  3. reporting a bug for cameras configuration
17 Posts 3 Posters 4.2k Views 1 Watching
  • Abdullah01A Offline
    Abdullah01A Offline
    Abdullah01
    wrote on last edited by Abdullah01
    I am using Voxl2 with the following image sensors:
    1- Tof
    2- RGB Camera (imx214)
    3- Fish Eye Camera (ov7251)
    and I am using VOXL2 SDK 1.1.2
    For the connection, I followed this documentation, and to be more specific I connected the cameras as it shown in this PIC
    Then, I select the camera configuration, I selected number (14) which is for this configuration, before that I changed the SKU configuration to be Voxl2 board only.
    But, when I run the cameras, it detected only (tof) and (rgb), and the (Fiah Eye Camera) is not detected.
    So, can you support me with this issue?
    thank you.
    ModeratorM 1 Reply Last reply
    • Abdullah01A Abdullah01
      1- Tof
      thank you.
      @Abdullah01 Can you try from a command line to run voxl-camera-server -d0 to view the output of the camera-server initialization process and please share that log?
      Abdullah01A 1 Reply Last reply
      • ModeratorM Moderator
        Abdullah01A Offline
        Abdullah01A Offline
        Abdullah01
        @Moderator
        Here is the log
        VERBOSE: Dumping GBM flags
        DEBUG:   	Found flag GBM_BO_USAGE_CPU_READ_QTI
        DEBUG:   	Found flag GBM_BO_USAGE_CPU_WRITE_QTI
        DEBUG:   	Found flag GBM_BO_USAGE_VIDEO_ENCODER_QTI
        DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888
        DEBUG:   Found video encoder usage, removing camera read/write usage
        DEBUG:   Converted gralloc flags 0x30022 to GBM flags 0x860000
        DEBUG:   Available color formats for OMX:
        DEBUG:   	Unknown (0x7fa30c06)
        DEBUG:   	OMX_QCOM_COLOR_FormatYUV420PackedSemiPlanar32m (0x7fa30c04)
        DEBUG:   	OMX_QCOM_COLOR_FormatYVU420SemiPlanar (0x7fa30c00)
        DEBUG:   	Unknown (0x7fa30c09)
        DEBUG:   	Unknown (0x7fa30c0a)
        DEBUG:   	Unknown (0x7fa30c08)
        DEBUG:   	Unknown (0x7fa30c07)
        DEBUG:   	OMX_COLOR_FormatAndroidOpaque (0x7f000789)
        DEBUG:   	OMX_COLOR_FormatYUV420SemiPlanar (0x15)
        DEBUG:   Buffer Count Expected: 16
        DEBUG:   Buffer Count Actual: 16
        WARNING: Port Def 0:
        	Count Min: 8
        	Count Actual: 16
        	Buffers Contiguous: Yes
        	Buffer Alignment: 0
        WARNING: Port Def 1:
        	Count Min: 4
        	Count Actual: 16
        	Buffers Contiguous: No
        	Buffer Alignment: 0
        DEBUG:   OMX_EventCmdComplete
        DEBUG:   Successfully set up pipeline for stream: STREAM_SMALL_VID
        DEBUG:   Allocated BO with width=4208 height=3120 stride=4608 aligned_w=4608 aligned_h=3584 size=24772608 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888
        	Count Min: 8
        	Count Actual: 16
        	Buffer Alignment: 0
        	Count Min: 4
