  3. VOXL2 - Cube Orange External Flight Controller Integration
voxl-2
14 Posts 3 Posters 4.0k Views 2 Watching
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Hello @Chad-Sweet @Eric-Katzfey @tom @Alex-Kushleyev ,
    I'm using VOXL2 as a compute unit and need to connect a external flight controller for port availability and other feasibility needs. In my application, I'm using Pixhawk standard Cube Orange as external FC.
    For hardware integration, I'm referring to the documentation as listed here as a model reference.
    1. I'm integrating the the USB3/UART Add-On Board (M0125) to VOXL 2 (M0054) which giving a 4 pin JST GH connector with a UART available at /dev/ttyHS1 from the applications processor.
    2. I'm connecting the 4 pin JST type Output to the Cube Orange's Telemetry (TELEM1) port using 4 Ping JST GH connector to 6 pin GH Connector.
    3. In VOXL2, under /etc/modalai/voxl-mavlink-server.conf , I set external_ap_flight_controller paramater to true instead of default.
    4. In QGC, once I check by connecting the debug port of Cube to host PC through a USB data cable, under mavlink console upon checking using mavlink status, I receive the following outputs,
    mavlink status
    instance #0:
        mavlink chan: #0
        type:        GENERIC LINK OR RADIO
        flow control: OFF
        rates:
          tx: 487.3 B/s
          txerr: 0.0 B/s
          tx rate mult: 1.000
          tx rate max: 2880 B/s
          rx: 0.0 B/s
          rx loss: 0.0%
        FTP enabled: NO, TX enabled: YES
        mode: Minimal
        Forwarding: Off
        MAVLink version: 1
        transport protocol: serial (/dev/ttyS4 @57600)
    instance #1:
        mavlink chan: #1
        flow control: OFF
        rates:
          tx: 601.9 B/s
          txerr: 0.0 B/s
          tx rate mult: 0.306
          tx rate max: 1200 B/s
          rx: 0.0 B/s
          rx loss: 0.0%
        FTP enabled: YES, TX enabled: YES
        mode: Normal
        Forwarding: On
        MAVLink version: 1
        transport protocol: serial (/dev/ttyS0 @921600)
    instance #2:
        mavlink chan: #2
        flow control: OFF
        rates:
          tx: 817.9 B/s
          txerr: 0.0 B/s
          tx rate mult: 0.306
          rx: 12875.7 B/s
          rx loss: 125.2%
        Received Messages:
          sysid:  1, compid:197, Total: 47361 (lost: 5999736)
          sysid:  1, compid:196, Total: 568 (lost: 24)
        mode: Normal
        Forwarding: On
        MAVLink version: 2
        transport protocol: serial (/dev/ttyS1 @921600)
    instance #3:
        GCS heartbeat valid
        mavlink chan: #3
        type:        USB CDC
        flow control: ON
        rates:
          tx: 32408.2 B/s
          txerr: 0.0 B/s
          tx rate mult: 1.000
          tx rate max: 100000 B/s
          rx: 20.9 B/s
          rx loss: 0.0%
        Received Messages:
          sysid:255, compid:190, Total: 1196 (lost: 0)
        mode: Config
        Forwarding: On
        MAVLink version: 2
        transport protocol: serial (/dev/ttyACM0 @2000000)
        ping statistics:
          last: 34.42 ms
          mean: 17.87 ms
          max: 426.75 ms
          min: 0.28 ms
          dropped packets: 0
    nsh>
    Is this the recommended method of integrating an external FC with VOXL2? How do I verify further to know that my external FC is being used instead of VOXL's internal FC?
    Assuming, I'm having a custom Starling drone setup on my hardware build and integrating external FC, how do I do vehicle actuator setup in QGC once I'm done setting up external FC?
    • Jetson NanoJ Jetson Nano
      mavlink status
      instance #0:
          mavlink chan: #0
          flow control: OFF
          rates:
            tx: 487.3 B/s
            txerr: 0.0 B/s
            tx rate mult: 1.000
            rx: 0.0 B/s
            rx loss: 0.0%
          mode: Minimal
          Forwarding: Off
          MAVLink version: 1
      instance #1:
          mavlink chan: #1
          flow control: OFF
          rates:
            tx: 601.9 B/s
            txerr: 0.0 B/s
            tx rate mult: 0.306
            rx: 0.0 B/s
            rx loss: 0.0%
          mode: Normal
          Forwarding: On
          MAVLink version: 1
      instance #2:
          mavlink chan: #2
          flow control: OFF
          rates:
            tx: 817.9 B/s
            txerr: 0.0 B/s
            tx rate mult: 0.306
            rx: 12875.7 B/s
            rx loss: 125.2%
          Received Messages:
          mode: Normal
          Forwarding: On
          MAVLink version: 2
      instance #3:
          GCS heartbeat valid
          mavlink chan: #3
          type:        USB CDC
          flow control: ON
          rates:
            tx: 32408.2 B/s
            txerr: 0.0 B/s
            tx rate mult: 1.000
            rx: 20.9 B/s
            rx loss: 0.0%
          Received Messages:
          mode: Config
          Forwarding: On
          MAVLink version: 2
          ping statistics:
            last: 34.42 ms
            mean: 17.87 ms
            max: 426.75 ms
            min: 0.28 ms
            dropped packets: 0
      nsh>
      @Jetson-Nano You can disable px4 on voxl with systemctl disable voxl-px4 to ensure its not running
        Jetson Nano
        Veteran
        @tom yes, I have done that.
