    reporting a bug for cameras configuration
    1642
    • Abdullah01A
      Abdullah01
      I am using Voxl2 with the following image sensors:
      1- Tof
      2- RGB Camera (imx214)
      3- Fish Eye Camera (ov7251)
      and I am using VOXL2 SDK 1.1.2
      For the connection, I followed this documentation, and to be more specific I connected the cameras as it shown in this PIC
      Then, I select the camera configuration, I selected number (14) which is for this configuration, before that I changed the SKU configuration to be Voxl2 board only.
      But, when I run the cameras, it detected only (tof) and (rgb), and the (Fiah Eye Camera) is not detected.
      So, can you support me with this issue?
      thank you.
      • ModeratorM
        Moderator ModalAI Team @Abdullah01
        @Abdullah01 Can you try from a command line to run voxl-camera-server -d0 to view the output of the camera-server initialization process and please share that log?
        Abdullah01A 1 Reply Last reply Reply Quote 0
        • Abdullah01A
          Abdullah01 @Moderator
          @Moderator
          Here is the log
          VERBOSE: Dumping GBM flags
          DEBUG:   	Found flag GBM_BO_USAGE_CPU_READ_QTI
          DEBUG:   	Found flag GBM_BO_USAGE_CPU_WRITE_QTI
          DEBUG:   	Found flag GBM_BO_USAGE_VIDEO_ENCODER_QTI
          DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888
          DEBUG:   Found video encoder usage, removing camera read/write usage
          DEBUG:   Converted gralloc flags 0x30022 to GBM flags 0x860000
          DEBUG:   Available color formats for OMX:
          DEBUG:   	Unknown (0x7fa30c06)
          DEBUG:   	OMX_QCOM_COLOR_FormatYUV420PackedSemiPlanar32m (0x7fa30c04)
          DEBUG:   	OMX_QCOM_COLOR_FormatYVU420SemiPlanar (0x7fa30c00)
          DEBUG:   	Unknown (0x7fa30c09)
          DEBUG:   	Unknown (0x7fa30c0a)
          DEBUG:   	Unknown (0x7fa30c08)
          DEBUG:   	Unknown (0x7fa30c07)
          DEBUG:   	OMX_COLOR_FormatAndroidOpaque (0x7f000789)
          DEBUG:   	OMX_COLOR_FormatYUV420SemiPlanar (0x15)
          DEBUG:   Buffer Count Expected: 16
          DEBUG:   Buffer Count Actual: 16
          WARNING: Port Def 0:
          	Count Min: 8
          	Count Actual: 16
          	Buffers Contiguous: Yes
          	Buffer Alignment: 0
          WARNING: Port Def 1:
          	Count Min: 4
          	Count Actual: 16
          	Buffers Contiguous: No
          	Buffer Alignment: 0
          DEBUG:   OMX_EventCmdComplete
          DEBUG:   Successfully set up pipeline for stream: STREAM_SMALL_VID
          DEBUG:   Allocated BO with width=4208 height=3120 stride=4608 aligned_w=4608 aligned_h=3584 size=24772608 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888
          	Count Min: 8
          	Count Actual: 16
          	Buffer Alignment: 0
          	Count Min: 4
          	Count Actual: 16
          	Buffer Alignment: 0
          DEBUG:   Successfully set up pipeline for stream: STREAM_LARGE_VID
          DEBUG:   Converted gralloc flags 0x20003 to GBM flags 0x420000
          DEBUG:   Allocated BO with width=39386888 height=1 stride=39386888 aligned_w=39386888 aligned_h=1 size=39386888 flags=0x20003 format=GBM_FORMAT_BLOB
          DEBUG:   Successfully set up pipeline for stream: SNAPSHOT
          DEBUG:   Started Camera: hires
          Starting Camera: tracking (id #2)
          VERBOSE: Entered thread: cam1-result(tid: 2902)
          VERBOSE: Entered thread: cam1-request(tid: 2901)
          ERBOSE: sid: 0x007A, addr: 0xB316, data: 0x902D