        	Count Actual: 16
        	Buffer Alignment: 0
        DEBUG:   Successfully set up pipeline for stream: STREAM_LARGE_VID
        DEBUG:   Converted gralloc flags 0x20003 to GBM flags 0x420000
        DEBUG:   	Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI
        DEBUG:   Allocated BO with width=39386888 height=1 stride=39386888 aligned_w=39386888 aligned_h=1 size=39386888 flags=0x20003 format=GBM_FORMAT_BLOB
        DEBUG:   Successfully set up pipeline for stream: SNAPSHOT
        DEBUG:   Started Camera: hires
        Starting Camera: tracking (id #2)
        VERBOSE: Entered thread: cam1-result(tid: 2902)
        VERBOSE: Entered thread: cam1-request(tid: 2901)
        ERBOSE: sid: 0x007A, addr: 0xB316, data: 0x902D
        VERBOSE: sid: 0x007A, addr: 0xB317, data: 0x0000
        VERBOSE: sid: 0x007A, addr: 0xB318, data: 0x048A
        VERBOSE: sid: 0x007A, addr: 0xB319, data: 0x902D
        VERBOSE: sid: 0x007A, addr: 0xB31A, data: 0x0000
        VERBOSE: sid: 0x007A, addr: 0xB31B, data: 0x04CE
        VERBOSE: sid: 0x007A, addr: 0xB334, data: 0x6A39
        VERBOSE: sid: 0x007A, addr: 0xB335, data: 0x1B4F
        VERBOSE: sid: 0x007A, addr: 0xB336, data: 0x03E8
        VERBOSE: sid: 0x007A, addr: 0xB337, data: 0x6261
        VERBOSE: sid: 0x007A, addr: 0xB338, data: 0xFC96
        VERBOSE: sid: 0x007A, addr: 0xB339, data: 0x0EE2
        VERBOSE: sid: 0x007A, addr: 0xB33A, data: 0x8245
        VERBOSE: sid: 0x007A, addr: 0xB33B, data: 0x3D71
        VERBOSE: sid: 0x007A, addr: 0xB33C, data: 0x060A
        VERBOSE: sid: 0x007A, addr: 0xB341, data: 0x0000
        VERBOSE: sid: 0x007A, addr: 0xB39D, data: 0x5529
        VERBOSE: sid: 0x007A, addr: 0xB39E, data: 0x9168
        VERBOSE: sid: 0x007A, addr: 0xB39F, data: 0x47CD
        VERBOSE: sid: 0x007A, addr: 0xB3A0, data: 0x5712
        VERBOSE: sid: 0x007A, addr: 0xB3A1, data: 0x0002
        VERBOSE: sid: 0x007A, addr: 0xB3A2, data: 0x5529
        VERBOSE: sid: 0x007A, addr: 0xB3A3, data: 0xE832
        VERBOSE: sid: 0x007A, addr: 0xB3A4, data: 0x34F4
        VERBOSE: sid: 0x007A, addr: 0xB3A5, data: 0x5712
        VERBOSE: sid: 0x007A, addr: 0xB3A6, data: 0x0002
        DEBUG:   setup accessLevel 3, ret 0
        DEBUG:   Changed to usecase MODE_9_5FPS exposure time limits [ 8 - 2200 ], cur exposure_time 2200, exposure mode 1
        VERBOSE:
        Setting use case: mode=9, fps = 5
        VERBOSE: startCapture E
        VERBOSE: sid: 0x007A, addr: 0x9005, data: 0x0002
        VERBOSE: sid: 0x007A, addr: 0xB420, data: 0x10C0
        VERBOSE: sid: 0x007A, addr: 0xB400, data: 0x0001
        VERBOSE: sid: 0x007A, addr: 0x9000, data: 0x0005
        VERBOSE: sid: 0x007A, addr: 0x9005, data: 0x0000
        VERBOSE: sid: 0x007A, addr: 0x982F, data: 0x0000
        VERBOSE: sid: 0x007A, addr: 0x9830, data: 0x0000
        VERBOSE: sid: 0x007A, addr: 0x982F, data: 0x0001
        VERBOSE: startCapture X
        VERBOSE: TOF interface created!
