  3. voxl-PX4 maxes 2 CPUs
15 Posts 4 Posters 1.8k Views 2 Watching
  • ModeratorM Moderator
    Hi Rowan, which software version are you using, what peripherals do you have connected and is the vehicle armed, etc?
    Rowan DempsterR Offline
    Rowan Dempster
    @Moderator Hi, I am using SDK1.0. No peripherals attached, just the VOXL2 Board alone.
    Eric KatzfeyE tomT 2 Replies Last reply
    • Rowan DempsterR Rowan Dempster
      @Rowan-Dempster No, that is definitely not expected. PX4 should only be using a small amount of CPU. Can you disable all other services so it's only PX4 running and see if that changes?
      Rowan DempsterR 1 Reply Last reply
        @Rowan-Dempster Can you also post the output of voxl-inspect-services so we can see the CPU usage by each service
          Rowan Dempster
          @Eric-Katzfey voxl-px4 and cpu-inspector were the only two services I have running
            Rowan Dempster
              @Rowan-Dempster If you run it as a service with voxl-configure-px4 do you see the same issue?
              tomT Rowan DempsterR 2 Replies Last reply
                @tom The output of journalctl -u voxl-px4 could be helpful
                  Rowan Dempster
                  @tom Yes I do
                    Rowan Dempster
                    @tom Here's the service log: https://drive.google.com/file/d/1JBxlCP5Ppelu4AFKIKV55oLfmyrgcdQC/view?usp=sharing
                      @Rowan-Dempster If you are running voxl-px4 as a service you need to change your /etc/modalai/voxl-px4.conf file to enable daemon mode. Your log shows you have it disabled DAEMON_MODE=DISABLE
                        Rowan Dempster
                        wrote on last edited by Rowan Dempster
                        #13
                        @Eric-Katzfey I don't have that .conf file, even after I run voxl-configure-px4 (I just select enable)
                          @Rowan-Dempster You need to do voxl-configure-px4 factory_enable
                            Rowan Dempster
                            @tom That fixed the CPU usage issue, thank you!
