    VOXL2 - Cube Orange External Flight Controller Integration
    3526
    • Jetson NanoJ
      Jetson Nano
      Hello @Chad-Sweet @Eric-Katzfey @tom @Alex-Kushleyev ,
      I'm using VOXL2 as a compute unit and need to connect a external flight controller for port availability and other feasibility needs. In my application, I'm using Pixhawk standard Cube Orange as external FC.
      For hardware integration, I'm referring to the documentation as listed here as a model reference.
      1. I'm integrating the the USB3/UART Add-On Board (M0125) to VOXL 2 (M0054) which giving a 4 pin JST GH connector with a UART available at /dev/ttyHS1 from the applications processor.
      2. I'm connecting the 4 pin JST type Output to the Cube Orange's Telemetry (TELEM1) port using 4 Ping JST GH connector to 6 pin GH Connector.
      3. In VOXL2, under /etc/modalai/voxl-mavlink-server.conf , I set external_ap_flight_controller paramater to true instead of default.
      4. In QGC, once I check by connecting the debug port of Cube to host PC through a USB data cable, under mavlink console upon checking using mavlink status, I receive the following outputs,
      mavlink status
      instance #0:
          mavlink chan: #0
          type:        GENERIC LINK OR RADIO
          flow control: OFF
          rates:
            tx: 487.3 B/s
            txerr: 0.0 B/s
            tx rate mult: 1.000
            tx rate max: 2880 B/s
            rx: 0.0 B/s
            rx loss: 0.0%
          FTP enabled: NO, TX enabled: YES
          mode: Minimal
          Forwarding: Off
          MAVLink version: 1
          transport protocol: serial (/dev/ttyS4 @57600)
      instance #1:
          mavlink chan: #1
          flow control: OFF
          rates:
            tx: 601.9 B/s
            txerr: 0.0 B/s
            tx rate mult: 0.306
            tx rate max: 1200 B/s
            rx: 0.0 B/s
            rx loss: 0.0%
          FTP enabled: YES, TX enabled: YES
          mode: Normal
          Forwarding: On
          MAVLink version: 1
          transport protocol: serial (/dev/ttyS0 @921600)
      instance #2:
          mavlink chan: #2
          flow control: OFF
          rates:
            tx: 817.9 B/s
            txerr: 0.0 B/s
            tx rate mult: 0.306
            rx: 12875.7 B/s
            rx loss: 125.2%
          Received Messages:
            sysid:  1, compid:197, Total: 47361 (lost: 5999736)
            sysid:  1, compid:196, Total: 568 (lost: 24)
          mode: Normal
          Forwarding: On
          MAVLink version: 2
          transport protocol: serial (/dev/ttyS1 @921600)
      instance #3:
          GCS heartbeat valid
          mavlink chan: #3
          type:        USB CDC
          flow control: ON
          rates:
            tx: 32408.2 B/s
            txerr: 0.0 B/s
            tx rate mult: 1.000
            tx rate max: 100000 B/s
            rx: 20.9 B/s
            rx loss: 0.0%
          Received Messages:
            sysid:255, compid:190, Total: 1196 (lost: 0)
          mode: Config
          Forwarding: On
          MAVLink version: 2
          transport protocol: serial (/dev/ttyACM0 @2000000)
          ping statistics:
            last: 34.42 ms
            mean: 17.87 ms
            max: 426.75 ms
            min: 0.28 ms
            dropped packets: 0
      nsh>
      Is this the recommended method of integrating an external FC with VOXL2? How do I verify further to know that my external FC is being used instead of VOXL's internal FC?
      Assuming, I'm having a custom Starling drone setup on my hardware build and integrating external FC, how do I do vehicle actuator setup in QGC once I'm done setting up external FC?
      • tomT
        tom admin @Jetson Nano
        @Jetson-Nano You can disable px4 on voxl with systemctl disable voxl-px4 to ensure its not running
        Jetson NanoJ 1 Reply Last reply Reply Quote 0
        • Jetson NanoJ
          Jetson Nano @tom
          @tom yes, I have done that.
