<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Voxl-mapper on VOXL2]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I was wondering if there's any updates on voxl-mapper working on VOXL2? I saw the post saying that it was being worked on internally and wished to deploy voxl-mapper with the stereo camera input (for the depth sensor), or even purchase a ToF sensor in order to make a map of the indoors with the Sentinel drone. I saw this in the docs over SDK 0.9 and will follow this if still relevant.</p>
<p dir="auto"><a href="https://docs.modalai.com/voxl-dfs-server-0_9/" rel="nofollow ugc">link text</a></p>
<p dir="auto">Also, I am curious about the autonomous capability of the drone, or its capability for autonomous flight. Does the VOXL2 enable some sort of flight path planning which can be controlled either manually or autonomously? I wish to use it to navigate first in a small indoor drone cage but eventually move to autonomous flight capabilities where it can follow instructions based on what the vision system sees.</p>
<p dir="auto">Thank you for your time as always!</p>
]]></description><link>https://forum.modalai.com/topic/2512/voxl-mapper-on-voxl2</link><generator>RSS for Node</generator><lastBuildDate>Thu, 19 Nov 2026 02:54:18 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2512.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 Jul 2023 17:09:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Wed, 30 Oct 2024 14:36:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plub" aria-label="Profile: plub">@<bdi>plub</bdi></a> said in <a href="/post/19490">Voxl-mapper on VOXL2</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zachary-lowell-0" aria-label="Profile: Zachary-Lowell-0">@<bdi>Zachary-Lowell-0</bdi></a> Does voxl-mapper need a TOF sensor to work properly?</p>
<p dir="auto">1 Reply Last reply a day ago Reply</p>
</blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plub" aria-label="Profile: plub">@<bdi>plub</bdi></a> yes you need a modalAI tof for voxl-mapper to work properly - you can technically get by by using another TOF sensor but then youd personally need to write the code to popuilte the MPA with pointcloud data the the voxl-mapper client is subscribing to.</p>
]]></description><link>https://forum.modalai.com/post/19497</link><guid isPermaLink="true">https://forum.modalai.com/post/19497</guid><dc:creator><![CDATA[Zachary Lowell 0]]></dc:creator><pubDate>Wed, 30 Oct 2024 14:36:33 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Tue, 29 Oct 2024 12:54:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plub" aria-label="Profile: plub">@<bdi>plub</bdi></a> yeah, unless you have other means to get the depth information. see the code: <a href="https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper/-/blob/master/server/voxl-mapper/voxl_mapper.cc?ref_type=heads#L99" rel="nofollow ugc">https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper/-/blob/master/server/voxl-mapper/voxl_mapper.cc?ref_type=heads#L99</a></p>
<p dir="auto">basically you need a depth sensor of sort.</p>
]]></description><link>https://forum.modalai.com/post/19491</link><guid isPermaLink="true">https://forum.modalai.com/post/19491</guid><dc:creator><![CDATA[Viktor Gal]]></dc:creator><pubDate>Tue, 29 Oct 2024 12:54:27 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Tue, 29 Oct 2024 12:42:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zachary-lowell-0" aria-label="Profile: Zachary-Lowell-0">@<bdi>Zachary-Lowell-0</bdi></a>  Does voxl-mapper need a TOF sensor to work properly?</p>
]]></description><link>https://forum.modalai.com/post/19490</link><guid isPermaLink="true">https://forum.modalai.com/post/19490</guid><dc:creator><![CDATA[plub]]></dc:creator><pubDate>Tue, 29 Oct 2024 12:42:57 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Thu, 24 Oct 2024 22:10:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jetson-nano" aria-label="Profile: Jetson-Nano">@<bdi>Jetson-Nano</bdi></a> can you upgrade to the most recent SDK please and paste the output of voxl-mapper - if its the ring buffer issue - which TOF are you using?</p>
