  3. Voxl-mapper on VOXL2
mapping
17 Posts 9 Posters 10.9k Views 1 Watching
  • ModeratorM Moderator
    voxl-mapper has been working on VOXL 2 for about a year. It should work out of the box on a Starling.
    What you may be referring to is better documentation for using with stereo sensors instead of TOF sensors, but in general the voxl-mapper package is working.
    This video shows how it works - https://www.youtube.com/watch?v=gqlSKRP8prc&ab_channel=ModalAI
    J Offline
    J Offline
    Jgaucin
    @Moderator I see, does it also work out of the box on Sentinel? Or do some adjustments need to be made? I say this because I am not able to run it on the Sentinel currently.
    • J Jgaucin
      @Jgaucin Are you on SDK 1.0?
      J 1 Reply Last reply
        J Offline
        J Offline
        Jgaucin
        @tom No, currently on SDK 0.9.5 I haven't flashed it yet for the new SDK update
          J Offline
          J Offline
          Jgaucin
          @Moderator I will update it now and see if it becomes available
          • sspillerS Offline
            sspillerS Offline
            sspiller
            @Tom, is Voxl-mapper working SDK 1.0 yet?
            • sspillerS sspiller
              J Offline
              J Offline
              Jgaucin
              @Moderator @tom This might be a more general question but, is there any way to push the voxl-mapper code to the Sentinel from the Gitlab? I want to test out the pointcloud 3D reconstruction of the environment using the dfs server if possible? Is it SLAM capable with stereo on the Sentinel Development Drone, I see that it is availble for the Starling which has PMD TOF, Tracking, 4k30 image sensors but I haven't seen any documentation or video for the Sentinel which has 2 Stereo Pairs, Tracking, 4K High-Res image sensors.
              What would be the best steps to move forward with my goal?
              Thanks, as always!
              • J Jgaucin
                Thanks, as always!
                @Jgaucin If your Sentinel is on SDK 1.0, voxl-mapper 0.1.9 should be available onboard for installation by running apt install voxl-mapper
                  J Offline
                  J Offline
                  Jgaucin
                  @tom Hello, due to the issue described in this discussion post here I wasn't able to run the dfs-server and therefore the voxl-mapper on SDK 1.0.0 on the Sentinel's VOXL2.
                  Now I am running into some issues after doing apt install voxl-mapper onto VOXL2 SDK 0.9.5 and running the command voxl-mapper on the Sentinel.
                  "ERROR fetching tf from tf ringbuffer
                  there wasn't sufficient data in the buffer
                  This only shows the following image onto voxl portal and does not construct a map.
                  Also, is this solution still relevant to 0.9.5? It states that there is an issue with the qvio server receiving a pose estimate here.
                  Taylor PresleyT 1 Reply Last reply
                  • J Jgaucin
                    Taylor PresleyT Offline
                    Taylor Presley
                    @Jgaucin @tom Any tips on getting this to work? I am running into the same issue using a Sentinel with voxl-suite 1.1
                    Any help is appreciated!
                    Taylor
                    • Taylor PresleyT Taylor Presley
                      Taylor
                      Taylor Presley
                      @tom nevermind, I got it figured out!
                        Jetson NanoJ Offline
                        Jetson Nano
                        Veteran
                        @Taylor-Presley Could you share how you solved the above error?
                        • Zachary Lowell 0Z Offline
                          Zachary Lowell 0
                          @Jetson-Nano can you upgrade to the most recent SDK please and paste the output of voxl-mapper - if its the ring buffer issue - which TOF are you using?
                          Also can you confirm the drone is in position mode prior to flight
                          P 1 Reply Last reply
                            P Offline
                            P Offline
                            plub
                            @Zachary-Lowell-0 Does voxl-mapper need a TOF sensor to work properly?
                            Viktor GalV 1 Reply Last reply
                            • P plub
                              Viktor GalV Offline
                              Viktor GalV Offline
                              Viktor Gal
                              @plub yeah, unless you have other means to get the depth information. see the code: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper/-/blob/master/server/voxl-mapper/voxl_mapper.cc?ref_type=heads#L99
                              basically you need a depth sensor of sort.
                                Zachary Lowell 0
                                @plub said in Voxl-mapper on VOXL2:
                                1 Reply Last reply a day ago Reply
                                @plub yes you need a modalAI tof for voxl-mapper to work properly - you can technically get by by using another TOF sensor but then youd personally need to write the code to popuilte the MPA with pointcloud data the the voxl-mapper client is subscribing to.