          • Eric KatzfeyE
            Eric Katzfey ModalAI Team @Jetson Nano
            @Jetson-Nano If you have disabled the internal flight controller and remove the USB connection to the external flight controller and are still seeing the connection to QGC then I think you are setup. Are seeing any issues?
            • Jetson NanoJ
              Jetson Nano @Eric Katzfey
              @Eric-Katzfey, I'm having a Starling drone setup on my custom airframe build and having integrated external FC, how do I do vehicle actuator setup in QGC once I'm done setting up external FC?
              • Eric KatzfeyE
                @Jetson-Nano Once you are up and running on your external Orange Cube then VOXL 2 is just a conduit for mavlink packets. You should be able to interact with your Orange Cube normally. I do not know anything about Orange Cubes so can't answer how to do vehicle actuator setup in QGC with it.
                • Jetson NanoJ
                  Hey @Eric-Katzfey , I saw this post and in this you have asked to add the driver to the build configuration, but how do I include the voxl_esc driver to a build of different board configuration?
                  One more question, can I use the J5 connector of this to connect to the telemetry port of the FC?
                  Eric KatzfeyE 2 Replies Last reply Reply Quote 0
                  • Eric KatzfeyE
                    @Jetson-Nano To add the driver you need to modify the build configuration file (https://github.com/PX4/PX4-Autopilot/blob/main/boards/cubepilot/cubeorange/default.px4board). You can add the voxl-esc driver to that with CONFIG_DRIVERS_ACTUATORS_VOXL_ESC=y
                    • Eric KatzfeyE
                      @Jetson-Nano Yes, you should be able to use the UART pins on that J5 connector.
                      • Jetson NanoJ
                        Thank you @Eric-Katzfey , I'll test this out and get back to you on the result
                        • Jetson NanoJ
                          Jetson Nano @Jetson Nano
                          Hey @Eric-Katzfey , I tested whatever you told,
                          1. I connected to the UART port on the J5 of M0141, and I tested, it is not working. When using a companion computer you can run
                          cat /dev/ttyHSx
                          to get data from the FC, you'll get random symbols. I tried it and it is not working, when I tested yesterday with this I got the output as said previously, but still with J5 I tried the pymavlink part by changing the baud rate, but I am getting this output
                          voxl2:/home$ python3 mavlink_shell.py /dev/ttyTHS1
                          Connecting to MAVLINK...
                          And what will be the port for the J5 connector of M0141, it is not listed in the below table.
                          1. The VOXL ESC Driver part, I added that to the board config and built, after that I am not able to see any VOXL_ESC parameters.
                          • Eric KatzfeyE
                            @Jetson-Nano For the UART issue it's best to take things step by step. I would first verify the Orange Cube telemetry port by attaching it to a laptop or desktop computer. Make sure you can attach to QGC that way. And note the baudrate being used when it is working. That will validate the Orange Cube. Then validate the port of the add on card that you want to use with VOXL 2. For example, with M0141, validate /dev/ttyHS1 by attaching to a computer with a serial to UART cable and sending / receiving test data with a simple Python script. Once you are sure that the parts are working individually then you can hook them together and start debugging higher level things like voxl-mavlink-server.
                            • Eric KatzfeyE
                              @Jetson-Nano For the VOXL ESC part, now that you have the driver in your build you need to start the driver. For testing you can just go to the Nuttx shell and run voxl_esc start -d <uart-port>. This will show you if it is starting correctly. Once it is working correctly you should see the VOXL_ESC_XXX parameters and then you need to add the device start into your Orange Cube start scripts.
                              • Jetson NanoJ
                                Thank you @Eric-Katzfey , it worked, I tested each port individually and made sure the individual ports are working, and then integrated the two and is working fine.
                                Here is my solution if anyone needs.
                                I used Telem 1 port of the cube and the UART pins on the J5 connector of USB2 Type A Breakout (M0141) . The parameters I set for MAV 1 is here
                                After disabling the voxl-px4 services, Connect to VOXL wifi and check QGC, you'll get the FC data in which the cube is used as the flight controller.
                                The VOXL ESC, I haven't tested it yet, I'll test and get back if any problems.