<p dir="auto">Also can you confirm the drone is in position mode prior to flight</p>
]]></description><link>https://forum.modalai.com/post/19426</link><guid isPermaLink="true">https://forum.modalai.com/post/19426</guid><dc:creator><![CDATA[Zachary Lowell 0]]></dc:creator><pubDate>Thu, 24 Oct 2024 22:10:16 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Wed, 23 Oct 2024 10:01:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/taylor-presley" aria-label="Profile: Taylor-Presley">@<bdi>Taylor-Presley</bdi></a> Could you share how you solved the above error?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.modalai.com/post/19390</link><guid isPermaLink="true">https://forum.modalai.com/post/19390</guid><dc:creator><![CDATA[Jetson Nano]]></dc:creator><pubDate>Wed, 23 Oct 2024 10:01:29 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Sun, 07 Jul 2024 03:07:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> nevermind, I got it figured out!</p>
]]></description><link>https://forum.modalai.com/post/18074</link><guid isPermaLink="true">https://forum.modalai.com/post/18074</guid><dc:creator><![CDATA[Taylor Presley]]></dc:creator><pubDate>Sun, 07 Jul 2024 03:07:00 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Sat, 06 Jul 2024 18:31:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jgaucin" aria-label="Profile: Jgaucin">@<bdi>Jgaucin</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> Any tips on getting this to work? I am running into the same issue using a Sentinel with voxl-suite 1.1</p>
<p dir="auto">Any help is appreciated!<br />
Thanks,<br />
Taylor</p>
]]></description><link>https://forum.modalai.com/post/18072</link><guid isPermaLink="true">https://forum.modalai.com/post/18072</guid><dc:creator><![CDATA[Taylor Presley]]></dc:creator><pubDate>Sat, 06 Jul 2024 18:31:55 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Tue, 12 Sep 2023 16:40:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> Hello, due to the issue described in this discussion post <a href="https://forum.modalai.com/post/11715">here</a> I wasn't able to run the dfs-server and therefore the voxl-mapper on SDK 1.0.0 on the Sentinel's VOXL2.</p>
<p dir="auto">Now I am running into some issues after doing apt install voxl-mapper onto VOXL2 SDK 0.9.5 and running the command voxl-mapper on the Sentinel.<br />
"<strong>ERROR fetching tf from tf ringbuffer<br />
there wasn't sufficient data in the buffer</strong>"</p>
<p dir="auto"><img src="/assets/uploads/files/1694536672949-voxl_map102-resized.png" alt="Voxl_Map102.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This only shows the following image onto voxl portal and does not construct a map.</p>
<p dir="auto"><img src="/assets/uploads/files/1694536546988-voxl_map101-resized.png" alt="Voxl_Map101.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Also, is this solution still relevant to 0.9.5? It states that there is an issue with the qvio server receiving a pose estimate <a href="https://forum.modalai.com/post/5876">here</a>.</p>
<p dir="auto"><img src="/assets/uploads/files/1694536759364-voxl_qvio103.png" alt="Voxl_Qvio103.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/12277</link><guid isPermaLink="true">https://forum.modalai.com/post/12277</guid><dc:creator><![CDATA[Jgaucin]]></dc:creator><pubDate>Tue, 12 Sep 2023 16:40:24 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Wed, 30 Aug 2023 16:56:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jgaucin" aria-label="Profile: Jgaucin">@<bdi>Jgaucin</bdi></a> If your Sentinel is on SDK 1.0, voxl-mapper 0.1.9 should be available onboard for installation by running <code>apt install voxl-mapper</code></p>
