  3. Starling Drone not showing up in ADB devices
starling2usbvoxllinuxhelp
23 Posts 4 Posters 6.5k Views 3 Watching
  • ijones2I Offline
    ijones2I Offline
    ijones2
    wrote on last edited by ijones2
    Hello my name is Ivy Jones!
    I am doing research under a professor at my college and I am using the Starling Drone. One day as I was setting up the Ground control, the front LED on the drone turned red and I looked up what that could mean. It meant that the the drone was not receiving enough voltage. So I got a new battery and it turned on. The LED was green, so I proceeded to the instructions.
    Next, I go into Ubuntu/Linux terminal and I am trying the adb commands and its saying no adb devices detected. I even ran the usb bus command to tell me if anything was plugged in and nothing. I changed the cord several times to see if it was the cord, tried a different laptop .and I was still unable to communicate with the drone.
    I thought it was bricked and it very well may be but it's still not showing up when I plug it into my laptop and it is not being listed when I run the command to list adb devices. Any help/advice/comments would be great! My whole research is based on flying this drone :') I am afraid that I broke it.
    B 1 Reply Last reply
    • ijones2I ijones2
      B Offline
      B Offline
      Bernhard
      @ijones2
      Hello Ivy!
      Just a suggestion - I have seen that problem, but it only occurred when using USB-C to USB-C. Have you used a USB-A to USB-C cable?
      Are you using a native Linux machine or a virtual machine?
      (Not an expert, just trying to help 🙂 )
      BR
      Bernhard
      ijones2I 1 Reply Last reply
      • B Bernhard
        @ijones2
        Hello Ivy!
        BR
        Bernhard
        ijones2I Offline
        ijones2I Offline
        ijones2
        @Bernhard
        Hey Bernhard!
        the cord is usb-a to usb-c. the laptop i’m using doesn’t have usb-c port and linux is native to the laptop. 🥹🥹
        VinnyV 1 Reply Last reply
        • ijones2I ijones2
          @Bernhard
          Hey Bernhard!
          Hi @ijones2
          Are you able to post a picture of your entire drone, and zoom in (second+ images) on your power source(s) and power connections to the drone?
          ijones2I 2 Replies Last reply
          • VinnyV Vinny
            Hi @ijones2
            ijones2I Offline
            ijones2I Offline
            ijones2
            @Vinny
            Hey Vinny! But of course! I hope this helps !!!!
            • ijones2I ijones2
              @Vinny
              ijones2I Offline
              ijones2I Offline
              ijones2
              @ijones2 @Vinny
              • VinnyV Vinny
                Hi @ijones2
                ijones2I Offline
                ijones2I Offline
                ijones2
                @Vinny
                • ijones2I ijones2
                  @Vinny
                  Hi @ijones2
                  Thanks for those. Your Starling looks like it's new out of the box, so I do not suspect anything severe is happening. All of the green lights when you power I can see in the image stay solid green, right (no flashing/flickering)?
                  if so, all should be OK and your system is likely booting, so you may have a problem with your host machine.
                  I am from Hardware, so I'll need to pull in someone from software team to help you.
                  @tom ,
                  My suspicion is ADB is not installed correctly on the host machine, but I do not know how to help someone through that.
                  Or...
                  If the drone was operating and the battery suddenly dropped out to give the red LED, it just means it was shut down. But, if the shut-down was occurring during a write operation which could have been happening from a QGC config, it might be bricked.
                  any ideas?
                  tomT ijones2I 2 Replies Last reply
                  • VinnyV Vinny
                    Hi @ijones2
                    @tom ,
                    Or...
                    any ideas?
                    @ijones2 When your drone is powered and plugged into your host machine via USB, what do you see with lsusb?
                    • VinnyV Vinny
                      Hi @ijones2
                      @tom ,
                      Or...
                      any ideas?
                      ijones2I Offline
                      ijones2I Offline
                      ijones2
                      @Vinny @tom
                      Yep! Solid green, no flickering!
                      I tried the unbrick guide but then I got to this step:
                      Initiate flash
                      While in the ufs sub-directory of the image release, run the following qdl command in order to flash the device:
                      $ sudo qdl --debug --storage ufs --include . prog_firehose_ddr.elf rawprogram_unsparse0.xml rawprogram1.xml rawprogram2.xml rawprogram3.xml rawprogram4.xml rawprogram5.xml patch0.xml patch1.xml patch2.xml patch3.xml patch4.xml patch5.xml
                      and it would say waiting for device and I left that on the screen because it said that the qdl flash will take some time. I had to end the process because it was going on 4+ hours of waiting for device. I restarted it and it was still taking hours. I never got to the point of seeing the completion output.
                      when I would run this $ lsusb the starling would not show up.
                      • ijones2I ijones2
                        @Vinny @tom
                        Initiate flash
                        @ijones2 When you are attempting to use QDL are you flipped the switch to the ON position?
                        QDL should start giving output instantly so no need to wait that long before trying something else
                          ijones2I Offline
                          ijones2I Offline
                          ijones2
                          Hey Tom!
                          I do have the switch flipped on!
                          • ijones2I ijones2
                            Hey Tom!
                            ijones2I Offline
                            ijones2I Offline
                            ijones2
                            @ijones2 @tom
                            • ijones2I ijones2
                              @ijones2 @tom
                              @ijones2 I would try opening a new terminal, running sudo dmesg -wH, then powering and plugging in your VOXL 2 to your host PC and see if you see any enumeration info come through. This will tell us if your cable setup is good
                                ijones2I Offline
                                ijones2I Offline
                                ijones2
                                Hey Tom!
                                I ran the code and I got a lot of input but I went and scrolled specifically to the usb part and here's what I got
                                I can send a picture of all the output it's a lot but let me know if that will be helpful.
                                • ijones2I ijones2
                                  Hey Tom!
                                  @ijones2 Can you try without running anything else? Just plugging in the board and powering it on should spit out some messages if it's detected correctly
                                    ijones2I Offline
                                    ijones2I Offline
                                    ijones2
                                    Hey Tom!
                                    Here'd what I got!
                                    • ijones2I ijones2
                                      Hey Tom!
                                      Here'd what I got!
                                      @ijones2 I'm not seeing any devices that seem to be the drone enumerating. Do you happen to have another machine or USB cable setup you can test with?
                                        ijones2I Offline
                                        ijones2I Offline
                                        ijones2
                                        Hey Tom!
                                        I have ordered another USB-C to USB-A cable and made sure that it included data transfer and should be here tomorrow. The cable I am currently using has/had worked but I am starting to think it might be the cord. I will find out tomorrow when it arrives and will update you then! If the new cords do not work on my lab laptop, I will try the cords on a different PC and if THAT does not work...😥
                                          ijones2I Offline
                                          ijones2I Offline
                                          ijones2
                                          Hey Tom! i think this is progress?
                                          I tried 3 different USB-C to USB-A cords and the third one gave me " Bus 002 Device 002: ID 05c6:9008 Qualcomm, Inc. Gobi Wireless Modem (QDL mode) "
                                          so I guess it was the cord? Or is it my lab laptop?
                                          I kind of don't know what to make of this??