          VERBOSE: sid: 0x007A, addr: 0xB317, data: 0x0000
          VERBOSE: sid: 0x007A, addr: 0xB318, data: 0x048A
          VERBOSE: sid: 0x007A, addr: 0xB319, data: 0x902D
          VERBOSE: sid: 0x007A, addr: 0xB31A, data: 0x0000
          VERBOSE: sid: 0x007A, addr: 0xB31B, data: 0x04CE
          VERBOSE: sid: 0x007A, addr: 0xB334, data: 0x6A39
          VERBOSE: sid: 0x007A, addr: 0xB335, data: 0x1B4F
          VERBOSE: sid: 0x007A, addr: 0xB336, data: 0x03E8
          VERBOSE: sid: 0x007A, addr: 0xB337, data: 0x6261
          VERBOSE: sid: 0x007A, addr: 0xB338, data: 0xFC96
          VERBOSE: sid: 0x007A, addr: 0xB339, data: 0x0EE2
          VERBOSE: sid: 0x007A, addr: 0xB33A, data: 0x8245
          VERBOSE: sid: 0x007A, addr: 0xB33B, data: 0x3D71
          VERBOSE: sid: 0x007A, addr: 0xB33C, data: 0x060A
          VERBOSE: sid: 0x007A, addr: 0xB341, data: 0x0000
          VERBOSE: sid: 0x007A, addr: 0xB39D, data: 0x5529
          VERBOSE: sid: 0x007A, addr: 0xB39E, data: 0x9168
          VERBOSE: sid: 0x007A, addr: 0xB39F, data: 0x47CD
          VERBOSE: sid: 0x007A, addr: 0xB3A0, data: 0x5712
          VERBOSE: sid: 0x007A, addr: 0xB3A1, data: 0x0002
          VERBOSE: sid: 0x007A, addr: 0xB3A2, data: 0x5529
          VERBOSE: sid: 0x007A, addr: 0xB3A3, data: 0xE832
          VERBOSE: sid: 0x007A, addr: 0xB3A4, data: 0x34F4
          VERBOSE: sid: 0x007A, addr: 0xB3A5, data: 0x5712
          VERBOSE: sid: 0x007A, addr: 0xB3A6, data: 0x0002
          DEBUG:   setup accessLevel 3, ret 0
          DEBUG:   Changed to usecase MODE_9_5FPS exposure time limits [ 8 - 2200 ], cur exposure_time 2200, exposure mode 1
          VERBOSE:
          Setting use case: mode=9, fps = 5
          VERBOSE: startCapture E
          VERBOSE: sid: 0x007A, addr: 0x9005, data: 0x0002
          VERBOSE: sid: 0x007A, addr: 0xB420, data: 0x10C0
          VERBOSE: sid: 0x007A, addr: 0xB400, data: 0x0001
          VERBOSE: sid: 0x007A, addr: 0x9000, data: 0x0005
          VERBOSE: sid: 0x007A, addr: 0x9005, data: 0x0000
          VERBOSE: sid: 0x007A, addr: 0x982F, data: 0x0000
          VERBOSE: sid: 0x007A, addr: 0x9830, data: 0x0000
          VERBOSE: sid: 0x007A, addr: 0x982F, data: 0x0001
          VERBOSE: startCapture X
          VERBOSE: TOF interface created!
          VERBOSE: setting hal3 exposure for tof     2259763   200
          VERBOSE: added request for preview stream
          VERBOSE: Sending request for frame 0 for camera tof for 1 streams
          VERBOSE: Received 0 buffers from camera tof, partial result:1
          VERBOSE: finished sending request for frame 0 for camera tof
          VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera tof
          VERBOSE: Sending request for frame 1 for camera tof for 1 streams
          VERBOSE: finished sending request for frame 1 for camera tof
          VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera tof
          VERBOSE: Sending request for frame 2 for camera tof for 1 streams
          VERBOSE: finished sending request for frame 2 for camera tof
          VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera tof
          VERBOSE: Sending request for frame 3 for camera tof for 1 streams
          VERBOSE: finished sending request for frame 3 for camera tof
          VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera tof
          VERBOSE: Sending request for frame 4 for camera tof for 1 streams
          ------ voxl-camera-server: Camera server exited gracefully
          • Abdullah01A
            Abdullah01 @Abdullah01
            @Abdullah01
            Is there any feed back?
