    4-1 ESC issue with idintify the ID
    1526
    • Abdullah01A
      Abdullah01
      I have an issue with running the ESC where it's not recognize all the ESC. It's recognize only 2 out of 4.
      When I run voxl-esc and select scan shows the below:
      voxl-esc
      Starting Wizard
      What do you want to do?
      1) scan		     3) spin		  5) upload_params
      2) detect	     4) upgrade_firmware
      #? 1
      enabling bridge
      bridge enabled
      [GCC 8.4.0]
      Found voxl-esc tools bin version: 1.4
      VOXL Platform: M0054
      INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000, protocol: firmware
      INFO: Verifying ESC Params..
      INFO: ESC Information:
      INFO: ---------------------
      	Board      : version 34: ModalAi 4-in-1 ESC (M0117-1)
      	UID        : 0x2037343356435707003E001E
      	Firmware   : version   39, hash d4fe8e3d
      	Bootloader : version  183, hash 25317f42
      	Params     : ../voxl-esc-params/starling_1504_3000kv/starling_1504_3000kv.xml
      	UID        : 0x2037343356435707003C0019
      WARNING: not all params match!
      successfully pinged ESCs
      disabling bridge
      bridge disabled
      DONE
      and when I run detect shows:
      voxl2:~$ voxl-esc
      Starting Wizard
      #? 2
      enabling bridge
      bridge enabled
      ESC detected: ModalAi 4-in-1 ESC (M0117-1)
      disabling bridge
      bridge disabled
      DONE
      I tried to disable voxl-px4 and run the test, but nothing changed using systemctl disable voxl-px4
      The issue is when I tried to upload_params the process has stopped and the files got corrupted .
      The issue is not with the wiring, the motors were running without issue before the upload_params .
      Also, I can't upgrade all ESC, it identify only 2 of them, and the other to can't be upgraded
      So, what do you recommend me?
      Thank you.
        Alex Kushleyev ModalAI Team @Abdullah01
        @Abdullah01 ,
        Sorry about that, please follow the recovery procedure outlined here : https://forum.modalai.com/topic/2897/voxl-mini-4in1-esc-and-voxl-2/8 (at the bottom)
        This upgrade issue should be fixed in the upcoming release.
          Also, I just documented the recovery procedure here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/recovery.md
          Abdullah01A 1 Reply Last reply Reply Quote 0
          • Abdullah01A
            Abdullah01 @Alex Kushleyev
            @Alex-Kushleyev
            Thank you for your fast support.
            I tried the ./voxl-esc-scan.py with the new voxl-esc tool and shows me the following
            /usr/share/modalai/tool/voxl-esc/voxl-esc-tools(dev)$ ./voxl-esc-scan.py
            [GCC 8.4.0]
            Found voxl-esc tools bin version: 1.5
            INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400
            Updated baud rate to 230400
            WARNING: No ESC(s) detected
            INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 921600
            INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 230400
            INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 57600
            INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 115200
            ERROR: not all ESC firmware hashes are the same
            Also, tried to upload the ESC parameters using this command ./voxl-esc-upload-params.py --params-file /usr/share/modalai/tool/voxl-esc/voxl-esc-params/mavic_mini_2/mavic_mini_2.xml
            it shows me errors for detecting the ESC as shown below
            [GCC 8.4.0]
            INFO: Params file name : /usr/share/modalai/tool/voxl-esc/voxl-esc-params/mavic_mini_2/mavic_mini_2.xml
            INFO: Params file size : 7652 bytes
            INFO: ESCs detected:
            ID: 0, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
            ID: 2, SW: 39, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
            INFO: Loading XML config file...
            INFO: Uploading params for ESC ID 255...
            -- board config
            -- id config
            -- uart config
            -- tune config
                DONE
            INFO: Resetting ESCs...
                DONE
            ERROR: No ESC(s) detected
            So, I can't recover the ESC, is there another way?
            thank you again for your support
              @Abdullah01 , this is odd! We can diagnose further..
              Can you please look at the blue status LEDs on the ESC board and see what their behavior looks like after you turn on the power. The correct sequence should be:
              • turn on power
              • all 4 blue leds on ESC blink fast (10hz) for 1 second. The ESCs are in bootloader mode
              • after 1 second, bootloader times out, the firmware should start (if valid firmware is present)
                • if the fast blink continues indefinitely on any of the 4 ESCs, it means the firmware was corrupted on that particular ESC, needs to be re-installed (i can tell you how)
              • then firmware starts and verifies params
                • if params are correct, there should be a motor beep sequence (configurable via esc params)
                • after motor beep, the blue leds will blink twice and turn off
                • if there are any ESCs that blink slowly about 5-6 times, and have a "sad" loud motor tone, it means esc params are corrupt
              Can you describe what you see or if possible make a video of the ESC LEDs upon power up?
              Thank you
              • Abdullah01A
                @Alex-Kushleyev
                I just checked the blue lights,
                It starts with the 4 leds blinking fast then turn off after one second.
                Then, blinking fast for ESC (ID 1 & 3) - the one which not working
                Finally, Blinking Slow for ESC (ID 0 & 2) - the one which working
                For the motors beep, there are no beep from them.
                Here is the video
                sorry for the bad angle, I can't remove the ESC for its place, took me a while to install it 🙂
                Thank you very much
                  @Abdullah01 ,
                  It looks like two of escs just dont have correct params. Please try the vommand ‘ voxl-esc-upload-params.py —baud-rate 57600 ‘ .. and add your params file to the command as you did before. This will force the script to only use 57600 baud rate. Please try a few times if that does not work on the first time.
                  • Abdullah01A Abdullah01 referenced this topic on
                  • Abdullah01A
                    @Alex-Kushleyev
                    Thaaaaaaaank you very much. It worked
                    	Firmware   : version   39, hash eb6fb500
                    	Params     : ../voxl-esc-params/mavic_mini_2/mavic_mini_2.xml
                    	UID        : 0x2037343356435707003B0022
                    	UID        : 0x2037343356435707003A0057
                    disabling bridge
                    bridge disabled
                    DONE
