  3. VOXL2 - Cube Orange External Flight Controller Integration
voxl-2
14 Posts 3 Posters 4.3k Views 2 Watching
    @Jetson-Nano If you have disabled the internal flight controller and remove the USB connection to the external flight controller and are still seeing the connection to QGC then I think you are setup. Are seeing any issues?
    Jetson NanoJ Offline
    Jetson Nano
    Veteran
    @Eric-Katzfey, I'm having a Starling drone setup on my custom airframe build and having integrated external FC, how do I do vehicle actuator setup in QGC once I'm done setting up external FC?
    • Jetson NanoJ Jetson Nano
      @Jetson-Nano Once you are up and running on your external Orange Cube then VOXL 2 is just a conduit for mavlink packets. You should be able to interact with your Orange Cube normally. I do not know anything about Orange Cubes so can't answer how to do vehicle actuator setup in QGC with it.
        Jetson Nano
        Veteran
        Hey @Eric-Katzfey , I saw this post and in this you have asked to add the driver to the build configuration, but how do I include the voxl_esc driver to a build of different board configuration?
        One more question, can I use the J5 connector of this to connect to the telemetry port of the FC?
          @Jetson-Nano To add the driver you need to modify the build configuration file (https://github.com/PX4/PX4-Autopilot/blob/main/boards/cubepilot/cubeorange/default.px4board). You can add the voxl-esc driver to that with CONFIG_DRIVERS_ACTUATORS_VOXL_ESC=y
            @Jetson-Nano Yes, you should be able to use the UART pins on that J5 connector.
              Jetson Nano
              Veteran
              Thank you @Eric-Katzfey , I'll test this out and get back to you on the result
                Jetson Nano
                Veteran
                Hey @Eric-Katzfey , I tested whatever you told,
                1. I connected to the UART port on the J5 of M0141, and I tested, it is not working. When using a companion computer you can run
                cat /dev/ttyHSx
                to get data from the FC, you'll get random symbols. I tried it and it is not working, when I tested yesterday with this I got the output as said previously, but still with J5 I tried the pymavlink part by changing the baud rate, but I am getting this output
                voxl2:/home$ python3 mavlink_shell.py /dev/ttyTHS1
                Connecting to MAVLINK...
                And what will be the port for the J5 connector of M0141, it is not listed in the below table.
                1. The VOXL ESC Driver part, I added that to the board config and built, after that I am not able to see any VOXL_ESC parameters.
                  cat /dev/ttyHSx
                  @Jetson-Nano For the UART issue it's best to take things step by step. I would first verify the Orange Cube telemetry port by attaching it to a laptop or desktop computer. Make sure you can attach to QGC that way. And note the baudrate being used when it is working. That will validate the Orange Cube. Then validate the port of the add on card that you want to use with VOXL 2. For example, with M0141, validate /dev/ttyHS1 by attaching to a computer with a serial to UART cable and sending / receiving test data with a simple Python script. Once you are sure that the parts are working individually then you can hook them together and start debugging higher level things like voxl-mavlink-server.
                    cat /dev/ttyHSx
                    @Jetson-Nano For the VOXL ESC part, now that you have the driver in your build you need to start the driver. For testing you can just go to the Nuttx shell and run voxl_esc start -d <uart-port>. This will show you if it is starting correctly. Once it is working correctly you should see the VOXL_ESC_XXX parameters and then you need to add the device start into your Orange Cube start scripts.
                      Jetson Nano
                      Veteran
                      #14
                      Thank you @Eric-Katzfey , it worked, I tested each port individually and made sure the individual ports are working, and then integrated the two and is working fine.
                      Here is my solution if anyone needs.
                      I used Telem 1 port of the cube and the UART pins on the J5 connector of USB2 Type A Breakout (M0141) . The parameters I set for MAV 1 is here
                      After disabling the voxl-px4 services, Connect to VOXL wifi and check QGC, you'll get the FC data in which the cube is used as the flight controller.
                      The VOXL ESC, I haven't tested it yet, I'll test and get back if any problems.