              Alex Kushleyev ModalAI Team @Abdullah01
              @Abdullah01 ,
              Is the above output of the voxl-camera-server -d0 complete or was some of it cut off? it should show which cameras were detected at the very beginning. Maybe the there were too many lines printed and your terminal discarded them. You should have an option to increase the history length in your terminal window, if needed.
              Also, can you please run voxl-camera-server -l to just list the detected cameras and resolutions.
              Finally, when you run voxl-configure-cameras and select the camera configuration number, this script copies appropriate camera drivers to /usr/lib/camera - do you mind sending the output of ls -la /usr/lib/camera ? This way we can check if all appropriate camera drivers have indeed been copied to this location by the configuration script.
              Thank you
              • Abdullah01A
                Abdullah01 @Alex Kushleyev
                sorry for the late reply.
                For the voxl-camera-server -d0 command line, the beginning output lines is shown below:
                configuration for 3 cameras:
                cam #0
                    sensor type:         pmd-tof
                    isEnabled:           1
                    camId:               0
                    camId2:              -1
                    fps:                 5
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           224
                    pre_height:          1557
                    en_raw_preview:      1
                    en_small_video:      0
                    small_video_width:   -1
                    small_video_height:  -1
                    en_large_video:      0
                    large_video_width:   -1
                    large_video_height:  -1
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             off
                    standby_enabled:     0
                    decimator:           5
                    independent_exposure:0
                cam #1
                    sensor type:         imx214
                    isEnabled:           1
                    camId:               1
                    camId2:              -1
                    fps:                 30
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          0
                    pre_width:           640
                    pre_height:          480
                    en_raw_preview:      0
                    en_small_video:      1
                    small_video_width:   1024
                --More--gbm_create_device(156): Info: backend name is: msm_drm
                    small_video_height:  768
                    en_large_video:      1
                    large_video_width:   4208
                    large_video_height:  3120
                    en_snapshot:         1
                    snap_width:          4208
                    snap_height:         3120
                    ae_mode:             isp
                    standby_enabled:     0
                    decimator:           1
                cam #2
                    sensor type:         ov7251
                    isEnabled:           1
                    camId:               2
                    camId2:              -1
                    fps:                 30
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          1
                    pre_width:           640
                    pre_height:          480
                    en_raw_preview:      1
                    en_small_video:      0
                    en_large_video:      0
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    ae_mode:             lme_msv
                    standby_enabled:     0
                    decimator:           1
                For the voxl-camera-server -l command, the output shows below:
                oxl2:~$ voxl-camera-server -l
                DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x007A, Sensor Id: 0x003D
                DEBUG:   Cam idx: 1, Cam slot: 2, Slave Address: 0x0020, Sensor Id: 0x0214
                DEBUG:   Number of cameras: 2
                Stats for camera: 0
                 224 x 1557
                 224 x 1557 HAL_PIXEL_FORMAT_RAW10
                 224 x 1557 HAL_PIXEL_FORMAT_RAW12
                 224 x 1557 HAL_PIXEL_FORMAT_RAW16
                 224 x 1557 HAL_PIXEL_FORMAT_RAW_OPAQUE
                	min = 54
                	max = 0
                	min = 0ns
                	max = 0ns
                Stats for camera: 1
                4208 x 3120
                3840 x 2160
                1920 x 1080
                1920 x 1080
                4208 x 3120 HAL_PIXEL_FORMAT_YCbCr_420_888
                4208 x 3120 HAL_PIXEL_FORMAT_BLOB
