  3. Starling Drone not showing up in ADB devices
starling2usbvoxllinuxhelp
23 Posts 4 Posters 7.2k Views 3 Watching
  • ijones2I ijones2
    @Bernhard
    Hey Bernhard!
    the cord is usb-a to usb-c. the laptop i’m using doesn’t have usb-c port and linux is native to the laptop. 🥹🥹
    Hi @ijones2
    Are you able to post a picture of your entire drone, and zoom in (second+ images) on your power source(s) and power connections to the drone?
    ijones2I 2 Replies Last reply
    • VinnyV Vinny
      Hi @ijones2
      ijones2I Offline
      ijones2I Offline
      ijones2
      @Vinny
      Hey Vinny! But of course! I hope this helps !!!!
      ijones2I 1 Reply Last reply
      • ijones2I ijones2
        @Vinny
        ijones2I Offline
        ijones2I Offline
        ijones2
        wrote on last edited by ijones2
        @ijones2 @Vinny
        • VinnyV Vinny
          Hi @ijones2
          ijones2I Offline
          ijones2I Offline
          ijones2
          @Vinny
          VinnyV 1 Reply Last reply
          • ijones2I ijones2
            @Vinny
            Hi @ijones2
            Thanks for those. Your Starling looks like it's new out of the box, so I do not suspect anything severe is happening. All of the green lights when you power I can see in the image stay solid green, right (no flashing/flickering)?
            if so, all should be OK and your system is likely booting, so you may have a problem with your host machine.
            I am from Hardware, so I'll need to pull in someone from software team to help you.
            @tom ,
            My suspicion is ADB is not installed correctly on the host machine, but I do not know how to help someone through that.
            Or...
            If the drone was operating and the battery suddenly dropped out to give the red LED, it just means it was shut down. But, if the shut-down was occurring during a write operation which could have been happening from a QGC config, it might be bricked.
            any ideas?
            tomT ijones2I 2 Replies Last reply
            • VinnyV Vinny
              Hi @ijones2
              @tom ,
              Or...
              any ideas?
              @ijones2 When your drone is powered and plugged into your host machine via USB, what do you see with lsusb?
              • VinnyV Vinny
                Hi @ijones2
                @tom ,
                Or...
                any ideas?
                ijones2I Offline
                ijones2I Offline
                ijones2
                @Vinny @tom
                Yep! Solid green, no flickering!
                I tried the unbrick guide but then I got to this step:
                Initiate flash
                While in the ufs sub-directory of the image release, run the following qdl command in order to flash the device:
                $ sudo qdl --debug --storage ufs --include . prog_firehose_ddr.elf rawprogram_unsparse0.xml rawprogram1.xml rawprogram2.xml rawprogram3.xml rawprogram4.xml rawprogram5.xml patch0.xml patch1.xml patch2.xml patch3.xml patch4.xml patch5.xml
                and it would say waiting for device and I left that on the screen because it said that the qdl flash will take some time. I had to end the process because it was going on 4+ hours of waiting for device. I restarted it and it was still taking hours. I never got to the point of seeing the completion output.
                when I would run this $ lsusb the starling would not show up.
                • ijones2I ijones2
                  @Vinny @tom
                  Initiate flash
                  @ijones2 When you are attempting to use QDL are you flipped the switch to the ON position?
                  QDL should start giving output instantly so no need to wait that long before trying something else
                    ijones2I Offline
                    ijones2I Offline
                    ijones2
                    Hey Tom!
                    I do have the switch flipped on!
                    • ijones2I ijones2
                      Hey Tom!
                      ijones2I Offline
                      ijones2I Offline
                      ijones2
                      @ijones2 @tom
                      • ijones2I ijones2
                        @ijones2 @tom
                        @ijones2 I would try opening a new terminal, running sudo dmesg -wH, then powering and plugging in your VOXL 2 to your host PC and see if you see any enumeration info come through. This will tell us if your cable setup is good
                          ijones2I Offline
                          ijones2I Offline
                          ijones2
                          Hey Tom!
                          I ran the code and I got a lot of input but I went and scrolled specifically to the usb part and here's what I got
                          I can send a picture of all the output it's a lot but let me know if that will be helpful.
                          • ijones2I ijones2
                            Hey Tom!
                            @ijones2 Can you try without running anything else? Just plugging in the board and powering it on should spit out some messages if it's detected correctly
                              ijones2I Offline
                              ijones2I Offline
                              ijones2
                              Hey Tom!
                              Here'd what I got!
                              • ijones2I ijones2
                                Hey Tom!
                                Here'd what I got!
                                @ijones2 I'm not seeing any devices that seem to be the drone enumerating. Do you happen to have another machine or USB cable setup you can test with?
                                  ijones2I Offline
                                  ijones2I Offline
                                  ijones2
                                  Hey Tom!
                                  I have ordered another USB-C to USB-A cable and made sure that it included data transfer and should be here tomorrow. The cable I am currently using has/had worked but I am starting to think it might be the cord. I will find out tomorrow when it arrives and will update you then! If the new cords do not work on my lab laptop, I will try the cords on a different PC and if THAT does not work...😥
                                    ijones2I Offline
                                    ijones2I Offline
                                    ijones2
                                    Hey Tom! i think this is progress?
                                    I tried 3 different USB-C to USB-A cords and the third one gave me " Bus 002 Device 002: ID 05c6:9008 Qualcomm, Inc. Gobi Wireless Modem (QDL mode) "
                                    so I guess it was the cord? Or is it my lab laptop?
                                    I kind of don't know what to make of this??
                                    • ijones2I ijones2
                                      @ijones2 QDL means that the QDL switch is likely switched to ON which would meant that the QDL unbricking process would likely work. Can you try the same test with the switch OFF (requires plugging/unplugging power) and see what lsusb shows?
                                        ijones2I Offline
                                        ijones2I Offline
                                        ijones2
                                        Hey Tom! good news!
                                        I got new cables for the drone now and when I connected the drone it shows up on the lsusb and I am able to run the adb shell. Would I have to unbrick it or because the adb shell is running I would not need to unbrick it? Essentially I'm asking what my next steps should be?
                                        • ijones2I ijones2
                                          Hey Tom! good news!
                                          @ijones2 This is great news! It looks like everything is functioning as expected so no need to go through the unbricking process at this point.
                                          It does appear that there is a fairly old SDK loaded on there so I would recommend flashing the latest SDK (1.3.3) from downloads.modalai.com under "VOXL 2 Platform Releases"
                                          Just follow the instructions here to do so: https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release