]]></description><link>https://forum.modalai.com/post/12060</link><guid isPermaLink="true">https://forum.modalai.com/post/12060</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Wed, 30 Aug 2023 16:56:27 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Wed, 30 Aug 2023 16:53:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moderator" aria-label="Profile: Moderator">@<bdi>Moderator</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a>  This might be a more general question but, is there any way to push the voxl-mapper code to the Sentinel from the Gitlab? I want to test out the pointcloud 3D reconstruction of the environment using the dfs server if possible? Is it SLAM capable with stereo on the Sentinel Development Drone, I see that it is availble for the Starling which has PMD TOF, Tracking, 4k30 image sensors but I haven't seen any documentation or video for the Sentinel which has 2 Stereo Pairs, Tracking, 4K High-Res image sensors.</p>
<p dir="auto">What would be the best steps to move forward with my goal?</p>
<p dir="auto">Thanks, as always!</p>
]]></description><link>https://forum.modalai.com/post/12059</link><guid isPermaLink="true">https://forum.modalai.com/post/12059</guid><dc:creator><![CDATA[Jgaucin]]></dc:creator><pubDate>Wed, 30 Aug 2023 16:53:08 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Thu, 03 Aug 2023 16:33:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: Tom">@<bdi>Tom</bdi></a>, is Voxl-mapper working SDK 1.0 yet?</p>
]]></description><link>https://forum.modalai.com/post/11694</link><guid isPermaLink="true">https://forum.modalai.com/post/11694</guid><dc:creator><![CDATA[sspiller]]></dc:creator><pubDate>Thu, 03 Aug 2023 16:33:04 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Tue, 01 Aug 2023 20:23:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moderator" aria-label="Profile: Moderator">@<bdi>Moderator</bdi></a>  I will update it now and see if it becomes available</p>
]]></description><link>https://forum.modalai.com/post/11617</link><guid isPermaLink="true">https://forum.modalai.com/post/11617</guid><dc:creator><![CDATA[Jgaucin]]></dc:creator><pubDate>Tue, 01 Aug 2023 20:23:09 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Tue, 01 Aug 2023 19:27:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> No, currently on SDK 0.9.5 I haven't flashed it yet for the new SDK update</p>
]]></description><link>https://forum.modalai.com/post/11616</link><guid isPermaLink="true">https://forum.modalai.com/post/11616</guid><dc:creator><![CDATA[Jgaucin]]></dc:creator><pubDate>Tue, 01 Aug 2023 19:27:45 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Tue, 01 Aug 2023 19:23:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jgaucin" aria-label="Profile: Jgaucin">@<bdi>Jgaucin</bdi></a> Are you on SDK 1.0?</p>
]]></description><link>https://forum.modalai.com/post/11615</link><guid isPermaLink="true">https://forum.modalai.com/post/11615</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Tue, 01 Aug 2023 19:23:34 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Tue, 01 Aug 2023 19:11:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moderator" aria-label="Profile: Moderator">@<bdi>Moderator</bdi></a> I see, does it also work out of the box on Sentinel? Or do some adjustments need to be made? I say this because I am not able to run it on the Sentinel currently.</p>
]]></description><link>https://forum.modalai.com/post/11613</link><guid isPermaLink="true">https://forum.modalai.com/post/11613</guid><dc:creator><![CDATA[Jgaucin]]></dc:creator><pubDate>Tue, 01 Aug 2023 19:11:28 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl-mapper on VOXL2 on Tue, 01 Aug 2023 06:09:16 GMT]]></title><description><![CDATA[<p dir="auto">voxl-mapper has been working on VOXL 2 for about a year. It should work out of the box on a Starling.</p>
<p dir="auto">What you may be referring to is better documentation for using with stereo sensors instead of TOF sensors, but in general the voxl-mapper package is working.</p>
<p dir="auto">This video shows how it works - <a href="https://www.youtube.com/watch?v=gqlSKRP8prc&amp;ab_channel=ModalAI" rel="nofollow ugc">https://www.youtube.com/watch?v=gqlSKRP8prc&amp;ab_channel=ModalAI</a></p>
]]></description><link>https://forum.modalai.com/post/11584</link><guid isPermaLink="true">https://forum.modalai.com/post/11584</guid><dc:creator><![CDATA[Moderator]]></dc:creator><pubDate>Tue, 01 Aug 2023 06:09:16 GMT</pubDate></item></channel></rss>
