  3. reporting a bug for cameras configuration
17 Posts 3 Posters 4.3k Views 1 Watching
  • ModeratorM Moderator
    @Abdullah01 Can you try from a command line to run voxl-camera-server -d0 to view the output of the camera-server initialization process and please share that log?
    Abdullah01A Offline
    Abdullah01A Offline
    Abdullah01
    @Moderator
    Here is the log
    VERBOSE: Dumping GBM flags
    DEBUG:   	Found flag GBM_BO_USAGE_CPU_READ_QTI
    DEBUG:   	Found flag GBM_BO_USAGE_CPU_WRITE_QTI
    DEBUG:   	Found flag GBM_BO_USAGE_VIDEO_ENCODER_QTI
    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888
    DEBUG:   Found video encoder usage, removing camera read/write usage
    DEBUG:   Converted gralloc flags 0x30022 to GBM flags 0x860000
    DEBUG:   Available color formats for OMX:
    DEBUG:   	Unknown (0x7fa30c06)
    DEBUG:   	OMX_QCOM_COLOR_FormatYUV420PackedSemiPlanar32m (0x7fa30c04)
    DEBUG:   	OMX_QCOM_COLOR_FormatYVU420SemiPlanar (0x7fa30c00)
    DEBUG:   	Unknown (0x7fa30c09)
    DEBUG:   	Unknown (0x7fa30c0a)
    DEBUG:   	Unknown (0x7fa30c08)
    DEBUG:   	Unknown (0x7fa30c07)
    DEBUG:   	OMX_COLOR_FormatAndroidOpaque (0x7f000789)
    DEBUG:   	OMX_COLOR_FormatYUV420SemiPlanar (0x15)
    DEBUG:   Buffer Count Expected: 16
    DEBUG:   Buffer Count Actual: 16
    WARNING: Port Def 0:
    	Count Min: 8
    	Count Actual: 16
    	Buffers Contiguous: Yes
    	Buffer Alignment: 0
    WARNING: Port Def 1:
    	Count Min: 4
    	Count Actual: 16
    	Buffers Contiguous: No
    	Buffer Alignment: 0
    DEBUG:   OMX_EventCmdComplete
    DEBUG:   Successfully set up pipeline for stream: STREAM_SMALL_VID
    DEBUG:   Allocated BO with width=4208 height=3120 stride=4608 aligned_w=4608 aligned_h=3584 size=24772608 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888
    	Count Min: 8
    	Count Actual: 16
    	Buffer Alignment: 0
    	Count Min: 4
    	Count Actual: 16
    	Buffer Alignment: 0
    DEBUG:   Successfully set up pipeline for stream: STREAM_LARGE_VID
    DEBUG:   Converted gralloc flags 0x20003 to GBM flags 0x420000
    DEBUG:   Allocated BO with width=39386888 height=1 stride=39386888 aligned_w=39386888 aligned_h=1 size=39386888 flags=0x20003 format=GBM_FORMAT_BLOB
    DEBUG:   Successfully set up pipeline for stream: SNAPSHOT
    DEBUG:   Started Camera: hires
    Starting Camera: tracking (id #2)
    VERBOSE: Entered thread: cam1-result(tid: 2902)
    VERBOSE: Entered thread: cam1-request(tid: 2901)
    ERBOSE: sid: 0x007A, addr: 0xB316, data: 0x902D
    VERBOSE: sid: 0x007A, addr: 0xB317, data: 0x0000
    VERBOSE: sid: 0x007A, addr: 0xB318, data: 0x048A
    VERBOSE: sid: 0x007A, addr: 0xB319, data: 0x902D
    VERBOSE: sid: 0x007A, addr: 0xB31A, data: 0x0000
    VERBOSE: sid: 0x007A, addr: 0xB31B, data: 0x04CE
    VERBOSE: sid: 0x007A, addr: 0xB334, data: 0x6A39
    VERBOSE: sid: 0x007A, addr: 0xB335, data: 0x1B4F
    VERBOSE: sid: 0x007A, addr: 0xB336, data: 0x03E8
    VERBOSE: sid: 0x007A, addr: 0xB337, data: 0x6261
    VERBOSE: sid: 0x007A, addr: 0xB338, data: 0xFC96
    VERBOSE: sid: 0x007A, addr: 0xB339, data: 0x0EE2
    VERBOSE: sid: 0x007A, addr: 0xB33A, data: 0x8245
    VERBOSE: sid: 0x007A, addr: 0xB33B, data: 0x3D71
    VERBOSE: sid: 0x007A, addr: 0xB33C, data: 0x060A
    VERBOSE: sid: 0x007A, addr: 0xB341, data: 0x0000
    VERBOSE: sid: 0x007A, addr: 0xB39D, data: 0x5529
    VERBOSE: sid: 0x007A, addr: 0xB39E, data: 0x9168
    VERBOSE: sid: 0x007A, addr: 0xB39F, data: 0x47CD
    VERBOSE: sid: 0x007A, addr: 0xB3A0, data: 0x5712