        VERBOSE: setting hal3 exposure for tof     2259763   200
        VERBOSE: added request for preview stream
        VERBOSE: Sending request for frame 0 for camera tof for 1 streams
        VERBOSE: Received result from HAl3 for frame number 0
        VERBOSE: Received 0 buffers from camera tof, partial result:1
        VERBOSE: finished sending request for frame 0 for camera tof
        VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera tof
        VERBOSE: Sending request for frame 1 for camera tof for 1 streams
        VERBOSE: finished sending request for frame 1 for camera tof
        VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera tof
        VERBOSE: Sending request for frame 2 for camera tof for 1 streams
        VERBOSE: finished sending request for frame 2 for camera tof
        VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera tof
        VERBOSE: Sending request for frame 3 for camera tof for 1 streams
        VERBOSE: Received result from HAl3 for frame number 1
        VERBOSE: finished sending request for frame 3 for camera tof
        VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera tof
        VERBOSE: Sending request for frame 4 for camera tof for 1 streams
        ------ voxl-camera-server: Camera server exited gracefully
          @Moderator
          Here is the log
          	Count Min: 8
          	Count Actual: 16
          	Buffer Alignment: 0
          	Count Min: 4
          	Count Actual: 16
          	Buffer Alignment: 0
          	Count Min: 8
          	Count Actual: 16
          	Buffer Alignment: 0
          	Count Min: 4
          	Count Actual: 16
          	Buffer Alignment: 0
          VERBOSE:
          Abdullah01A Offline
          Abdullah01A Offline
          Abdullah01
          @Abdullah01
          Is there any feed back?
            @Abdullah01
            @Abdullah01 ,
            Is the above output of the voxl-camera-server -d0 complete or was some of it cut off? it should show which cameras were detected at the very beginning. Maybe the there were too many lines printed and your terminal discarded them. You should have an option to increase the history length in your terminal window, if needed.
            Also, can you please run voxl-camera-server -l to just list the detected cameras and resolutions.
            Finally, when you run voxl-configure-cameras and select the camera configuration number, this script copies appropriate camera drivers to /usr/lib/camera - do you mind sending the output of ls -la /usr/lib/camera ? This way we can check if all appropriate camera drivers have indeed been copied to this location by the configuration script.
            Thank you
              @Abdullah01 ,
              Thank you
              Abdullah01A Offline
              Abdullah01A Offline
              Abdullah01
              @Alex-Kushleyev
              sorry for the late reply.
              For the voxl-camera-server -d0 command line, the beginning output lines is shown below:
              configuration for 3 cameras:
              cam #0
                  sensor type:         pmd-tof
                  isEnabled:           1
                  camId:               0
                  camId2:              -1
                  fps:                 5
                  en_rotate:           0
                  en_rotate2:          0
                  en_preview:          1
                  pre_width:           224
                  pre_height:          1557
                  en_raw_preview:      1
                  en_small_video:      0
                  small_video_width:   -1
                  small_video_height:  -1
                  en_large_video:      0
                  large_video_width:   -1
                  large_video_height:  -1
                  en_snapshot:         0
                  snap_width:          -1
                  snap_height:         -1
                  ae_mode:             off
                  standby_enabled:     0
                  decimator:           5