          @Jetson-Nano If you have disabled the internal flight controller and remove the USB connection to the external flight controller and are still seeing the connection to QGC then I think you are setup. Are seeing any issues?
            Jetson Nano
            Veteran
            @Eric-Katzfey, I'm having a Starling drone setup on my custom airframe build and having integrated external FC, how do I do vehicle actuator setup in QGC once I'm done setting up external FC?
              @Jetson-Nano Once you are up and running on your external Orange Cube then VOXL 2 is just a conduit for mavlink packets. You should be able to interact with your Orange Cube normally. I do not know anything about Orange Cubes so can't answer how to do vehicle actuator setup in QGC with it.
                Jetson Nano
                Veteran
                Hey @Eric-Katzfey , I saw this post and in this you have asked to add the driver to the build configuration, but how do I include the voxl_esc driver to a build of different board configuration?
                One more question, can I use the J5 connector of this to connect to the telemetry port of the FC?
                  @Jetson-Nano To add the driver you need to modify the build configuration file (https://github.com/PX4/PX4-Autopilot/blob/main/boards/cubepilot/cubeorange/default.px4board). You can add the voxl-esc driver to that with CONFIG_DRIVERS_ACTUATORS_VOXL_ESC=y
                    @Jetson-Nano Yes, you should be able to use the UART pins on that J5 connector.
                      Jetson Nano
                      Veteran
                      Thank you @Eric-Katzfey , I'll test this out and get back to you on the result
                        Jetson Nano
                        Veteran
                        Hey @Eric-Katzfey , I tested whatever you told,
                        1. I connected to the UART port on the J5 of M0141, and I tested, it is not working. When using a companion computer you can run
                        cat /dev/ttyHSx
                        to get data from the FC, you'll get random symbols. I tried it and it is not working, when I tested yesterday with this I got the output as said previously, but still with J5 I tried the pymavlink part by changing the baud rate, but I am getting this output
                        voxl2:/home$ python3 mavlink_shell.py /dev/ttyTHS1
                        Connecting to MAVLINK...
                        And what will be the port for the J5 connector of M0141, it is not listed in the below table.
                        1. The VOXL ESC Driver part, I added that to the board config and built, after that I am not able to see any VOXL_ESC parameters.
                          cat /dev/ttyHSx
                          @Jetson-Nano For the UART issue it's best to take things step by step. I would first verify the Orange Cube telemetry port by attaching it to a laptop or desktop computer. Make sure you can attach to QGC that way. And note the baudrate being used when it is working. That will validate the Orange Cube. Then validate the port of the add on card that you want to use with VOXL 2. For example, with M0141, validate /dev/ttyHS1 by attaching to a computer with a serial to UART cable and sending / receiving test data with a simple Python script. Once you are sure that the parts are working individually then you can hook them together and start debugging higher level things like voxl-mavlink-server.
                            cat /dev/ttyHSx
                            @Jetson-Nano For the VOXL ESC part, now that you have the driver in your build you need to start the driver. For testing you can just go to the Nuttx shell and run voxl_esc start -d <uart-port>. This will show you if it is starting correctly. Once it is working correctly you should see the VOXL_ESC_XXX parameters and then you need to add the device start into your Orange Cube start scripts.
                              Jetson Nano
                              Veteran
                              #14
                              Thank you @Eric-Katzfey , it worked, I tested each port individually and made sure the individual ports are working, and then integrated the two and is working fine.
                              Here is my solution if anyone needs.
                              I used Telem 1 port of the cube and the UART pins on the J5 connector of USB2 Type A Breakout (M0141) . The parameters I set for MAV 1 is here
                              After disabling the voxl-px4 services, Connect to VOXL wifi and check QGC, you'll get the FC data in which the cube is used as the flight controller.
                              The VOXL ESC, I haven't tested it yet, I'll test and get back if any problems.
