  3. avoidance collision prevention disabled
41 Posts 4 Posters 25.3k Views 1 Watching
    @AP123 When you click on Not Ready does it give you any more info?
    • ? A Former User
      [[topic:post-is-deleted]]
      @AP123 What hardware setup are you using? One of our drones or a custom setup?
      ? 1 Reply Last reply
        • ? A Former User
          @AP123 It's possible, I would take a look here as well for some relevant info: https://docs.modalai.com/configure-extrinsics/
          ? 3 Replies Last reply
                • ? A Former User
                  @AP123 I'm at the end of my personal knowledge with VOA, I'll see if I can tag someone in
                    Cliff WongC 1 Reply Last reply
                    • ? A Former User
                      Cliff WongC Offline
                      Cliff WongC Offline
                      Cliff Wong
                      @AP123 Hey there. Are you running VOA against a stereo camera pair or via a ToF sensor?
                      If you run voxl-inspect-points voa_pc_out and see data, then the voxl2 SDK services are good and generating the correct mavlink obstacle distance points to PX4. If not then there's a configuration issue.
                      If that is good, then you need to make sure PX4 has
                      MPC_POS_MODE = Simple pos control or smooth pos control, COM_OBS_AVOID is enabled, CP_DIST > 0 (e.g. 2) and you must have an established home position (or good position from qvio if that is the case). Typically an "obstacle system not ready" is due to the MPC_POS_MODE (I think we default to acceleration-based input).
                      If all those check out, then it's likely missing a home position requirement in PX4 & not voxl, and we'll need to look that up.
                      • Cliff WongC Cliff Wong
                        #31
                        • ? A Former User
                          @AP123 We just released SDK 1.1 yesterday which contains a few months worth of bug fixes, I would recommend loading that and seeing if your issue is resolved
                            • ? A Former User
                              @AP123 No, didn't realize you were tackling that as well. M0065 PWM support will be in SDK 1.1.1 and we're actively polishing / testing that release and hope to have it out in the next couple weeks
                                • ? A Former User
                                  @AP123 We don't have any known issues with the 4 in 1 escs. If you have an issue can you open a new thread?
                                    wilkinsafW 1 Reply Last reply
                                    • ? A Former User
                                      wilkinsafW Offline
                                      wilkinsafW Offline
                                      wilkinsaf
                                      @AP123 This is a shot in the dark, but can you turn off your GPS and Mag and see if that works. We tried to do collision prevention with GPS on and we were getting these errors
                                      • wilkinsafW wilkinsaf
                                        • ? A Former User
                                          wilkinsafW Offline
                                          wilkinsafW Offline
                                          wilkinsaf
                                          @AP123
                                          you can turn it off with has_gps and has_mag parameters I believe.
                                          Yes, i believe this might be a PX4 thing. Might need to troubleshoot that PX4 bug in order to resolve
