  2. Software Development
  3. Mapping and Planning
  4. Voxl-mapper on VOXL2
Scheduled Pinned Locked Moved Mapping and Planning
17 Posts 9 Posters 10.5k Views 1 Watching
  • J Offline
    J Offline
    Jgaucin
    I was wondering if there's any updates on voxl-mapper working on VOXL2? I saw the post saying that it was being worked on internally and wished to deploy voxl-mapper with the stereo camera input (for the depth sensor), or even purchase a ToF sensor in order to make a map of the indoors with the Sentinel drone. I saw this in the docs over SDK 0.9 and will follow this if still relevant.
    link text
    Also, I am curious about the autonomous capability of the drone, or its capability for autonomous flight. Does the VOXL2 enable some sort of flight path planning which can be controlled either manually or autonomously? I wish to use it to navigate first in a small indoor drone cage but eventually move to autonomous flight capabilities where it can follow instructions based on what the vision system sees.
    Thank you for your time as always!
    • ModeratorM Offline
      voxl-mapper has been working on VOXL 2 for about a year. It should work out of the box on a Starling.
      What you may be referring to is better documentation for using with stereo sensors instead of TOF sensors, but in general the voxl-mapper package is working.
      This video shows how it works - https://www.youtube.com/watch?v=gqlSKRP8prc&ab_channel=ModalAI
      J 2 Replies Last reply
      • ModeratorM Moderator
        J Offline
        J Offline
        Jgaucin
        @Moderator I see, does it also work out of the box on Sentinel? Or do some adjustments need to be made? I say this because I am not able to run it on the Sentinel currently.
        • J Jgaucin
          @Jgaucin Are you on SDK 1.0?
          J 1 Reply Last reply
            J Offline
            J Offline
            Jgaucin
            @tom No, currently on SDK 0.9.5 I haven't flashed it yet for the new SDK update
              J Offline
              J Offline
              Jgaucin
              @Moderator I will update it now and see if it becomes available
              • sspillerS Offline
                sspillerS Offline
                sspiller
                @Tom, is Voxl-mapper working SDK 1.0 yet?
                • sspillerS sspiller
                  J Offline
                  J Offline
                  Jgaucin
                  @Moderator @tom This might be a more general question but, is there any way to push the voxl-mapper code to the Sentinel from the Gitlab? I want to test out the pointcloud 3D reconstruction of the environment using the dfs server if possible? Is it SLAM capable with stereo on the Sentinel Development Drone, I see that it is availble for the Starling which has PMD TOF, Tracking, 4k30 image sensors but I haven't seen any documentation or video for the Sentinel which has 2 Stereo Pairs, Tracking, 4K High-Res image sensors.
                  What would be the best steps to move forward with my goal?
                  Thanks, as always!
                  • J Jgaucin
                    Thanks, as always!
                    @Jgaucin If your Sentinel is on SDK 1.0, voxl-mapper 0.1.9 should be available onboard for installation by running apt install voxl-mapper
                      J Offline
                      J Offline
                      Jgaucin
                      @tom Hello, due to the issue described in this discussion post here I wasn't able to run the dfs-server and therefore the voxl-mapper on SDK 1.0.0 on the Sentinel's VOXL2.
                      Now I am running into some issues after doing apt install voxl-mapper onto VOXL2 SDK 0.9.5 and running the command voxl-mapper on the Sentinel.
                      "ERROR fetching tf from tf ringbuffer
                      there wasn't sufficient data in the buffer
                      This only shows the following image onto voxl portal and does not construct a map.
                      Also, is this solution still relevant to 0.9.5? It states that there is an issue with the qvio server receiving a pose estimate here.
                      Taylor PresleyT 1 Reply Last reply
                      • J Jgaucin
                        Taylor PresleyT Offline
                        Taylor Presley
                        @Jgaucin @tom Any tips on getting this to work? I am running into the same issue using a Sentinel with voxl-suite 1.1
                        Any help is appreciated!
                        Taylor
                        • Taylor PresleyT Taylor Presley
                          Taylor
                          Taylor Presley
                          @tom nevermind, I got it figured out!
                            Jetson NanoJ Offline
                            Jetson Nano
                            Veteran
                            @Taylor-Presley Could you share how you solved the above error?
                            • Zachary Lowell 0Z Offline
                              Zachary Lowell 0
                              @Jetson-Nano can you upgrade to the most recent SDK please and paste the output of voxl-mapper - if its the ring buffer issue - which TOF are you using?
                              Also can you confirm the drone is in position mode prior to flight
                              P 1 Reply Last reply
                                P Offline
                                P Offline
                                plub
                                @Zachary-Lowell-0 Does voxl-mapper need a TOF sensor to work properly?
                                Viktor GalV 1 Reply Last reply
                                • P plub
                                  Viktor GalV Offline
                                  Viktor GalV Offline
                                  Viktor Gal
                                  @plub yeah, unless you have other means to get the depth information. see the code: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper/-/blob/master/server/voxl-mapper/voxl_mapper.cc?ref_type=heads#L99
                                  basically you need a depth sensor of sort.
                                    Zachary Lowell 0
                                    @plub said in Voxl-mapper on VOXL2:
                                    1 Reply Last reply a day ago Reply
                                    @plub yes you need a modalAI tof for voxl-mapper to work properly - you can technically get by by using another TOF sensor but then youd personally need to write the code to popuilte the MPA with pointcloud data the the voxl-mapper client is subscribing to.
