  3. Voxl-mapper on VOXL2
mapping
17 Posts 9 Posters 10.8k Views 1 Watching
  • ModeratorM Moderator
    voxl-mapper has been working on VOXL 2 for about a year. It should work out of the box on a Starling.
    What you may be referring to is better documentation for using with stereo sensors instead of TOF sensors, but in general the voxl-mapper package is working.
    This video shows how it works - https://www.youtube.com/watch?v=gqlSKRP8prc&ab_channel=ModalAI
    J Offline
    J Offline
    Jgaucin
    @Moderator I will update it now and see if it becomes available
    • sspillerS Offline
      sspillerS Offline
      sspiller
      @Tom, is Voxl-mapper working SDK 1.0 yet?
      J 1 Reply Last reply
      • sspillerS sspiller
        J Offline
        J Offline
        Jgaucin
        @Moderator @tom This might be a more general question but, is there any way to push the voxl-mapper code to the Sentinel from the Gitlab? I want to test out the pointcloud 3D reconstruction of the environment using the dfs server if possible? Is it SLAM capable with stereo on the Sentinel Development Drone, I see that it is availble for the Starling which has PMD TOF, Tracking, 4k30 image sensors but I haven't seen any documentation or video for the Sentinel which has 2 Stereo Pairs, Tracking, 4K High-Res image sensors.
        What would be the best steps to move forward with my goal?
        Thanks, as always!
        • J Jgaucin
          Thanks, as always!
          @Jgaucin If your Sentinel is on SDK 1.0, voxl-mapper 0.1.9 should be available onboard for installation by running apt install voxl-mapper
            J Offline
            J Offline
            Jgaucin
            @tom Hello, due to the issue described in this discussion post here I wasn't able to run the dfs-server and therefore the voxl-mapper on SDK 1.0.0 on the Sentinel's VOXL2.
            Now I am running into some issues after doing apt install voxl-mapper onto VOXL2 SDK 0.9.5 and running the command voxl-mapper on the Sentinel.
            "ERROR fetching tf from tf ringbuffer
            there wasn't sufficient data in the buffer
            This only shows the following image onto voxl portal and does not construct a map.
            Also, is this solution still relevant to 0.9.5? It states that there is an issue with the qvio server receiving a pose estimate here.
            Taylor PresleyT 1 Reply Last reply
            • J Jgaucin
              Taylor PresleyT Offline
              Taylor Presley
              @Jgaucin @tom Any tips on getting this to work? I am running into the same issue using a Sentinel with voxl-suite 1.1
              Any help is appreciated!
              Taylor
              • Taylor PresleyT Taylor Presley
                Taylor
                Taylor Presley
                @tom nevermind, I got it figured out!
                  Jetson NanoJ Offline
                  Jetson Nano
                  Veteran
                  @Taylor-Presley Could you share how you solved the above error?
                  • Zachary Lowell 0Z Offline
                    Zachary Lowell 0
                    @Jetson-Nano can you upgrade to the most recent SDK please and paste the output of voxl-mapper - if its the ring buffer issue - which TOF are you using?
                    Also can you confirm the drone is in position mode prior to flight
                    P 1 Reply Last reply
                      P Offline
                      P Offline
                      plub
                      @Zachary-Lowell-0 Does voxl-mapper need a TOF sensor to work properly?
                      Viktor GalV 1 Reply Last reply
                      • P plub
                        Viktor GalV Offline
                        Viktor GalV Offline
                        Viktor Gal
                        @plub yeah, unless you have other means to get the depth information. see the code: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper/-/blob/master/server/voxl-mapper/voxl_mapper.cc?ref_type=heads#L99
                        basically you need a depth sensor of sort.
                          Zachary Lowell 0
                          @plub said in Voxl-mapper on VOXL2:
                          1 Reply Last reply a day ago Reply
                          @plub yes you need a modalAI tof for voxl-mapper to work properly - you can technically get by by using another TOF sensor but then youd personally need to write the code to popuilte the MPA with pointcloud data the the voxl-mapper client is subscribing to.