    VERBOSE: sid: 0x007A, addr: 0xB3A1, data: 0x0002
    VERBOSE: sid: 0x007A, addr: 0xB3A2, data: 0x5529
    VERBOSE: sid: 0x007A, addr: 0xB3A3, data: 0xE832
    VERBOSE: sid: 0x007A, addr: 0xB3A4, data: 0x34F4
    VERBOSE: sid: 0x007A, addr: 0xB3A5, data: 0x5712
    VERBOSE: sid: 0x007A, addr: 0xB3A6, data: 0x0002
    DEBUG:   setup accessLevel 3, ret 0
    DEBUG:   Changed to usecase MODE_9_5FPS exposure time limits [ 8 - 2200 ], cur exposure_time 2200, exposure mode 1
    VERBOSE:
    Setting use case: mode=9, fps = 5
    VERBOSE: startCapture E
    VERBOSE: sid: 0x007A, addr: 0x9005, data: 0x0002
    VERBOSE: sid: 0x007A, addr: 0xB420, data: 0x10C0
    VERBOSE: sid: 0x007A, addr: 0xB400, data: 0x0001
    VERBOSE: sid: 0x007A, addr: 0x9000, data: 0x0005
    VERBOSE: sid: 0x007A, addr: 0x9005, data: 0x0000
    VERBOSE: sid: 0x007A, addr: 0x982F, data: 0x0000
    VERBOSE: sid: 0x007A, addr: 0x9830, data: 0x0000
    VERBOSE: sid: 0x007A, addr: 0x982F, data: 0x0001
    VERBOSE: startCapture X
    VERBOSE: TOF interface created!
    VERBOSE: setting hal3 exposure for tof     2259763   200
    VERBOSE: added request for preview stream
    VERBOSE: Sending request for frame 0 for camera tof for 1 streams
    VERBOSE: Received 0 buffers from camera tof, partial result:1
    VERBOSE: finished sending request for frame 0 for camera tof
    VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera tof
    VERBOSE: Sending request for frame 1 for camera tof for 1 streams
    VERBOSE: finished sending request for frame 1 for camera tof
    VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera tof
    VERBOSE: Sending request for frame 2 for camera tof for 1 streams
    VERBOSE: finished sending request for frame 2 for camera tof
    VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera tof
    VERBOSE: Sending request for frame 3 for camera tof for 1 streams
    VERBOSE: finished sending request for frame 3 for camera tof
    VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera tof
    VERBOSE: Sending request for frame 4 for camera tof for 1 streams
    ------ voxl-camera-server: Camera server exited gracefully
    Abdullah01A 1 Reply Last reply
    • Abdullah01A Abdullah01
      @Moderator
      Here is the log
      	Count Min: 8
      	Count Actual: 16
      	Buffer Alignment: 0
      	Count Min: 4
      	Count Actual: 16
      	Buffer Alignment: 0
      	Count Min: 8
      	Count Actual: 16
      	Buffer Alignment: 0
      	Count Min: 4
      	Count Actual: 16
      	Buffer Alignment: 0
      VERBOSE:
      Abdullah01A Offline
      Abdullah01A Offline
      Abdullah01
      @Abdullah01
      Is there any feed back?
        @Abdullah01
        @Abdullah01 ,
        Is the above output of the voxl-camera-server -d0 complete or was some of it cut off? it should show which cameras were detected at the very beginning. Maybe the there were too many lines printed and your terminal discarded them. You should have an option to increase the history length in your terminal window, if needed.
        Also, can you please run voxl-camera-server -l to just list the detected cameras and resolutions.
        Finally, when you run voxl-configure-cameras and select the camera configuration number, this script copies appropriate camera drivers to /usr/lib/camera - do you mind sending the output of ls -la /usr/lib/camera ? This way we can check if all appropriate camera drivers have indeed been copied to this location by the configuration script.