                4160 x 3120 HAL_PIXEL_FORMAT_YCbCr_420_888
                4160 x 3120 HAL_PIXEL_FORMAT_BLOB
                4096 x 2304 HAL_PIXEL_FORMAT_YCbCr_420_888
                4096 x 2304 HAL_PIXEL_FORMAT_BLOB
                4096 x 2160 HAL_PIXEL_FORMAT_YCbCr_420_888
                4096 x 2160 HAL_PIXEL_FORMAT_BLOB
                1280 x  960 HAL_PIXEL_FORMAT_YCbCr_420_888
                1280 x  960 HAL_PIXEL_FORMAT_BLOB
                1280 x  800 HAL_PIXEL_FORMAT_YCbCr_420_888
                1280 x  800 HAL_PIXEL_FORMAT_BLOB
                1280 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
                1280 x  768 HAL_PIXEL_FORMAT_BLOB
                1280 x  720 HAL_PIXEL_FORMAT_YCbCr_420_888
                1280 x  720 HAL_PIXEL_FORMAT_BLOB
                1024 x  738 HAL_PIXEL_FORMAT_YCbCr_420_888
                1024 x  738 HAL_PIXEL_FORMAT_BLOB
                1024 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
                1024 x  768 HAL_PIXEL_FORMAT_BLOB
                 864 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
                 864 x  480 HAL_PIXEL_FORMAT_BLOB
                 800 x  600 HAL_PIXEL_FORMAT_YCbCr_420_888
                 800 x  600 HAL_PIXEL_FORMAT_BLOB
                 800 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
                 800 x  480 HAL_PIXEL_FORMAT_BLOB
                 720 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
                 720 x  480 HAL_PIXEL_FORMAT_BLOB
                4208 x 3120 HAL_PIXEL_FORMAT_RAW10
                4208 x 3120 HAL_PIXEL_FORMAT_RAW12
                4208 x 3120 HAL_PIXEL_FORMAT_RAW16
                4208 x 3120 HAL_PIXEL_FORMAT_RAW_OPAQUE
                	min = 54
                	max = 431
                	431
                	min = 10449ns
                	max = 683714540ns
                Number of cameras detected: 2
                For the camera configuration, as I mentioned above, I selected configuration #14, which is for Tof, Fish eye, and RGB
                The output for ls -la /usr/lib/camera is shown below:
                voxl2:~$ ls -la /usr/lib/camera
                total 4876
                drwxr-xr-x  3 root root   4096 Jan 14 08:38 .
                drwxr-xr-x 72 root root  24576 Dec 27 06:49 ..
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.eeprom.cmk_imx577.so
                -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.ar0144.so
                -rwxr-xr-x  1 root root   5816 Oct 26 03:51 com.qti.sensor.cmk_imx577.so
                -rwxr-xr-x  1 root root   5816 Oct 26 03:51 com.qti.sensor.cmk_imx577_flip.so
                -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.imx214.so
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.imx214_flip.so
                -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.imx335.so
                -rwxr-xr-x  1 root root   5808 Oct 26 03:51 com.qti.sensor.imx377.so
                -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.imx678.so
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.imx678_flip.so
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.imx678_mod.so
                -rwxr-xr-x  1 root root   5808 Oct 26 03:51 com.qti.sensor.irs1645.so
                -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.ov7251.so
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_front_left.so
                -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_front_left_flip.so
                -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_front_right.so
                -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_front_right_flip.so
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_fsin.so
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_fsout.so
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_rear_left.so
                -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_rear_left_flip.so
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov7251_rear_right.so
                -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov7251_rear_right_flip.so
                -rwxr-xr-x  1 root root   9904 Oct 26 03:51 com.qti.sensor.ov9782.so
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov9782_front_left.so
                -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_front_left_flip.so
                -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_front_right.so
                -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_front_right_flip.so
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov9782_rear_left.so
                -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_rear_left_flip.so
                -rwxr-xr-x  1 root root   9912 Oct 26 03:51 com.qti.sensor.ov9782_rear_right.so