                  independent_exposure:0
              cam #1
                  sensor type:         imx214
                  isEnabled:           1
                  camId:               1
                  camId2:              -1
                  fps:                 30
                  en_rotate:           0
                  en_rotate2:          0
                  en_preview:          0
                  pre_width:           640
                  pre_height:          480
                  en_raw_preview:      0
                  en_small_video:      1
                  small_video_width:   1024
              --More--gbm_create_device(156): Info: backend name is: msm_drm
                  small_video_height:  768
                  en_large_video:      1
                  large_video_width:   4208
                  large_video_height:  3120
                  en_snapshot:         1
                  snap_width:          4208
                  snap_height:         3120
                  ae_mode:             isp
                  standby_enabled:     0
                  decimator:           1
              cam #2
                  sensor type:         ov7251
                  isEnabled:           1
                  camId:               2
                  camId2:              -1
                  fps:                 30
                  en_rotate:           0
                  en_rotate2:          0
                  en_preview:          1
                  pre_width:           640
                  pre_height:          480
                  en_raw_preview:      1
                  en_small_video:      0
                  en_large_video:      0
                  en_snapshot:         0
                  snap_width:          -1
                  snap_height:         -1
                  ae_mode:             lme_msv
                  standby_enabled:     0
                  decimator:           1
              For the voxl-camera-server -l command, the output shows below:
              oxl2:~$ voxl-camera-server -l
              DEBUG:   ----------- Number of cameras: 2
              DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x007A, Sensor Id: 0x003D
              DEBUG:   Cam idx: 1, Cam slot: 2, Slave Address: 0x0020, Sensor Id: 0x0214
              DEBUG:   Note: This list comes from the HAL module and may not be indicative
              DEBUG:   	of configurations that have full pipelines
              DEBUG:   Number of cameras: 2
              Stats for camera: 0
              ANDROID_SCALER_AVAILABLE_RAW_SIZES:
              These are likely supported by the sensor
               224 x 1557
              ANDROID_SCALER_AVAILABLE_STREAM_CONFIGURATIONS:
              These are NOT necessarily supported by the sensor
               176 x  144 HAL_PIXEL_FORMAT_YCbCr_420_888
               176 x  144 HAL_PIXEL_FORMAT_BLOB
               224 x 1557 HAL_PIXEL_FORMAT_RAW10
               224 x 1557 HAL_PIXEL_FORMAT_RAW12
               224 x 1557 HAL_PIXEL_FORMAT_RAW16
               224 x 1557 HAL_PIXEL_FORMAT_RAW_OPAQUE
              ANDROID_SENSOR_INFO_SENSITIVITY_RANGE
              	min = 54
              	max = 0
              ANDROID_SENSOR_MAX_ANALOG_SENSITIVITY
              ANDROID_SENSOR_INFO_EXPOSURE_TIME_RANGE
              	min = 0ns
              	max = 0ns
              Stats for camera: 1
              4208 x 3120
              3840 x 2160
              1920 x 1080
              1920 x 1080
              4208 x 3120 HAL_PIXEL_FORMAT_YCbCr_420_888
              4208 x 3120 HAL_PIXEL_FORMAT_BLOB
              4160 x 3120 HAL_PIXEL_FORMAT_YCbCr_420_888
              4160 x 3120 HAL_PIXEL_FORMAT_BLOB
              4096 x 2304 HAL_PIXEL_FORMAT_YCbCr_420_888
              4096 x 2304 HAL_PIXEL_FORMAT_BLOB
              4096 x 2160 HAL_PIXEL_FORMAT_YCbCr_420_888
              4096 x 2160 HAL_PIXEL_FORMAT_BLOB
              4056 x 3040 HAL_PIXEL_FORMAT_YCbCr_420_888
              4056 x 3040 HAL_PIXEL_FORMAT_BLOB
              4000 x 3000 HAL_PIXEL_FORMAT_YCbCr_420_888