        Thank you
          @Abdullah01 ,
          Thank you
          Abdullah01A Offline
          Abdullah01A Offline
          Abdullah01
          sorry for the late reply.
          For the voxl-camera-server -d0 command line, the beginning output lines is shown below:
          configuration for 3 cameras:
          cam #0
              sensor type:         pmd-tof
              isEnabled:           1
              camId:               0
              camId2:              -1
              fps:                 5
              en_rotate:           0
              en_rotate2:          0
              en_preview:          1
              pre_width:           224
              pre_height:          1557
              en_raw_preview:      1
              en_small_video:      0
              small_video_width:   -1
              small_video_height:  -1
              en_large_video:      0
              large_video_width:   -1
              large_video_height:  -1
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             off
              standby_enabled:     0
              decimator:           5
              independent_exposure:0
          cam #1
              sensor type:         imx214
              isEnabled:           1
              camId:               1
              camId2:              -1
              fps:                 30
              en_rotate:           0
              en_rotate2:          0
              en_preview:          0
              pre_width:           640
              pre_height:          480
              en_raw_preview:      0
              en_small_video:      1
              small_video_width:   1024
          --More--gbm_create_device(156): Info: backend name is: msm_drm
              small_video_height:  768
              en_large_video:      1
              large_video_width:   4208
              large_video_height:  3120
              en_snapshot:         1
              snap_width:          4208
              snap_height:         3120
              ae_mode:             isp
              standby_enabled:     0
              decimator:           1
          cam #2
              sensor type:         ov7251
              isEnabled:           1
              camId:               2
              camId2:              -1
              fps:                 30
              en_rotate:           0
              en_rotate2:          0
              en_preview:          1
              pre_width:           640
              pre_height:          480
              en_raw_preview:      1
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             lme_msv
              standby_enabled:     0
              decimator:           1
          For the voxl-camera-server -l command, the output shows below:
          oxl2:~$ voxl-camera-server -l
          DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x007A, Sensor Id: 0x003D
          DEBUG:   Cam idx: 1, Cam slot: 2, Slave Address: 0x0020, Sensor Id: 0x0214
          DEBUG:   Number of cameras: 2
          Stats for camera: 0
           224 x 1557
           224 x 1557 HAL_PIXEL_FORMAT_RAW10
           224 x 1557 HAL_PIXEL_FORMAT_RAW12
           224 x 1557 HAL_PIXEL_FORMAT_RAW16
           224 x 1557 HAL_PIXEL_FORMAT_RAW_OPAQUE
          	min = 54
          	max = 0
          	min = 0ns
          	max = 0ns
          Stats for camera: 1
          4208 x 3120
          3840 x 2160
          1920 x 1080
          1920 x 1080
          4208 x 3120 HAL_PIXEL_FORMAT_YCbCr_420_888
          4208 x 3120 HAL_PIXEL_FORMAT_BLOB
          4160 x 3120 HAL_PIXEL_FORMAT_YCbCr_420_888
          4160 x 3120 HAL_PIXEL_FORMAT_BLOB
          4096 x 2304 HAL_PIXEL_FORMAT_YCbCr_420_888
          4096 x 2304 HAL_PIXEL_FORMAT_BLOB
          4096 x 2160 HAL_PIXEL_FORMAT_YCbCr_420_888
          4096 x 2160 HAL_PIXEL_FORMAT_BLOB
          1280 x  960 HAL_PIXEL_FORMAT_YCbCr_420_888
          1280 x  960 HAL_PIXEL_FORMAT_BLOB
          1280 x  800 HAL_PIXEL_FORMAT_YCbCr_420_888
          1280 x  800 HAL_PIXEL_FORMAT_BLOB
          1280 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
          1280 x  768 HAL_PIXEL_FORMAT_BLOB
          1280 x  720 HAL_PIXEL_FORMAT_YCbCr_420_888
          1280 x  720 HAL_PIXEL_FORMAT_BLOB
          1024 x  738 HAL_PIXEL_FORMAT_YCbCr_420_888
          1024 x  738 HAL_PIXEL_FORMAT_BLOB
          1024 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
          1024 x  768 HAL_PIXEL_FORMAT_BLOB
           864 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
           864 x  480 HAL_PIXEL_FORMAT_BLOB
           800 x  600 HAL_PIXEL_FORMAT_YCbCr_420_888
           800 x  600 HAL_PIXEL_FORMAT_BLOB
           800 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
           800 x  480 HAL_PIXEL_FORMAT_BLOB
           720 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
           720 x  480 HAL_PIXEL_FORMAT_BLOB
          4208 x 3120 HAL_PIXEL_FORMAT_RAW10
          4208 x 3120 HAL_PIXEL_FORMAT_RAW12
          4208 x 3120 HAL_PIXEL_FORMAT_RAW16
          4208 x 3120 HAL_PIXEL_FORMAT_RAW_OPAQUE
          	min = 54
          	max = 431
          	431
          	min = 10449ns
          	max = 683714540ns
          Number of cameras detected: 2
          For the camera configuration, as I mentioned above, I selected configuration #14, which is for Tof, Fish eye, and RGB
          The output for ls -la /usr/lib/camera is shown below:
          voxl2:~$ ls -la /usr/lib/camera
          total 4876
          drwxr-xr-x  3 root root   4096 Jan 14 08:38 .
