  3. voxl-PX4 maxes 2 CPUs
15 Posts 4 Posters 1.8k Views 2 Watching
  • Rowan DempsterR Offline
    Rowan Dempster
    When I start voxl-px4 on VOXL2 I noticed that the CPU usage goes from 0% to over 25%, is this expected?
    • ModeratorM Offline
      Hi Rowan, which software version are you using, what peripherals do you have connected and is the vehicle armed, etc?
      Rowan DempsterR 1 Reply Last reply
      • ModeratorM Moderator
        Rowan Dempster
        @Moderator Hi, I am using SDK1.0. No peripherals attached, just the VOXL2 Board alone.
        Eric KatzfeyE tomT 2 Replies Last reply
        • Rowan DempsterR Rowan Dempster
          @Rowan-Dempster No, that is definitely not expected. PX4 should only be using a small amount of CPU. Can you disable all other services so it's only PX4 running and see if that changes?
            @Rowan-Dempster Can you also post the output of voxl-inspect-services so we can see the CPU usage by each service
              Rowan Dempster
              @Eric-Katzfey voxl-px4 and cpu-inspector were the only two services I have running
                Rowan Dempster
                  @Rowan-Dempster If you run it as a service with voxl-configure-px4 do you see the same issue?
                  tomT Rowan DempsterR 2 Replies Last reply
                    @tom The output of journalctl -u voxl-px4 could be helpful
                      Rowan Dempster
                      @tom Yes I do
                        Rowan Dempster
                        @tom Here's the service log: https://drive.google.com/file/d/1JBxlCP5Ppelu4AFKIKV55oLfmyrgcdQC/view?usp=sharing
                          @Rowan-Dempster If you are running voxl-px4 as a service you need to change your /etc/modalai/voxl-px4.conf file to enable daemon mode. Your log shows you have it disabled DAEMON_MODE=DISABLE
                            Rowan Dempster
                            wrote on last edited by Rowan Dempster
                            #13
                            @Eric-Katzfey I don't have that .conf file, even after I run voxl-configure-px4 (I just select enable)
                              @Rowan-Dempster You need to do voxl-configure-px4 factory_enable
                                Rowan Dempster
                                @tom That fixed the CPU usage issue, thank you!