              4000 x 3000 HAL_PIXEL_FORMAT_BLOB
              3840 x 2160 HAL_PIXEL_FORMAT_YCbCr_420_888
              3840 x 2160 HAL_PIXEL_FORMAT_BLOB
              3264 x 2448 HAL_PIXEL_FORMAT_YCbCr_420_888
              3264 x 2448 HAL_PIXEL_FORMAT_BLOB
              3200 x 2400 HAL_PIXEL_FORMAT_YCbCr_420_888
              3200 x 2400 HAL_PIXEL_FORMAT_BLOB
              2976 x 2976 HAL_PIXEL_FORMAT_YCbCr_420_888
              2976 x 2976 HAL_PIXEL_FORMAT_BLOB
              2688 x 1512 HAL_PIXEL_FORMAT_YCbCr_420_888
              2688 x 1512 HAL_PIXEL_FORMAT_BLOB
              2592 x 1944 HAL_PIXEL_FORMAT_YCbCr_420_888
              2592 x 1944 HAL_PIXEL_FORMAT_BLOB
              2048 x 1536 HAL_PIXEL_FORMAT_YCbCr_420_888
              2048 x 1536 HAL_PIXEL_FORMAT_BLOB
              1920 x 1440 HAL_PIXEL_FORMAT_YCbCr_420_888
              1920 x 1440 HAL_PIXEL_FORMAT_BLOB
              1928 x 1208 HAL_PIXEL_FORMAT_YCbCr_420_888
              1928 x 1208 HAL_PIXEL_FORMAT_BLOB
              1920 x 1080 HAL_PIXEL_FORMAT_YCbCr_420_888
              1920 x 1080 HAL_PIXEL_FORMAT_BLOB
              1600 x 1200 HAL_PIXEL_FORMAT_YCbCr_420_888
              1600 x 1200 HAL_PIXEL_FORMAT_BLOB
              1440 x 1080 HAL_PIXEL_FORMAT_YCbCr_420_888
              1440 x 1080 HAL_PIXEL_FORMAT_BLOB
              1280 x  960 HAL_PIXEL_FORMAT_YCbCr_420_888
              1280 x  960 HAL_PIXEL_FORMAT_BLOB
              1280 x  800 HAL_PIXEL_FORMAT_YCbCr_420_888
              1280 x  800 HAL_PIXEL_FORMAT_BLOB
              1280 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
              1280 x  768 HAL_PIXEL_FORMAT_BLOB
              1280 x  720 HAL_PIXEL_FORMAT_YCbCr_420_888
              1280 x  720 HAL_PIXEL_FORMAT_BLOB
              1080 x 1080 HAL_PIXEL_FORMAT_YCbCr_420_888
              1080 x 1080 HAL_PIXEL_FORMAT_BLOB
              1024 x  738 HAL_PIXEL_FORMAT_YCbCr_420_888
              1024 x  738 HAL_PIXEL_FORMAT_BLOB
              1024 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
              1024 x  768 HAL_PIXEL_FORMAT_BLOB
               864 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
               864 x  480 HAL_PIXEL_FORMAT_BLOB
               800 x  600 HAL_PIXEL_FORMAT_YCbCr_420_888
               800 x  600 HAL_PIXEL_FORMAT_BLOB
               800 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
               800 x  480 HAL_PIXEL_FORMAT_BLOB
               720 x 1280 HAL_PIXEL_FORMAT_YCbCr_420_888
               720 x 1280 HAL_PIXEL_FORMAT_BLOB
               720 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
               720 x  480 HAL_PIXEL_FORMAT_BLOB
               640 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
               640 x  480 HAL_PIXEL_FORMAT_BLOB
               640 x  400 HAL_PIXEL_FORMAT_YCbCr_420_888
               640 x  400 HAL_PIXEL_FORMAT_BLOB
               640 x  360 HAL_PIXEL_FORMAT_YCbCr_420_888
               640 x  360 HAL_PIXEL_FORMAT_BLOB
               352 x  288 HAL_PIXEL_FORMAT_YCbCr_420_888
               352 x  288 HAL_PIXEL_FORMAT_BLOB
               320 x  240 HAL_PIXEL_FORMAT_YCbCr_420_888
               320 x  240 HAL_PIXEL_FORMAT_BLOB
               240 x  320 HAL_PIXEL_FORMAT_YCbCr_420_888
               240 x  320 HAL_PIXEL_FORMAT_BLOB
              4208 x 3120 HAL_PIXEL_FORMAT_RAW10
              4208 x 3120 HAL_PIXEL_FORMAT_RAW12
              4208 x 3120 HAL_PIXEL_FORMAT_RAW16
              4208 x 3120 HAL_PIXEL_FORMAT_RAW_OPAQUE
              	min = 54
              	max = 431
              	431
              	min = 10449ns
              	max = 683714540ns
              Number of cameras detected: 2
              For the camera configuration, as I mentioned above, I selected configuration #14, which is for Tof, Fish eye, and RGB
              The output for ls -la /usr/lib/camera is shown below:
              voxl2:~$ ls -la /usr/lib/camera
              total 4876
              drwxr-xr-x  3 root root   4096 Jan 14 08:38 .
              drwxr-xr-x 72 root root  24576 Dec 27 06:49 ..