                -rwxr-xr-x  1 root root   9920 Oct 26 03:51 com.qti.sensor.ov9782_rear_right_flip.so
                -rw-r--r--  1 root root 149272 Jan 14 08:38 com.qti.sensormodule.imx214_2.bin
                -rw-r--r--  1 root root 674736 Jan 14 08:38 com.qti.sensormodule.irs1645_0.bin
                -rw-r--r--  1 root root 142472 Jan 14 08:38 com.qti.sensormodule.ov7251_3.bin
                -rw-r--r--  1 root root 957344 Oct 26 03:51 com.qti.tuned.cmk_imx577.bin
                -rw-r--r--  1 root root 835464 Oct 26 03:51 com.qti.tuned.cmk_ov9282.bin
                -rw-r--r--  1 root root 931864 Oct 26 03:51 com.qti.tuned.default.bin
                -rw-r--r--  1 root root 882376 Oct 26 03:51 com.qti.tuned.sony_imx335.bin
                drwxr-xr-x  2 root root   4096 Oct 26 04:00 components
                Thank you
                • Abdullah01A
                  @Abdullah01 said in reporting a bug for cameras configuration:
                  So, what should I do now?
                  is everything looks good?
                  • Abdullah01A
                    @Abdullah01
                    BTW,
                    Once I select the camera configuration, it's saved in these directories
                    camera_server_config_helper is done copying required camera drivers in place /usr/share/modalai/chi-cdk/irs1645/com.qti.sensormodule.irs1645_0.bin /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_2.bin /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_3.bin enabling voxl-camera-server
                      @Abdullah01 , I believe you have the correct sensormodules in place. I am looking at the photo in our documentation : https://docs.modalai.com/voxl2-camera-configs/#c-14-tof-hires-and-tracking and i can see that it is not shown how the tracking camera is plugged in (connector mating orientation).
                      If you take a look at this configuration, https://docs.modalai.com/voxl2-camera-configs/#c-11-front-stereo-rear-stereo-hires-and-tracking-d0006-sentinel , the tracking camera, when plugged in correctly, has the flex going back towards the VOXL2 board, while the hires camera (imx214) is going away from VOXL2. Even though for C11, the hires and tracking are swapped places, but the connector orientation is the same for C11 and C14.
                      Specifically, the tracking camera flex, once plugged in, goes on top of the CAMERA label on the flex, but IMX214 camera flex does not cross over the CAMERA label.
                      Please double check and perhaps you need to rotate your tracking camera connection 180 degrees.
                      • Abdullah01A
                        I tried to rotate the tracking camera connection 180 degree, but some how if I did so, the wifi that is connected to the VOXL2 does not work.
                        So, I assumed that the connection is not correct,
                        In this configuration
                        alt text
                        We can see the Tracking camera is connected backward to the voxl direction
                        and this is what I did
                        Thank you
                          @Abdullah01 , ok that seems like it is correct.
                          Let's try the following:
                          • power off voxl2 and remove TOF and hires camera (gently unplug), just leave tracking camera as is, connected via the dual camera flex
                          • power on voxl2 and check using voxl-camera-server -l to see if any cameras are detected
                          If above still does not detect the tracking camera,
                          • lets try connecting tracking camera where hires camera was previously connected
                          • power off voxl2, gently disconnect tracking camera from the dual flex and plug it into the slot where hires camera used to be (in the same orientation, with tracking camera flex pointing towards voxl2 board)
                          • power on voxl2 and copy the ov7251 sensormodule for port 2 (instead of port 3 that you were using before):
                          cp /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_2.bin /usr/lib/camera/
                          • you can leave the other sensormodule files in /usr/lib/camera for now (no need to remove any)
                          • then try voxl-camera-server -l again to see if tracking camera is detected.
                          • Abdullah01A
                            If I connect in this configuration with camera configuration (14)
                            it will show me no camera is attached
                            For connecting the tracking where the Hris is connected with camera configuration 14 as shown below:
                            is not detected as well.