          drwxr-xr-x 72 root root  24576 Dec 27 06:49 ..
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.eeprom.cmk_imx577.so
          -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.ar0144.so
          -rwxr-xr-x  1 root root   5816 Oct 26 03:51 com.qti.sensor.cmk_imx577.so
          -rwxr-xr-x  1 root root   5816 Oct 26 03:51 com.qti.sensor.cmk_imx577_flip.so
          -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.imx214.so
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.imx214_flip.so
          -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.imx335.so
          -rwxr-xr-x  1 root root   5808 Oct 26 03:51 com.qti.sensor.imx377.so
          -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.imx678.so
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.imx678_flip.so
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.imx678_mod.so
          -rwxr-xr-x  1 root root   5808 Oct 26 03:51 com.qti.sensor.irs1645.so
          -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.ov7251.so
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_front_left.so
          -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_front_left_flip.so
          -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_front_right.so
          -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_front_right_flip.so
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_fsin.so
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_fsout.so
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_rear_left.so
          -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_rear_left_flip.so
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_rear_right.so
          -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_rear_right_flip.so
          -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.ov9782.so
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov9782_front_left.so
          -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_front_left_flip.so
          -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_front_right.so
          -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_front_right_flip.so
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov9782_rear_left.so
          -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_rear_left_flip.so
          -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov9782_rear_right.so
          -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_rear_right_flip.so
          -rw-r--r--  1 root root 149272 Jan 14 08:38 com.qti.sensormodule.imx214_2.bin
          -rw-r--r--  1 root root 674736 Jan 14 08:38 com.qti.sensormodule.irs1645_0.bin
          -rw-r--r--  1 root root 142472 Jan 14 08:38 com.qti.sensormodule.ov7251_3.bin
          -rw-r--r--  1 root root 957344 Oct 26 03:51 com.qti.tuned.cmk_imx577.bin
          -rw-r--r--  1 root root 835464 Oct 26 03:51 com.qti.tuned.cmk_ov9282.bin
          -rw-r--r--  1 root root 931864 Oct 26 03:51 com.qti.tuned.default.bin
          -rw-r--r--  1 root root 882376 Oct 26 03:51 com.qti.tuned.sony_imx335.bin
          drwxr-xr-x  2 root root   4096 Oct 26 04:00 components
          Thank you
            cam #0
                isEnabled:           1
                camId:               0
                camId2:              -1
                fps:                 5
                en_rotate:           0
                en_rotate2:          0
                en_preview:          1
                pre_width:           224
                pre_height:          1557
                en_raw_preview:      1
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             off
                standby_enabled:     0
                decimator:           5
            cam #1
                sensor type:         imx214
                isEnabled:           1
                camId:               1
                camId2:              -1
                fps:                 30
                en_rotate:           0
                en_rotate2:          0
                en_preview:          0
                pre_width:           640
                pre_height:          480
                en_raw_preview:      0
                en_small_video:      1
                en_large_video:      1
                en_snapshot:         1
                snap_width:          4208
                snap_height:         3120
                ae_mode:             isp
                standby_enabled:     0
                decimator:           1
            cam #2
                sensor type:         ov7251
                isEnabled:           1
                camId:               2
                camId2:              -1
                fps:                 30
                en_rotate:           0
                en_rotate2:          0
                en_preview:          1
                pre_width:           640
                pre_height:          480
                en_raw_preview:      1
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             lme_msv
                standby_enabled:     0
                decimator:           1
            Stats for camera: 0
             224 x 1557
            	min = 54
            	max = 0
            	min = 0ns
            	max = 0ns
            Stats for camera: 1
            4208 x 3120
            3840 x 2160
            1920 x 1080
            1920 x 1080
            	min = 54
            	max = 431
            	431
            	min = 10449ns
            	max = 683714540ns
            total 4876
            Thank you
            Abdullah01A Offline
            Abdullah01A Offline
            Abdullah01
            @Abdullah01 said in reporting a bug for cameras configuration:
            So, what should I do now?
            is everything looks good?