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.eeprom.cmk_imx577.so
              -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.ar0144.so
              -rwxr-xr-x  1 root root   5816 Oct 26 03:51 com.qti.sensor.cmk_imx577.so
              -rwxr-xr-x  1 root root   5816 Oct 26 03:51 com.qti.sensor.cmk_imx577_flip.so
              -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.imx214.so
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.imx214_flip.so
              -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.imx335.so
              -rwxr-xr-x  1 root root   5808 Oct 26 03:51 com.qti.sensor.imx377.so
              -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.imx678.so
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.imx678_flip.so
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.imx678_mod.so
              -rwxr-xr-x  1 root root   5808 Oct 26 03:51 com.qti.sensor.irs1645.so
              -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.ov7251.so
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_front_left.so
              -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_front_left_flip.so
              -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_front_right.so
              -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_front_right_flip.so
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_fsin.so
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_fsout.so
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_rear_left.so
              -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_rear_left_flip.so
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_rear_right.so
              -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_rear_right_flip.so
              -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.ov9782.so
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov9782_front_left.so
              -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_front_left_flip.so
              -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_front_right.so
              -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_front_right_flip.so
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov9782_rear_left.so
              -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_rear_left_flip.so
              -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov9782_rear_right.so
              -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_rear_right_flip.so
              -rw-r--r--  1 root root 149272 Jan 14 08:38 com.qti.sensormodule.imx214_2.bin
              -rw-r--r--  1 root root 674736 Jan 14 08:38 com.qti.sensormodule.irs1645_0.bin
              -rw-r--r--  1 root root 142472 Jan 14 08:38 com.qti.sensormodule.ov7251_3.bin
              -rw-r--r--  1 root root 957344 Oct 26 03:51 com.qti.tuned.cmk_imx577.bin
              -rw-r--r--  1 root root 835464 Oct 26 03:51 com.qti.tuned.cmk_ov9282.bin
              -rw-r--r--  1 root root 931864 Oct 26 03:51 com.qti.tuned.default.bin
              -rw-r--r--  1 root root 882376 Oct 26 03:51 com.qti.tuned.sony_imx335.bin
              drwxr-xr-x  2 root root   4096 Oct 26 04:00 components
              Thank you
                @Alex-Kushleyev
                cam #0
                    isEnabled:           1
                    camId:               0
                    camId2:              -1
                    fps:                 5
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           224
                    pre_height:          1557
                    en_raw_preview:      1
                    en_small_video:      0
                    en_large_video:      0
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             off
                    standby_enabled:     0
                    decimator:           5
                cam #1
                    sensor type:         imx214
                    isEnabled:           1
                    camId:               1
                    camId2:              -1
                    fps:                 30
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          0
                    pre_width:           640
                    pre_height:          480
                    en_raw_preview:      0
                    en_small_video:      1
                    en_large_video:      1
                    en_snapshot:         1
                    snap_width:          4208
                    snap_height:         3120
                    ae_mode:             isp
                    standby_enabled:     0
                    decimator:           1
                cam #2
                    sensor type:         ov7251
                    isEnabled:           1
                    camId:               2
                    camId2:              -1
                    fps:                 30
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           640
                    pre_height:          480
                    en_raw_preview:      1
                    en_small_video:      0
                    en_large_video:      0
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             lme_msv
                    standby_enabled:     0
                    decimator:           1
                Stats for camera: 0
                 224 x 1557
                	min = 54
                	max = 0
                	min = 0ns
                	max = 0ns
                Stats for camera: 1
                4208 x 3120
                3840 x 2160
                1920 x 1080
                1920 x 1080
                	min = 54
                	max = 431
                	431
                	min = 10449ns
                	max = 683714540ns
                total 4876
                Thank you
                Abdullah01A Offline
                Abdullah01A Offline
                Abdullah01
                @Abdullah01 said in reporting a bug for cameras configuration:
                So, what should I do now?
                is everything looks good?
                  Abdullah01A Offline
                  Abdullah01A Offline
                  Abdullah01
                  @Abdullah01
                  BTW,
                  Once I select the camera configuration, it's saved in these directories
                  camera_server_config_helper is done copying required camera drivers in place /usr/share/modalai/chi-cdk/irs1645/com.qti.sensormodule.irs1645_0.bin /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_2.bin /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_3.bin enabling voxl-camera-server
                    @Abdullah01
                    BTW,
                    @Abdullah01 , I believe you have the correct sensormodules in place. I am looking at the photo in our documentation : https://docs.modalai.com/voxl2-camera-configs/#c-14-tof-hires-and-tracking and i can see that it is not shown how the tracking camera is plugged in (connector mating orientation).
