chase Riley
                                          @Eric-Katzfey I am out of the office for the night. I will get back to you first thing in the morning EST. If you could try the custom file that would be great. It may help me continue testing while we work on debugging this issue more.