              Abdullah01A Offline
              Abdullah01A Offline
              Abdullah01
              @Abdullah01
              BTW,
              Once I select the camera configuration, it's saved in these directories
              camera_server_config_helper is done copying required camera drivers in place /usr/share/modalai/chi-cdk/irs1645/com.qti.sensormodule.irs1645_0.bin /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_2.bin /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_3.bin enabling voxl-camera-server
                @Abdullah01
                BTW,
                @Abdullah01 , I believe you have the correct sensormodules in place. I am looking at the photo in our documentation : https://docs.modalai.com/voxl2-camera-configs/#c-14-tof-hires-and-tracking and i can see that it is not shown how the tracking camera is plugged in (connector mating orientation).
                If you take a look at this configuration, https://docs.modalai.com/voxl2-camera-configs/#c-11-front-stereo-rear-stereo-hires-and-tracking-d0006-sentinel , the tracking camera, when plugged in correctly, has the flex going back towards the VOXL2 board, while the hires camera (imx214) is going away from VOXL2. Even though for C11, the hires and tracking are swapped places, but the connector orientation is the same for C11 and C14.
                Specifically, the tracking camera flex, once plugged in, goes on top of the CAMERA label on the flex, but IMX214 camera flex does not cross over the CAMERA label.
                Please double check and perhaps you need to rotate your tracking camera connection 180 degrees.
                  Abdullah01A Offline
                  Abdullah01A Offline
                  Abdullah01
                  wrote on last edited by Abdullah01
                  #10
                  I tried to rotate the tracking camera connection 180 degree, but some how if I did so, the wifi that is connected to the VOXL2 does not work.
                  So, I assumed that the connection is not correct,
                  In this configuration
                  alt text
                  We can see the Tracking camera is connected backward to the voxl direction
                  and this is what I did
                  Thank you
                    alt text
                    Thank you
                    @Abdullah01 , ok that seems like it is correct.
                    Let's try the following:
                    • power off voxl2 and remove TOF and hires camera (gently unplug), just leave tracking camera as is, connected via the dual camera flex
                    • power on voxl2 and check using voxl-camera-server -l to see if any cameras are detected
                    If above still does not detect the tracking camera,
                    • lets try connecting tracking camera where hires camera was previously connected
                    • power off voxl2, gently disconnect tracking camera from the dual flex and plug it into the slot where hires camera used to be (in the same orientation, with tracking camera flex pointing towards voxl2 board)
                    • power on voxl2 and copy the ov7251 sensormodule for port 2 (instead of port 3 that you were using before):
                    cp /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_2.bin /usr/lib/camera/
                    • you can leave the other sensormodule files in /usr/lib/camera for now (no need to remove any)
                    • then try voxl-camera-server -l again to see if tracking camera is detected.
                      Abdullah01A Offline
                      Abdullah01A Offline
                      Abdullah01
                      If I connect in this configuration with camera configuration (14)
                      it will show me no camera is attached
                      For connecting the tracking where the Hris is connected with camera configuration 14 as shown below:
                      is not detected as well.