                    If you take a look at this configuration, https://docs.modalai.com/voxl2-camera-configs/#c-11-front-stereo-rear-stereo-hires-and-tracking-d0006-sentinel , the tracking camera, when plugged in correctly, has the flex going back towards the VOXL2 board, while the hires camera (imx214) is going away from VOXL2. Even though for C11, the hires and tracking are swapped places, but the connector orientation is the same for C11 and C14.
                    Specifically, the tracking camera flex, once plugged in, goes on top of the CAMERA label on the flex, but IMX214 camera flex does not cross over the CAMERA label.
                    Please double check and perhaps you need to rotate your tracking camera connection 180 degrees.
                      Abdullah01A Offline
                      Abdullah01A Offline
                      Abdullah01
                      #10
                      @Alex-Kushleyev
                      I tried to rotate the tracking camera connection 180 degree, but some how if I did so, the wifi that is connected to the VOXL2 does not work.
                      So, I assumed that the connection is not correct,
                      In this configuration
                      alt text
                      We can see the Tracking camera is connected backward to the voxl direction
                      and this is what I did
                      Thank you
                        @Alex-Kushleyev
                        alt text
                        Thank you
                        @Abdullah01 , ok that seems like it is correct.
                        Let's try the following:
                        • power off voxl2 and remove TOF and hires camera (gently unplug), just leave tracking camera as is, connected via the dual camera flex
                        • power on voxl2 and check using voxl-camera-server -l to see if any cameras are detected
                        If above still does not detect the tracking camera,
                        • lets try connecting tracking camera where hires camera was previously connected
                        • power off voxl2, gently disconnect tracking camera from the dual flex and plug it into the slot where hires camera used to be (in the same orientation, with tracking camera flex pointing towards voxl2 board)
                        • power on voxl2 and copy the ov7251 sensormodule for port 2 (instead of port 3 that you were using before):
                        cp /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_2.bin /usr/lib/camera/
                        • you can leave the other sensormodule files in /usr/lib/camera for now (no need to remove any)
                        • then try voxl-camera-server -l again to see if tracking camera is detected.
                          Abdullah01A Offline
                          Abdullah01A Offline
                          Abdullah01
                          @Alex-Kushleyev
                          If I connect in this configuration with camera configuration (14)
                          it will show me no camera is attached
                          For connecting the tracking where the Hris is connected with camera configuration 14 as shown below:
                          is not detected as well.
                          But once I changed the camera configuration to 4 which is for tracking and Hris
                          the tracking is detected as shown below:
                          voxl2:~$ voxl-camera-server -l
                          DEBUG:   ----------- Number of cameras: 1
                          DEBUG:   Cam idx: 0, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750
                          DEBUG:   Number of cameras: 1
                          Stats for camera: 0
                           640 x  480
                           640 x  480
                           640 x  480
                           640 x  480 HAL_PIXEL_FORMAT_RAW10
                           640 x  480 HAL_PIXEL_FORMAT_RAW12
                           640 x  480 HAL_PIXEL_FORMAT_RAW16
                           640 x  480 HAL_PIXEL_FORMAT_RAW_OPAQUE
                          	min = 54
                          	max = 3451
                          	3451
                          	min = 0ns
                          	max = 1266732525ns
                          Number of cameras detected: 1
                          Also, I tried to attach the Hris as shown below with camera configuration 4
                          Both of them are detected
                          existing instance of voxl-camera-server found, attempting to stop it
                          DEBUG:   Cam idx: 1, Cam slot: 3, Slave Address: 0x0020, Sensor Id: 0x0214
                          Stats for camera: 0
                           640 x  480
                           640 x  480
                           640 x  480
                          	min = 54
                          	max = 3451
                          	3451
                          	min = 0ns
                          	max = 1266732525ns
                          Stats for camera: 1
                          4208 x 3120
                          3840 x 2160
                          1920 x 1080
                          1920 x 1080
                          	min = 54
                          	max = 431
                          	431
                          	min = 10449ns
                          	max = 683714540ns
                          The second part of copying the sensor module is not clear. What configuration should I use?
