    Starling Drone not showing up in ADB devices
    starling2 usb voxl linux help
    1397
    • ijones2I
      ijones2
      Hello my name is Ivy Jones!
      I am doing research under a professor at my college and I am using the Starling Drone. One day as I was setting up the Ground control, the front LED on the drone turned red and I looked up what that could mean. It meant that the the drone was not receiving enough voltage. So I got a new battery and it turned on. The LED was green, so I proceeded to the instructions.
      Next, I go into Ubuntu/Linux terminal and I am trying the adb commands and its saying no adb devices detected. I even ran the usb bus command to tell me if anything was plugged in and nothing. I changed the cord several times to see if it was the cord, tried a different laptop .and I was still unable to communicate with the drone.
      I thought it was bricked and it very well may be but it's still not showing up when I plug it into my laptop and it is not being listed when I run the command to list adb devices. Any help/advice/comments would be great! My whole research is based on flying this drone :') I am afraid that I broke it.
      • B
        Bernhard @ijones2
        @ijones2
        Hello Ivy!
        Just a suggestion - I have seen that problem, but it only occurred when using USB-C to USB-C. Have you used a USB-A to USB-C cable?
        Are you using a native Linux machine or a virtual machine?
        (Not an expert, just trying to help 🙂 )
        BR
        Bernhard
        ijones2I 1 Reply Last reply Reply Quote 1
        • ijones2I
          ijones2 @Bernhard
          @Bernhard
          Hey Bernhard!
          the cord is usb-a to usb-c. the laptop i’m using doesn’t have usb-c port and linux is native to the laptop. 🥹🥹
          • VinnyV
            Vinny ModalAI Team @ijones2
            Hi @ijones2
            Are you able to post a picture of your entire drone, and zoom in (second+ images) on your power source(s) and power connections to the drone?
            ijones2I 2 Replies Last reply Reply Quote 0
            • ijones2I
              ijones2 @Vinny
              @Vinny
              Hey Vinny! But of course! I hope this helps !!!!
              ijones2I 1 Reply Last reply Reply Quote 0
              • ijones2I
                ijones2 @ijones2
                @ijones2 @Vinny
                • ijones2I
                  ijones2 @Vinny
                  @Vinny
                  • VinnyV
                    Hi @ijones2
                    Thanks for those. Your Starling looks like it's new out of the box, so I do not suspect anything severe is happening. All of the green lights when you power I can see in the image stay solid green, right (no flashing/flickering)?
                    if so, all should be OK and your system is likely booting, so you may have a problem with your host machine.
                    I am from Hardware, so I'll need to pull in someone from software team to help you.
                    @tom ,
                    My suspicion is ADB is not installed correctly on the host machine, but I do not know how to help someone through that.
                    Or...
                    If the drone was operating and the battery suddenly dropped out to give the red LED, it just means it was shut down. But, if the shut-down was occurring during a write operation which could have been happening from a QGC config, it might be bricked.
                    any ideas?
                    tomT ijones2I 2 Replies Last reply Reply Quote 0
                      tom admin @Vinny
                      @ijones2 When your drone is powered and plugged into your host machine via USB, what do you see with lsusb?
                      • ijones2I
                        ijones2 @Vinny
                        @Vinny @tom
                        Yep! Solid green, no flickering!
                        I tried the unbrick guide but then I got to this step:
                        Initiate flash
                        While in the ufs sub-directory of the image release, run the following qdl command in order to flash the device:
                        $ sudo qdl --debug --storage ufs --include . prog_firehose_ddr.elf rawprogram_unsparse0.xml rawprogram1.xml rawprogram2.xml rawprogram3.xml rawprogram4.xml rawprogram5.xml patch0.xml patch1.xml patch2.xml patch3.xml patch4.xml patch5.xml
                        and it would say waiting for device and I left that on the screen because it said that the qdl flash will take some time. I had to end the process because it was going on 4+ hours of waiting for device. I restarted it and it was still taking hours. I never got to the point of seeing the completion output.
                        when I would run this $ lsusb the starling would not show up.
                          tom admin @ijones2
                          @ijones2 When you are attempting to use QDL are you flipped the switch to the ON position?
                          QDL should start giving output instantly so no need to wait that long before trying something else
                          • ijones2I
                            ijones2 @tom
                            Hey Tom!
                            I do have the switch flipped on!
                            • ijones2I
                              ijones2 @ijones2
                              @ijones2 @tom
                                tom admin @ijones2
                                @ijones2 I would try opening a new terminal, running sudo dmesg -wH, then powering and plugging in your VOXL 2 to your host PC and see if you see any enumeration info come through. This will tell us if your cable setup is good
                                • ijones2I
                                  ijones2 @tom
                                  Hey Tom!
                                  I ran the code and I got a lot of input but I went and scrolled specifically to the usb part and here's what I got
                                  I can send a picture of all the output it's a lot but let me know if that will be helpful.
                                    tom admin @ijones2
                                    @ijones2 Can you try without running anything else? Just plugging in the board and powering it on should spit out some messages if it's detected correctly
                                    • ijones2I
                                      ijones2 @tom
                                      Hey Tom!
                                      Here'd what I got!
                                        tom admin @ijones2
                                        @ijones2 I'm not seeing any devices that seem to be the drone enumerating. Do you happen to have another machine or USB cable setup you can test with?
                                        • ijones2I
                                          ijones2 @tom
                                          Hey Tom!
                                          I have ordered another USB-C to USB-A cable and made sure that it included data transfer and should be here tomorrow. The cable I am currently using has/had worked but I am starting to think it might be the cord. I will find out tomorrow when it arrives and will update you then! If the new cords do not work on my lab laptop, I will try the cords on a different PC and if THAT does not work...😥
                                          • ijones2I
                                            ijones2 @tom
                                            Hey Tom! i think this is progress?
                                            I tried 3 different USB-C to USB-A cords and the third one gave me " Bus 002 Device 002: ID 05c6:9008 Qualcomm, Inc. Gobi Wireless Modem (QDL mode) "
                                            so I guess it was the cord? Or is it my lab laptop?
                                            I kind of don't know what to make of this??