                      But once I changed the camera configuration to 4 which is for tracking and Hris
                      the tracking is detected as shown below:
                      voxl2:~$ voxl-camera-server -l
                      DEBUG:   Cam idx: 0, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750
                      DEBUG:   Number of cameras: 1
                      Stats for camera: 0
                       640 x  480
                       640 x  480
                       640 x  480
                       640 x  480 HAL_PIXEL_FORMAT_RAW10
                       640 x  480 HAL_PIXEL_FORMAT_RAW12
                       640 x  480 HAL_PIXEL_FORMAT_RAW16
                       640 x  480 HAL_PIXEL_FORMAT_RAW_OPAQUE
                      	min = 54
                      	max = 3451
                      	3451
                      	min = 0ns
                      	max = 1266732525ns
                      Number of cameras detected: 1
                      Also, I tried to attach the Hris as shown below with camera configuration 4
                      Both of them are detected
                      DEBUG:   Cam idx: 1, Cam slot: 3, Slave Address: 0x0020, Sensor Id: 0x0214
                      Stats for camera: 0
                       640 x  480
                       640 x  480
                       640 x  480
                      	min = 54
                      	max = 3451
                      	3451
                      	min = 0ns
                      	max = 1266732525ns
                      Stats for camera: 1
                      4208 x 3120
                      3840 x 2160
                      1920 x 1080
                      1920 x 1080
                      	min = 54
                      	max = 431
                      	431
                      	min = 10449ns
                      	max = 683714540ns
                      The second part of copying the sensor module is not clear. What configuration should I use?
                      If you noticed I have two issues:
                      1- the camera configuration (this post)
                      2- the ESC issue (Other post
                      is there another direct way to communicate with you directly?
                      Thank you for the support and fast response
                        Stats for camera: 0
                         640 x  480
                         640 x  480
                         640 x  480
                        	min = 54
                        	max = 3451
                        	3451
                        	min = 0ns
                        	max = 1266732525ns
                        Stats for camera: 0
                         640 x  480
                         640 x  480
                         640 x  480
                        	min = 54
                        	max = 3451
                        	3451
                        	min = 0ns
                        	max = 1266732525ns
                        Stats for camera: 1
                        4208 x 3120
                        3840 x 2160
                        1920 x 1080
                        1920 x 1080
                        	min = 54
                        	max = 431
                        	431
                        	min = 10449ns
                        	max = 683714540ns
                        Abdullah01A Offline
                        Abdullah01A Offline
                        Abdullah01
                        @Abdullah01
                        My issue now is how to connect the tof with the above configuration.
                        I chose the camera configuration 4 and this is why they work, but if I chose configuration 14 which is with ToF it wouldn't work
                        • Abdullah01A Offline
                          Abdullah01A Offline
                          Abdullah01
                          Is there any update?
                            @Abdullah01 , now that you have both cameras detected (tracking and hires), just plug in the TOF sensor in the original place where it worked before (power off when connecting / disconnecting cameras).
                            Also double check that /usr/lib/camera has the following file com.qti.sensormodule.irs1645_0.bin , if not, you can manually copy it from /usr/share/modalai/chi-cdk/ folder (search for it).
                            Then just try voxl-camera-server -l again
                              Abdullah01A Offline
                              Abdullah01A Offline
                              Abdullah01
                              the issues is that the configuration in this case is 4 where it detects only Hris and Tracking.
                              I added the file to the /usr/lib/camera directory.
                              /usr/lib/camera/com.qti.sensormodule.irs1645_0.bin
                              and still, the ToF is not detected, and tried the command voxl-camera-server -l
                              and here is the output, only detected two cameras.
                              3DEBUG:   Attempting to open the hal module
                              Stats for camera: 0
                               640 x  480
                               640 x  480
                               640 x  480
                              	min = 54
                              	max = 3451
                              	3451
                              	min = 0ns
                              	max = 1266732525ns
                              Stats for camera: 1
                              4208 x 3120
                              3840 x 2160
                              1920 x 1080
                              1920 x 1080
                              	min = 54
                              	max = 431
                              	431
                              	min = 10449ns
                              	max = 683714540ns
                                Stats for camera: 0
                                 640 x  480
                                 640 x  480
                                 640 x  480
                                	min = 54
                                	max = 3451
                                	3451
                                	min = 0ns
                                	max = 1266732525ns
                                Stats for camera: 1
                                4208 x 3120
                                3840 x 2160
                                1920 x 1080
                                1920 x 1080
                                	min = 54
                                	max = 431
                                	431
                                	min = 10449ns
                                	max = 683714540ns
                                @Abdullah01 , OK this is strange.
                                So it seems like all the cameras are functional, because originally you were able to detect TOF and Hires camera, but not tracking camera. However, now you can detect hires and tracking but not TOF.
                                I am not sure why this is happening. Are you able to do a clean install of SDK 1.1.2 and follow the same configuration option as you originally tried (TOF + Hires + Tracking). Make sure to plug the cameras as instructed here : https://docs.modalai.com/voxl2-camera-configs/#c-14-tof-hires-and-tracking
