    voxl-PX4 maxes 2 CPUs
    808
    • Rowan DempsterR
      Rowan Dempster
      When I start voxl-px4 on VOXL2 I noticed that the CPU usage goes from 0% to over 25%, is this expected?
      • ModeratorM
        Moderator ModalAI Team
        Hi Rowan, which software version are you using, what peripherals do you have connected and is the vehicle armed, etc?
        Rowan DempsterR 1 Reply Last reply Reply Quote 0
        • Rowan DempsterR
          Rowan Dempster @Moderator
          @Moderator Hi, I am using SDK1.0. No peripherals attached, just the VOXL2 Board alone.
          Eric KatzfeyE tomT 2 Replies Last reply Reply Quote 0
            Eric Katzfey ModalAI Team @Rowan Dempster
            @Rowan-Dempster No, that is definitely not expected. PX4 should only be using a small amount of CPU. Can you disable all other services so it's only PX4 running and see if that changes?
              tom admin @Rowan Dempster
              @Rowan-Dempster Can you also post the output of voxl-inspect-services so we can see the CPU usage by each service
              • Rowan DempsterR
                Rowan Dempster @Eric Katzfey
                @Eric-Katzfey voxl-px4 and cpu-inspector were the only two services I have running
                • Rowan DempsterR
                  Rowan Dempster @tom
                    @Rowan-Dempster If you run it as a service with voxl-configure-px4 do you see the same issue?
                    tomT Rowan DempsterR 2 Replies Last reply Reply Quote 0
                      tom admin @tom
                      @tom The output of journalctl -u voxl-px4 could be helpful
                      • Rowan DempsterR
                        Rowan Dempster @tom
                        @tom Yes I do
                        • Rowan DempsterR
                          Rowan Dempster @tom
                          @tom Here's the service log: https://drive.google.com/file/d/1JBxlCP5Ppelu4AFKIKV55oLfmyrgcdQC/view?usp=sharing
                            @Rowan-Dempster If you are running voxl-px4 as a service you need to change your /etc/modalai/voxl-px4.conf file to enable daemon mode. Your log shows you have it disabled DAEMON_MODE=DISABLE
                            • Rowan DempsterR
                              @Eric-Katzfey I don't have that .conf file, even after I run voxl-configure-px4 (I just select enable)
                                @Rowan-Dempster You need to do voxl-configure-px4 factory_enable
                                Rowan DempsterR 1 Reply Last reply Reply Quote 1
                                • Rowan DempsterR
                                  Rowan Dempster @tom
                                  @tom That fixed the CPU usage issue, thank you!