                            But once I changed the camera configuration to 4 which is for tracking and Hris
                            the tracking is detected as shown below:
                            voxl2:~$ voxl-camera-server -l
                            DEBUG:   Cam idx: 0, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750
                            DEBUG:   Number of cameras: 1
                            Stats for camera: 0
                             640 x  480
                             640 x  480
                             640 x  480
                             640 x  480 HAL_PIXEL_FORMAT_RAW10
                             640 x  480 HAL_PIXEL_FORMAT_RAW12
                             640 x  480 HAL_PIXEL_FORMAT_RAW16
                             640 x  480 HAL_PIXEL_FORMAT_RAW_OPAQUE
                            	min = 54
                            	max = 3451
                            	3451
                            	min = 0ns
                            	max = 1266732525ns
                            Number of cameras detected: 1
                            Also, I tried to attach the Hris as shown below with camera configuration 4
                            Both of them are detected
                            DEBUG:   Cam idx: 1, Cam slot: 3, Slave Address: 0x0020, Sensor Id: 0x0214
                            Stats for camera: 0
                             640 x  480
                             640 x  480
                             640 x  480
                            	min = 54
                            	max = 3451
                            	3451
                            	min = 0ns
                            	max = 1266732525ns
                            Stats for camera: 1
                            4208 x 3120
                            3840 x 2160
                            1920 x 1080
                            1920 x 1080
                            	min = 54
                            	max = 431
                            	431
                            	min = 10449ns
                            	max = 683714540ns
                            The second part of copying the sensor module is not clear. What configuration should I use?
                            If you noticed I have two issues:
                            1- the camera configuration (this post)
                            2- the ESC issue (Other post
                            is there another direct way to communicate with you directly?
                            Thank you for the support and fast response
                            • Abdullah01A
                              @Abdullah01
                              My issue now is how to connect the tof with the above configuration.
                              I chose the camera configuration 4 and this is why they work, but if I chose configuration 14 which is with ToF it wouldn't work
                              • Abdullah01A
                                Abdullah01
                                Is there any update?
                                  @Abdullah01 , now that you have both cameras detected (tracking and hires), just plug in the TOF sensor in the original place where it worked before (power off when connecting / disconnecting cameras).
                                  Also double check that /usr/lib/camera has the following file com.qti.sensormodule.irs1645_0.bin , if not, you can manually copy it from /usr/share/modalai/chi-cdk/ folder (search for it).
                                  Then just try voxl-camera-server -l again
                                  • Abdullah01A
                                    the issues is that the configuration in this case is 4 where it detects only Hris and Tracking.
                                    I added the file to the /usr/lib/camera directory.
                                    /usr/lib/camera/com.qti.sensormodule.irs1645_0.bin
                                    and still, the ToF is not detected, and tried the command voxl-camera-server -l
                                    and here is the output, only detected two cameras.
                                    3DEBUG:   Attempting to open the hal module
                                    Stats for camera: 0
                                     640 x  480
                                     640 x  480
                                     640 x  480
                                    	min = 54
                                    	max = 3451
                                    	3451
                                    	min = 0ns
                                    	max = 1266732525ns
                                    Stats for camera: 1
                                    4208 x 3120
                                    3840 x 2160
                                    1920 x 1080
                                    1920 x 1080
                                    	min = 54
                                    	max = 431
                                    	431
                                    	min = 10449ns
                                    	max = 683714540ns
                                      @Abdullah01 , OK this is strange.
                                      So it seems like all the cameras are functional, because originally you were able to detect TOF and Hires camera, but not tracking camera. However, now you can detect hires and tracking but not TOF.
                                      I am not sure why this is happening. Are you able to do a clean install of SDK 1.1.2 and follow the same configuration option as you originally tried (TOF + Hires + Tracking). Make sure to plug the cameras as instructed here : https://docs.modalai.com/voxl2-camera-configs/#c-14-tof-hires-and-tracking