                          If you noticed I have two issues:
                          1- the camera configuration (this post)
                          2- the ESC issue (Other post
                          is there another direct way to communicate with you directly?
                          Thank you for the support and fast response
                            @Alex-Kushleyev
                            Stats for camera: 0
                             640 x  480
                             640 x  480
                             640 x  480
                            	min = 54
                            	max = 3451
                            	3451
                            	min = 0ns
                            	max = 1266732525ns
                            Stats for camera: 0
                             640 x  480
                             640 x  480
                             640 x  480
                            	min = 54
                            	max = 3451
                            	3451
                            	min = 0ns
                            	max = 1266732525ns
                            Stats for camera: 1
                            4208 x 3120
                            3840 x 2160
                            1920 x 1080
                            1920 x 1080
                            	min = 54
                            	max = 431
                            	431
                            	min = 10449ns
                            	max = 683714540ns
                            Abdullah01A Offline
                            Abdullah01A Offline
                            Abdullah01
                            @Abdullah01
                            My issue now is how to connect the tof with the above configuration.
                            I chose the camera configuration 4 and this is why they work, but if I chose configuration 14 which is with ToF it wouldn't work
                              Abdullah01A Offline
                              Abdullah01
                              Is there any update?
                                @Abdullah01 , now that you have both cameras detected (tracking and hires), just plug in the TOF sensor in the original place where it worked before (power off when connecting / disconnecting cameras).
                                Also double check that /usr/lib/camera has the following file com.qti.sensormodule.irs1645_0.bin , if not, you can manually copy it from /usr/share/modalai/chi-cdk/ folder (search for it).
                                Then just try voxl-camera-server -l again
                                  Abdullah01A Offline
                                  Abdullah01A Offline
                                  Abdullah01
                                  @Alex-Kushleyev
                                  the issues is that the configuration in this case is 4 where it detects only Hris and Tracking.
                                  I added the file to the /usr/lib/camera directory.
                                  /usr/lib/camera/com.qti.sensormodule.irs1645_0.bin
                                  and still, the ToF is not detected, and tried the command voxl-camera-server -l
                                  and here is the output, only detected two cameras.
                                  3DEBUG:   Attempting to open the hal module
                                  Stats for camera: 0
                                   640 x  480
                                   640 x  480
                                   640 x  480
                                  	min = 54
                                  	max = 3451
                                  	3451
                                  	min = 0ns
                                  	max = 1266732525ns
                                  Stats for camera: 1
                                  4208 x 3120
                                  3840 x 2160
                                  1920 x 1080
                                  1920 x 1080
                                  	min = 54
                                  	max = 431
                                  	431
                                  	min = 10449ns
                                  	max = 683714540ns
                                    @Alex-Kushleyev
                                    Stats for camera: 0
                                     640 x  480
                                     640 x  480
                                     640 x  480
                                    	min = 54
                                    	max = 3451
                                    	3451
                                    	min = 0ns
                                    	max = 1266732525ns
                                    Stats for camera: 1
                                    4208 x 3120
                                    3840 x 2160
                                    1920 x 1080
                                    1920 x 1080
                                    	min = 54
                                    	max = 431
                                    	431
                                    	min = 10449ns
                                    	max = 683714540ns
                                    @Abdullah01 , OK this is strange.
                                    So it seems like all the cameras are functional, because originally you were able to detect TOF and Hires camera, but not tracking camera. However, now you can detect hires and tracking but not TOF.
                                    I am not sure why this is happening. Are you able to do a clean install of SDK 1.1.2 and follow the same configuration option as you originally tried (TOF + Hires + Tracking). Make sure to plug the cameras as instructed here : https://docs.modalai.com/voxl2-camera-configs/#c-14-tof-hires-and-tracking
